Inlining a C-callable ASM routine in a loop
HI,
I have a hand-tuned ASM routine I wrote that is highly efficient.
_my_speedy_ASM_routine(float*, float*, int, int)
However, it gets called within a loop that my goal is to have it be SW pipelined:
for (i=0; i<numChans; ++i)
<i1>
<i2>
_my_speedy_ASM_routine(pIn, pOut,  size, length)
Can I inline this ASM routine in the loop to get the advantages of SW pipelining?
  • Hi Dave,
    Have you checked the assembly file after the file is compiled (compiling with -k option)?
    No.  Only C code can be inlined.  Perhaps you should attempt creating a C version of your algorithm that uses intrinsics.  It might not be quite as fast as your hand-written version, though perhaps the end result of having it inlined will boost your overall performance.
