The function I2CMasterErr() reply the the error status 0x0C and SCL will stuck low
Does any function can recover the I2C bus?
Hi lin wei-hung,
Are you using BIOSPSP?. If so, could you please mention which version of the biospsp you are using?.
Raghavendra
lin wei-hung,
Where is the function I2CMasterErr() coming from?. Which package are you referring to? [EDIT]
Raghavendra
After use the below function the bus is ok,
SysCtlPeripheralReset(SYSCTL_PERIPH_I2C0);
I2CMasterInitExpClk(I2C0_MASTER_BASE,, SysCtlClockGet(), 0);
I2CMasterControl(I2C0_MASTER_BASE,, I2C_MASTER_CMD_BURST_SEND_ERROR_STOP);
