Other Parts Discussed in Thread: OMAPL138
Hi All,
I need assistance in calculating timing requirement for CYDM128B with OMAPL138. This is a 16 bit device interfaced using EMIF.
http://www.cypress.com/?mpn=CYDM128B16-55BVXI
Dinu
Hi All,
Dinu
Dinu
What is the VCC voltage you plan to use for your application? Have you got a chance to look at the OMAPL138 TRM? The formula for calculating the EMIF timing is in the TRM.
David
David,
Thanks for your interest. Sorry to mention about the voltage. Our board is working at 1.8V. I went through both the documents. Some AN provided is also in the link above. From those I came to understood that the CYDM is working as ASYNC Memory. So as per my understanding only CEnCFG need to be configured. Interface 16bit with BA[1] controllong A0 of CYDM. So I went to calculate R_SETUP/W_SETUP, R_STROBE/W_STROBE and R_HOLD/W_HOLD. But I failed to achieve at a desired result. My EMIF Interface is operating @100MHz. I came across the key timing to be noted for calculate SETUP/STROBE/HOLD timing but I can't correlate it with CYDM data sheet.
Dinu
