OMAP-L138 Line out problem
Other Parts Discussed in Thread: OMAP-L138
I have several OMAP-L138 Boards (TMDSEXPL138-UNV) from LogicPD, and I can't get anything to come out of the line out port. I've tried both LogicPD's example code and some code from a textbook.
If it helps, I've attached the LogicPD example code that wont work. It hangs at line 199, the while loop condition is never satisfied.
// \file    test_audio.c
// \brief   implementation of OMAP-L138 audio test.
#include "stdio.h"
#include "types.h"
#include "evmomapl138.h"
#include "evmomapl138_mcasp.h"
#include "evmomapl138_aic3106.h"
#include "test_audio.h"
// Private Defines and Macros
// Static Variable Declarations
static int16_t sinetable[48] = {
    0x0000, 0x10b4, 0x2120, 0x30fb, 0x3fff, 0x4dea, 0x5a81, 0x658b,
    0x6ed8, 0x763f, 0x7ba1, 0x7ee5, 0x7ffd, 0x7ee5, 0x7ba1, 0x76ef,
    0x6ed8, 0x658b, 0x5a81, 0x4dea, 0x3fff, 0x30fb, 0x2120, 0x10b4,
    0x0000, 0xef4c, 0xdee0, 0xcf06, 0xc002, 0xb216, 0xa57f, 0x9a75,
    0x9128, 0x89c1, 0x845f, 0x811b, 0x8002, 0x811b, 0x845f, 0x89c1,
    0x9128, 0x9a76, 0xa57f, 0xb216, 0xc002, 0xcf06, 0xdee0, 0xef4c
// Private Function Prototypes
static uint32_t testAudioLineOut(void);
static uint32_t testAudioLineIn(void);
static void shutdownAudio(void);
// Public Function Definitions
// \brief   tests the AIC3106 CODEC
// \param   none.
// \return  uint32_t
uint32_t TEST_audio(void)
	uint32_t rtn = ERR_NO_ERROR;
   printf("--------------------------------------------------------------------\r\n");
   printf("                     Audio CODEC test\r\n\r\n");
   printf("Additional Equipment\r\n");
   printf("--------------------\r\n");
   printf("- 3.5mm pass through cable\r\n\r\n");
   printf("- 3.5mm headphones\r\n\r\n");
   printf("Test Description\r\n");
   printf("----------------\r\n");
   printf("The test will begin by playing a 5 second tone though the line\r\n");
   printf("out port. The 3.5mm pass through cable will not be needed for\r\n");
   printf("this portion of the test. After playing the tone, audio from the\n\r");
   printf("line in port will be played through the line out port for 15 seconds.\r\n");
   printf("--------------------------------------------------------------------\r\n\r\n");
	// initialize the required bsl modules
   printf("Initialize the Required BSL Modules\r\n");
   printf("-----------------------------------\r\n\r\n");
	rtn = MCASP_init();
	if (rtn != ERR_NO_ERROR)
		printf("error initializing mcasp!\r\n");
		return (rtn);
	rtn = AIC3106_init();
		printf("error initializing aic3106!\r\n");
		return (rtn);
	// execute line out test.
   printf("\r\nExecute Test\r\n");
   printf("------------\r\n\r\n");
	printf("--- test audio line out (put on your headphones...) ---\r\n");
	rtn = testAudioLineOut();
      printf("\tline out test failed\r\n\r\n");
      return (rtn);
   else
      printf("\tline out test passed\r\n\r\n");
	rtn = MCASP_init();
		return (rtn);
		return (rtn);
	// execute line in test.
	printf("--- test audio line in (put on your headphones and plug in source to line in...) ---\r\n");
	rtn = testAudioLineIn();
      printf("\tline in test failed\r\n\r\n");
      return (rtn);
   else
      printf("\tline in test passed\r\n\r\n");
	// kill codec and mcasp.
   shutdownAudio();
	return (rtn);
// Private Function Definitions
   int16_t msec, sec;
   int16_t sample;
   // enable the audio clocks, verifying each bit is properly set.
   SETBIT(MCASP->XGBLCTL, XHCLKRST);
   while (!CHKBIT(MCASP->XGBLCTL, XHCLKRST)) {}
   SETBIT(MCASP->RGBLCTL, RHCLKRST);
   while (!CHKBIT(MCASP->RGBLCTL, RHCLKRST)) {}
   SETBIT(MCASP->XGBLCTL, XCLKRST);
   while (!CHKBIT(MCASP->XGBLCTL, XCLKRST)) {}
   SETBIT(MCASP->RGBLCTL, RCLKRST);
   while (!CHKBIT(MCASP->RGBLCTL, RCLKRST)) {}
   SETBIT(MCASP->XGBLCTL, XSRCLR);
   while (!CHKBIT(MCASP->XGBLCTL, XSRCLR)) {}
   SETBIT(MCASP->RGBLCTL, RSRCLR);
   while (!CHKBIT(MCASP->RGBLCTL, RSRCLR)) {}
   /* Write a 0, so that no underrun occurs after releasing the state machine */
   MCASP->XBUF11 = 0;
   //MCASP->RBUF12 = 0;
   SETBIT(MCASP->XGBLCTL, XSMRST);
   while (!CHKBIT(MCASP->XGBLCTL, XSMRST)) {}
   SETBIT(MCASP->RGBLCTL, RSMRST);
   while (!CHKBIT(MCASP->RGBLCTL, RSMRST)) {}
   SETBIT(MCASP->XGBLCTL, XFRST);
   while (!CHKBIT(MCASP->XGBLCTL, XFRST)) {}
   SETBIT(MCASP->RGBLCTL, RFRST);
   while (!CHKBIT(MCASP->RGBLCTL, RFRST)) {}
   // wait for transmit ready and send a dummy byte.
   while(!CHKBIT(MCASP->SRCTL11, XRDY)) {}
   MCASP->XBUF11 = 0;
   // transmit beep.
   for (sec = 0; sec < 5; sec++)
      for (msec = 0; msec < 1000; msec++)
         for (sample = 0; sample < 48; sample++)
            // wait for xmit ready and send a sample to the left channel.
            while (!CHKBIT(MCASP->SRCTL11, XRDY)) {} //Gets stuck here forever
            MCASP->XBUF11 = (sinetable[sample] << 15) | 0x00000000;
   return (rtn);
   int16_t msec, sec, sample;
   int32_t dat;
   MCASP->XBUF11 = 0;
   MCASP->XBUF11 = 0;
   // loop audio
   for (sec = 0; sec < 15; sec++)
            // wait for recv ready and send a sample to the left channel.
   			MCASP->XBUF11 = dat;
            dat = MCASP->XBUF12;
            // wait for recv ready and send a sample to the right channel.
   return (rtn);
   // close codec.
   AIC3106_writeRegister(AIC3106_REG_PAGESELECT, 0);
   AIC3106_writeRegister(AIC3106_REG_RESET, 0x80);
   // close mcasp.
   MCASP->SRCTL0 = 0;
   MCASP->SRCTL1 = 0;
   MCASP->SRCTL2 = 0;
   MCASP->SRCTL3 = 0;
   MCASP->SRCTL5 = 0;
   MCASP->SRCTL11 = 0;
   MCASP->SRCTL12 = 0;
   MCASP->GBLCTL = 0;
Edit: Here's more information: the code in question is waiting for the register SRCTL11 of the McASP0DSP to have its XRDY flag (bit 4) set to 1. Inspecting the register in CCS shows that the while loop hangs with SRCTL11 having the value 0x000D, which indicates that the serializer is set to transmit, and the corresponding transmit buffer (XBUF11) is clear and ready to receive data. I can't figure out why the McASP isn't setting bit 4 on SRCTL11. Can anyone help me?
  • Hi team,
    Is there an update available regarding this inquiry?
  • Hi Rudolph,
    Can you try the attached main_audio.c and test_audio.c which is working fine for us on OMAP-L138.
    From CCSv4-2-4_with_SOM-M1_BSL_WS\DSP eXp Audio Test
    In main_audio.c – the code is
    // uncomment this define if running without gel initialization.
    //#define NO_GEL    (1)
    Change this code to
    #define NO_GEL    (1)
    Also, in the above code attached, in test_audio.c the testAudioLineIn() has been disabled for your clear understanding of the testAudioLineOut() code flow.
    As last checkpoint, do check whether your headphones are working properly.
    Iyshwarya
    If you need more help, please reply back. If this answers the question, please click Verify Answer , below.
    // \file    main.c
    // \brief   implementation of main() to test bsl drivers.
    #include "stdio.h"
    #include "types.h"
    #include "evmomapl138_timer.h"
    #include "evmomapl138_gpio.h"
    #include "evmomapl138_i2c.h"
    #define NO_GEL    (1)
    // \brief   entry point for bsl test code.
    // \param   none.
    // \return  none.
    int main(void)
       uint32_t results = 0;
    #if NO_GEL
       EVMOMAPL138_init();
       EVMOMAPL138_initRAM();
    #endif
       // init the us timer and i2c for all to use.
       USTIMER_init();
       I2C_init(I2C0, I2C_CLK_400K);
       // TEST AUDIO
       results += TEST_audio();
       printf("\r\n\r\n");
       if (results != ERR_NO_ERROR)
          printf("\r\n\r\n********** OMAP-L138 TEST FAILED **********\r\n\r\n");
       else
          printf("\r\n\r\n********** OMAP-L138 TEST PASSED **********\r\n\r\n");
    #include "stdio.h"
    #include "types.h"
    // \param   none.
    // \return  uint32_t
    	rtn = MCASP_init();
    		return (rtn);
    		return (rtn);
          return (rtn);
       else
    #if 0
    	rtn = MCASP_init();
    		return (rtn);
    		return (rtn);
          return (rtn);
       else
       shutdownAudio();
    #endif
    	return (rtn);
       int16_t msec, sec;
       int16_t sample;
       MCASP->XBUF11 = 0;
       MCASP->XBUF11 = 0;
       // transmit beep.
       return (rtn);
       int32_t dat;
       MCASP->XBUF11 = 0;
       MCASP->XBUF11 = 0;
       // loop audio
       return (rtn);
       // close codec.
       // close mcasp.
       MCASP->SRCTL0 = 0;
       MCASP->SRCTL1 = 0;
       MCASP->SRCTL2 = 0;
       MCASP->SRCTL3 = 0;
       MCASP->SRCTL5 = 0;
       MCASP->SRCTL11 = 0;
       MCASP->SRCTL12 = 0;
       MCASP->GBLCTL = 0;
  • Thank you, that code works.
    -Rudy Raab
  • Is LogicPD's example code correct for the audio line in example? Shouldn't it be reading from RBUF rather than XBUF12?
