Hi ,
I am running ICS with Pandaboard (OMAP4430).
I have downloaded release software from "http://omappedia.org/wiki/4AI.1.4_OMAP4_Icecream_Sandwich_Panda_Notes"
But the board is rebooting after every 2 minute.
bellow is the the log message.
shell@android:/ $ [ 10.679229] android_work: sent uevent USB_STATE=CONNECTED
[ 10.685516] android_work: sent uevent USB_STATE=DISCONNECTED
[ 10.840240] android_work: sent uevent USB_STATE=CONNECTED
[ 10.847320] android_usb gadget: high speed config #1: android
[ 10.854553] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.273254] misc dsscomp: [e96ad800] ignoring set failure -22
[ 12.071319] (stc): remove_channel_from_table: id 2
[ 12.076477] (stc): remove_channel_from_table: id 3
[ 12.081695] (stc): remove_channel_from_table: id 4
[ 12.086822] (stc): all chnl_ids unregistered
[ 12.091583] (stk) :ldisc_install = 0
[ 12.095458] (stc): st_tty_close
309] request_suspend_state: wakeup (3->0) at 408916229247 (2000-01-01 00:06:44.747100827 UTC)
[ 408.935516] DSSCOMP: dsscomp_late_resume
[ 411.747100] _omap4_module_wait_ready: Timeout waiting for module enable (mcpdm_fck: clkctrl = 0x30002)
[ 411.761535] ------------[ cut here ]------------
[ 411.766876] WARNING: at sound/soc/omap/omap-mcpdm.c:401 omap_mcpdm_dai_startup+0x168/0x188()
[ 411.776428] Clock not enabled: PDM_CLKCTRL=0x30000
[ 411.781860] Modules linked in: omaplfb_sgx540_120 cfg80211 pvrsrvkm_sgx540_120 compat
[ 411.790740] Backtrace:
[ 411.793487] [<c00541a0>] (dump_backtrace+0x0/0x110) from [<c056acdc>] (dump_stack+0x18/0x1c)
[ 411.802520] r6:00000191 r5:c03f14b0 r4:e8395bd0 r3:e8394000
[ 411.808898] [<c056acc4>] (dump_stack+0x0/0x1c) from [<c009b120>] (warn_slowpath_common+0x5c/0x6c)
[ 411.818450] [<c009b0c4>] (warn_slowpath_common+0x0/0x6c) from [<c009b1d4>] (warn_slowpath_fmt+0x38/0x40)
[ 411.828796] r8:c076e328 r7:d704dc00 r6:ec998060 r5:ec8cdcd0 r4:ec8cdcc0
[ 411.836151] r3:00000009
[ 411.839141] [<c009b19c>] (warn_slowpath_fmt+0x0/0x40) from [<c03f14b0>] (omap_mcpdm_dai_startup+0x168/0x188)
[ 411.849700] r3:00030000 r2:c06e0b64
[ 411.853729] [<c03f1348>] (omap_mcpdm_dai_startup+0x0/0x188) from [<c03e4438>] (soc_pcm_open+0x9c/0x5a4)
[ 411.863800] r6:ec98fba0 r5:ec998060 r4:ecb85760 r3:c03f1348
[ 411.870178] [<c03e439c>] (soc_pcm_open+0x0/0x5a4) from [<c03ebfb8>] (soc_dsp_be_dai_startup+0x10c/0x264)
[ 411.880371] [<c03ebeac>] (soc_dsp_be_dai_startup+0x0/0x264) from [<c03ec1a0>] (soc_dsp_fe_dai_open+0x90/0x398)
[ 411.891113] [<c03ec110>] (soc_dsp_fe_dai_open+0x0/0x398) from [<c03c1b94>] (snd_pcm_open_substream+0x70/0xb0)
[ 411.901763] [<c03c1b24>] (snd_pcm_open_substream+0x0/0xb0) from [<c03c1d14>] (snd_pcm_open+0x140/0x258)
[ 411.911834] r5:ecbaace0 r4:e271e240
[ 411.915863] [<c03c1bd4>] (snd_pcm_open+0x0/0x258) from [<c03c1eb8>] (snd_pcm_playback_open+0x44/0x48)
[ 411.925964] [<c03c1e74>] (snd_pcm_playback_open+0x0/0x48) from [<c03b3af8>] (snd_open+0x144/0x2c0)
[ 411.935577] r5:e271e240 r4:c059fc60
[ 411.939605] [<c03b39b4>] (snd_open+0x0/0x2c0) from [<c0122a38>] (chrdev_open+0x128/0x1ec)
[ 411.948394] [<c0122910>] (chrdev_open+0x0/0x1ec) from [<c011d6a8>] (__dentry_open+0x188/0x2c8)
[ 411.957672] r7:ebc6b990 r6:ec9ac000 r5:ec58cc60 r4:e271e240
[ 411.964050] [<c011d520>] (__dentry_open+0x0/0x2c8) from [<c011d8c8>] (nameidata_to_filp+0x68/0x70)
[ 411.973663] [<c011d860>] (nameidata_to_filp+0x0/0x70) from [<c012c2c4>] (do_last+0xc8/0x6d4)
[ 411.982727] r7:00000026 r6:00000000 r5:00020002 r4:e8395ed0
[ 411.989105] [<c012c1fc>] (do_last+0x0/0x6d4) from [<c012d908>] (path_openat+0xc4/0x3d4)
[ 411.997741] [<c012d844>] (path_openat+0x0/0x3d4) from [<c012dd10>] (do_filp_open+0x38/0x8c)
[ 412.006713] [<c012dcd8>] (do_filp_open+0x0/0x8c) from [<c011d434>] (do_sys_open+0xe8/0x17c)
[ 412.015838] r8:00000001 r7:ffffff9c r6:00000014 r5:00020002 r4:eb933000
[ 412.023498] [<c011d34c>] (do_sys_open+0x0/0x17c) from [<c011d500>] (sys_open+0x24/0x28)
[ 412.032135] [<c011d4dc>] (sys_open+0x0/0x28) from [<c004ff00>] (ret_fast_syscall+0x0/0x30)
[ 412.040954] ---[ end trace 3e90230ac8eee4fc ]---
[ 412.045959] ------------[ cut here ]------------
[ 412.050933] WARNING: at arch/arm/mach-omap2/omap_hwmod.c:1323 _idle+0x174/0x17c()
[ 412.058990] omap_hwmod: mcpdm: idle state can only be entered from enabled state
[ 412.066925] Modules linked in: omaplfb_sgx540_120 cfg80211 pvrsrvkm_sgx540_120 compat
[ 412.075683] Backtrace:
[ 412.078399] [<c00541a0>] (dump_backtrace+0x0/0x110) from [<c056acdc>] (dump_stack+0x18/0x1c)
[ 412.087463] r6:0000052b r5:c0063a44 r4:e83959d8 r3:e8394000
[ 412.093902] [<c056acc4>] (dump_stack+0x0/0x1c) from [<c009b120>] (warn_slowpath_common+0x5c/0x6c)
[ 412.103363] [<c009b0c4>] (warn_slowpath_common+0x0/0x6c) from [<c009b1d4>] (warn_slowpath_fmt+0x38/0x40)
[ 412.113525] r8:3b9aca00 r7:c072f874 r6:a0000113 r5:c0741954 r4:c0741908
[ 412.120880] r3:00000009
[ 412.123870] [<c009b19c>] (warn_slowpath_fmt+0x0/0x40) from [<c0063a44>] (_idle+0x174/0x17c)
[ 412.132843] r3:c068d88c r2:c068e9a4
[ 412.136840] [<c00638d0>] (_idle+0x0/0x17c) from [<c0064490>] (omap_hwmod_idle+0x30/0x44)
[ 412.145538] r6:a0000113 r5:c0741954 r4:c0741908
[ 412.150726] [<c0064460>] (omap_hwmod_idle+0x0/0x44) from [<c007ee20>] (omap_device_idle_hwmods+0x30/0x44)
[ 412.160980] r6:00000000 r5:ec8ace00 r4:00000001 r3:00000001
[ 412.167388] [<c007edf0>] (omap_device_idle_hwmods+0x0/0x44) from [<c007ef4c>] (_omap_device_deactivate+0x7c/0x118)
[ 412.178497] r5:c072f874 r4:ec8ace00
[ 412.182495] [<c007eed0>] (_omap_device_deactivate+0x0/0x118) from [<c007f194>] (omap_device_idle+0x28/0x74)
[ 412.192932] [<c007f16c>] (omap_device_idle+0x0/0x74) from [<c007f3a4>] (_od_runtime_suspend+0x24/0x2c)
[ 412.202911] r4:00000000
[ 412.205749] [<c007f380>] (_od_runtime_suspend+0x0/0x2c) from [<c02a13f0>] (rpm_callback+0x54/0x68)
[ 412.215362] r5:ec8ace08 r4:c007f380
[ 412.219360] [<c02a139c>] (rpm_callback+0x0/0x68) from [<c02a177c>] (rpm_suspend+0x110/0x494)
[ 412.228424] r6:00000000 r5:00000000 r4:ec8ace08 r3:c0748250
[ 412.234802] [<c02a166c>] (rpm_suspend+0x0/0x494) from [<c02a2a8c>] (__pm_runtime_suspend+0x80/0xac)
[ 412.244506] [<c02a2a0c>] (__pm_runtime_suspend+0x0/0xac) from [<c029edb4>] (pm_generic_runtime_idle+0x4c/0x54)
[ 412.255218] r7:ec8ace7c r6:c007f348 r5:ec8ace08 r4:ec8ace08
[ 412.261566] [<c029ed68>] (pm_generic_runtime_idle+0x0/0x54) from [<c007f358>] (_od_runtime_idle+0x10/0x14)
[ 412.271911] r4:00000000 r3:00000000
[ 412.275939] [<c007f348>] (_od_runtime_idle+0x0/0x14) from [<c02a1c54>] (rpm_idle+0xe0/0x180)
[ 412.284942] [<c02a1b74>] (rpm_idle+0x0/0x180) from [<c02a1ddc>] (__pm_runtime_idle+0x6c/0x98)
[ 412.294067] r7:60000113 r6:ec8ace7c r5:00000004 r4:ec8ace08
[ 412.300506] [<c02a1d70>] (__pm_runtime_idle+0x0/0x98) from [<c03f14c8>] (omap_mcpdm_dai_startup+0x180/0x188)
[ 412.310974] r7:d704dc00 r6:00000000 r5:ec8cdcd0 r4:ec8cdcc0
[ 412.317413] [<c03f1348>] (omap_mcpdm_dai_startup+0x0/0x188) from [<c03e4438>] (soc_pcm_open+0x9c/0x5a4)
[ 412.327484] r6:ec98fba0 r5:ec998060 r4:ecb85760 r3:c03f1348
[ 412.333831] [<c03e439c>] (soc_pcm_open+0x0/0x5a4) from [<c03ebfb8>] (soc_dsp_be_dai_startup+0x10c/0x264)
[ 412.343994] [<c03ebeac>] (soc_dsp_be_dai_startup+0x0/0x264) from [<c03ec1a0>] (soc_dsp_fe_dai_open+0x90/0x398)
[ 412.354736] [<c03ec110>] (soc_dsp_fe_dai_open+0x0/0x398) from [<c03c1b94>] (snd_pcm_open_substream+0x70/0xb0)
[ 412.365356] [<c03c1b24>] (snd_pcm_open_substream+0x0/0xb0) from [<c03c1d14>] (snd_pcm_open+0x140/0x258)
[ 412.375427] r5:ecbaace0 r4:e271e240
[ 412.379425] [<c03c1bd4>] (snd_pcm_open+0x0/0x258) from [<c03c1eb8>] (snd_pcm_playback_open+0x44/0x48)
[ 412.389312] [<c03c1e74>] (snd_pcm_playback_open+0x0/0x48) from [<c03b3af8>] (snd_open+0x144/0x2c0)
[ 412.398925] r5:e271e240 r4:c059fc60
[ 412.402954] [<c03b39b4>] (snd_open+0x0/0x2c0) from [<c0122a38>] (chrdev_open+0x128/0x1ec)
[ 412.411743] [<c0122910>] (chrdev_open+0x0/0x1ec) from [<c011d6a8>] (__dentry_open+0x188/0x2c8)
[ 412.420928] r7:ebc6b990 r6:ec9ac000 r5:ec58cc60 r4:e271e240
[ 412.427337] [<c011d520>] (__dentry_open+0x0/0x2c8) from [<c011d8c8>] (nameidata_to_filp+0x68/0x70)
[ 412.436950] [<c011d860>] (nameidata_to_filp+0x0/0x70) from [<c012c2c4>] (do_last+0xc8/0x6d4)
[ 412.445953] r7:00000026 r6:00000000 r5:00020002 r4:e8395ed0
[ 412.452362] [<c012c1fc>] (do_last+0x0/0x6d4) from [<c012d908>] (path_openat+0xc4/0x3d4)
[ 412.460968] [<c012d844>] (path_openat+0x0/0x3d4) from [<c012dd10>] (do_filp_open+0x38/0x8c)
[ 412.469879] [<c012dcd8>] (do_filp_open+0x0/0x8c) from [<c011d434>] (do_sys_open+0xe8/0x17c)
[ 412.478851] r8:00000001 r7:ffffff9c r6:00000014 r5:00020002 r4:eb933000
[ 412.486450] [<c011d34c>] (do_sys_open+0x0/0x17c) from [<c011d500>] (sys_open+0x24/0x28)
[ 412.494995] [<c011d4dc>] (sys_open+0x0/0x28) from [<c004ff00>] (ret_fast_syscall+0x0/0x30)
[ 412.503875] ---[ end trace 3e90230ac8eee4fd ]---
[ 412.509979] asoc: can't open interface mcpdm-dl2
[ 412.523529] PDM-DL2: BE open failed -19
[ 412.574523] _omap4_module_wait_ready: Timeout waiting for module enable (mcpdm_fck: clkctrl = 0x30002)
[ 412.587463] ------------[ cut here ]------------
[ 412.592498] WARNING: at sound/soc/omap/omap-mcpdm.c:401 omap_mcpdm_dai_startup+0x168/0x188()
[ 412.601745] Clock not enabled: PDM_CLKCTRL=0x30000
[ 412.607391] Modules linked in: omaplfb_sgx540_120 cfg80211 pvrsrvkm_sgx540_120 compat
[ 412.617187] Backtrace:
[ 412.620483] [<c00541a0>] (dump_backtrace+0x0/0x110) from [<c056acdc>] (dump_stack+0x18/0x1c)
[ 412.629852] r6:00000191 r5:c03f14b0 r4:e8395bd0 r3:e8394000
[ 412.636718] [<c056acc4>] (dump_stack+0x0/0x1c) from [<c009b120>] (warn_slowpath_common+0x5c/0x6c)
[ 412.646301] [<c009b0c4>] (warn_slowpath_common+0x0/0x6c) from [<c009b1d4>] (warn_slowpath_fmt+0x38/0x40)
[ 412.656524] r8:c076e328 r7:d704dc00 r6:ec998060 r5:ec8cdcd0 r4:ec8cdcc0
[ 412.663879] r3:00000009
[ 412.666870] [<c009b19c>] (warn_slowpath_fmt+0x0/0x40) from [<c03f14b0>] (omap_mcpdm_dai_startup+0x168/0x188)
[ 412.677398] r3:00030000 r2:c06e0b64
[ 412.681488] [<c03f1348>] (omap_mcpdm_dai_startup+0x0/0x188) from [<c03e4438>] (soc_pcm_open+0x9c/0x5a4)
[ 412.691497] r6:ec98fba0 r5:ec998060 r4:ecb85760 r3:c03f1348
[ 412.698120] [<c03e439c>] (soc_pcm_open+0x0/0x5a4) from [<c03ebfb8>] (soc_dsp_be_dai_startup+0x10c/0x264)
[ 412.708312] [<c03ebeac>] (soc_dsp_be_dai_startup+0x0/0x264) from [<c03ec1a0>] (soc_dsp_fe_dai_open+0x90/0x398)
[ 412.719055] [<c03ec110>] (soc_dsp_fe_dai_open+0x0/0x398) from [<c03c1b94>] (snd_pcm_open_substream+0x70/0xb0)
[ 412.729614] [<c03c1b24>] (snd_pcm_open_substream+0x0/0xb0) from [<c03c1d14>] (snd_pcm_open+0x140/0x258)
[ 412.739715] r5:ecbaace0 r4:e25a9780
[ 412.743774] [<c03c1bd4>] (snd_pcm_open+0x0/0x258) from [<c03c1eb8>] (snd_pcm_playback_open+0x44/0x48)
[ 412.753631] [<c03c1e74>] (snd_pcm_playback_open+0x0/0x48) from [<c03b3af8>] (snd_open+0x144/0x2c0)
[ 412.763244] r5:e25a9780 r4:c059fc60
[ 412.767364] [<c03b39b4>] (snd_open+0x0/0x2c0) from [<c0122a38>] (chrdev_open+0x128/0x1ec)
[ 412.776092] [<c0122910>] (chrdev_open+0x0/0x1ec) from [<c011d6a8>] (__dentry_open+0x188/0x2c8)
[ 412.785339] r7:ebc6b990 r6:ec9ac000 r5:ec58cc60 r4:e25a9780
[ 412.791961] [<c011d520>] (__dentry_open+0x0/0x2c8) from [<c011d8c8>] (nameidata_to_filp+0x68/0x70)
[ 412.801544] [<c011d860>] (nameidata_to_filp+0x0/0x70) from [<c012c2c4>] (do_last+0xc8/0x6d4)
[ 412.810607] r7:00000026 r6:00000000 r5:00020002 r4:e8395ed0
[ 412.817047] [<c012c1fc>] (do_last+0x0/0x6d4) from [<c012d908>] (path_openat+0xc4/0x3d4)
[ 412.825592] [<c012d844>] (path_openat+0x0/0x3d4) from [<c012dd10>] (do_filp_open+0x38/0x8c)
[ 412.834594] [<c012dcd8>] (do_filp_open+0x0/0x8c) from [<c011d434>] (do_sys_open+0xe8/0x17c)
[ 412.843566] r8:00000001 r7:ffffff9c r6:00000014 r5:00020002 r4:eb933000
[ 412.851104] [<c011d34c>] (do_sys_open+0x0/0x17c) from [<c011d500>] (sys_open+0x24/0x28)
[ 412.859741] [<c011d4dc>] (sys_open+0x0/0x28) from [<c004ff00>] (ret_fast_syscall+0x0/0x30)
[ 412.868621] ---[ end trace 3e90230ac8eee4fe ]---
[ 412.873596] ------------[ cut here ]------------
[ 412.878601] WARNING: at arch/arm/mach-omap2/omap_hwmod.c:1323 _idle+0x174/0x17c()
[ 412.886596] omap_hwmod: mcpdm: idle state can only be entered from enabled state
[ 412.894531] Modules linked in: omaplfb_sgx540_120 cfg80211 pvrsrvkm_sgx540_120 compat
[ 412.903320] Backtrace:
[ 412.906066] [<c00541a0>] (dump_backtrace+0x0/0x110) from [<c056acdc>] (dump_stack+0x18/0x1c)
[ 412.915130] r6:0000052b r5:c0063a44 r4:e83959d8 r3:e8394000
[ 412.921478] [<c056acc4>] (dump_stack+0x0/0x1c) from [<c009b120>] (warn_slowpath_common+0x5c/0x6c)
[ 412.930999] [<c009b0c4>] (warn_slowpath_common+0x0/0x6c) from [<c009b1d4>] (warn_slowpath_fmt+0x38/0x40)
[ 412.941162] r8:3b9aca00 r7:c072f874 r6:a0000113 r5:c0741954 r4:c0741908
[ 412.948425] r3:00000009
[ 412.951477] [<c009b19c>] (warn_slowpath_fmt+0x0/0x40) from [<c0063a44>] (_idle+0x174/0x17c)
[ 412.960388] r3:c068d88c r2:c068e9a4
[ 412.964447] [<c00638d0>] (_idle+0x0/0x17c) from [<c0064490>] (omap_hwmod_idle+0x30/0x44)
[ 412.973083] r6:a0000113 r5:c0741954 r4:c0741908
[ 412.978332] [<c0064460>] (omap_hwmod_idle+0x0/0x44) from [<c007ee20>] (omap_device_idle_hwmods+0x30/0x44)
[ 412.988586] r6:00000000 r5:ec8ace00 r4:00000001 r3:00000001
[ 412.994964] [<c007edf0>] (omap_device_idle_hwmods+0x0/0x44) from [<c007ef4c>] (_omap_device_deactivate+0x7c/0x118)
[ 413.006042] r5:c072f874 r4:ec8ace00
[ 413.010040] [<c007eed0>] (_omap_device_deactivate+0x0/0x118) from [<c007f194>] (omap_device_idle+0x28/0x74)
[ 413.020507] [<c007f16c>] (omap_device_idle+0x0/0x74) from [<c007f3a4>] (_od_runtime_suspend+0x24/0x2c)
[ 413.030456] r4:00000000
[ 413.033294] [<c007f380>] (_od_runtime_suspend+0x0/0x2c) from [<c02a13f0>] (rpm_callback+0x54/0x68)
[ 413.042907] r5:ec8ace08 r4:c007f380
[ 413.046905] [<c02a139c>] (rpm_callback+0x0/0x68) from [<c02a177c>] (rpm_suspend+0x110/0x494)
[ 413.055969] r6:00000000 r5:00000000 r4:ec8ace08 r3:c0748250
[ 413.062377] [<c02a166c>] (rpm_suspend+0x0/0x494) from [<c02a2a8c>] (__pm_runtime_suspend+0x80/0xac)
[ 413.072021] [<c02a2a0c>] (__pm_runtime_suspend+0x0/0xac) from [<c029edb4>] (pm_generic_runtime_idle+0x4c/0x54)
[ 413.082733] r7:ec8ace7c r6:c007f348 r5:ec8ace08 r4:ec8ace08
[ 413.089172] [<c029ed68>] (pm_generic_runtime_idle+0x0/0x54) from [<c007f358>] (_od_runtime_idle+0x10/0x14)
[ 413.099517] r4:00000000 r3:00000000
[ 413.103515] [<c007f348>] (_od_runtime_idle+0x0/0x14) from [<c02a1c54>] (rpm_idle+0xe0/0x180)
[ 413.112579] [<c02a1b74>] (rpm_idle+0x0/0x180) from [<c02a1ddc>] (__pm_runtime_idle+0x6c/0x98)
[ 413.121643] r7:60000113 r6:ec8ace7c r5:00000004 r4:ec8ace08
[ 413.128082] [<c02a1d70>] (__pm_runtime_idle+0x0/0x98) from [<c03f14c8>] (omap_mcpdm_dai_startup+0x180/0x188)
[ 413.138610] r7:d704dc00 r6:00000000 r5:ec8cdcd0 r4:ec8cdcc0
[ 413.144958] [<c03f1348>] (omap_mcpdm_dai_startup+0x0/0x188) from [<c03e4438>] (soc_pcm_open+0x9c/0x5a4)
[ 413.155029] r6:ec98fba0 r5:ec998060 r4:ecb85760 r3:c03f1348
[ 413.161376] [<c03e439c>] (soc_pcm_open+0x0/0x5a4) from [<c03ebfb8>] (soc_dsp_be_dai_startup+0x10c/0x264)
[ 413.171539] [<c03ebeac>] (soc_dsp_be_dai_startup+0x0/0x264) from [<c03ec1a0>] (soc_dsp_fe_dai_open+0x90/0x398)
[ 413.182189] [<c03ec110>] (soc_dsp_fe_dai_open+0x0/0x398) from [<c03c1b94>] (snd_pcm_open_substream+0x70/0xb0)
[ 413.192840] [<c03c1b24>] (snd_pcm_open_substream+0x0/0xb0) from [<c03c1d14>] (snd_pcm_open+0x140/0x258)
[ 413.202911] r5:ecbaace0 r4:e25a9780
[ 413.206909] [<c03c1bd4>] (snd_pcm_open+0x0/0x258) from [<c03c1eb8>] (snd_pcm_playback_open+0x44/0x48)
[ 413.216796] [<c03c1e74>] (snd_pcm_playback_open+0x0/0x48) from [<c03b3af8>] (snd_open+0x144/0x2c0)
[ 413.226409] r5:e25a9780 r4:c059fc60
[ 413.230407] [<c03b39b4>] (snd_open+0x0/0x2c0) from [<c0122a38>] (chrdev_open+0x128/0x1ec)
[ 413.239196] [<c0122910>] (chrdev_open+0x0/0x1ec) from [<c011d6a8>] (__dentry_open+0x188/0x2c8)
[ 413.248413] r7:ebc6b990 r6:ec9ac000 r5:ec58cc60 r4:e25a9780
[ 413.254760] [<c011d520>] (__dentry_open+0x0/0x2c8) from [<c011d8c8>] (nameidata_to_filp+0x68/0x70)
[ 413.264373] [<c011d860>] (nameidata_to_filp+0x0/0x70) from [<c012c2c4>] (do_last+0xc8/0x6d4)
[ 413.273437] r7:00000026 r6:00000000 r5:00020002 r4:e8395ed0
[ 413.279785] [<c012c1fc>] (do_last+0x0/0x6d4) from [<c012d908>] (path_openat+0xc4/0x3d4)
[ 413.288391] [<c012d844>] (path_openat+0x0/0x3d4) from [<c012dd10>] (do_filp_open+0x38/0x8c)
[ 413.297363] [<c012dcd8>] (do_filp_open+0x0/0x8c) from [<c011d434>] (do_sys_open+0xe8/0x17c)
[ 413.306304] r8:00000001 r7:ffffff9c r6:00000014 r5:00020002 r4:eb933000
[ 413.313873] [<c011d34c>] (do_sys_open+0x0/0x17c) from [<c011d500>] (sys_open+0x24/0x28)
[ 413.322448] [<c011d4dc>] (sys_open+0x0/0x28) from [<c004ff00>] (ret_fast_syscall+0x0/0x30)
[ 413.331329] ---[ end trace 3e90230ac8eee4ff ]---
[ 413.336395] asoc: can't open interface mcpdm-dl2
[ 413.342163] PDM-DL2: BE open failed -19
[ 413.396514] _omap4_module_wait_ready: Timeout waiting for module enable (mcpdm_fck: clkctrl = 0x30002)
[ 413.410919] ------------[ cut here ]------------
[ 413.416168] WARNING: at sound/soc/omap/omap-mcpdm.c:401 omap_mcpdm_dai_startup+0x168/0x188()
[ 413.425689] Clock not enabled: PDM_CLKCTRL=0x30000
[ 413.431549] Modules linked in: omaplfb_sgx540_120 cfg80211 pvrsrvkm_sgx540_120 compat
[ 413.440643] Backtrace:
[ 413.443389] [<c00541a0>] (dump_backtrace+0x0/0x110) from [<c056acdc>] (dump_stack+0x18/0x1c)
[ 413.452514] r6:00000191 r5:c03f14b0 r4:e8395bd0 r3:e8394000
[ 413.458892] [<c056acc4>] (dump_stack+0x0/0x1c) from [<c009b120>] (warn_slowpath_common+0x5c/0x6c)
[ 413.468444] [<c009b0c4>] (warn_slowpath_common+0x0/0x6c) from [<c009b1d4>] (warn_slowpath_fmt+0x38/0x40)
[ 413.478607] r8:c076e328 r7:d704dc00 r6:ec998060 r5:ec8cdcd0 r4:ec8cdcc0
[ 413.485961] r3:00000009
[ 413.488952] [<c009b19c>] (warn_slowpath_fmt+0x0/0x40) from [<c03f14b0>] (omap_mcpdm_dai_startup+0x168/0x188)
[ 413.499511] r3:00030000 r2:c06e0b64
[ 413.503509] [<c03f1348>] (omap_mcpdm_dai_startup+0x0/0x188) from [<c03e4438>] (soc_pcm_open+0x9c/0x5a4)
[ 413.513580] r6:ec98fba0 r5:ec998060 r4:ecb85760 r3:c03f1348
[ 413.519958] [<c03e439c>] (soc_pcm_open+0x0/0x5a4) from [<c03ebfb8>] (soc_dsp_be_dai_startup+0x10c/0x264)
[ 413.530303] [<c03ebeac>] (soc_dsp_be_dai_startup+0x0/0x264) from [<c03ec1a0>] (soc_dsp_fe_dai_open+0x90/0x398)
[ 413.541046] [<c03ec110>] (soc_dsp_fe_dai_open+0x0/0x398) from [<c03c1b94>] (snd_pcm_open_substream+0x70/0xb0)
[ 413.551696] [<c03c1b24>] (snd_pcm_open_substream+0x0/0xb0) from [<c03c1d14>] (snd_pcm_open+0x140/0x258)
[ 413.561767] r5:ecbaace0 r4:e25a9300
[ 413.565765] [<c03c1bd4>] (snd_pcm_open+0x0/0x258) from [<c03c1eb8>] (snd_pcm_playback_open+0x44/0x48)
[ 413.575683] [<c03c1e74>] (snd_pcm_playback_open+0x0/0x48) from [<c03b3af8>] (snd_open+0x144/0x2c0)
[ 413.585296] r5:e25a9300 r4:c059fc60
[ 413.589324] [<c03b39b4>] (snd_open+0x0/0x2c0) from [<c0122a38>] (chrdev_open+0x128/0x1ec)
[ 413.598114] [<c0122910>] (chrdev_open+0x0/0x1ec) from [<c011d6a8>] (__dentry_open+0x188/0x2c8)
[ 413.607360] r7:ebc6b990 r6:ec9ac000 r5:ec58cc60 r4:e25a9300
[ 413.613739] [<c011d520>] (__dentry_open+0x0/0x2c8) from [<c011d8c8>] (nameidata_to_filp+0x68/0x70)
[ 413.623565] [<c011d860>] (nameidata_to_filp+0x0/0x70) from [<c012c2c4>] (do_last+0xc8/0x6d4)
[ 413.632629] r7:00000026 r6:00000000 r5:00020002 r4:e8395ed0
[ 413.638977] [<c012c1fc>] (do_last+0x0/0x6d4) from [<c012d908>] (path_openat+0xc4/0x3d4)
[ 413.647613] [<c012d844>] (path_openat+0x0/0x3d4) from [<c012dd10>] (do_filp_open+0x38/0x8c)
[ 413.656585] [<c012dcd8>] (do_filp_open+0x0/0x8c) from [<c011d434>] (do_sys_open+0xe8/0x17c)
[ 413.665496] r8:00000001 r7:ffffff9c r6:00000014 r5:00020002 r4:eb933000
[ 413.673095] [<c011d34c>] (do_sys_open+0x0/0x17c) from [<c011d500>] (sys_open+0x24/0x28)
[ 413.681701] [<c011d4dc>] (sys_open+0x0/0x28) from [<c004ff00>] (ret_fast_syscall+0x0/0x30)
[ 413.690551] ---[ end trace 3e90230ac8eee500 ]---
[ 413.695556] ------------[ cut here ]------------
[ 413.700531] WARNING: at arch/arm/mach-omap2/omap_hwmod.c:1323 _idle+0x174/0x17c()
[ 413.708587] omap_hwmod: mcpdm: idle state can only be entered from enabled state
[ 413.716461] Modules linked in: omaplfb_sgx540_120 cfg80211 pvrsrvkm_sgx540_120 compat
[ 413.725250] Backtrace:
[ 413.727996] [<c00541a0>] (dump_backtrace+0x0/0x110) from [<c056acdc>] (dump_stack+0x18/0x1c)
[ 413.737060] r6:0000052b r5:c0063a44 r4:e83959d8 r3:e8394000
[ 413.743408] [<c056acc4>] (dump_stack+0x0/0x1c) from [<c009b120>] (warn_slowpath_common+0x5c/0x6c)
[ 413.752868] [<c009b0c4>] (warn_slowpath_common+0x0/0x6c) from [<c009b1d4>] (warn_slowpath_fmt+0x38/0x40)
[ 413.763031] r8:3b9aca00 r7:c072f874 r6:a0000113 r5:c0741954 r4:c0741908
[ 413.770355] r3:00000009
[ 413.773345] [<c009b19c>] (warn_slowpath_fmt+0x0/0x40) from [<c0063a44>] (_idle+0x174/0x17c)
[ 413.782318] r3:c068d88c r2:c068e9a4
[ 413.786315] [<c00638d0>] (_idle+0x0/0x17c) from [<c0064490>] (omap_hwmod_idle+0x30/0x44)
[ 413.795013] r6:a0000113 r5:c0741954 r4:c0741908
[ 413.800201] [<c0064460>] (omap_hwmod_idle+0x0/0x44) from [<c007ee20>] (omap_device_idle_hwmods+0x30/0x44)
[ 413.810424] r6:00000000 r5:ec8ace00 r4:00000001 r3:00000001
[ 413.816864] [<c007edf0>] (omap_device_idle_hwmods+0x0/0x44) from [<c007ef4c>] (_omap_device_deactivate+0x7c/0x118)
[ 413.827880] r5:c072f874 r4:ec8ace00
[ 413.831939] [<c007eed0>] (_omap_device_deactivate+0x0/0x118) from [<c007f194>] (omap_device_idle+0x28/0x74)
[ 413.842376] [<c007f16c>] (omap_device_idle+0x0/0x74) from [<c007f3a4>] (_od_runtime_suspend+0x24/0x2c)
[ 413.852294] r4:00000000
[ 413.855133] [<c007f380>] (_od_runtime_suspend+0x0/0x2c) from [<c02a13f0>] (rpm_callback+0x54/0x68)
[ 413.864715] r5:ec8ace08 r4:c007f380
[ 413.868713] [<c02a139c>] (rpm_callback+0x0/0x68) from [<c02a177c>] (rpm_suspend+0x110/0x494)
[ 413.877777] r6:00000000 r5:00000000 r4:ec8ace08 r3:c0748250
[ 413.884124] [<c02a166c>] (rpm_suspend+0x0/0x494) from [<c02a2a8c>] (__pm_runtime_suspend+0x80/0xac)
[ 413.893829] [<c02a2a0c>] (__pm_runtime_suspend+0x0/0xac) from [<c029edb4>] (pm_generic_runtime_idle+0x4c/0x54)
[ 413.904541] r7:ec8ace7c r6:c007f348 r5:ec8ace08 r4:ec8ace08
[ 413.910888] [<c029ed68>] (pm_generic_runtime_idle+0x0/0x54) from [<c007f358>] (_od_runtime_idle+0x10/0x14)
[ 413.921234] r4:00000000 r3:00000000
[ 413.925231] [<c007f348>] (_od_runtime_idle+0x0/0x14) from [<c02a1c54>] (rpm_idle+0xe0/0x180)
[ 413.934265] [<c02a1b74>] (rpm_idle+0x0/0x180) from [<c02a1ddc>] (__pm_runtime_idle+0x6c/0x98)
[ 413.943420] r7:60000113 r6:ec8ace7c r5:00000004 r4:ec8ace08
[ 413.949768] [<c02a1d70>] (__pm_runtime_idle+0x0/0x98) from [<c03f14c8>] (omap_mcpdm_dai_startup+0x180/0x188)
[ 413.960296] r7:d704dc00 r6:00000000 r5:ec8cdcd0 r4:ec8cdcc0
[ 413.966705] [<c03f1348>] (omap_mcpdm_dai_startup+0x0/0x188) from [<c03e4438>] (soc_pcm_open+0x9c/0x5a4)
[ 413.976776] r6:ec98fba0 r5:ec998060 r4:ecb85760 r3:c03f1348
[ 413.983123] [<c03e439c>] (soc_pcm_open+0x0/0x5a4) from [<c03ebfb8>] (soc_dsp_be_dai_startup+0x10c/0x264)
[ 413.993286] [<c03ebeac>] (soc_dsp_be_dai_startup+0x0/0x264) from [<c03ec1a0>] (soc_dsp_fe_dai_open+0x90/0x398)
[ 414.003997] [<c03ec110>] (soc_dsp_fe_dai_open+0x0/0x398) from [<c03c1b94>] (snd_pcm_open_substream+0x70/0xb0)
[ 414.014617] [<c03c1b24>] (snd_pcm_open_substream+0x0/0xb0) from [<c03c1d14>] (snd_pcm_open+0x140/0x258)
[ 414.024658] r5:ecbaace0 r4:e25a9300
[ 414.028686] [<c03c1bd4>] (snd_pcm_open+0x0/0x258) from [<c03c1eb8>] (snd_pcm_playback_open+0x44/0x48)
[ 414.038574] [<c03c1e74>] (snd_pcm_playback_open+0x0/0x48) from [<c03b3af8>] (snd_open+0x144/0x2c0)
[ 414.048156] r5:e25a9300 r4:c059fc60
[ 414.052154] [<c03b39b4>] (snd_open+0x0/0x2c0) from [<c0122a38>] (chrdev_open+0x128/0x1ec)
[ 414.060943] [<c0122910>] (chrdev_open+0x0/0x1ec) from [<c011d6a8>] (__dentry_open+0x188/0x2c8)
[ 414.070098] r7:ebc6b990 r6:ec9ac000 r5:ec58cc60 r4:e25a9300
[ 414.076538] [<c011d520>] (__dentry_open+0x0/0x2c8) from [<c011d8c8>] (nameidata_to_filp+0x68/0x70)
[ 414.086120] [<c011d860>] (nameidata_to_filp+0x0/0x70) from [<c012c2c4>] (do_last+0xc8/0x6d4)
[ 414.095123] r7:00000026 r6:00000000 r5:00020002 r4:e8395ed0
[ 414.101562] [<c012c1fc>] (do_last+0x0/0x6d4) from [<c012d908>] (path_openat+0xc4/0x3d4)
[ 414.110137] [<c012d844>] (path_openat+0x0/0x3d4) from [<c012dd10>] (do_filp_open+0x38/0x8c)
[ 414.119049] [<c012dcd8>] (do_filp_open+0x0/0x8c) from [<c011d434>] (do_sys_open+0xe8/0x17c)
[ 414.127990] r8:00000001 r7:ffffff9c r6:00000014 r5:00020002 r4:eb933000
[ 414.135589] [<c011d34c>] (do_sys_open+0x0/0x17c) from [<c011d500>] (sys_open+0x24/0x28)
[ 414.144134] [<c011d4dc>] (sys_open+0x0/0x28) from [<c004ff00>] (ret_fast_syscall+0x0/0x30)
[ 414.153015] ---[ end trace 3e90230ac8eee501 ]---
[ 414.158111] asoc: can't open interface mcpdm-dl2
[ 414.163940] PDM-DL2: BE open failed -19
[ 414.218414] _omap4_module_wait_ready: Timeout waiting for module enable (mcpdm_fck: clkctrl = 0x30002)
[ 414.232818] ------------[ cut here ]------------
[ 414.238281] WARNING: at sound/soc/omap/omap-mcpdm.c:401 omap_mcpdm_dai_startup+0x168/0x188()
[ 414.247650] Clock not enabled: PDM_CLKCTRL=0x30000
[ 414.253051] Modules linked in: omaplfb_sgx540_120 cfg80211 pvrsrvkm_sgx540_120 compat
[ 414.261840] Backtrace:
[ 414.264648] [<c00541a0>] (dump_backtrace+0x0/0x110) from [<c056acdc>] (dump_stack+0x18/0x1c)
[ 414.273651] r6:00000191 r5:c03f14b0 r4:e8395bd0 r3:e8394000
[ 414.280090] [<c056acc4>] (dump_stack+0x0/0x1c) from [<c009b120>] (warn_slowpath_common+0x5c/0x6c)
[ 414.289611] [<c009b0c4>] (warn_slowpath_common+0x0/0x6c) from [<c009b1d4>] (warn_slowpath_fmt+0x38/0x40)
[ 414.299713] r8:c076e328 r7:d704dc00 r6:ec998060 r5:ec8cdcd0 r4:ec8cdcc0
[ 414.307067] r3:00000009
[ 414.310058] [<c009b19c>] (warn_slowpath_fmt+0x0/0x40) from [<c03f14b0>] (omap_mcpdm_dai_startup+0x168/0x188)
[ 414.320587] r3:00030000 r2:c06e0b64
[ 414.324584] [<c03f1348>] (omap_mcpdm_dai_startup+0x0/0x188) from [<c03e4438>] (soc_pcm_open+0x9c/0x5a4)
[ 414.334655] r6:ec98fba0 r5:ec998060 r4:ecb85760 r3:c03f1348
[ 414.341094] [<c03e439c>] (soc_pcm_open+0x0/0x5a4) from [<c03ebfb8>] (soc_dsp_be_dai_startup+0x10c/0x264)
[ 414.351440] [<c03ebeac>] (soc_dsp_be_dai_startup+0x0/0x264) from [<c03ec1a0>] (soc_dsp_fe_dai_open+0x90/0x398)
[ 414.362182] [<c03ec110>] (soc_dsp_fe_dai_open+0x0/0x398) from [<c03c1b94>] (snd_pcm_open_substream+0x70/0xb0)
[ 414.372741] [<c03c1b24>] (snd_pcm_open_substream+0x0/0xb0) from [<c03c1d14>] (snd_pcm_open+0x140/0x258)
[ 414.382812] r5:ecbaace0 r4:e25a9780
[ 414.386871] [<c03c1bd4>] (snd_pcm_open+0x0/0x258) from [<c03c1eb8>] (snd_pcm_playback_open+0x44/0x48)
[ 414.396728] [<c03c1e74>] (snd_pcm_playback_open+0x0/0x48) from [<c03b3af8>] (snd_open+0x144/0x2c0)
[ 414.406341] r5:e25a9780 r4:c059fc60
[ 414.410339] [<c03b39b4>] (snd_open+0x0/0x2c0) from [<c0122a38>] (chrdev_open+0x128/0x1ec)
[ 414.419067] [<c0122910>] (chrdev_open+0x0/0x1ec) from [<c011d6a8>] (__dentry_open+0x188/0x2c8)
[ 414.428314] r7:ebc6b990 r6:ec9ac000 r5:ec58cc60 r4:e25a9780
[ 414.434661] [<c011d520>] (__dentry_open+0x0/0x2c8) from [<c011d8c8>] (nameidata_to_filp+0x68/0x70)
[ 414.444244] [<c011d860>] (nameidata_to_filp+0x0/0x70) from [<c012c2c4>] (do_last+0xc8/0x6d4)
[ 414.453491] r7:00000026 r6:00000000 r5:00020002 r4:e8395ed0
[ 414.459899] [<c012c1fc>] (do_last+0x0/0x6d4) from [<c012d908>] (path_openat+0xc4/0x3d4)
[ 414.468444] [<c012d844>] (path_openat+0x0/0x3d4) from [<c012dd10>] (do_filp_open+0x38/0x8c)
[ 414.477447] [<c012dcd8>] (do_filp_open+0x0/0x8c) from [<c011d434>] (do_sys_open+0xe8/0x17c)
[ 414.486419] r8:00000001 r7:ffffff9c r6:00000014 r5:00020002 r4:eb933000
[ 414.493957] [<c011d34c>] (do_sys_open+0x0/0x17c) from [<c011d500>] (sys_open+0x24/0x28)
[ 414.502563] [<c011d4dc>] (sys_open+0x0/0x28) from [<c004ff00>] (ret_fast_syscall+0x0/0x30)
[ 414.511444] ---[ end trace 3e90230ac8eee502 ]---
[ 414.516418] ------------[ cut here ]------------
Vishnu
