I'm trying to build a CE simple application using a dvsdk_2.00.00.22.29 with full version of Codec Engine (cetools directory) and CCSv5.2. I build it by following these guidelines.
DM6446 software installation - http://processors.wiki.ti.com/index.php/DMAI_GStreamer_Plug-In_Getting_Started_Guide#DM6446_software_installation_.28DVSDK_2.00.00.22.29.
In CE directory I've modified xdcpaths.mak and products.mak and build the CE example codecs successfully.
Next I'm creating new blank ccs project with main.c and main.cfg. When i try use engine module var Engine = xdc.useModule('ti.sdo.ce.Engine') i'm getting output from the console :
'/home/student/ti/grace_1_10_04_36/packages;/home/student/ti/ipc_1_24_03_32/packages;/home/student/ti/bios_6_33_05_46/packages;/home/student/ti/uia_1_01_00_04/packages;/home/student/ti/xdais_7_21_01_07/packages;/home/student/ti/xdais_7_21_01_07/examples;/home/student/ti/ccsv5/ccs_base;/home/student/ti/xdctools_3_23_03_53/packages;..;'. Ensure that the package path is set correctly.
When I add some XDCtools/Package Repositories
/home/student/dvsdk_2_00_00_22/codec_engine_2_23_01/packages
i get :
can't locate the package 'ti.sdo.fc.dskt2' along the path: '/home/student/ti/grace_1_10_04_36/packages;/home/student/dvsdk_2_00_00_22/codec_engine_2_23_01/packages;/home/student/ti/ipc_1_24_03_32/packages;/home/student/ti/bios_6_33_05_46/packages;/home/student/ti/uia_1_01_00_04/packages;/home/student/ti/xdais_7_21_01_07/packages;/home/student/ti/xdais_7_21_01_07/examples;/home/student/ti/ccsv5/ccs_base;/home/student/ti/xdctools_3_23_03_53/packages;..;'. Ensure that the package path is set correctly.
When i try add framework components repositories
/home/student/dvsdk_2_00_00_22/framework_components_2_23_01/packages
i have issues :
Cannot call method "instances" of undefined.
What is possible reason of this error.
