I am trying to encode data by ffmpeg h264 encoder plugin and sending the same over the network.
At the client side I am using omx_h264 decoder to decode the stream .
I am able to decode but the decoder is doing decoding by adding extra 128 bytes.As a result my output is getting cropped i.e. the last row and last column are not there in the output.While using the ffmpeg decoder I am getting the proper output.
Can anyone help me in this?
I am getting the following messages from gstreamer pipeline :
>Setting pipeline to PAUSED ...
>/GstPipeline:pipeline0/GstUDPSrc:udpsrc0.GstPad:src: caps = application/x-rtp, payload=(int)96, clock-rate=(int)90000, media=(string)video, encoding-name=(string)H264
>Pipeline is live and does not need PREROLL ...
>Setting pipeline to PLAYING ...
>New clock: GstSystemClock
>/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)nal
>/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, payload=(int)96, clock-rate=(int)90000, media=(string)video, encoding-name=(string)H264
>/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)nal
>/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1920, height=(int)1080, framerate=(fraction)30/1
>/GstPipeline:pipeline0/GstOmxH264Dec:omxh264dec0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1920, height=(int)1080, framerate=(fraction)30/1
>/GstPipeline:pipeline0/GstOmxH264Dec:omxh264dec0.GstPad:src: caps = video/x-raw-yuv-strided, width=(int)1920, height=(int)1080, format=(fourcc)NV12, rowstride=(int)2048, framerate=(fraction)30/1, interlaced=(boolean)false
>/GstPipeline:pipeline0/GstOmxScaler:omxscaler0.GstPad:sink: caps = video/x-raw-yuv-strided, width=(int)1920, height=(int)1080, format=(fourcc)NV12, rowstride=(int)2048, framerate=(fraction)30/1, interlaced=(boolean)false
>/GstPipeline:pipeline0/GstOmxScaler:omxscaler0.GstPad:src: caps = video/x-raw-yuv, width=(int)1920, height=(int)1080, format=(fourcc)YUY2, framerate=(fraction)30/1, interlaced=(boolean)false
>/GstPipeline:pipeline0/GstOmxBaseCtrl:omxbasectrl0.GstPad:src: caps = video/x-raw-yuv, width=(int)1920, height=(int)1080, format=(fourcc)YUY2, framerate=(fraction)30/1, interlaced=(boolean)false
>/GstPipeline:pipeline0/GstOmxBaseCtrl:omxbasectrl0.GstPad:sink: caps = video/x-raw-yuv, width=(int)1920, height=(int)1080, format=(fourcc)YUY2, framerate=(fraction)30/1, interlaced=(boolean)false
>/GstPipeline:pipeline0/GstOmxVideoSink:omxvideosink0.GstPad:sink: caps = video/x-raw-yuv, width=(int)1920, height=(int)1080, format=(fourcc)YUY2, framerate=(fraction)30/1, interlaced=(boolean)false
