I have made a codec server that use a codec called "viddec_binarize.x64P" on dsp side,and I didn't enable the gnu.targets.MVArm9 in "usr.bld“ file.
As a result , it failed...
So I then enable the gnu.targets.MVArm9
When I build the Codec Engine Application on GPP side, it shows that :
making package.mak (because of package.bld) ...
generating interfaces for package ceapp (because package/package.xdc.xml is older than package.xdc) ...
configuring ceapp.x470MV from package/cfg/ceapp_x470MV.cfg ...
Info: Configuring engine named 'video_binarize' from the info file for DSP server './video_binarize.x64P',
located in package 'wucao.zhsh.ce.servers.video_binarize':
Target app will look for the DSP server image 'video_binarize.x64P' in its current directory.
Adding codec 'viddec_binarize' (wucao.zhsh.ce.codecs.viddec_binarize.VIDDEC_BINARIZE), scratch groupId=0
Info: Reading DSP memory map from the info file for DSP server './video_binarize.x64P',
ti.sdo.ce.utils.trace.close() ...
ti.sdo.ce.utils.trace.validate() ...
will link with ti.sdo.ce.utils.trace:lib/TraceUtil.a470MV
will link with ti.sdo.ce.bioslog:lib/bioslog.a470MV
will link with wucao.zhsh.ce.codecs.viddec_binarize:lib/viddec_binarize.a470MV
will link with ti.sdo.ce.video:lib/video.a470MV
will link with ti.sdo.ce:lib/ce.a470MV
will link with ti.sdo.ce.ipc.dsplink:lib/ipc_dsplink_6467.a470MV
will link with ti.sdo.ce.osal.linux:lib/osal_linux_470.a470MV
will link with ti.sdo.ce.alg:lib/Algorithm_noOS.a470MV;lib/alg.a470MV
will link with ti.sdo.linuxutils.cmem:lib/cmem.a
will link with dsplink.gpp:export/BIN/Linux/Davinci/DM6467/RELEASE/dsplink.lib
will link with ti.sdo.fc.acpy3:acpy3.a470MV
will link with ti.sdo.fc.dman3:dman3Cfg.a470MV
will link with ti.sdo.ce.utils.xdm:lib/XdmUtils.a470MV
will link with ti.sdo.utils.trace:lib/gt.a470MV
cl470MV package/cfg/ceapp_x470MV.c ...
so I don't know why the GPP application have to link with a viddec_binarize.a470MV which is a codec on MV ARM target since I have already a codec viddec_binarize.x64P on dsp side ?
