Other Parts Discussed in Thread: WL1271, DM3730, TVP5146M2
Hello Team ,
I 'm using custom tablet board Omap3evm Dm3730 with Android ICS 4.0 Stack , after building the File system wifi & Bluetooth is not working we usig wl1271 chipset .
Could please help to solve this issue . log as follow
Console Log
Welcome to minicom 2.5
OPTIONS: I18n
Compiled on May 2 2011, 00:39:27.
Port /dev/ttyUSB0
Press CTRL-A Z for help on special keys
Texas Instruments X-Loader 1.46 (Oct 21 2011 - 08:35:44)
Starting X-loader on MMC
Reading boot sector
217404 Bytes Read from MMC
Starting OS Bootloader from MMC...
Starting OS Bootloader...
U-Boot 2010.06 (Aug 24 2012 - 03:01:20)
OMAP34xx/35xx-GP ES2.1, CPU-OPP2 L3-165MHz
OMAP3 EVM board + LPDDR/NAND
I2C: ready
DRAM: 128 MiB
NAND: HW ECC [Kernel/FS layout] selected
1024 MiB
In: serial
Out: serial
Err: serial
Read back SMSC id 0xffff0000
Die ID #297800029ff800000160716409017017
Net: No ethernet found.
Hit any key to stop autoboot: 0
mmc1 is available
reading boot.scr
458 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
reading uImage
3673792 bytes read
***** Kernel: /dev/mmcblk0p1/uImage *****
***** RootFS: /dev/mmcblk0p2 *****
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-2.6.37-g5c414d7-dirty
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3673728 Bytes = 3.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
p_i2c.1: addr: 0x004b, len: 2, flags: 0x0, stop: 1
[ 0.063262] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.063293] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.064056] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.070709] regulator: VIO: 1800 mV normal standby
[ 0.071594] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[ 0.072387] regulator: VDAC: 1800 mV normal standby
[ 0.073211] regulator: VAUX2_4030: 2800 mV normal standby
[ 0.074005] regulator: VPLL2: 1800 mV normal standby
[ 0.074859] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
[ 0.075683] regulator: VAUX3: 2800 mV normal standby
[ 0.076568] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.092163] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 0.094085] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.094940] Bluetooth: Core ver 2.15
[ 0.095153] NET: Registered protocol family 31
[ 0.095153] Bluetooth: HCI device and connection manager initialized
[ 0.095184] Bluetooth: HCI socket layer initialized
[ 0.095794] cfg80211: Calling CRDA to update world regulatory domain
[ 0.096527] Switching to clocksource 32k_counter
[ 0.225952] WL1271: BT_EN GPIO initialized
[ 0.226196] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
[ 0.226318] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[ 0.226684] musb-hdrc musb-hdrc.0: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 0.227264] NET: Registered protocol family 2
[ 0.227447] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.227905] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.228118] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.228271] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.228302] TCP reno registered
[ 0.228302] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.228332] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.228546] NET: Registered protocol family 1
[ 0.228912] RPC: Registered udp transport module.
[ 0.228912] RPC: Registered tcp transport module.
[ 0.228942] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.229125] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.236846] omap3evm camera init done successfully...
[ 0.237152] omap-iommu omap-iommu.0: isp registered
[ 0.237518] AM37x/DM37x Linux PSP version 04.02.00.07 (OMAP3EVM)
[ 0.409362] ashmem: initialized
[ 0.409881] VFS: Disk quotas dquot_6.5.2
[ 0.409973] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.411468] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.412170] msgmni has been set to 475
[ 0.413604] io scheduler noop registered
[ 0.413635] io scheduler deadline registered
[ 0.413757] io scheduler cfq registered (default)
[ 0.471893] OMAP DSS rev 2.0
[ 0.471984] OMAP DISPC rev 3.0
[ 0.472015] OMAP VENC rev 2
[ 0.472351] OMAP DSI rev 1.0
[ 0.801208] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.803253] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.098693] console [ttyO0] enabled
[ 1.102844] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.110687] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.118469] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
[ 1.137695] brd: module loaded
[ 1.146514] loop: module loaded
[ 1.150817] (stk) :sysfs entries created
[ 1.154998] (stk) : debugfs entries created
[ 1.162170] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.168975] omap2-nand driver initializing
[ 1.173645] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xb3 (Micron )
[ 1.180633] Creating 5 MTD partitions on "omap2-nand.0":
[ 1.186248] 0x000000000000-0x000000080000 : "X-Loader-NAND"
[ 1.194152] 0x000000080000-0x0000001c0000 : "U-Boot-NAND"
[ 1.201904] 0x0000001c0000-0x000000280000 : "Boot Env-NAND"
[ 1.209594] 0x000000280000-0x000000780000 : "Kernel-NAND"
[ 1.218933] 0x000000780000-0x000040000000 : "File System - NAND"
[ 1.649963] OneNAND driver initializing
[ 1.654113] omap2-onenand omap2-onenand: Cannot request GPMC CS
[ 1.660369] omap2-onenand: probe of omap2-onenand failed with error -16
[ 1.669433] smsc911x: Driver version 2008-10-21.
[ 1.674835] usbcore: registered new interface driver asix
[ 1.680725] usbcore: registered new interface driver cdc_ether
[ 1.687072] usbcore: registered new interface driver net1080
[ 1.693206] usbcore: registered new interface driver cdc_subset
[ 1.699645] usbcore: registered new interface driver zaurus
[ 1.705688] usbcore: registered new interface driver zd1201
[ 1.711547] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.718505] ehci-omap.0 supply hsusb0 not found, using dummy regulator
[ 2.729492] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 2.735534] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 2.743560] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 2.760803] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 2.766937] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.774078] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.781677] usb usb1: Product: OMAP-EHCI Host Controller
[ 2.787261] usb usb1: Manufacturer: Linux 2.6.37-g5c414d7-dirty ehci_hcd
[ 2.794311] usb usb1: SerialNumber: ehci-omap.0
[ 2.800109] hub 1-0:1.0: USB hub found
[ 2.804077] hub 1-0:1.0: 3 ports detected
[ 2.839202] Initializing USB Mass Storage driver...
[ 2.844604] usbcore: registered new interface driver usb-storage
[ 2.850921] USB Mass Storage support registered.
[ 2.856018] usbcore: registered new interface driver usbtest
[ 2.861968] android init
[ 2.864715] android_probe pdata: c0712e8c
[ 2.869140] android_bind
[ 2.872558] android_usb gadget: android_usb ready
[ 2.877502] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 2.883148] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 2.891052] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.898193] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.905822] usb usb2: Product: MUSB HDRC host driver
[ 2.911071] usb usb2: Manufacturer: Linux 2.6.37-g5c414d7-dirty musb-hcd
[ 2.918121] usb usb2: SerialNumber: musb-hdrc.0
[ 2.923828] hub 2-0:1.0: USB hub found
[ 2.927795] hub 2-0:1.0: 1 port detected
[ 2.932800] f_adb init
[ 2.935272] android_register_function adb
[ 2.939453] f_mass_storage init
[ 2.942871] fsg_probe pdev: c0712a88, pdata: c0712f1c
[ 2.948394] android_register_function usb_mass_storage
[ 2.953796] adb_bind_config
[ 2.957733] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.964996] android_usb gadget: Number of LUNs=1
[ 2.969848] lun0: LUN: removable file: (no medium)
[ 2.975280] f_mtp init
[ 2.977752] android_register_function mtp
[ 2.982574] mice: PS/2 mouse device common for all mice
[ 2.989044] input: TWL4030 Keypad as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/twl4030_keypad/input/input0
[ 3.002685]
[ 3.002685] WRITE FAILED 1
[ 3.007415]
[ 3.007415] WRITE SUCCESS 1
[ 3.012207]
[ 3.012207] WRITE SUCCESS 1
[ 3.016967]
[ 3.016967] WRITE SUCCESS 1
[ 3.021606]
[ 3.021606] WRITE SUCCESS 1
[ 3.026245]
[ 3.026245] WRITE SUCCESS 1
[ 3.030914]
[ 3.030914] WRITE SUCCESS 1
[ 3.035705]
[ 3.035705] WRITE SUCCESS 1
[ 3.040466]
[ 3.040466] WRITE SUCCESS 1
[ 3.045257]
[ 3.045257] WRITE SUCCESS 1
[ 3.050079]
[ 3.050079] WRITE SUCCESS 1
[ 3.054840]
[ 3.054840] WRITE SUCCESS 1
[ 3.059631]
[ 3.059631] WRITE SUCCESS 1
[ 3.064392]
[ 3.064392] WRITE SUCCESS 1
[ 3.069183]
[ 3.069183] WRITE SUCCESS 1
[ 3.073974]
[ 3.073974] WRITE SUCCESS 1
[ 3.078735]
[ 3.078735] WRITE SUCCESS 1
[ 3.083526]
[ 3.083526] WRITE SUCCESS 1
[ 3.088287]
[ 3.088287] WRITE SUCCESS 1
[ 3.092926]
[ 3.092926] WRITE SUCCESS 1
[ 3.097625]
[ 3.097625] WRITE SUCCESS 1
[ 3.102264]
[ 3.102264] WRITE SUCCESS 1
[ 3.107055]
[ 3.107055] WRITE SUCCESS 1
[ 3.111816]
[ 3.111816] WRITE SUCCESS 1
[ 3.116607]
[ 3.116607] WRITE SUCCESS 1
[ 3.121398]
[ 3.121398] WRITE SUCCESS 1
[ 3.126159]
[ 3.126159] WRITE SUCCESS 1
[ 3.130950]
[ 3.130950] WRITE SUCCESS 1
[ 3.135711]
[ 3.135711] WRITE SUCCESS 1
[ 3.140472]
[ 3.140472] WRITE SUCCESS 1
[ 3.145263]
[ 3.145263] WRITE SUCCESS 1
[ 3.150024]
[ 3.150024] WRITE SUCCESS 1
[ 3.154663]
[ 3.154663] WRITE SUCCESS 1
[ 3.159332]
[ 3.159332] WRITE SUCCESS 1
[ 3.164093]
[ 3.164093] WRITE SUCCESS 1
[ 3.168884]
[ 3.168884] WRITE SUCCESS 1
[ 3.173645]
[ 3.173645] WRITE SUCCESS 1
[ 3.178436]
[ 3.178436] WRITE SUCCESS 1
[ 3.183227]
[ 3.183227] WRITE SUCCESS 1
[ 3.187988]
[ 3.187988] WRITE SUCCESS 1
[ 3.192779]
[ 3.192779] WRITE SUCCESS 1
[ 3.197540]
[ 3.197540] WRITE SUCCESS 1
[ 3.202331]
[ 3.202331] WRITE SUCCESS 1
[ 3.207122]
[ 3.207122] WRITE SUCCESS 1
[ 3.211883]
[ 3.211883] WRITE SUCCESS 1
[ 3.216522]
[ 3.216522] WRITE SUCCESS 1
[ 3.221160]
[ 3.221160] WRITE SUCCESS 1
[ 3.225738] usb 1-1: new high speed USB device using ehci-omap and address 2
[ 3.233215]
[ 3.233215] WRITE SUCCESS 1
[ 3.237915]
[ 3.237915] WRITE SUCCESS 1
[ 3.242553]
[ 3.242553] WRITE SUCCESS 1
[ 3.769653] input: ssd2531_input as /devices/virtual/input/input1
[ 3.776885] input: 7k_ffa_keypad as /devices/virtual/input/input2
[ 3.785552] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input3
[ 3.798980] using rtc device, twl_rtc, for alarms
[ 3.803833] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 3.810760] twl_rtc twl_rtc: Power up reset detected.
[ 3.816467] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[ 3.823516] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.831695] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 3.837615] hub 1-1:1.0: USB hub found
[ 3.841888] i2c /dev entries driver
[ 3.845703] hub 1-1:1.0: 4 ports detected
[ 3.851562] Linux media interface: v0.10
[ 3.856018] Linux video capture interface: v2.00
[ 3.862152] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[ 3.869232] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[ 3.876495] omap3isp omap3isp: Revision 15.0 found
[ 3.881591] omap-iommu omap-iommu.0: isp: version 1.1
[ 3.945037] mt9t111 2-003c: Unable to detectmt9t111sensor
[ 3.951995] isp_register_subdev_group: Unable to register subdev mt9t111
[ 3.959411] i2c i2c-3: Failed to register i2c client tvp5146m2 at 0x5c (-16)
[ 3.966857] isp_register_subdev_group: Unable to register subdev tvp5146m2
[ 3.974731] usbcore: registered new interface driver uvcvideo
[ 3.980804] USB Video Class driver (v1.0.0)
[ 3.985534] device-mapper: uevent: version 1.0.3
[ 3.991058] device-mapper: ioctl: 4.18.0-ioctl (2010-06-29) initialised: dm-devel@redhat.com
[ 4.000030] Bluetooth: HCI UART driver ver 2.2
[ 4.004730] Bluetooth: HCI H4 protocol initialized
[ 4.009765] Bluetooth: HCI BCSP protocol initialized
[ 4.014984] Bluetooth: HCILL protocol initialized
[ 4.019927] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 4.026184] cpuidle: using governor ladder
[ 4.030517] cpuidle: using governor menu
[ 4.038909] mmci-omap-hs.1 supply vmmc_aux not found, using dummy regulator
[ 4.049011] usbcore: registered new interface driver usbhid
[ 4.054901] usbhid: USB HID core driver
[ 4.059722] logger: created 64K log 'log_main'
[ 4.064666] logger: created 256K log 'log_events'
[ 4.069915] logger: created 64K log 'log_radio'
[ 4.074981] logger: created 64K log 'log_system'
[ 4.080993] usbcore: registered new interface driver snd-usb-audio
[ 4.088958] OMAP3 EVM SoC init
[ 4.164703] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 4.171539] asoc: wl1271bt <-> omap-mcbsp-dai.0 mapping ok
[ 4.179656] ALSA device list:
[ 4.182830] #0: omap3evm
[ 4.185668] oprofile: hardware counters not available
[ 4.190979] oprofile: using timer interrupt.
[ 4.195617] nf_conntrack version 0.5.0 (3802 buckets, 15208 max)
[ 4.202392] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.208221] TCP cubic registered
[ 4.211608] Initializing XFRM netlink socket
[ 4.216522] NET: Registered protocol family 10
[ 4.221984] IPv6 over IPv4 tunneling driver
[ 4.226989] usb 1-1.3: new full speed USB device using ehci-omap and address 3
[ 4.235107] NET: Registered protocol family 17
[ 4.239837] NET: Registered protocol family 15
[ 4.244689] Bluetooth: L2CAP ver 2.15
[ 4.248565] Bluetooth: L2CAP socket layer initialized
[ 4.254028] Bluetooth: RFCOMM TTY layer initialized
[ 4.259124] Bluetooth: RFCOMM socket layer initialized
[ 4.264556] Bluetooth: RFCOMM ver 1.11
[ 4.268493] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.274078] Bluetooth: BNEP filters: protocol multicast
[ 4.279663] Registering the dns_resolver key type
[ 4.284667] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 4.293395] ThumbEE CPU extension supported.
[ 4.304107] Power Management for TI OMAP3.
[ 4.314056] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 4.322357] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 4.330810] SmartReflex Class3 initialized
[ 4.339324] clock: disabling unused clocks to save power
[ 4.345855] platform iva.0: omap_voltage_scale: Already at the requestedrate 800000000
[ 4.354156] platform mpu.0: omap_voltage_scale: Already at the requestedrate 1000000000
[ 4.395111] usb 1-1.3: New USB device found, idVendor=147e, idProduct=2016
[ 4.402313] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.409942] usb 1-1.3: Product: Biometric Coprocessor
[ 4.415222] usb 1-1.3: Manufacturer: UPEK
[ 4.482299] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 4.490875] omap_vout omap_vout: Buffer Size = 3686400
[ 4.510650] usb 1-1.4: new full speed USB device using ehci-omap and address 4
[ 4.518310] omap_vout omap_vout: : registered and initialized video device 15
[ 4.525848] omap_vout omap_vout: Buffer Size = 3686400
[ 4.532318] omap_vout omap_vout: : registered and initialized video device 16
[ 4.540252] Waiting 1sec before mounting root device...
[ 4.565521] mmc0: new high speed SDHC card at address 0002
[ 4.571716] mmcblk0: mmc0:0002 00000 3.70 GiB
[ 4.578247] mmcblk0: p1 p2 p3
[ 4.685974] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52e
[ 4.693176] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.700836] usb 1-1.4: Product: USB Receiver
[ 4.705261] usb 1-1.4: Manufacturer: Logitech
[ 4.717163] input: Logitech USB Receiver as /devices/platform/ehci-omap.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input4
[ 4.728179] generic-usb 0003:046D:C52E.0001: input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-ehci-omap.0-1.4/input0
[ 4.745574] input: Logitech USB Receiver as /devices/platform/ehci-omap.0/usb1/1-1/1-1.4/1-1.4:1.1/input/input5
[ 4.756988] generic-usb 0003:046D:C52E.0002: input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-ehci-omap.0-1.4/input1
[ 5.011352] usb 1-1.2: new high speed USB device using ehci-omap and address 5
[ 5.143737] usb 1-1.2: New USB device found, idVendor=5149, idProduct=13d3
[ 5.150878] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.158508] usb 1-1.2: Product: USB 2.0 PC Cam
[ 5.163269] usb 1-1.2: Manufacturer: Image Processor
[ 5.169830] uvcvideo: Found UVC 1.00 device USB 2.0 PC Cam (5149:13d3)
[ 5.180786] input: USB 2.0 PC Cam as /devices/platform/ehci-omap.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input6
[ 5.555541] EXT3-fs: barriers not enabled
[ 5.560821] kjournald starting. Commit interval 5 seconds
[ 5.566589] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[ 5.785522] EXT3-fs (mmcblk0p2): using internal journal
[ 5.790985] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 5.798187] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 5.804534] Freeing init memory: 228K
[ 5.831024] init: /init.rc: 284: invalid command '//'
[ 5.836364] init: /init.rc: 287: invalid command '//'
[ 5.841644] init: /init.rc: 288: invalid command '//'
[ 5.847717] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 5.989837] init: cannot open '/initlogo.rle'
[ 6.062225] Compat-wireless backport release: compat-wireless-2011-12-05-1-g84dbe2c
[ 6.070251] Backport based on wl12xx.git v2.6.39-1328-g0890f48
[ 6.104003] cfg80211: disagrees about version of symbol wireless_send_event
[ 6.111297] cfg80211: Unknown symbol wireless_send_event (err -22)
[ 6.162048] mac80211: disagrees about version of symbol cfg80211_send_assoc_timeout
[ 6.170104] mac80211: Unknown symbol cfg80211_send_assoc_timeout (err -22)
[ 6.177642] mac80211: Unknown symbol cfg80211_sched_scan_results (err 0)
[ 6.186370] mac80211: disagrees about version of symbol cfg80211_scan_done
[ 6.194061] mac80211: Unknown symbol cfg80211_scan_done (err -22)
[ 6.200866] mac80211: Unknown symbol cfg80211_sched_scan_stopped (err 0)
[ 6.208679] mac80211: disagrees about version of symbol cfg80211_send_auth_timeout
[ 6.216583] mac80211: Unknown symbol cfg80211_send_auth_timeout (err -22)
[ 6.224029] mac80211: disagrees about version of symbol cfg80211_remain_on_channel_expired
[ 6.232635] mac80211: Unknown symbol cfg80211_remain_on_channel_expired (err -22)
[ 6.241394] mac80211: disagrees about version of symbol ieee80211_amsdu_to_8023s
[ 6.249114] mac80211: Unknown symbol ieee80211_amsdu_to_8023s (err -22)
[ 6.256225] mac80211: disagrees about version of symbol cfg80211_send_deauth
[ 6.263580] mac80211: Unknown symbol cfg80211_send_deauth (err -22)
[ 6.272003] mac80211: disagrees about version of symbol __cfg80211_send_deauth
[ 6.279541] mac80211: Unknown symbol __cfg80211_send_deauth (err -22)
[ 6.287322] mac80211: disagrees about version of symbol cfg80211_new_sta
[ 6.294311] mac80211: Unknown symbol cfg80211_new_sta (err -22)
[ 6.300994] mac80211: Unknown symbol cfg80211_send_intermediate_result (err 0)
[ 6.308807] mac80211: Unknown symbol cfg80211_send_unprot_deauth (err 0)
[ 6.316894] mac80211: disagrees about version of symbol cfg80211_ready_on_channel
[ 6.324707] mac80211: Unknown symbol cfg80211_ready_on_channel (err -22)
[ 6.332183] mac80211: disagrees about version of symbol cfg80211_classify8021d
[ 6.339721] mac80211: Unknown symbol cfg80211_classify8021d (err -22)
[ 6.346740] mac80211: Unknown symbol cfg80211_send_unprot_disassoc (err 0)
[ 6.354217] mac80211: disagrees about version of symbol wiphy_register
[ 6.361022] mac80211: Unknown symbol wiphy_register (err -22)
[ 6.367340] mac80211: disagrees about version of symbol wiphy_new
[ 6.373718] mac80211: Unknown symbol wiphy_new (err -22)
[ 6.381988] mac80211: disagrees about version of symbol cfg80211_ibss_joined
[ 6.389343] mac80211: Unknown symbol cfg80211_ibss_joined (err -22)
[ 6.396087] mac80211: disagrees about version of symbol __cfg80211_send_disassoc
[ 6.403778] mac80211: Unknown symbol __cfg80211_send_disassoc (err -22)
[ 6.411651] mac80211: disagrees about version of symbol cfg80211_michael_mic_failure
[ 6.419738] mac80211: Unknown symbol cfg80211_michael_mic_failure (err -22)
[ 6.427276] mac80211: Unknown symbol cfg80211_cqm_pktloss_notify (err 0)
[ 6.434448] mac80211: disagrees about version of symbol cfg80211_send_rx_auth
[ 6.441894] mac80211: Unknown symbol cfg80211_send_rx_auth (err -22)
[ 6.449890] mac80211: disagrees about version of symbol wiphy_unregister
[ 6.456878] mac80211: Unknown symbol wiphy_unregister (err -22)
[ 6.463531] mac80211: disagrees about version of symbol cfg80211_send_disassoc
[ 6.471069] mac80211: Unknown symbol cfg80211_send_disassoc (err -22)
[ 6.478851] mac80211: Unknown symbol cfg80211_notify_new_peer_candidate (err 0)
[ 6.486816] mac80211: disagrees about version of symbol __cfg80211_auth_canceled
[ 6.494537] mac80211: Unknown symbol __cfg80211_auth_canceled (err -22)
[ 6.501678] mac80211: disagrees about version of symbol cfg80211_get_bss
[ 6.508666] mac80211: Unknown symbol cfg80211_get_bss (err -22)
[ 6.515441] mac80211: disagrees about version of symbol __ieee80211_get_channel
[ 6.523040] mac80211: Unknown symbol __ieee80211_get_channel (err -22)
[ 6.531555] mac80211: disagrees about version of symbol cfg80211_mgmt_tx_status
[ 6.539184] mac80211: Unknown symbol cfg80211_mgmt_tx_status (err -22)
[ 6.547790] mac80211: Unknown symbol cfg80211_del_sta (err 0)
[ 6.553955] mac80211: disagrees about version of symbol ieee80211_data_to_8023
[ 6.561492] mac80211: Unknown symbol ieee80211_data_to_8023 (err -22)
[ 6.568908] mac80211: disagrees about version of symbol cfg80211_send_rx_assoc
[ 6.576446] mac80211: Unknown symbol cfg80211_send_rx_assoc (err -22)
[ 6.583740] mac80211: disagrees about version of symbol ieee80211_channel_to_frequency
[ 6.592010] mac80211: Unknown symbol ieee80211_channel_to_frequency (err -22)
[ 6.599609] mac80211: disagrees about version of symbol cfg80211_rx_mgmt
[ 6.606597] mac80211: Unknown symbol cfg80211_rx_mgmt (err -22)
[ 6.614685] mac80211: disagrees about version of symbol cfg80211_inform_bss_frame
[ 6.622497] mac80211: Unknown symbol cfg80211_inform_bss_frame (err -22)
[ 6.631439] mac80211: disagrees about version of symbol cfg80211_unlink_bss
[ 6.638702] mac80211: Unknown symbol cfg80211_unlink_bss (err -22)
[ 6.645324] mac80211: disagrees about version of symbol wiphy_free
[ 6.651763] mac80211: Unknown symbol wiphy_free (err -22)
[ 6.658294] mac80211: disagrees about version of symbol cfg80211_cqm_rssi_notify
[ 6.666564] mac80211: Unknown symbol cfg80211_cqm_rssi_notify (err -22)
[ 6.689575] wl12xx: disagrees about version of symbol ieee80211_connection_loss
[ 6.697265] wl12xx: Unknown symbol ieee80211_connection_loss (err -22)
[ 6.704559] wl12xx: disagrees about version of symbol skb_put
[ 6.710540] wl12xx: Unknown symbol skb_put (err -22)
[ 6.715881] wl12xx: disagrees about version of symbol consume_skb
[ 6.722259] wl12xx: Unknown symbol consume_skb (err -22)
[ 6.728302] wl12xx: Unknown symbol cfg80211_testmode_reply (err 0)
[ 6.734954] wl12xx: disagrees about version of symbol skb_dequeue
[ 6.741302] wl12xx: Unknown symbol skb_dequeue (err -22)
[ 6.747070] wl12xx: disagrees about version of symbol ieee80211_free_hw
[ 6.754455] wl12xx: Unknown symbol ieee80211_free_hw (err -22)
[ 6.760742] wl12xx: disagrees about version of symbol ieee80211_probereq_get
[ 6.768096] wl12xx: Unknown symbol ieee80211_probereq_get (err -22)
[ 6.775146] wl12xx: Unknown symbol ieee80211_ap_probereq_get (err 0)
[ 6.781982] wl12xx: disagrees about version of symbol ieee80211_alloc_hw
[ 6.789001] wl12xx: Unknown symbol ieee80211_alloc_hw (err -22)
[ 6.795440] wl12xx: disagrees about version of symbol ieee80211_nullfunc_get
[ 6.802795] wl12xx: Unknown symbol ieee80211_nullfunc_get (err -22)
[ 6.809509] wl12xx: disagrees about version of symbol ieee80211_pspoll_get
[ 6.816680] wl12xx: Unknown symbol ieee80211_pspoll_get (err -22)
[ 6.823242] wl12xx: disagrees about version of symbol ieee80211_register_hw
[ 6.830474] wl12xx: Unknown symbol ieee80211_register_hw (err -22)
[ 6.837097] wl12xx: disagrees about version of symbol ieee80211_restart_hw
[ 6.844268] wl12xx: Unknown symbol ieee80211_restart_hw (err -22)
[ 6.851348] wl12xx: disagrees about version of symbol ieee80211_get_hdrlen_from_skb
[ 6.859344] wl12xx: Unknown symbol ieee80211_get_hdrlen_from_skb (err -22)
[ 6.866882] wl12xx: Unknown symbol ieee80211_stop_rx_ba_session (err 0)
[ 6.873992] wl12xx: disagrees about version of symbol ieee80211_find_sta
[ 6.880981] wl12xx: Unknown symbol ieee80211_find_sta (err -22)
[ 6.887329] wl12xx: disagrees about version of symbol kfree_skb
[ 6.893493] wl12xx: Unknown symbol kfree_skb (err -22)
[ 6.899261] wl12xx: disagrees about version of symbol __alloc_skb
[ 6.905609] wl12xx: Unknown symbol __alloc_skb (err -22)
[ 6.911560] wl12xx: disagrees about version of symbol skb_queue_tail
[ 6.918182] wl12xx: Unknown symbol skb_queue_tail (err -22)
[ 6.924468] wl12xx: disagrees about version of symbol ieee80211_queue_delayed_work
[ 6.932373] wl12xx: Unknown symbol ieee80211_queue_delayed_work (err -22)
[ 6.939605] wl12xx: disagrees about version of symbol skb_pull
[ 6.946197] wl12xx: Unknown symbol skb_pull (err -22)
[ 6.951873] wl12xx: disagrees about version of symbol skb_push
[ 6.957977] wl12xx: Unknown symbol skb_push (err -22)
[ 6.963409] wl12xx: disagrees about version of symbol ieee80211_rx
[ 6.969848] wl12xx: Unknown symbol ieee80211_rx (err -22)
[ 6.975585] wl12xx: disagrees about version of symbol nla_put
[ 6.981597] wl12xx: Unknown symbol nla_put (err -22)
[ 6.987030] wl12xx: disagrees about version of symbol ieee80211_wake_queues
[ 6.994293] wl12xx: Unknown symbol ieee80211_wake_queues (err -22)
[ 7.001251] wl12xx: disagrees about version of symbol dev_alloc_skb
[ 7.007781] wl12xx: Unknown symbol dev_alloc_skb (err -22)
[ 7.013946] wl12xx: disagrees about version of symbol ieee80211_tx_status
[ 7.021026] wl12xx: Unknown symbol ieee80211_tx_status (err -22)
[ 7.027465] wl12xx: disagrees about version of symbol ieee80211_stop_queues
[ 7.035217] wl12xx: Unknown symbol ieee80211_stop_queues (err -22)
[ 7.041809] wl12xx: disagrees about version of symbol skb_trim
[ 7.047882] wl12xx: Unknown symbol skb_trim (err -22)
[ 7.053955] wl12xx: disagrees about version of symbol ieee80211_scan_completed
[ 7.061492] wl12xx: Unknown symbol ieee80211_scan_completed (err -22)
[ 7.068481] wl12xx: disagrees about version of symbol ieee80211_channel_to_frequency
[ 7.076568] wl12xx: Unknown symbol ieee80211_channel_to_frequency (err -22)
[ 7.083984] wl12xx: disagrees about version of symbol ieee80211_unregister_hw
[ 7.091430] wl12xx: Unknown symbol ieee80211_unregister_hw (err -22)
[ 7.098266] wl12xx: disagrees about version of symbol ieee80211_enable_dyn_ps
[ 7.105712] wl12xx: Unknown symbol ieee80211_enable_dyn_ps (err -22)
[ 7.112884] wl12xx: disagrees about version of symbol ieee80211_beacon_get_tim
[ 7.120422] wl12xx: Unknown symbol ieee80211_beacon_get_tim (err -22)
[ 7.127532] wl12xx: disagrees about version of symbol ieee80211_cqm_rssi_notify
[ 7.135711] wl12xx: Unknown symbol ieee80211_cqm_rssi_notify (err -22)
[ 7.142822] wl12xx: Unknown symbol cfg80211_testmode_alloc_reply_skb (err 0)
[ 7.150756] wl12xx: disagrees about version of symbol ieee80211_queue_work
[ 7.157928] wl12xx: Unknown symbol ieee80211_queue_work (err -22)
[ 7.164459] wl12xx: disagrees about version of symbol ieee80211_disable_dyn_ps
[ 7.171997] wl12xx: Unknown symbol ieee80211_disable_dyn_ps (err -22)
[ 7.179016] wl12xx: Unknown symbol ieee80211_sta_ps_transition (err 0)
[ 7.186645] wl12xx: disagrees about version of symbol skb_queue_head
[ 7.193267] wl12xx: Unknown symbol skb_queue_head (err -22)
[ 7.224975] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 7.378540] enabling adb
[ 7.383026] adb_open
root@android:/ # [ 8.865234] init: untracked pid 1171 exited
[ 17.961517] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 23.912719] request_suspend_state: wakeup (3->0) at 24120819096 (2000-01-01 00:00:19.917968751 UTC)
root@android:/ #
root@android:/ # lsmod
omaplfb 10602 0 - Live 0xbf108000
pvrsrvkm 154341 43 omaplfb, Live 0xbf0d7000
compat 7223 0 - Live 0xbf000000
root@android:/ #
Waiting for reply
Thanks in advance
bhagavath
