How to write a new link for dm8168 rdk to separate our own mux video signal?
we develop on dm8168 dvrrdk 2.80.
we design our own board.
we mux 2 XGA 60 video using FPGA in our own format, and after that we have to separate  two streams,
so a new link is needed,
how to to then?
i read the dup link, but i am not familiar with link framework,
can someone tell me how links works deelpy
best regards
xavier
  • Can you pls explain your usecase data flow.For example Capture -> NSF -> Encoder . Based on your description it does not look like you need a new link. I understand you are going to capture 2 channel XGA @ 60 fields / sec . Is that correct ? Is you question how to capture the video frame or have you already done that ? For capturing video, you will have to configure the external video decoder (FPGA in your case) and then configure capture link. you dont have to create  a new link. For configring capture link you will have to provide info on how the two channels muxed video format. (Pixel Muxed/Line muxed).(EMbedded Sync/Discrete Sync).It may require some changes in capture link file.
  • thank you ,
    i have solved this problem.
