Hi ,
I am observing a 4 to 7 bit mismatch in Rate Dematcher output as well as SSL output for RB Count greater than 12 RBs. The position of bit mismatch is not fixed or without any pattern for differenet number of RBs however position remains same for multiple runs for same RB case.For reference I am taking Matlab Rate Dematcher Output for the same test configuration as given to BCP. We doubted Descrambler so by disabling descrambler in SSL header we took Demod output and compared with Matlab reference output (by disabling descrambler there also) and found that there is same bit mismatch at same positions as was earlier for 18 RB case.
NOTE: We are doing first stage deinterleaving on Resource Demapped data from Matlab and feeding the same to BCP.
Thanks & Regards
Naveen Kumar
