ecu doesn't remove echo
sevel month ago, i use ecu to remove echo, it work well. but now, when i run it again, it can't remove echo, according to dsp load, it seems that ecu is woking, but echo not removed. does anyone encounter same problem ? is there any constrain on ecu ?
  • Hi Jack,
    Please provide as much of the following information to help me understand your problem:
    Basic Information:
    • What target platform are you using?
    • What is your application?
    • What ECU version are you using?
    • Has anything else changed in your code?
    Specific Information:
    • What do you mean by "it can't remove echo"?  Is the signal at send-out the same as the signal applied to send-in?  Is some echo leaking through?
    • Are you using the same signals as before?
    • What are the signals?  Voice?  Tones?  Noise?
    • Did you implement the ecuGetPerformance() API?  If so, please provide the output from this so I can determine what state the ECU is in.
    • Can you disable the ECU and ensure that the RX and TX path signals are intact?
    This should get us started.
    Charlie
