Hi all,
Refer the design of IPNC 8127, we build our own board. when we config to host mode, it meet proble.
1)Using default config of IPNC8127, we can debug our board to device mode(slave), just like the IPNC8127 slave mode function. Of course, in our board, we must do some change.(USB_ID to disconnect; VBUS to connect to VBUSIN);
2)But we try to config to Host USB mode, when insmod ti81xx.ko module, the informations are following:
kernle config:
<*> Support for Host-side USB
[*]USB device class-device (DEPRECATED)
<*>USB Monitor
<*>Inventra HIGHSpeed DUAL Role Controller(TI, ADI, ...)
<M> TI81XX
TI81XX usb connctor's ID pin controll (from usb connector)
Dirver Mode (Host mode)
<*> USB Mass Storage support
When insmod the ti81xx.ko, the information is following:
root@dm814x-evm:/opt/ipnc# insmod ti81xx.ko
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37_DM8127_IPNC_3.00.00_2012-1026 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at c58b0000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37_DM8127_IPNC_3.00.00_2012-1026 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at c58b4800 using DMA, IRQ 19
hub 1-0:1.0: over-current change on port 1
hub 2-0:1.0: over-current change on port 1
hub 2-0:1.0: over-current change on port 1 #continuously print.
There are two differences between IPNC8127 and our board.
1)VBUS: Our board output 5V power supply, our board use it to Host USB; But Ipnc connect it to VBUSIN;
2)USB_ID:Our board force to low level; IPNC 8127 do not connect.(R278 is not jointing in fact.)
Anybody can give me some advices? Thanks a lot.
