Customer wants to know if there is a command line approach to check memory bandwidth and CPU usage during benchmark tests on the Blaze 2 Tablet? They haven’t found a simple way to measure these metrics during tests. Thanks for your help.
Harini,
Top is a good way to measure CPU usage. You can just run a command such as:
# top -m 8 -n 5 -t
This will show the top 8 processes by CPU usage, for 5 iterations.
You can use omapconf to access the EMIF statistics collector for EMIF load monitoring, with the command:
# omapconf trace bw
This will show the read and write throughput in MB/s.
Gina
