Other Parts Discussed in Thread: AM3894, AM5K2E04
I am starting so spec a Linux mini-PC design using the AM3894 for which I would prefer to use standard socketed 2GByte SO-DIMM DDR3 memory.
Please can you tell me if the AM3894 can be interfaced to commercial SO-DIMM DDR3 laptop memory?
e.g. http://download.micron.com/pdf/datasheets/modules/ddr3/jsf16c256x64h.pdf
Please let me know if there are any limitations regarding how Linux would see the 2GByte address space. Thank you.
And/Or If there is some fundamental memory interface limitation of the AM3894 that prevents me from using a socketed 2GByte SO-DIMM DDR3 memory, then please can you deescribe a 2GByte-total discrete memory chips solution that I could use. i.e. memory chip part number, and how many of those chips to make 2GByte. (4 chips max please)
Thank you
