Other Parts Discussed in Thread: DM385
we get APPRO DM8127 IPNC camera kit with RDK version 3.0.0. It starts booting once powered on but ipnc application is not running and the target enters into continuous loop . We can see next output on our terminal console:
DRAM: 1 GiB
NAND: HW ECC BCH8 Selected
256 MiB
MMC: OMAP SD/MMC: 0, ON-BOARD SDIO: 1
Date: 2000-01-01 (Sunday) Time: 3:26:27
Net: Ethernet clocking: 0x0
Detected MACID:30:30:3a:31:38:3a
cpsw
Hit any key to stop autoboot: 0
Loading from nand0, offset 0x280000
Image Name: Linux-2.6.37_DM385_IPNC_2.80.00
Created: 2012-04-27 14:48:53 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2369872 Bytes = 2.3 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 81000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM385_IPNC_2.80.00 (a0393203@bangvideoapps01) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Fri Apr 27 20:18:49 IST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: dm385ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is DM385 1.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19296
Kernel command line: console=ttyO0,115200n8 mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 noinitrd root=/dev/mtdblock4 rw rootfstype=jffs2 eth=00:0C:0C:02:31:88 ip=192.168.1.168 earlyprintk
cpsw: kernel boot params Ethernet address: 00:0C:0C:02:31:88
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 76MB = 76MB total
Memory: 71968k/71968k available, 9952k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xf8000000 ( 808 MB)
lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0038000 ( 192 kB)
.text : 0xc0038000 - 0xc047c000 (4368 kB)
.data : 0xc047c000 - 0xc04ba580 ( 250 kB)
Freeing init memory: 192K
INIT: version 2.86 booting
JFFS2 notice: (40) check_node_data: wrong data CRC in data node at 0x000043ac: read 0xaec63cbe, calculated 0xc402649f.
INIT: Entering runlevel: 5
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org 192.168.1.168 ttyO0
Arago 2010.11 192.168.1.168 ttyO0
192 login: root (automatic login)
_____ _____ _ _
|___| |___|
_____ _____ _ _
|___| |___|
_____ _____ _ _
|___| |___|
_____ _____ _ _
|___| |___|
_____ _____ _ _
|___| |___|
_____ _____ _ _
|___| |___|
_____ _____ _ _
|___| |___|
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x03abb6c4: read 0xb8de8170, calculated 0xedbfcec.
_____ _____ _ _
|___| |___|
_____ _____ _ _
|___| |___|
INIT: Id "1" respawning too fast: disabled for 5 minutes
INIT: no more processes left in this runlevel
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x02cf8fcc: read 0x2a7599e9, calculated 0x4b53e6c1.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x00646c18: read 0x66080b3a, calculated 0x3e0cd3ff.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x0062c57c: read 0x4cd509be, calculated 0x60e52380.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x005b042c: read 0xc4e4703, calculated 0x4a12ac85.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x0058bf60: read 0x1e77be90, calculated 0xc974971b.
JFFS2 notice: (38) read_dnode: wrong data CRC in data node at 0x00cbcad0: read 0xb3c388aa, calculated 0xa4a4f258.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x01081dec: read 0x468248d3, calculated 0x912d606b.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x00e2cb38: read 0xbba4fc89, calculated 0x600202ea.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x00da44f4: read 0xa4b9aa36, calculated 0x39fb4911.
JFFS2 notice: (38) read_dnode: wrong data CRC in data node at 0x016f3224: read 0x72133302, calculated 0x85d62db7.
JFFS2 notice: (38) read_dnode: wrong data CRC in data node at 0x016b51e8: read 0x6493334f, calculated 0xd0b24353.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x016024f8: read 0x285a5f15, calculated 0x9da4847a.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x01465d94: read 0x3b35046a, calculated 0xa5865f8d.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x011b783c: read 0x3c224f7e, calculated 0xbbc53c48.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x01728038: read 0x422976c, calculated 0x84dd47.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x01714b50: read 0x7cebe4d5, calculated 0x5478c331.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x01b18420: read 0x26992f4f, calculated 0x664f9cfb.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x01decb10: read 0xf4c7ea4c, calculated 0xcf4ba647.
JFFS2 notice: (38) check_node_data: wrong data CRC in data node at 0x02374604: read 0xc3ce0600, calculated 0xeec07ed7.
current bootargs:
DM385_IPNC#printenv
bootdelay=3
baudrate=115200
verify=yes
bootfile=uImage
ramdisk_file=ramdisk.gz
loadaddr=0x81000000
script_addr=0x80900000
loadbootscript=fatload mmc 0 ${script_addr} boot.scr
bootscript= echo Running bootscript from MMC/SD to set the ENV...; source ${script_addr}
ethaddr=30:30:3a:31:38:3a
ethact=cpsw
filesize=2895340
bootcmd=nboot 0x81000000 0 0x280000; bootm
bootargs=console=ttyO0,115200n8 mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 noinitrd root=/dev/mtdblock4 rw rootfstype=jffs2 eth=00:0C:0C:02:31:88 ip=192.168.1.168 earlyprintk
stdin=serial
stdout=serial
stderr=serial
ver=U-Boot 2010.06 (Apr 27 2012 - 20:12:59) DM385_IPNC_2.80.00
Can you help?
Thank you in advance
Julia
