Hi ,
I'm having a custom dm3730 board which is running Android ICS stack,now I cannot turn-on the wifi and bluetooth.
Here is the minicom Console messeges :
0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP3 EVM
[ 0.000000] Reserving 8388608 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 62976
[ 0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootdelay=1 init=/init ip=off omaM
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 248MB = 248MB total
[ 0.000000] Memory: 243608k/243608k available, 18536k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0041000 ( 228 kB)
[ 0.000000] .text : 0xc0041000 - 0xc06c2000 (6660 kB)
[ 0.000000] .data : 0xc06c2000 - 0xc0714240 ( 329 kB)
[ 0.000000] NR_IRQS:409
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz
[ 0.000000] Reprogramming SDRC clock to 400000000 Hz
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] GPMC revision 5.0
[ 0.000000] Trying to install interrupt handler for IRQ402
[ 0.000000] Trying to install interrupt handler for IRQ403
[ 0.000000] Trying to install interrupt handler for IRQ404
[ 0.000000] Trying to install interrupt handler for IRQ405
[ 0.000000] Trying to install interrupt handler for IRQ406
[ 0.000000] Trying to install interrupt handler for IRQ407
[ 0.000000] Trying to install interrupt handler for IRQ408
[ 0.000000] Trying to install type control for IRQ409
[ 0.000000] Trying to set irq flags for IRQ409
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 597.64 BogoMIPS (lpj=2334720)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] regulator: core version 0.5
[ 0.000000] regulator: dummy:
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.000000] omap3evm: bt init
[ 0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.000000] OMAP DMA hardware revision 5.0
[ 0.030487] bio: create slab <bio-0> at 0
[ 0.031799] regulator: vwl1271: 1800 mV
[ 0.033447] SCSI subsystem initialized
[ 0.036193] usbcore: registered new interface driver usbfs
[ 0.036590] usbcore: registered new interface driver hub
[ 0.036834] usbcore: registered new device driver usb
[ 0.038146] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[ 0.051971] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.052001] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.052581] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.058502] regulator: VIO: 1800 mV normal standby
[ 0.059234] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[ 0.059967] regulator: VDAC: 1800 mV normal standby
[ 0.060668] regulator: VAUX2_4030: 2800 mV normal standby
[ 0.061431] regulator: VPLL2: 1800 mV normal standby
[ 0.062194] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
[ 0.062927] regulator: VAUX3: 2800 mV normal standby
[ 0.076507] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.092132] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 0.094024] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.094909] Bluetooth: Core ver 2.15
[ 0.095123] NET: Registered protocol family 31
[ 0.095123] Bluetooth: HCI device and connection manager initialized
[ 0.095153] Bluetooth: HCI socket layer initialized
[ 0.095642] Switching to clocksource 32k_counter
[ 0.225036] WL1271: BT_EN GPIO initialized
[ 0.225280] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
[ 0.225433] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[ 0.225769] musb-hdrc musb-hdrc.0: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 0.226379] NET: Registered protocol family 2
[ 0.226562] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.227020] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.227233] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.227386] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.227386] TCP reno registered
[ 0.227416] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.227447] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.227661] NET: Registered protocol family 1
[ 0.227996] RPC: Registered udp transport module.
[ 0.228027] RPC: Registered tcp transport module.
[ 0.228027] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.228240] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.235778] omap3evm camera init done successfully...
[ 0.236053] omap-iommu omap-iommu.0: isp registered
[ 0.236358] AM37x/DM37x Linux PSP version 04.02.00.07 (OMAP3EVM)
[ 0.402313] ashmem: initialized
[ 0.402801] VFS: Disk quotas dquot_6.5.2
[ 0.402862] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.404388] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.405090] msgmni has been set to 475
[ 0.406524] io scheduler noop registered
[ 0.406524] io scheduler deadline registered
[ 0.406677] io scheduler cfq registered (default)
[ 0.463195] OMAP DSS rev 2.0
[ 0.463287] OMAP DISPC rev 3.0
[ 0.463317] OMAP VENC rev 2
[ 0.463623] OMAP DSI rev 1.0
[ 0.792419] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.794464] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.460418] console [ttyO0] enabled
[ 1.464538] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.472351] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.480163] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
[ 1.499359] brd: module loaded
[ 1.508270] loop: module loaded
[ 1.512542] (stk) :sysfs entries created
[ 1.516693] (stk) : debugfs entries created
[ 1.523681] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.530670] omap2-nand driver initializing
[ 1.535369] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xb3 (Micron )
[ 1.542358] Creating 5 MTD partitions on "omap2-nand.0":
[ 1.547943] 0x000000000000-0x000000080000 : "X-Loader-NAND"
[ 1.555877] 0x000000080000-0x0000001c0000 : "U-Boot-NAND"
[ 1.563690] 0x0000001c0000-0x000000280000 : "Boot Env-NAND"
[ 1.571380] 0x000000280000-0x000000780000 : "Kernel-NAND"
[ 1.580780] 0x000000780000-0x000040000000 : "File System - NAND"
[ 2.011993] OneNAND driver initializing
[ 2.016082] omap2-onenand omap2-onenand: Cannot request GPMC CS
[ 2.022369] omap2-onenand: probe of omap2-onenand failed with error -16
[ 2.031066] smsc911x: Driver version 2008-10-21.
[ 2.036468] usbcore: registered new interface driver asix
[ 2.042358] usbcore: registered new interface driver cdc_ether
[ 2.048675] usbcore: registered new interface driver net1080
[ 2.054840] usbcore: registered new interface driver cdc_subset
[ 2.061248] usbcore: registered new interface driver zaurus
[ 2.067321] usbcore: registered new interface driver zd1201
[ 2.073181] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.080139] ehci-omap.0 supply hsusb0 not found, using dummy regulator
[ 3.087951] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.093963] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 3.101867] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.119293] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.125396] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.132568] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.140136] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.145751] usb usb1: Manufacturer: Linux 2.6.37-g5c414d7-dirty ehci_hcd
[ 3.152801] usb usb1: SerialNumber: ehci-omap.0
[ 3.158599] hub 1-0:1.0: USB hub found
[ 3.162536] hub 1-0:1.0: 3 ports detected
[ 3.197601] Initializing USB Mass Storage driver...
[ 3.203002] usbcore: registered new interface driver usb-storage
[ 3.209350] USB Mass Storage support registered.
[ 3.214447] usbcore: registered new interface driver usbtest
[ 3.220397] android init
[ 3.223144] android_probe pdata: c06d2eac
[ 3.227539] android_bind
[ 3.230987] android_usb gadget: android_usb ready
[ 3.235931] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 3.241577] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 3.249450] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.256591] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.264190] usb usb2: Product: MUSB HDRC host driver
[ 3.269409] usb usb2: Manufacturer: Linux 2.6.37-g5c414d7-dirty musb-hcd
[ 3.276458] usb usb2: SerialNumber: musb-hdrc.0
[ 3.282196] hub 2-0:1.0: USB hub found
[ 3.286193] hub 2-0:1.0: 1 port detected
[ 3.291198] f_adb init
[ 3.293670] android_register_function adb
[ 3.297851] f_mass_storage init
[ 3.301269] fsg_probe pdev: c06d2aa8, pdata: c06d2f3c
[ 3.306793] android_register_function usb_mass_storage
[ 3.312194] adb_bind_config
[ 3.316162] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.323425] android_usb gadget: Number of LUNs=1
[ 3.328277] lun0: LUN: removable file: (no medium)
[ 3.333709] f_mtp init
[ 3.336181] android_register_function mtp
[ 3.341003] mice: PS/2 mouse device common for all mice
[ 3.347503] input: TWL4030 Keypad as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/twl4030_keypad/input/input0
[ 3.361083]
[ 3.361083] WRITE FAILED 1
[ 3.365783]
[ 3.365783] WRITE SUCCESS 1
[ 3.370391]
[ 3.370391] WRITE SUCCESS 1
[ 3.374969]
[ 3.374969] WRITE SUCCESS 1
[ 3.379638]
[ 3.502136] usb 1-1: new high speed USB device using ehci-omap and address 2
[ 3.509582]
[ 3.598754]
[ 3.598754] WRITE SUCCESS 1
[ 4.123931] input: ssd2531_input as /devices/virtual/input/input1
[ 4.131134] input: 7k_ffa_keypad as /devices/virtual/input/input2
[ 4.139129] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input3
[ 4.152618] using rtc device, twl_rtc, for alarms
[ 4.157440] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 4.164398] twl_rtc twl_rtc: Power up reset detected.
[ 4.170227] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[ 4.177307] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.185302] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 4.191192] i2c /dev entries driver
[ 4.195129] hub 1-1:1.0: USB hub found
[ 4.199371] hub 1-1:1.0: 4 ports detected
[ 4.205047] Linux media interface: v0.10
[ 4.209716] Linux video capture interface: v2.00
[ 4.215606] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[ 4.222717] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[ 4.229949] omap3isp omap3isp: Revision 15.0 found
[ 4.235015] omap-iommu omap-iommu.0: isp: version 1.1
[ 4.299285] mt9t111 2-003c: Unable to detectmt9t111sensor
[ 4.305877] isp_register_subdev_group: Unable to register subdev mt9t111
[ 4.313354] i2c i2c-3: Failed to register i2c client tvp5146m2 at 0x5c (-16)
[ 4.320770] isp_register_subdev_group: Unable to register subdev tvp5146m2
[ 4.328643] usbcore: registered new interface driver uvcvideo
[ 4.334716] USB Video Class driver (v1.0.0)
[ 4.339904] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 4.346771] device-mapper: uevent: version 1.0.3
[ 4.352203] device-mapper: ioctl: 4.18.0-ioctl (2010-06-29) initialised: dm-devel@redhat.com
[ 4.361175] Bluetooth: HCI UART driver ver 2.2
[ 4.365844] Bluetooth: HCI H4 protocol initialized
[ 4.370910] Bluetooth: HCILL protocol initialized
[ 4.375915] cpuidle: using governor ladder
[ 4.380249] cpuidle: using governor menu
[ 4.389465] mmci-omap-hs.1 supply vmmc_aux not found, using dummy regulator
[ 4.398895] usbcore: registered new interface driver usbhid
[ 4.404785] usbhid: USB HID core driver
[ 4.409973] logger: created 64K log 'log_main'
[ 4.414916] logger: created 256K log 'log_events'
[ 4.420166] logger: created 64K log 'log_radio'
[ 4.425354] logger: created 64K log 'log_system'
[ 4.431579] usbcore: registered new interface driver snd-usb-audio
[ 4.439575] OMAP3 EVM SoC init
[ 4.513610] usb 1-1.4: new full speed USB device using ehci-omap and address 3
[ 4.528137] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 4.535034] asoc: wl1271bt <-> omap-mcbsp-dai.0 mapping ok
[ 4.543304] ALSA device list:
[ 4.546417] #0: omap3evm
[ 4.549285] oprofile: hardware counters not available
[ 4.554595] oprofile: using timer interrupt.
[ 4.559295] nf_conntrack version 0.5.0 (3806 buckets, 15224 max)
[ 4.566101] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.571777] TCP cubic registered
[ 4.575225] Initializing XFRM netlink socket
[ 4.580078] NET: Registered protocol family 10
[ 4.585510] IPv6 over IPv4 tunneling driver
[ 4.590850] NET: Registered protocol family 17
[ 4.595550] NET: Registered protocol family 15
[ 4.600372] Bluetooth: L2CAP ver 2.15
[ 4.604309] Bluetooth: L2CAP socket layer initialized
[ 4.609771] Bluetooth: RFCOMM TTY layer initialized
[ 4.614959] Bluetooth: RFCOMM socket layer initialized
[ 4.620391] Bluetooth: RFCOMM ver 1.11
[ 4.624328] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.629913] Bluetooth: BNEP filters: protocol multicast
[ 4.635406] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.642120] Registering the dns_resolver key type
[ 4.647155] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 4.658721] ThumbEE CPU extension supported.
[ 4.666625] Power Management for TI OMAP3.
[ 4.677337] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 4.685638] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 4.694183] SmartReflex Class3 initialized
[ 4.702697] clock: disabling unused clocks to save power
[ 4.709320] platform iva.0: omap_voltage_scale: Already at the requestedrate 800000000
[ 4.717590] platform mpu.0: omap_voltage_scale: Already at the requestedrate 1000000000
[ 4.726043] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52e
[ 4.733215] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.740844] usb 1-1.4: Product: USB Receiver
[ 4.745300] usb 1-1.4: Manufacturer: Logitech
[ 4.756683] input: Logitech USB Receiver as /devices/platform/ehci-omap.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input4
[ 4.767761] generic-usb 0003:046D:C52E.0001: input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-ehci-omap.0-1.4/input0
[ 4.786529] input: Logitech USB Receiver as /devices/platform/ehci-omap.0/usb1/1-1/1-1.4/1-1.4:1.1/input/input5
[ 4.797851] generic-usb 0003:046D:C52E.0002: input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-ehci-omap.0-1.4/input1
[ 4.838439] mmc0: new high speed SDHC card at address e624
[ 4.844604] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 4.859375] mmcblk0: p1 p2 p3
[ 4.936462] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 4.945037] omap_vout omap_vout: Buffer Size = 3686400
[ 4.965301] omap_vout omap_vout: : registered and initialized video device 15
[ 4.972808] omap_vout omap_vout: Buffer Size = 3686400
[ 4.979217] omap_vout omap_vout: : registered and initialized video device 16
[ 4.987213] Waiting 1sec before mounting root device...
[ 4.997070] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 5.033264] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.045562] mmc1: new SDIO card at address 0001
[ 5.997924] EXT3-fs: barriers not enabled
[ 6.523468] kjournald starting. Commit interval 5 seconds
[ 6.529846] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[ 6.542083] EXT3-fs (mmcblk0p2): using internal journal
[ 6.547546] EXT3-fs (mmcblk0p2): recovery complete
[ 6.554870] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 6.562103] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 6.568420] Freeing init memory: 228K
[ 6.592590] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 6.719848] init: cannot open '/initlogo.rle'
[ 6.759796] Compat-wireless backport release: compat-wireless-2011-12-05-1-g84dbe2c
[ 6.767822] Backport based on wl12xx.git v2.6.39-1328-g0890f48
[ 6.840454] cfg80211: Calling CRDA to update world regulatory domain
[ 7.023193] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 7.142913] enabling adb
[ 7.146118] adb_open
[ 7.230651] cfg80211: World regulatory domain updated:
[ 7.236022] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 7.244781] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 7.253051] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 7.261322] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 7.269561] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 7.278381] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
root@android:/ # [ 8.564178] init: untracked pid 1156 exited
[ 15.569763] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 20.075866] request_suspend_state: wakeup (3->0) at 20284881593 (2000-01-01 00:00:15.632263184 UTC)
[ 20.862335] wl1271: loaded
[ 21.732421] wl1271: firmware booted (Rev 6.3.6.0.79_2)
[ 21.737792] wl1271: Driver version: R4_SP2_03_00
[ 21.756378] ADDRCONF(NETDEV_UP): wlan0: link is not ready
after lsmod
$lsmod
wl12xx_sdio 3426 0 - Live 0xbf118000
omaplfb 10622 0 - Live 0xbf110000
pvrsrvkm 154437 35 omaplfb, Live 0xbf0df000
wl12xx 151894 1 wl12xx_sdio, Live 0xbf0ac000
mac80211 330314 1 wl12xx, Live 0xbf03d000
cfg80211 146983 2 wl12xx,mac80211, Live 0xbf008000
compat 7243 2 wl12xx,mac80211, Live 0xbf000000
Error messge :
oot@android:/ # [ 448.026153] wl1271: loaded
[ 452.540466] wl1271: ERROR timeout waiting for the hardware to complete initialization
[ 457.210388] wl1271: ERROR timeout waiting for the hardware to complete initialization
[ 461.542602] wl1271: ERROR timeout waiting for the hardware to complete initialization
[ 461.551116] wl1271: ERROR firmware boot failed despite 3 retries
[ 482.606933] wl1271: ERROR timeout waiting for the hardware to complete initialization
[ 487.200378] wl1271: ERROR timeout waiting for the hardware to complete initialization
please help me.
