Other Parts Discussed in Thread: ADS7846
Dear all,
I have upgraded the processor from OMAP3530DCUS to OMAP3530ECUS for certain reason. After change of processor i am facing the "kernel panic error" while loading the kernel. I have used same binaries of old processor.
The error log is as follows;
Uncompressing Linux....................................................................................................................................................................................................................... done, booting the kernel.
[ 0.000000] Linux version 2.6.29-omap1 (root@rahman-OptiPlex-330) (gcc version 4.2.1 (CodeSourcery Sourcery G++ Lite 2007q3-51)) #110 PREEMPT Wed Apr 11 10:49:25 IST 2012
[ 0.000000] CPU: ARMv7 Processor [411fc087] revision 7 (ARMv7), cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430 Unknown revision
[ 0.000000]
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
[ 0.000000] Reserving 14680064 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP34xx GPIO hardware version 2.5
[ 0.000000] PID hash table entries: 512 (order: 9, 2048 bytes)
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 128MB = 128MB total
[ 0.000000] Memory: 108272KB available (6296K code, 637K data, 208K init)
[ 0.000000] Calibrating delay loop... 485.26 BogoMIPS (lpj=1896448)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] Calling driver_init
[ 0.000000] net_namespace: 1036 bytes
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] MUX: setup J25_34XX_GPIO170 (0xd80021c6): 0x001c -> 0x0104
[ 0.000000] MUX: setup AG4_3530_GPIO134 (0xd8002160): 0x011c -> 0x0104
[ 0.000000] MUX: setup K26_34XX_GPIO161 (0xd8002196): 0x0004 -> 0x0104
[ 0.000000] GPIO-156 autorequested
[ 0.000000] GPIO-159 autorequested
[ 0.000000] GPIO-140 autorequested
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] fpga_gpmc_get_base: gpmc_cs_address 0xc9000000
[ 19.913482] OMAP DMA hardware revision 4.0
[ 19.960845] bio: create slab <bio-0> at 0
[ 20.022338] OMAP DSS rev 2.0
[ 20.022460] OMAP DISPC rev 3.0
[ 20.022491] OMAP VENC rev 2
[ 20.022644] OMAP DSI rev 1.0
[ 20.037536] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 20.041625] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 20.041656] twl4030: power (irq 373) chaining IRQs 376..383
[ 20.042236] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 20.042846] MUX: setup AH8_34XX_GPIO29 (0xd80025fa): 0x010b -> 0x0104
[ 20.045623] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 20.046600] regulator: VDAC: 1800 mV normal standby
[ 20.047546] regulator: VUSB1V5: 1500 <--> 0 mV normal standby
[ 20.048492] regulator: VUSB1V8: 1800 <--> 0 mV normal standby
[ 20.049468] regulator: VUSB3V1: 3100 <--> 0 mV normal standby
[ 20.050384] regulator: VPLL2: 1800 mV normal standby
[ 20.051361] regulator: VMMC2: 3150 mV normal standby
[ 20.052368] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 20.060455] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[ 20.075653] i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
[ 20.078247] SCSI subsystem initialized
[ 20.084564] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 20.086151] usbcore: registered new interface driver usbfs
[ 20.086791] usbcore: registered new interface driver hub
[ 20.087249] usbcore: registered new device driver usb
[ 20.090759] Bluetooth: Core ver 2.14
[ 20.091339] NET: Registered protocol family 31
[ 20.091369] Bluetooth: HCI device and connection manager initialized
[ 20.091369] Bluetooth: HCI socket layer initialized
[ 20.091400] NET: Registered protocol family 8
[ 20.091400] NET: Registered protocol family 20
[ 20.092498] cfg80211: Using static regulatory domain info
[ 20.092529] cfg80211: Regulatory domain: US
[ 20.092529] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 20.092559] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 20.092590] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 20.092590] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 20.092620] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 20.092651] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 20.092651] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 20.092681] cfg80211: Calling CRDA for country: US
[ 20.096557] musb_hdrc: version 6.0, musb-dma, host, debug=0
[ 20.097290] musb_hdrc: USB Host mode controller at d80ab000 using DMA, IRQ 92
[ 20.097320] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 20.097869] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 20.098937] usb usb1: configuration #1 chosen from 1 choice
[ 20.099395] hub 1-0:1.0: USB hub found
[ 20.099487] hub 1-0:1.0: 1 port detected
[ 20.102355] NET: Registered protocol family 2
[ 20.102630] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 20.103332] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 20.103485] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 20.103576] TCP: Hash tables configured (established 4096 bind 4096)
[ 20.103607] TCP reno registered
[ 20.103881] NET: Registered protocol family 1
[ 20.109313] VFS: Disk quotas dquot_6.5.2
[ 20.109436] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 20.110076] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 20.110900] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 20.111877] msgmni has been set to 211
[ 20.117187] alg: No test for stdrng (krng)
[ 20.117309] io scheduler noop registered
[ 20.117340] io scheduler anticipatory registered
[ 20.117340] io scheduler deadline registered
[ 20.117584] io scheduler cfq registered (default)
[ 20.144744] NOD = gpio_test & Major No = 252
[ 20.146575] NOD = led-dip-test & Major No = 251
[ 20.147247] NOD = timer_pwm_test & Major No = 250
[ 20.147918] NOD = mcbsp_test & Major No = 249
[ 20.148559] NOD = sdma_test & Major No = 248
[ 20.149841] NOD = leddip_test & Major No = 246
[ 20.149871] fpga_gpmc_get_base: gpmc_cs_address 0xc9000000
[ 20.150512] NOD = 7seg_led_test & Major No = 245
[ 20.542327] NOD = ddr_test & Major No = 244
[ 25.397003] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 25.419342] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 25.439880] serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 25.460357] serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 25.460388] console [ttyS2] enabled
[ 26.105194] brd: module loaded
[ 26.115264] loop: module loaded
[ 26.119995] smsc911x: Driver version 2008-10-21.
[ 26.124847] smsc911x: Driver version 2008-10-21.
[ 26.131500] smsc911x-mdio: probed
[ 26.134887] eth0: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=ffffffff:01, irq=-1)
[ 26.143585] net eth0: MAC Address: 3e:17:be:7b:f0:9a
[ 26.148773] smsc911x: Driver version Success
[ 26.154052] enc28j60 spi4.0: enc28j60 Ethernet driver 1.01 loaded
[ 26.162841] enc28j60 spi4.0: enc28j60 chip not found
[ 26.167877] enc28j60: probe of spi4.0 failed with error -5
[ 26.174102] usbcore: registered new interface driver catc
[ 26.179626] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 26.185943] usbcore: registered new interface driver kaweth
[ 26.191558] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 26.199462] usbcore: registered new interface driver pegasus
[ 26.205261] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 26.212493] usbcore: registered new interface driver rtl8150
[ 26.218536] usbcore: registered new interface driver asix
[ 26.224334] usbcore: registered new interface driver cdc_ether
[ 26.230499] usbcore: registered new interface driver dm9601
[ 26.236480] usbcore: registered new interface driver smsc95xx
[ 26.242645] usbcore: registered new interface driver gl620a
[ 26.248596] usbcore: registered new interface driver net1080
[ 26.254608] usbcore: registered new interface driver plusb
[ 26.260528] usbcore: registered new interface driver rndis_host
[ 26.266845] usbcore: registered new interface driver cdc_subset
[ 26.273162] usbcore: registered new interface driver zaurus
[ 26.279144] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 26.286987] Broadcom 43xx driver loaded [ Features: L, Firmware-ID: FW13 ]
[ 26.294433] usbcore: registered new interface driver zd1211rw
[ 26.300537] usbcore: registered new interface driver rtl8187
[ 26.306640] usbcore: registered new interface driver rndis_wlan
[ 26.312957] usbcore: registered new interface driver zd1201
[ 26.319030] usbcore: registered new interface driver usb8xxx
[ 26.325134] usbcore: registered new interface driver rt2500usb
[ 26.331359] usbcore: registered new interface driver rt73usb
[ 26.337432] usbcore: registered new interface driver p54usb
[ 26.343109] i2c /dev entries driver
[ 26.348602] KERR:AT24C04 EEPROM: Added i2c driver
[ 26.353454] at24_eeprom: 238
[ 26.356658] KERR:AT24C04A I2C EEPROM Character Driver Registered Succussesfully
[ 26.364471] KERR:I2C Slave address = 50
[ 26.369232] Driver 'sd' needs updating - please use bus_type methods
[ 26.375976] Driver 'sr' needs updating - please use bus_type methods
[ 26.383636] omap2-nand driver initializing
[ 26.388122] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xb1 (Micron NAND 128MiB 1,8V 16-bit)
[ 26.397308] cmdlinepart partition parsing not available
[ 26.402557] Creating 5 MTD partitions on "omap2-nand":
[ 26.407775] 0x000000000000-0x000000080000 : "X-Loader"
[ 26.415191] 0x000000080000-0x000000260000 : "U-Boot"
[ 26.422454] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 26.429290] 0x000000280000-0x000000680000 : "Kernel"
[ 26.437377] 0x000000680000-0x000008000000 : "File System"
[ 26.497039] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 26.503967] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 26.510253] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[ 26.518096] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 26.535919] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 26.542602] usb usb2: configuration #1 chosen from 1 choice
[ 26.548797] hub 2-0:1.0: USB hub found
[ 26.552703] hub 2-0:1.0: 3 ports detected
[ 26.558868] Initializing USB Mass Storage driver...
[ 26.564300] usbcore: registered new interface driver usb-storage
[ 26.570404] USB Mass Storage support registered.
[ 26.575927] mice: PS/2 mouse device common for all mice
[ 26.581878] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 26.590698] ads7846 spi1.0: touchscreen, irq 191
[ 26.596160] input: ADS784x Touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/input1
[ 26.607543] input: twl4030_pwrbutton as /devices/platform/i2c_omap.1/i2c-adapter/i2c-1/1-0049/twl4030_pwrbutton/input/input2
[ 26.621856] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 26.628234] Bluetooth: HCI UART driver ver 2.2
[ 26.632751] Bluetooth: HCI H4 protocol initialized
[ 26.637664] Bluetooth: HCI BCSP protocol initialized
[ 26.642669] Bluetooth: HCILL protocol initialized
[ 26.647430] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[ 26.654113] usbcore: registered new interface driver bcm203x
[ 26.659851] Bluetooth: Digianswer Bluetooth USB driver ver 0.10
[ 26.666198] usbcore: registered new interface driver bpa10x
[ 26.671936] Bluetooth: BlueFRITZ! USB driver ver 1.2
[ 26.677307] usbcore: registered new interface driver bfusb
[ 26.682830] Bluetooth: Generic Bluetooth USB driver ver 0.4
[ 26.688842] usbcore: registered new interface driver btusb
[ 26.694458] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 26.701080] mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
[ 26.817352] mmci-omap-hs mmci-omap-hs.1: Failed to get debounce clock
[ 26.823944] regulator: Unable to get requested regulator: vmmc_aux
[ 26.833190] Registered led device: beagleboard::usr0
[ 26.838562] Registered led device: beagleboard::usr1
[ 26.851226] usbcore: registered new interface driver usbhid
[ 26.856903] usbhid: v2.6:USB HID core driver
[ 26.862548] Advanced Linux Sound Architecture Driver Version 1.0.18a.
[ 26.870147] usbcore: registered new interface driver snd-usb-audio
[ 26.876831] No device for DAI twl4030
[ 26.880706] No device for DAI omap-mcbsp-dai-0
[ 26.885192] No device for DAI omap-mcbsp-dai-1
[ 26.889801] No device for DAI omap-mcbsp-dai-2
[ 26.894287] No device for DAI omap-mcbsp-dai-3
[ 26.898803] No device for DAI omap-mcbsp-dai-4
[ 26.903320] OMAP3 Beagle SoC init
[ 26.907135] TWL4030 Audio Codec init
[ 26.912414] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 26.928863] ALSA device list:
[ 26.931854] #0: omap3beagle (twl4030)
[ 26.944061] oprofile: using arm/armv7
[ 26.948028] IPv4 over IPv4 tunneling driver
[ 26.953308] GRE over IPv4 tunneling driver
[ 26.958404] TCP cubic registered
[ 26.962188] NET: Registered protocol family 10
[ 26.968444] Mobile IPv6
[ 26.970916] IPv6 over IPv4 tunneling driver
[ 26.980957] NET: Registered protocol family 17
[ 26.985534] NET: Registered protocol family 15
[ 26.990325] Bridge firewalling registered
[ 26.994415] Bluetooth: L2CAP ver 2.11
[ 26.998168] Bluetooth: L2CAP socket layer initialized
[ 27.003265] Bluetooth: SCO (Voice Link) ver 0.6
[ 27.007843] Bluetooth: SCO socket layer initialized
[ 27.013000] Bluetooth: RFCOMM socket layer initialized
[ 27.018218] Bluetooth: RFCOMM TTY layer initialized
[ 27.023193] Bluetooth: RFCOMM ver 1.10
[ 27.026977] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 27.032379] Bluetooth: BNEP filters: protocol multicast
[ 27.037689] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 27.044769] RPC: Registered udp transport module.
[ 27.049530] RPC: Registered tcp transport module.
[ 27.054565] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
[ 27.061462] All bugs added by David S. Miller <davem@redhat.com>
[ 27.069030] CCID: Activated CCID 2 (TCP-like)
[ 27.073608] CCID: Activated CCID 3 (TCP-Friendly Rate Control)
[ 27.080780] SCTP: Hash tables configured (established 4096 bind 8192)
[ 27.087646] lib80211: common routines for IEEE802.11 drivers
[ 27.093475] TIPC: Activated (version 1.6.4 compiled Apr 11 2012 10:48:53)
[ 27.100952] NET: Registered protocol family 30
[ 27.105438] TIPC: Started in single node mode
[ 27.109863] ThumbEE CPU extension supported.
[ 27.114196] Power Management for TI OMAP3.
[ 27.118865] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 27.128845] registered taskstats version 1
[ 27.140472] Console: switching to colour frame buffer device 40x30
[ 27.150268] clock: clksel_round_rate_div: dpll4_m4_ck target_rate 48000000
[ 27.157196] clock: new_div = 9, new_rate = 48000000
[ 27.192413] omapdss: DSS Requested 6300 kHz, got 6300 kHz,19,37,29,4,14,3
[ 27.201751] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 27.208526] Waiting for root device /dev/mmcblk0p2...
[ 27.247009] mmc0: new SD card at address aaaa
[ 27.252197] mmcblk0: mmc0:aaaa SU02G 1.84 GiB (ro)
[ 27.257385] mmcblk0: p1 p2
[ 27.317657] VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2)
[ 27.324737] Please append a correct "root=" boot option; here are the available partitions:
[ 27.333251] 1f00 512 mtdblock0 (driver?)
[ 27.338287] 1f01 1920 mtdblock1 (driver?)
[ 27.343322] 1f02 128 mtdblock2 (driver?)
[ 27.348388] 1f03 4096 mtdblock3 (driver?)
[ 27.353393] 1f04 124416 mtdblock4 (driver?)
[ 27.358428] b300 1931264 mmcblk0 driver: mmcblk
[ 27.363708] b301 72261 mmcblk0p1
[ 27.368041] b302 1855507 mmcblk0p2
[ 27.372406] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
For your kind information;
Kernel Version:2.6.29
Cross compiler: /ulk/toolchain/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi
Please help me to come out from this issue.
Thanks and regards,
Sujay
