print info as follows: is anybody here know why this happen?
done
Bytes transferred = 2560808 (271328 hex)
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-2.6.37
Created: 2012-09-29 2:15:24 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2560744 Bytes = 2.4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.37 (root@haha-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #3 Sat Sep 29 10:15:19 CST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8168_dvr
vram size = 20971520 at 0x0
reserved size = 20971520 at 0x0
FB: Reserving 20971520 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8168 1.1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 59904
Kernel command line: mem=256M console=ttyO2,115200n8 ip=192.168.2.109:192.168.2.107:192.168.2.1:255.255.255.0:talent:eth0:off eth=18:0e:99:02:b1:88 vram=20M notifyk.vpssm3_sva=0xBFD00000 root=/dev/nfs rw nfsroot=192.168.2.107:/opt/DVSDK8168/DVRRDK_02.80.00.10/target/rfs_816x/
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 236MB = 236MB total
Memory: 233892k/233892k available, 28252k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0x90800000 - 0xf8000000 (1656 MB)
lowmem : 0x80000000 - 0x90000000 ( 256 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.init : 0x80008000 - 0x8003b000 ( 204 kB)
.text : 0x8003b000 - 0x804d8000 (4724 kB)
.data : 0x804d8000 - 0x80520d80 ( 292 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 27000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 0
3-wired eeprom init done. (H/W ver:00)
_omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
_omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
registered ti816x_sr device
pm_dbg_init: only OMAP3 supported
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea20808
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
pmbus 1-0038: no platform data supplied
pmbus: probe of 1-0038 failed with error -5
omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc: kernel must blacklist external hubs
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at 9081e000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at 90828800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 456
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
console [ttyO2] enabled
brd: module loaded
loop: module loaded
ahci ahci.0: forcing PORTS_IMPL to 0x3
ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16
omap2-nand driver initializing
NAND device: Maf ID: 0xad, Chip ID: 0xf1 (Hynix, )
erasesize: 0x20000, writesize: 2048, oobsize: 64
Creating 6 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000240000 : "U-Boot"
0x000000240000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000400000 : "U-Boot Logo"
0x000000400000-0x000000840000 : "Kernel"
0x000000840000-0x000010840000 : "File System"
mtd: partition "File System" extends beyond the end of device "omap2-nand.0" -- size truncated to 0x77c0000
0x000008000000-0x000008000000 : "Reserved"
mtd: partition "Reserved" is out of reach -- disabled
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffd
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
rtc-ds1307: probe of 1-0068 failed with error -5
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
usbcore: registered new interface driver snd-usb-audio
Registered tvp5158 audio codec
asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI81XX DVR
TCP cubic registered
NET: Registered protocol family 17
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
smartreflex-ti816x: ti816x_sr_probe done!
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
davinci_mdio davinci_mdio.0: resetting idled controller
net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=282f014)
IP-Config: Complete:
device=eth0, addr=192.168.2.109, mask=255.255.255.0, gw=192.168.2.1,
host=talent, domain=, nis-domain=(none),
bootserver=192.168.2.107, rootserver=192.168.2.107, rootpath=
PHY: 0:01 - Link is Up - 100/Full
ata2: SATA link down (SStatus 0 SControl 300)
ata1: SATA link down (SStatus 0 SControl 300)
VFS: Mounted root (nfs filesystem) on device 0:15.
devtmpfs: mounted
Freeing init memory: 204K
INIT: version 2.86 booting
Error opening /dev/fb0: No such file or directory
Please wait: booting...
Starting udev
udevd (77): /proc/77/oom_adj is deprecated, please use /proc/77/oom_score_adj instead.
udev: starting version 141
udevd-event[88]: error changing netif name eth0 to eth2: Device or resource busy
Root filesystem already rw, not remounting
Caching udev devnodes
Populating dev cachemv: cannot rename '/tmp/devices': No such file or directory
ALSA: Restoring mixer settings...
NOT configuring network interfaces: / is an NFS mount
No state is present for card DVR
Found hardware: "" "" "" "" ""
Hardware is initialized using a generic method
Mon Apr 11 10:13:00 UTC 2011
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
/etc/rc5.d/S99startapp: line 6: syntax error: "fi" unexpected
_ _ ___ _ _ _
| | | | | ||| |___ ___| | _ ___
| |_| | |) | ~ | . | _| |/_| -|
|_____|___ /____/ ___|_| |_| _|-__|
DVR_Netra Board (2011.04)
dvr login: root
root@dvr:~# cd /opt/dvr_rdk/ti816x
root@dvr:/opt/dvr_rdk/ti816x# ./capture_initLoad_Run.sh
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.10.02.17
SysLink module created on Date:Sep 28 2012 Time:16:42:28
Trace enabled
Trace SetFailureReason enabled
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
*** TVP5158 probe : START ***
TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
TI DVR : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f
Device found : I2C (0xXX): 0x08 = 0x51
I2C (0xXX): 0x09 = 0x58
Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x58): 0x08 = 0x51
I2C (0x58): 0x09 = 0x58
I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5c): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5d): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5e): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5f): Read ERROR !!! (reg[0x08], count = 2)
*** TVP5158 probe : END ***
/opt/dvr_rdk/ti816x
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 560000 Khz ***
[m3vpss ]
[m3vpss ] 43: SYSTEM : System Common Init in progress !!!
[m3vpss ] 43: SYSTEM: IPC init in progress !!!
[m3vpss ] 43: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1043: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1045: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1045: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x097d2000]
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000
[m3vpss ] 2045: SYSTEM: Attaching to [DSP] ...
[m3video]
[m3video] *** UTILS: CPU KHz = 560000 Khz ***
[m3video]
[m3video] 1403: SYSTEM : System Common Init in progress !!!
[m3video] 1403: SYSTEM: IPC init in progress !!!
[m3video] 1403: SYSTEM: Attaching to [HOST] ...
[m3video] 2402: SYSTEM: Attaching to [HOST] ...
[m3video] 2404: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 2404: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x00000000]
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 800000000
[m3video] 3404: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 3045: SYSTEM: Attaching to [DSP] ...
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 800000 Khz ***
[c6xdsp ]
[c6xdsp ] 5: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 5: SYSTEM: IPC init in progress !!!
[c6xdsp ] 5: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1029: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1031: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1031: SYSTEM: Attaching to [VIDEO-M3] ...
After Ipc_startcallback DMA: Module install successful, device major num = 251
status [0x000000DRV: Module install successful
00]
DRV: Module built on Sep 28 2012 16:50:51
[m3vpss ] 4045: SYSTEM: Attaching to [DSP] ...
[m3video] 4404: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2055: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 5045: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2908: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 5404: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2908: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 5404: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 5404: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 6045: SYSTEM: Attaching to [DSP] ...
[m3video] 6404: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 3931: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4576: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 7045: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4576: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 7045: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 7045: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 7404: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 8045: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 8045: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 8045: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 8045: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 8046: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 8045: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8046: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 8046: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 8046: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[c6xdsp ] 5600: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8047: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3vpss ] 8047: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[c6xdsp ] 5600: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[m3video] 8048: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3vpss ] 8048: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[c6xdsp ] 5600: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[m3video] 8048: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3vpss ] 8048: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[c6xdsp ] 5600: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3video] 8048: SYSTEM: IPC init DONE !!!
[m3vpss ] 8048: SYSTEM: IPC init DONE !!!
[c6xdsp ] 5600: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[m3video] 8054: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB)
[m3vpss ] 8053: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB)
[c6xdsp ] 5600: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3video] 8054: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d180000 (209 MB)
[m3vpss ] 8054: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d180000 (209 MB)
[c6xdsp ] 5600: SYSTEM: IPC init DONE !!!
[m3video] 8055: SYSTEM : System Common Init Done !!!
[m3vpss ] 8055: SYSTEM : System Common Init Done !!!
[c6xdsp ] 5602: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB)
[m3video] 8056: SYSTEM : System Video Init in progress !!!
[m3vpss ] 8055: SYSTEM : System VPSS Init in progress !!!
[c6xdsp ] 5602: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d180000 (209 MB)
[m3video] 8056: SYSTEM : System Video Init Done !!!
[c6xdsp ] 5603: SYSTEM : System Common Init Done !!!
[m3video] 8056: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 5468: SYSTEM : System DSP Init in progress !!!
[m3video] 8056: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 5468: SYSTEM : RpeServer_init() done... Ret Val 0!!!
[m3video] 8056: SYSTEM: ListElem Shared Addr = 0xbe98b680
[c6xdsp ] 5606: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
[m3video] 8058: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3vpss ] === HDVPSS Clocks are enabled ===
[c6xdsp ] 5606: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[m3video] 8059: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3vpss ] === HDVPSS is fully functional ===
[c6xdsp ] 5606: SYSTEM: ListElem Shared Addr = 0xbe98eb80
[m3video] 8059: SYSTEM: ListElem Shared Addr = 0xbe9ae580
[m3vpss ] === HDVPSS module is not in standby ===
[c6xdsp ] 5606: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[m3video] 8065: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] === I2C1 Clk is active ===
[c6xdsp ] 5606: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[m3video] 8065: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_23] in region 0 ...
[m3vpss ] 8060: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 5606: SYSTEM: ListElem Shared Addr = 0xbe9b1a80
[m3video] 8065: SYSTEM: ListElem Shared Addr = 0xbea30f80
[m3vpss ] 8061: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 5607: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[m3vpss ] 8061: SYSTEM: ListElem Shared Addr = 0xbea0da00
[c6xdsp ] 5607: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[m3vpss ] 8063: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[c6xdsp ] 5607: SYSTEM: ListElem Shared Addr = 0xbe9d1480
[m3vpss ] Received character 's'
[m3video] 8067: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 8063: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[c6xdsp ] 5608: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[m3video] 8067: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 8063: SYSTEM: ListElem Shared Addr = 0xbea2da80
[c6xdsp ] 5608: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[m3video] 8068: SYSTEM: ListElem Shared Addr = 0xbea50980
[m3vpss ] 8077: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[c6xdsp ] 5608: SYSTEM: ListElem Shared Addr = 0xbe9f1100
[m3video] 8070: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 8077: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[c6xdsp ] 5609: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[m3video] 8070: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 8077: SYSTEM: ListElem Shared Addr = 0xbea8fd80
[c6xdsp ] 5609: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[m3video] 8071: SYSTEM: ListElem Shared Addr = 0xbea70380
[m3vpss ] 8080: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[c6xdsp ] 5609: SYSTEM: ListElem Shared Addr = 0xbea10f00
[m3video] 8083: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 8080: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 5474: SYSTEM : Initializing Links !!!
[m3video] 8084: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 8080: SYSTEM: ListElem Shared Addr = 0xbeaaf780
[m3video] 8084: SYSTEM: ListElem Shared Addr = 0xbeaeeb80
[m3vpss ] 8082: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[c6xdsp ] 5609: SYSTEM : FREE SPACE : System Heap = 10268448 B, Mbx = 10240 msgs)
[m3video] 8086: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 8083: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3video] 8086: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 8083: SYSTEM: ListElem Shared Addr = 0xbeacf180
[c6xdsp ] 5482: SYSTEM : Initializing Links ... DONE !!!
[m3video] 8086: SYSTEM: ListElem Shared Addr = 0xbeb0b700
[m3vpss ] 8084: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3video] 8088: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 8085: SYSTEM : FVID2 Init in progress !!!
[c6xdsp ] 5482: SYSTEM : System DSP Init Done !!!
[m3video] 8088: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 8154: SYSTEM : FVID2 Init in progress DONE !!!
[m3video] 8088: HDVICP: Doing PRCM for IVAHD[1] ...
[m3vpss ] 8154: SYSTEM : Device Init in progress !!!
[m3video] 8088: HDVICP: PRCM for IVAHD[1] ... DONE.
[m3video] 8088: HDVICP: Doing PRCM for IVAHD[2] ...
[m3vpss ] initPrms.isI2cInitReq = 0
[m3video] 8088: HDVICP: PRCM for IVAHD[2] ... DONE.
[m3video] 8089: SYSTEM : Initializing Links !!!
[m3vpss ] 8157: SYSTEM : Device Init in progress DONE !!!
[m3video] 8089: SYSTEM : FREE SPACE : System Heap = 6280232 B, Mbx = 10240 msgs)
[m3vpss ] 8275: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 8275: UTILS: DMA: HWI Create for INT62 !!!
[m3video] 8089: SYSTEM : FREE SPACE : SR0 Heap = 14517120 B (13 MB)
[m3vpss ] 8275: SYSTEM : Initializing Links !!!
[m3video] 8089: SYSTEM : FREE SPACE : Frame Buffer = 244318080 B (232 MB)
[m3vpss ] 8275: SYSTEM : FREE SPACE : System Heap = 13024 B, Mbx = 10240 msgs)
[m3video] Received character 's'
[m3video] 8089: SYSTEM : FREE SPACE : Bitstream Buffer = 219676544 B (209 MB)
[m3vpss ] 8275: SYSTEM : FREE SPACE : SR0 Heap = 14517120 B (13 MB)
[c6xdsp ] Received character 's'
/opt/d[module] vpss probe done.
vr_rdk/ti816x
[m3video] 8090: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 8276: SYSTEM : FREE SPACE : Frame Buffer = 240008064 B (228 MB)
[m3video] 8090: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 8276: SYSTEM : FREE SPACE : Bitstream Buffer = 219676544 B (209 MB)
[m3video] 8090: SYSTEM : FREE SPACE : Tiler 16-bit = 13421[module] ti81xxfb probe done.
[m3vpss ] 8276: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON
[m3video] 8122: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 8276: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 8380: SYSTHDMI W1 rev 2.0
[module] ti81xx_hdmi probe done.
I2C No Ack
ORG 0x46c00524: 0
NEW 0x46c00524: 2
Main Menu DEMO_TALENT 20120906
1: VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
2: VCAP + VENC + VDEC + VDIS - Interlaced SD Encode + Decode
3: VCAP + VENC + VDIS - SD Encode ONLY
4: VCAP + VENC + VDIS - HD Encode ONLY
5: VDEC + VDIS - SD/HD Decode ONLY
6: VCAP + VDIS - NO Encode or Decode
7: CUSTOM DEMO - 2Ch D1 Encode
8: CUSTOM DEMO - 1Ch D1 + 4CIF Encode
9: CUSTOM DEMO - 1Ch D1 Decode
a: 4CH VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
e: Exit
Enter Choice: a
---------------parame print------------------
vcapParams.numChn= 4
vencParams.numPrimaryChn= 4
vdecParams.numChn= 4
vdisParams.numChannels= 8
vsysParams.numChs= 4
---------------parame print end------------------
--------------- CHANNEL DETAILS-------------
Capture Channels => 4
Enc Channels => Primary 4, Secondary 4
Dec Channels => 4
Disp Channels => 8
0: SYSTEM: System Common Init in progress !!!
0: SYSTEM: IPC init in progress !!!
11: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
15: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
16: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
16: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
17: SYSTEM: Notify register to [DSP] line 0, event 15 ...
18: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
18: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
18: SYSTEM: IPC init DONE !!!
20: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
22: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
23: SYSTEM: ListElem Shared Addr = 0x2b236280
24: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
26: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
28: SYSTEM: ListElem Shared Addr = 0x2b252e00
29: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
31: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
33: SYSTEM: ListElem Shared Addr = 0x2b26f980
34: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
36: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
37: SYSTEM: ListElem Shared Addr = 0x2b28f380
38: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
40: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
42: SYSTEM: ListElem Shared Addr = 0x2b2aed80
58: SYSTEM: System Common Init Done !!!
Enable SCD block metadata Write
Enable file write (YES - y / NO - n) : n
File write DISABLED !!!
[host] MCFW_IPCBITS:VcapVencVdecVdis_ipcBitsSendFxn:Entered... [FBDEV]
[FBDEV] FB: Starting !!!
[FBDEV] FB: OpeLPW ti81xxfb_ioctl
ned device [/devLPW ti81xxfb_ioctl
/fb0] (fd=23) !!LPW ti81xxfb_ioctl
[FBDEV]
[LPW ti81xxfb_ioctl
FBDEV] Fix Screen Info
[FBDEV] ---------------LPW ti81xxfb_ioctl
[FBDEV] Line LPW ti81xxfb_ioctl
Length - 2560
[FBDEV] Physical Address = 8ec00000
[FBDEV] Buffer Length = 8294400
[FBDEV]
[FBDEV]
[FBDEV] Var Screen Info
[FBDEV] Xres - 1280
[FBDEV] Yres - 720
[FBDEV] Xres Virtual - 1280
[FBDEV] Yres Virtual - 720
[FBDEV] Bits Per Pixel - 16
[FBDEV] Pixel Clk - 6734
[FBDEV] Rotation - 0
[FBDEV]
[FBDEV]
[FBDEV] Reg Params Info
[FBDEV] region 0, postion 0 x 0, prioirty 1
[FBDEV] first 1, last 1
[FBDEV] sc en 0, sten en 0
[FBDEV] tran en 0, type 0, key 0
[FBDEV] blend 0, alpha 0
[FBDEV] bb en 0, alpha 0
[FBDEV]
[FBDEV]
[FBDEV] ### BUF SIZE = 1843200 Bytes !!!
[FBDEV]
[FBDEV]
[FBDEV] Fix Screen Info
[FBDEV] Line Length - 2560
[FBDEV]
[FBDEV]
[FBDEV] Xres - 1280
[FBDEV] Yres - 720
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] grpx_fb_draw ...
[FBDEV] grpx_fb_draw ... Done !!!
[FBDEV] FB: Start DONE !!!
[FBDEV]
gVsysModuleContext.vsysConfig.systemUseCase: 8
case VSYS_USECASE_MULTICHN_PROGRESSIVE_VCAP_VDIS_VENC_VDEC_4CH NUM : @@run--->@@@@MultiCh_createProgressive4D1VcapVencVdecVdis@@@@@@
********* Entered usecase 4CH <814x> Enc/Dec OSD Enabled SCD Enabled ********LPW modify it to TI_816x 4ch mod
2963: MCFW : CPU Revision [ES1.1] !!!
2963: MCFW : Detected [(null)] Board !!!
2963: MCFW : Base Board Revision [DVR] !!!
2963: MCFW : Daughter Card Revision [DVR] !!!
---run-->----Vcap_configVideoDecoder-----numDevices:1 --------
VCAP: TVP5158-0 (0x58): Detected video (720x288@50Hz, 1) !!!
TVP5158: 0x58: Downloading patch ...
TVP5158: 0x58: Downloading patch ... DONE !!!
TVP5158: 0x58: 5158:0002:0302
[m3vpss ] 17377: CAPTURE: Create in progress !!!@@@@@@@@@@
[m3vpss ] 17406: CAPTURE: VIP1 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
[m3vpss ] @@@@@@@@@
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[m3vpss ] CAPTURE::HEAPID:0 USED:416
[m3vpss ] CAPTURE::HEAPID:4 USED:17713152
[m3vpss ] 17468: CAPTURE: Create Done !!!
[m3vpss ] 17469: NSF: Create in progress !!!
[m3vpss ] NSF::HEAPID:0 USED:128
[m3vpss ] NSF::HEAPID:1 USED:9152
[m3vpss ] NSF::HEAPID:4 USED:7299072
[m3vpss ] 17503: NSF: Create Done !!!
[m3vpss ] 17503: DEI : Create in progress !!!
[m3vpss ] 17534: DEI: OUT0: 0: 0xb1bf6c80, 704 x 576, 8 frames
[m3vpss ] 17563: DEI: OUT0: 1: 0xb2226c80, 704 x 576, 8 frames
[m3vpss ] 17593: DEI: OUT0: 2: 0xb2856c80, 704 x 576, 8 frames
[m3vpss ] 17622: DEI: OUT0: 3: 0xb2e86c80, 704 x 576, 8 frames
[m3vpss ] 17622: DEI: OUT1: 0: 0x00000020, 704 x 576, 8 frames
[m3vpss ] 17623: DEI: OUT1: 1: 0x00001620, 704 x 576, 8 frames
[m3vpss ] 17623: DEI: OUT1: 2: 0x00002c20, 704 x 576, 8 frames
[m3vpss ] 17623: DEI: OUT1: 3: 0x009002c0, 704 x 576, 8 frames
[m3vpss ] 17629: DEI: OUT2: 0: 0xb34b6c80, 352 x 288, 8 frames
[m3vpss ] 17635: DEI: OUT2: 1: 0xb35dfc80, 352 x 288, 8 frames
[m3vpss ] 17640: DEI: OUT2: 2: 0xb3708c80, 352 x 288, 8 frames
[m3vpss ] 17646: DEI: OUT2: 3: 0xb3831c80, 352 x 288, 8 frames
[m3vpss ] 17674: DEI : Loading Up-scaling Co-effs
[m3vpss ] 17674: DEI : Co-effs Loading ... DONE !!!
[c6xdsp ] 15391: IPC_FRAMES_IN : Create in progress !!!
[c6xdsp ] 15391: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_23] ...
[m3vpss ] DEI:HEAPID:0 USED:64
[c6xdsp ] 15392: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_23] ...
[m3vpss ] DEI:HEAPID:1 USED:9984
[c6xdsp ] 15392: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] DEI:HEAPID:4 USED:36495360
[m3vpss ] 17674: DEI : Create Done !!!
[m3vpss ] 17680: DUP : Create Done !!!
[c6xdsp ] IPC_FRAMES_IN:HEAPID:0 USED:304
[m3vpss ] 17680: NSF: Create in progress !!!
[c6xdsp ] 15393: IPC_FRAMES_IN : Create Done !!!
[c6xdsp ] 15395: ALG : Create in progress !!!
[m3vpss ] NSF::HEAPID:1 USED:5632
[m3vpss ] 17682: NSF: Create Done !!!
[m3vpss ] 17683: MERGE : Create Done !!!
[m3vpss ] 17683: IPC_FRAMES_OUT : Create in progress !!!
[c6xdsp ] 15402: SCD : Create in progress !!!
[c6xdsp ] 15402: SCD : Max WxH = 352 x 288, Max CH = 4, FPS = 5 !!!
[m3vpss ] 17685: IPC_FRAMES_OUT : Create Done !!!
[c6xdsp ] Setting block configuration data
[host] IpcBitsInLink_tskMain:Entered
[host] 4625: IPC_BITS_IN : Create in progress !!!
[host] 4625: IPC_BITS_IN : ListMPOpen start !!!
[host] 4625: SYSTEM: Opening ListMP [DSP_IPC_OUT_28] ...
4627: SYSTEM: Opening ListMP [DSP_IPC_IN_28] ...
[host] 4628: IPC_BITS_IN : ListMPOpen done !!!
[host] 4629: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 4630: IPC_BITS_IN : Create Done !!!
[c6xdsp ] > SCD: Algorithm memory requirements queried ::
[m3video] 17715: IPC_IN_M3 : Create in progress !!!
[m3vpss ] 17714: IPC_OUT_M3 : Create in progress !!!
[c6xdsp ] > Processing Frame Resolution = 352x288
[m3video] 17715: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] 17715: IPC_OUT_M3 : Create Done !!!
[c6xdsp ] > Number of buffers = 11
[m3video] 17716: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[c6xdsp ] > Number of channels supported = 4
[m3video] 17718: IPC_IN_M3 : Create Done !!!
[c6xdsp ] > Persistent Internal Memory = 11204 bytes
[m3video] 17718: ENCODE: Create in progress ... !!!
[c6xdsp ] > Persistent External Memory = 2551296 bytes
[m3video] ENCLINK:INFO: !!!Number of output buffers for ch[8] set to [1]
[c6xdsp ] > Scratch Internal Memory = 61248 bytes
[c6xdsp ] > SCD: Initializing Scene Change Detection Algorithm...
[c6xdsp ] 15411: SCD : 4: 352 x 288, In FPS = 30, Out FPS = 5!!!
[c6xdsp ] 15411: SCD : 5: 352 x 288, In FPS = 30, Out FPS = 5!!!
[c6xdsp ] 15411: SCD : 6: 352 x 288, In FPS = 30, Out FPS = 5!!!
[c6xdsp ] 15411: SCD : 7: 352 x 288, In FPS = 30, Out FPS = 5!!!
[c6xdsp ] 15411: SCD : Create Done !!!
[c6xdsp ] ALGLINK:HEAPID:0 USED:2554168
[c6xdsp ] ALGLINK:HEAPID:1 USED:78488
[c6xdsp ] ALGLINK:HEAPID:3 USED:208896
[c6xdsp ] 15412: ALG : Create Done !!!
[c6xdsp ] 15414: IPC_BITS_OUT : Create in progress !!!
[c6xdsp ] 15415: IPC_BITS_OUT : Create Done !!!
[m3video] 17786: ENCODE: Creating CH0 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:0 USED:13808
[m3video] ENCLINK_H264:HEAPID:3 USED:49152
[m3video] 17789: ENCODE: Creating CH1 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[host] 4735: IPC_BITS_IN : Create in progress !!!
[host] 4735: IPC_BITS_IN : ListMPOpen start !!!
[host] 4735: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
4737: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 4739: IPC_BITS_IN : ListMPOpen done !!!
[host] 4740: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 4741: IPC_BITS_IN : Create Done !!!
========bitsProducerLinkInfo============
numQ 1, numCh 12
Ch [0] Width 704, Height 576
Ch [1] Width 704, Height 576
Ch [2] Width 704, Height 576
Ch [3] Width 704, Height 576
Ch [4] Width 352, Height 288
Ch [5] Width 352, Height 288
Ch [6] Width 352, Height 288
Ch [7] Width 352, Height 288
Ch [8] Width 704, Height 576
Ch [9] Width 704, Height 576
Ch [10] Width 704, Height 576
Ch [11] Width 704, Height 576
Reducing bitsProducerLinkInfo.numCh to 4
[host] 4741: IPC_BITS_OUT : Create in progress !!!
###Bit buff of size from the SR # 1 : 9953280
[host] IPC_BITSOUT:BitBuffer Alloc.PoolID:0,Size:0x97E000
[host] IPCBITSOUTLINK:Translated Addr Virt:0x2ce53d80 To Phy:0x90e3cd80
[host] 4741: IPC_BITS_OUT : Create Done !!!
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3video] 17791: ENCODE: Creating CH2 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[m3video] 17793: ENCODE: Creating CH3 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[m3video] 17796: ENCODE: Creating CH4 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 500 Kbps ...
[m3vpss ] 17875: IPC_IN_M3 : Create in progress !!!
[m3vpss ] 17875: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[m3video] ENCLINK_H264:HEAPID:3 USED:757760
[m3vpss ] 17875: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[m3video] 17800: ENCODE: Creating CH5 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 500 Kbps ...
[m3vpss ] 17876: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 17878: IPC_IN_M3 : Create Done !!!
[m3vpss ] 17878: MERGE : Create Done !!!
[m3video] 17804: ENCODE: Creating CH6 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 500 Kbps ...
[m3vpss ] 17884: DUP : Create Done !!!
[m3vpss ] 17884: SWMS: Create in progress !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59)
[m3video] 17809: ENCODE: Creating CH7 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 500 Kbps ...
[m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 17
[m3vpss ] 18038: SWMS : VipScReq is FALSE!!!
[m3vpss ] 18041: SWMS0 : Loading Co-effs (UPSCALE)x ...
[m3vpss ] 18041: SWMS : Co-effs Loading ... DONE !!!
[m3video] 17813: ENCODE: Creating CH8 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 100 Kbps ...
[m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[0]
[m3vpss ] 18042: SWMS : ******* Configuring clock 32 secs...
[m3vpss ] 18042: SWMS0 : Loading Co-effs (UPSCALE)x ...
[m3video] ENCLINK_JPEG:HEAPID:0 USED:2064
[m3vpss ] 18042: SWMS : Co-effs Loading ... DONE !!!
[m3video] 17814: ENCODE: Creating CH9 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 100 Kbps ...
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 29
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format|
[m3vpss ] --------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 0 | 704 x 288 | 2816 / 2816 | NON-TILED | 0, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3vpss ] 1 | 1 | 0, 0 | 704 x 288 | 2816 / 2816 | NON-TILED | 480, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3vpss ] 2 | 2 | 0, 0 | 704 x 288 | 2816 / 2816 | NON-TILED | 960, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3video] 17815: ENCODE: Creating CH10 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 100 Kbps ...
[m3vpss ] 3 | 3 | 0, 0 | 704 x 288 | 2816 / 2816 | NON-TILED | 1440, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3vpss ] 4 | 4 | 0, 0 | 704 x 576 | 16384 / 32768 | TILED | 0, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 5 | 5 | 0, 0 | 704 x 576 | 16384 / 32768 | TILED | 480, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 6 | 6 | 0, 0 | 704 x 576 | 16384 / 32768 | TILED | 960, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP |
[m3video] 17815: ENCODE: Creating CH11 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 100 Kbps ...
[m3vpss ] 7 | 7 | 0, 0 | 704 x 576 | 16384 / 32768 | TILED | 1440, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 8 | 255 | 0, 0 | 320 x 240 | 1408 / 1408 | NON-TILED | 0, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3vpss ] 9 | 255 | 0, 0 | 320 x 240 | 1408 / 1408 | NON-TILED | 480, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3vpss ] 10 | 255 | 0, 0 | 320 x 240 | 1408 / 1408 | NON-TILED | 960, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3video] 17816: ENCODE: All CH Create ... DONE !!!
[m3vpss ] 11 | 255 | 0, 0 | 320 x 240 | 1408 / 1408 | NON-TILED | 1440, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3vpss ] 12 | 255 | 0, 0 | 320 x 240 | 1408 / 1408 | NON-TILED | 0, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3vpss ] 13 | 255 | 0, 0 | 320 x 240 | 1408 / 1408 | NON-TILED | 480, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3video] ENCLINK:HEAPID:0 USED:105568
[m3vpss ] 14 | 255 | 0, 0 | 320 x 240 | 1408 / 1408 | NON-TILED | 960, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3video] ENCLINK:HEAPID:2 USED:14720256
[m3vpss ] 15 | 255 | 0, 0 | 320 x 240 | 1408 / 1408 | NON-TILED | 1440, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I |
[m3video] ENCLINK:HEAPID:3 USED:3227648
[m3vpss ]
[m3video] 17817: ENCODE: Create ... DONE !!!
[m3video] 17818: IPC_BITS_OUT : Create in progress !!!
[m3vpss ] SWMS:HEAPID:0 USED:360
[m3vpss ] SWMS:HEAPID:1 USED:19360
[m3video] 17819: IPC_BITS_OUT : Create Done !!!
[m3vpss ] SWMS:HEAPID:4 USED:33177600
[m3video] 17825: IPC_BITS_IN : Create in progress !!!
[m3vpss ] 18047: SWMS: Create Done !!!
[m3video] 17826: SYSTEM: Opening ListMP [HOST_IPC_OUT_28] ...
[m3vpss ] 18048: SWMS: Create in progress !!!
[m3video] 17826: SYSTEM: Opening ListMP [HOST_IPC_IN_28] ...
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 60 (60)
[m3video] 17827: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
[m3video] 17829: IPC_BITS_IN : Create Done !!!
[m3vpss ] 18084: SWMS1 : Loading Co-effs (UPSCALE)x ...
[m3video] 17829: DECODE: Create in progress ... !!!
[m3vpss ] 18084: SWMS : Co-effs Loading ... DONE !!!
Audio capture task created
[m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[2]
[m3video] DECLINK_H264:HEAPID:0 USED:2368
[m3vpss ] 18085: SWMS : ******* Configuring clock 32 secs...
[m3video] DECLINK_H264:HEAPID:3 USED:1409024
[m3vpss ] 18085: SWMS1 : Loading Co-effs (UPSCALE)x ...
[m3video] 17840: DECODE: Creating CH0 of 704 x 576 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] 18085: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 0 | 0, 0 | 704 x 576 | 1408 / 1408 | NON-TILED | 0, 0 | 528 x 360 | 1472 / 0 | NON-TILED | OFF | 0 | 422I |
[m3vpss ] 1 | 1 | 0, 0 | 704 x 288 | 2816 / 2816 | NON-TILED | 528, 0 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I |
[m3vpss ] 2 | 2 | 0, 0 | 704 x 288 | 2816 / 2816 | NON-TILED | 528, 120 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I |
[m3video] 17849: DECODE: Creating CH1 of 704 x 576 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] 3 | 3 | 0, 0 | 704 x 288 | 2816 / 2816 | NON-TILED | 528, 240 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I |
[m3vpss ] 4 | 4 | 0, 0 | 704 x 576 | 16384 / 32768 | TILED | 0, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 5 | 5 | 0, 0 | 704 x 576 | 16384 / 32768 | TILED | 176, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 6 | 6 | 0, 0 | 704 x 576 | 16384 / 32768 | TILED | 352, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 7 | 7 | 0, 0 | 704 x 576 | 16384 / 32768 | TILED | 528, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP |
[m3video] 17859: DECODE: Creating CH2 of 704 x 576 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ]
Audio playback task created
---run--> Vcap_start-----------
[m3vpss ] SWMS:HEAPID:1 USED:47296
[m3video] 17869: DECODE: Creating CH3 of 704 x 576 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] SWMS:HEAPID:4 USED:6782976
[m3video] 17871: DECODE: All CH Create ... DONE !!!
[m3vpss ] 18088: SWMS: Create Done !!!
[m3vpss ] 18089: DISPLAY: Create in progress !!!
[m3vpss ] 18090: DISPLAY: Create Done !!!
[m3video] DECLINK:HEAPID:0 USED:9592
[m3vpss ] 18090: DISPLAY: Create in progress !!!
[m3video] DECLINK:HEAPID:3 USED:5636096
[m3vpss ] 18090: DISPLAY: 47: Field Separate Mode ENABLED for Que 0 !!!
[m3video] 17873: DECODE: Create ... DONE !!!
[m3vpss ] 18091: DISPLAY: Create Done !!!
[m3video] 17874: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 18567: DISPLAY: Start in progress !!!
[m3video] 17874: IPC_OUT_M3 : Create Done !!!
[m3vpss ] 18604: DISPLAY: Start Done !!!
[m3vpss ] 18604: DISPLAY: HDDAC(BP0) : 55 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 18604: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 1
[m3vpss ] 18604: SYSTEM : FREE SPACE : System Heap = 5616 B, Mbx = 10238 msgs)
[m3vpss ] 18604: SYSTEM : FREE SPACE : SR0 Heap = 12022272 B (11 MB)
[m3vpss ] 18604: SYSTEM : FREE SPACE : Frame Buffer = 129676160 B (123 MB)
[m3vpss ] 18604: SYSTEM : FREE SPACE : Bitstream Buffer = 194794112 B (185 MB)
[m3vpss ] 18605: SYSTEM : FREE SPACE : Tiler 8-bit = 82313216 B (78 MB) - TILER ON
[m3vpss ] 18605: SYSTEM : FREE SPACE : Tiler 16-bit = 102760448 B (98 MB) - TILER ON
[m3vpss ] 18605: DISPLAY: Start in progress !!!
[m3vpss ] 18664: DISPLAY: Start Done !!!
[m3vpss ] 18664: DISPLAY: SDDAC(SEC1): 16 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 18664: SWMS: Start in Progress !!!
[m3vpss ] 18664: SWMS: Start Done !!!
[m3vpss ] 18665: SWMS: Start in Progress !!!
[m3vpss ] 18665: SWMS: Start Done !!!
[m3vpss ] 18912: CAPTURE: Start in progress !!!
[m3vpss ] 18912: CAPTURE: Start Done !!!
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
5: Audio Capture / Playback Settings
6: Audio Capture <TVP5158> & Encode <AAC-LC> demo
7: Audio encode demo <AAC-LC File In/Out>
8: Audio decode demo <AAC-LC File In/Out>
i: Print detailed system information
s: Core Status: Active/In-active
e: Stop Demo
Enter Choice: [m3video] Channel:0 inputframerate:25 targetfps:25
[m3video] Channel:1 inputframerate:25 targetfps:25
[m3video] Channel:2 inputframerate:25 targetfps:25
[m3video] Channel:3 inputframerate:25 targetfps:25
[m3video] Channel:8 inputframerate:25 targetfps:25
[m3video] Channel:9 inputframerate:25 targetfps:25
[m3video] Channel:10 inputframerate:25 targetfps:25
[m3video] Channel:11 inputframerate:25 targetfps:25
[m3video] ENCLINK: new targetbitrate to set:100000
[m3video] ENCLINK: new targetframerate to set:25000
[m3video] ENCLINK: Run time parameters changed 0
[m3video] Channel:4 inputframerate:25 targetfps:25
[m3video] Channel:5 inputframerate:25 targetfps:25
[m3video] Channel:6 inputframerate:25 targetfps:25
[m3video] Channel:7 inputframerate:25 targetfps:25
[m3vpss ] 20109: CAPTURE: Overflow detected on VIP1, Total Resets = 1
[m3vpss ] 20116: DEI : Loading Up-scaling Co-effs
[m3vpss ] 20116: DEI : Co-effs Loading ... DONE !!!
[TAMPER DETECTED] 10533: SCD CH <4> CAP CH = 0
[c6xdsp ] 21421: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[TAMPER DETECTED] 10772: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 11009: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 11251: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 11489: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 11732: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 11973: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 12212: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 12453: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 12689: SCD CH <4> CAP CH = 0
## AVERAGE: ENCODE [ 111.4] FPS, DECODE [ 53.7] FPS, ENC+DEC [ 165.1] FPS ... in 10.0 secs,
[TAMPER DETECTED] 12929: SCD CH <4> CAP CH = 0
thread -----------display_process_main------LPW
[TAMPER DETECTED] 13170: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 13475: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 13649: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 13891: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 14131: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 14384: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 14611: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 14849: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 15091: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 15329: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 15569: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 15731: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 15860: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 16100: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 16339: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 16419: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 16577: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 16818: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 16998: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 17057: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 17299: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 17379: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 17571: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 17811: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 17861: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 18097: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 18304: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 18339: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 18577: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 18784: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 18819: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 19091: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 19155: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 19412: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 19535: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 19699: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 19939: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 20064: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 20210: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 20580: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 20660: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 20821: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 21057: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 21141: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 21406: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 21698: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 21845: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 21953: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 22291: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 22611: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 22661: SCD CH <4> CAP CH = 0
## AVERAGE: ENCODE [ 162.7] FPS, DECODE [ 78.7] FPS, ENC+DEC [ 241.3] FPS ... in 10.0 secs,
[TAMPER DETECTED] 22898: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 23076: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 23171: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 23361: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 23411: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 23728: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 23827: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 23971: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 24211: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 24357: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 24498: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 24771: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 24979: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 25076: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 25379: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 25504: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 25617: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 25892: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 26164: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 26177: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 26420: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 26658: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 26901: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 27043: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 27137: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 27377: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 27443: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 27664: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 27907: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 28145: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 28218: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 28388: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 28625: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 28645: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 28869: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 29105: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 29188: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 29349: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 29587: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 29779: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 29827: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 30069: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 30309: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 30547: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 30557: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 30818: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 31059: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 31089: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 31299: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 31538: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 31558: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 31778: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 32017: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 32130: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 32259: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 32467: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 32500: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 32787: SCD CH <4> CAP CH = 0
## AVERAGE: ENCODE [ 163.5] FPS, DECODE [ 79.2] FPS, ENC+DEC [ 242.6] FPS ... in 10.0 secs,
[TAMPER DETECTED] 33025: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 33076: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 33267: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 33508: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 33620: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 33745: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 33985: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 34226: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 34469: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 34479: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 34701: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 34947: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 34996: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 35185: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 35397: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 35425: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 35665: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 35907: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 35927: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 36145: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 36368: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 36465: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 36707: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 36945: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 37044: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 37217: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 37411: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 37509: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 37777: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 37989: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 38067: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 38307: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 38421: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 38545: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 38819: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 38883: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 39105: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 39348: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 39397: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 39586: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 39907: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 39924: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 40244: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 40309: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 40498: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 40820: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 40850: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 41105: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 41357: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 41427: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 41683: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 42035: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 42067: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 42338: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 42580: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 42621: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 42817: SCD CH <4> CAP CH = 0
## AVERAGE: ENCODE [ 163.0] FPS, DECODE [ 78.8] FPS, ENC+DEC [ 241.7] FPS ... in 10.0 secs,
[TAMPER DETECTED] 43107: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 43212: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 43348: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 43680: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 43923: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 44001: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 44258: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 44419: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 44545: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 44788: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 44820: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 45029: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 45265: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 45379: SCD CH <6> CAP CH = 2
[TAMPER DETECTED] 45507: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 45779: SCD CH <4> CAP CH = 0
[TAMPER DETECTED] 45859: SCD CH <6> CAP CH = 2
[m3vpss ] 59117: CAPTURE: Overflow detected on VIP1, Total Resets = 2
