Problems when loading VICP/VPSS/DSP firmware
Other Parts Discussed in Thread: TPS40400, PMP, TVP5158
Dear all,
I have problems when loading the VICP/VPSS/DSP firmware.
First, it looks extremely strange about the files size between those originally prebuilt in my purchased DVRRDK box and those I built by myself.
ie:
Pre-built in my DVRRKD I build by myself
dvr_rdk_fw_c6xdsp.xe674 909.7 KB 13.7 MB
dvr_rdk_fw_m3video.xem3 4.1MB 14.6 MB
dvr_rdk_fw_m3vpss.xem3 5.6MB 19.8 MB
It looks much different in size. Does anyone have any idea about this?
Furthermore, when I loaded them in the terminal with below command,
seems there is problem with my built firmware from the log as below:
command:
 @ ./init.sh
 @ ./load.sh
Log of loading the prebuilt firmware: (looks good)
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
 [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 280000000
 [m3vpss ] notify_attach  rtnVal  0
 [m3vpss ] initProxyServer  rtnVal  0
 [m3vpss ]
 [m3vpss ]  *** UTILS: CPU KHz = 560000 Khz ***
 [m3vpss ]
 [m3vpss ]  43: SYSTEM  : System Common Init in progress !!!
 [m3vpss ]  43: SYSTEM: IPC init in progress !!!
 [m3vpss ]  43: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1043: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1044: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3vpss ]  1044: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x097d2000]
Attached to slave procId 1.
 [m3vpss ]  2045: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  3045: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  4045: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  5045: SYSTEM: Attaching to [DSP] ...
Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
Started slave procId 1.
 [m3video] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 280000000
After Ipc_startcallback status [0x00000000]
 [m3vpss ]  6045: SYSTEM: Attaching to [DSP] ...
 [m3video]
 [m3video]  *** UTILS: CPU KHz = 560000 Khz ***
 [m3video]
 [m3video]  5691: SYSTEM  : System Common Init in progress !!!
 [m3video]  5691: SYSTEM: IPC init in progress !!!
 [m3video]  5691: SYSTEM: Attaching to [HOST] ...
 [m3video]  6690: SYSTEM: Attaching to [HOST] ...
 [m3video]  6693: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3video]  6693: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 0.
 [m3vpss ]  7045: SYSTEM: Attaching to [DSP] ...
 [m3video]  7692: SYSTEM: Attaching to [DSP] ...
Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
Started slave procId 0.
 [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 800000000, <NEW> - 800000000
 [c6xdsp ]
 [c6xdsp ]  *** UTILS: CPU KHz = 800000 Khz ***
 [c6xdsp ]
 [c6xdsp ]  5: SYSTEM  : System Common Init in progress !!!
 [c6xdsp ]  5: SYSTEM: IPC init in progress !!!
 [c6xdsp ]  5: SYSTEM: Attaching to [HOST] ...
 [c6xdsp ]  7: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [c6xdsp ]  7: SYSTEM: Attaching to [VIDEO-M3] ...
DMA: Module install successful, device major num = 251
DRV: Module install successful
DRV: Module built on Oct 26 2012 09:55:45
 [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
 [m3video] Remote Debug Shared Memory @ 0xbf005020
 [m3vpss ] Remote Debug Shared Memory @ 0xbf00a040
 [m3vpss ]  8045: SYSTEM: Attaching to [DSP] ...
 [m3video]  8692: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  1014: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3vpss ]  9045: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  1902: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  9692: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  1902: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  9693: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3video]  9693: SYSTEM: Attaching to [VPSS-M3] ...
 [m3vpss ]  10045: SYSTEM: Attaching to [DSP] ...
 [m3video]  10692: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  2909: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  3254: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  11045: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  3255: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  11045: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3vpss ]  11045: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  11692: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  4261: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3video]  12045: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  12045: SYSTEM: Attaching to [VIDEO-M3] ...
 [c6xdsp ]  4261: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
 [m3video]  12045: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  12045: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [c6xdsp ]  4261: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
 [m3video]  12045: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  12045: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [c6xdsp ]  4262: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3video]  12046: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
 [m3vpss ]  12045: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
 [c6xdsp ]  4262: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [m3video]  12047: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3vpss ]  12046: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
 [c6xdsp ]  4262: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3video]  12047: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [m3vpss ]  12047: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [c6xdsp ]  4262: SYSTEM: IPC init DONE !!!
 [m3video]  12047: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3vpss ]  12047: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [m3video]  12048: SYSTEM: IPC init DONE !!!
 [m3vpss ]  12047: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [m3video]  12053: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
 [m3vpss ]  12048: SYSTEM: IPC init DONE !!!
 [m3video]  12053: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d000000 (208 MB)
 [m3vpss ]  12053: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
 [m3vpss ]  12053: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d000000 (208 MB)
 [c6xdsp ]  4264: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
 [m3video]  12055: SYSTEM  : System Common Init Done !!!
 [m3vpss ]  12055: SYSTEM  : System Common Init Done !!!
 [c6xdsp ]  4264: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d000000 (208 MB)
 [m3video]  12055: SYSTEM  : System Video Init in progress !!!
 [m3vpss ]  12055: SYSTEM  : System VPSS Init in progress !!!
 [c6xdsp ]  4264: SYSTEM  : System Common Init Done !!!
 [m3video]  12055: SYSTEM  : System Video Init Done !!!
 [m3vpss ]  12055: SYSTEM: All VPDMA Free !!!
 [c6xdsp ]  4229: SYSTEM  : System DSP Init in progress !!!
 [m3video]  12056: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
 [m3vpss ] === HDVPSS Clocks are enabled ===
 [c6xdsp ]  4229: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
 [m3video]  12056: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
 [m3vpss ] === HDVPSS is fully functional ===
 [c6xdsp ]  4267: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
 [m3video]  12056: SYSTEM: ListElem Shared Addr = 0xbf18b680
 [m3vpss ] === HDVPSS module is not in standby ===
 [c6xdsp ]  4267: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
 [m3video]  12058: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
 [m3vpss ] === I2C1 Clk is active ===
 [c6xdsp ]  4267: SYSTEM: ListElem Shared Addr = 0xbf18eb80
 [m3video]  12058: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
 [m3vpss ]  12060: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
 [c6xdsp ]  4268: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
 [m3video]  12058: SYSTEM: ListElem Shared Addr = 0xbf1ae580
 [m3vpss ]  12060: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
 [c6xdsp ]  4268: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
 [m3video]  12063: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
 [m3vpss ]  12060: SYSTEM: ListElem Shared Addr = 0xbf20e980
 [c6xdsp ]  4268: SYSTEM: ListElem Shared Addr = 0xbf1b1a80
 [m3video]  12064: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
 [m3vpss ]  12062: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
 [c6xdsp ]  4269: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
 [m3vpss ] Received character 's'
 [m3video]  12064: SYSTEM: ListElem Shared Addr = 0xbf232e80
 [m3vpss ]  12062: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
 [c6xdsp ]  4269: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
 [m3video]  12066: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
 [m3vpss ]  12063: SYSTEM: ListElem Shared Addr = 0xbf22f980
 [c6xdsp ]  4269: SYSTEM: ListElem Shared Addr = 0xbf1d1480
 [m3video]  12066: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
 [m3vpss ]  12073: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
 [c6xdsp ]  4269: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
 [m3video]  12066: SYSTEM: ListElem Shared Addr = 0xbf252880
 [m3vpss ]  12074: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
 [c6xdsp ]  4270: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
 [m3video]  12068: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
 [m3vpss ]  12074: SYSTEM: ListElem Shared Addr = 0xbf291c80
 [c6xdsp ]  4270: SYSTEM: ListElem Shared Addr = 0xbf1f1100
 [m3video]  12068: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
 [m3vpss ]  12076: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
 [c6xdsp ]  4270: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
 [m3video]  12069: SYSTEM: ListElem Shared Addr = 0xbf272280
 [m3vpss ]  12076: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
 [c6xdsp ]  4270: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
 [m3video]  12079: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
 [m3vpss ]  12076: SYSTEM: ListElem Shared Addr = 0xbf2b1680
 [c6xdsp ]  4270: SYSTEM: ListElem Shared Addr = 0xbf211e80
 [m3video]  12079: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
 [m3vpss ]  12078: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
 [c6xdsp ] !!WARNING.Resource already registered:2
 [c6xdsp ]  4235: SYSTEM  : Initializing Links !!!
 [m3video]  12079: SYSTEM: ListElem Shared Addr = 0xbf2f0a80
 [m3vpss ]  12078: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
 [m3video]  12081: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
 [m3vpss ]  12079: SYSTEM: ListElem Shared Addr = 0xbf2d1080
 [c6xdsp ]  4271: SYSTEM  : FREE SPACE : System Heap      = 10268448 B, Mbx = 10240 msgs)
 [m3video]  12081: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
 [m3vpss ]  12080: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
 [m3video]  12081: SYSTEM: ListElem Shared Addr = 0xbf30e580
 [m3vpss ]  12080: SYSTEM  : FVID2 Init in progress !!!
 [c6xdsp ]  4244: SYSTEM  : Initializing Links ... DONE !!!
 [m3video]  12083: HDVICP: Doing PRCM for IVAHD[0] ...
 [m3vpss ]  12163: SYSTEM  : FVID2 Init in progress DONE !!!
 [m3video]  12083: HDVICP: PRCM for IVAHD[0] ... DONE.
 [m3vpss ]  12163: SYSTEM  : Device Init in progress !!!
 [c6xdsp ]  4244: SYSTEM  : System DSP Init Done !!!
 [m3video]  12083: HDVICP: Doing PRCM for IVAHD[1] ...
 [m3video]  12083: HDVICP: PRCM for IVAHD[1] ... DONE.
 [m3vpss ] initPrms.isI2cInitReq = 0
 [m3video]  12083: HDVICP: Doing PRCM for IVAHD[2] ...
 [m3video]  12084: HDVICP: PRCM for IVAHD[2] ... DONE.
 [m3video]  12084: SYSTEM  : Initializing Links !!!
 [m3vpss ]  12166: SYSTEM  : Device Init in progress DONE !!!
 [m3vpss ]  12284: SYSTEM  : System VPSS Init Done !!!
 [m3video]  12084: SYSTEM  : FREE SPACE : System Heap      = 6280232 B, Mbx = 10240 msgs)
 [m3vpss ]  12284: UTILS: DMA: HWI Create for INT63 !!!
 [m3vpss ]  12284: SYSTEM  : Initializing Links !!!
 [m3video]  12084: SYSTEM  : FREE SPACE : SR0 Heap         = 13452672 B (12 MB)
 [m3vpss ]  12284: SYSTEM  : FREE SPACE : System Heap      = 13024 B, Mbx = 10240 msgs)
 [m3video]  12084: SYSTEM  : FREE SPACE : Frame Buffer     = 245104512 B (233 MB)
 [m3vpss ]  12284: SYSTEM  : FREE SPACE : SR0 Heap         = 13452672 B (12 MB)
 [m3video]  12084: SYSTEM  : FREE SPACE : Bitstream Buffer = 218103680 B (207 MB)
 [m3vpss ]  12284: SYSTEM  : FREE SPACE : Frame Buffer     = 240794496 B (229 MB)
 [m3video]  12085: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [m3video]  12085: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
 [m3vpss ]  12285: SYSTEM  : FREE SPACE : Bitstream Buffer = 218103680 B (207 MB)
 [m3video] Received character 's'
 [m3video]  12085: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
 [m3vpss ]  12285: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
 [c6xdsp ] Received character 's'
/home/root/dvr_rdk/ti816x_john
 [m3video]  12114: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ]  12285: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
 [m3vpss ]  12384: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ]  12384: SYSTEM  : Set Static L3 pressure for HDVPSS as High
[module] vpss probe done.
[module] ti81xxfb probe done.
HDMI W1 rev 2.0
[module] ti81xx_hdmi probe done.
 ORG 0x46c00524: 0
 NEW 0x46c00524: 2
Log of loading my-built firmwares: (looks problematic)
Loaded file ../firmware/dvr_rdk_BUG: Your driver calls ioremap() on system memory.  This leads
to architecturally unpredictable behaviour on ARMv6+, and ioremap()
will fail in the next kernel release.  Please fix your driver.
fw_m3vpss.xem3 o------------[ cut here ]------------
n slave procId 2WARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x58/0x190()
Started slaveModules linked in: procId 2.
 syslink
Backtrace:
[<80049b7c>] (dump_backtrace+0x0/0x10c) from [<8039c118>] (dump_stack+0x18/0x1c)
 r7:00000000 r6:8004d60c r5:8045c7dc r4:000000d3
[<8039c100>] (dump_stack+0x0/0x1c) from [<8006d3bc>] (warn_slowpath_common+0x54/0x6c)
[<8006d368>] (warn_slowpath_common+0x0/0x6c) from [<8006d3f8>] (warn_slowpath_null+0x24/0x2c)
 r9:00000002 r8:00000000 r7:7f03608c r6:00088000 r5:15000000
r4:00000002
[<8006d3d4>] (warn_slowpath_null+0x0/0x2c) from [<8004d60c>] (__arm_ioremap_pfn_caller+0x58/0x190)
[<8004d5b4>] (__arm_ioremap_pfn_caller+0x0/0x190) from [<8004d7c8>] (__arm_ioremap_caller+0x64/0x6c)
[<8004d764>] (__arm_ioremap_caller+0x0/0x6c) from [<8006000c>] (omap_ioremap+0x60/0x64)
 r6:00000002 r5:15000000 r4:88000000
[<8005ffac>] (omap_ioremap+0x0/0x64) from [<7f03608c>] (MemoryOS_map+0x1f0/0x3a8 [syslink])
 r7:8d5dbe28 r6:00000001 r5:8d5dbd48 r4:908fe000
[<7f035e9c>] (MemoryOS_map+0x0/0x3a8 [syslink]) from [<7f004594>] (_ProcMgr_map+0x1cc/0x4ac [syslink])
 r8:8d5dbe28 r7:8d5dbe28 r6:00000001 r5:9302e000 r4:90abc000
[<7f0043c8>] (_ProcMgr_map+0x0/0x4ac [syslink]) from [<7f004990>] (ProcMgr_map+0x11c/0x1b4 [syslink])
[<7f004874>] (ProcMgr_map+0x0/0x1b4 [syslink]) from [<7f019954>] (Platform_loadCallback+0x4a0/0x7a0 [syslink])
[<7f0194b4>] (Platform_loadCallback+0x0/0x7a0 [syslink]) from [<7f04d418>] (Ipc_control+0x68/0x14c [syslink])
[<7f04d3b0>] (Ipc_control+0x0/0x14c [syslink]) from [<7f0868f0>] (IpcDrv_drvioctl+0x68/0x298 [syslink])
 r7:00000004 r6:7f0fa820 r5:c014f497 r4:7ec13afc
[<7f086888>] (IpcDrv_drvioctl+0x0/0x298 [syslink]) from [<800d26a4>] (vfs_ioctl+0x28/0x44)
 r6:00000004 r5:8ddbdc80 r4:00000000
[<800d267c>] (vfs_ioctl+0x0/0x44) from [<800d2db4>] (do_vfs_ioctl+0x500/0x540)
[<800d28b4>] (do_vfs_ioctl+0x0/0x540) from [<800d2e4c>] (sys_ioctl+0x58/0x7c)
[<800d2df4>] (sys_ioctl+0x0/0x7c) from [<80045da0>] (ret_fast_syscall+0x0/0x30)
 r8:80045f48 r7:00000036 r6:0007e478 r5:c014f497 r4:7ec13afc
---[ end trace e5c0d78609f092a6 ]---
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  209: SYSTEM  : System Common Init in progress !!!
 [m3vpss ]  209: SYSTEM: IPC init in progress !!!
 [m3vpss ]  210: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1210: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1212: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3vpss ]  1212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  2212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  3212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  4212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  5212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  6212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  7212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  8212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  9212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  10212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  11212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  12212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  13212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  14212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  15212: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  16212: SYSTEM: Attaching to [DSP] ...
 [m3video]
 [m3video]
 [m3video]  15689: SYSTEM  : System Common Init in progress !!!
 [m3video]  15689: SYSTEM: IPC init in progress !!!
 [m3video]  15690: SYSTEM: Attaching to [HOST] ...
 [m3video]  16689: SYSTEM: Attaching to [HOST] ...
 [m3video]  16691: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3video]  16691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  17212: SYSTEM: Attaching to [DSP] ...
 [m3video]  17691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  18212: SYSTEM: Attaching to [DSP] ...
 [m3video]  18691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  19212: SYSTEM: Attaching to [DSP] ...
 [m3video]  19691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  20212: SYSTEM: Attaching to [DSP] ...
 [m3video]  20691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  21212: SYSTEM: Attaching to [DSP] ...
 [m3video]  21691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  22212: SYSTEM: Attaching to [DSP] ...
 [m3video]  22691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  23212: SYSTEM: Attaching to [DSP] ...
 [m3video]  23691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  24212: SYSTEM: Attaching to [DSP] ...
 [m3video]  24691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  25212: SYSTEM: Attaching to [DSP] ...
 [m3video]  25691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  26212: SYSTEM: Attaching to [DSP] ...
 [m3video]  26691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  27212: SYSTEM: Attaching to [DSP] ...
 [m3video]  27691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  28212: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]
 [c6xdsp ]
 [c6xdsp ]  8: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [c6xdsp ]  8: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  28691: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  29212: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  1245: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  29691: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  1245: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  29691: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3video]  29691: SYSTEM: Attaching to [VPSS-M3] ...
 [m3vpss ]  30212: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  2252: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  30691: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  2766: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  31212: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  2766: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  31212: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3vpss ]  31212: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  31691: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  3773: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3video]  32212: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  32212: SYSTEM: Attaching to [VIDEO-M3] ...
 [c6xdsp ]  3773: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
 [m3video]  32212: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  32212: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [c6xdsp ]  3773: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
 [m3video]  32212: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  32212: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [c6xdsp ]  3773: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3video]  32213: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
 [m3vpss ]  32212: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
 [c6xdsp ]  3773: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [m3video]  32214: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3vpss ]  32212: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
 [c6xdsp ]  3773: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3video]  32214: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [m3vpss ]  32214: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [c6xdsp ]  3773: SYSTEM: IPC init DONE !!!
 [m3video]  32214: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3vpss ]  32214: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [c6xdsp ]  3775: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
 [m3video]  32215: SYSTEM: IPC init DONE !!!
 [m3vpss ]  32214: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [c6xdsp ]  3775: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
 [m3video]  32220: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
 [m3vpss ]  32214: SYSTEM: IPC init DONE !!!
 [m3video]  32220: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
 [m3vpss ]  32220: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
 [m3vpss ]  32220: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
 [m3vpss ]  32222: SYSTEM  : System Common Init Done !!!
 [m3vpss ]  32222: SYSTEM  : System VPSS Init in progress !!!
 [m3vpss ]  32222: SYSTEM: All VPDMA Free !!!
 [m3video]  32222: SYSTEM  : System Common Init Done !!!
 [c6xdsp ]  3776: SYSTEM  : System Common Init Done !!!
 [c6xdsp ]  3744: SYSTEM  : System DSP Init in progress !!!
 [m3video]  32222: SYSTEM  : System Video Init in progress !!!
 [c6xdsp ]  3744: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
 [m3video]  32222: SYSTEM  : System Video Init Done !!!
 [c6xdsp ]  3779: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
 [m3video]  32223: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
 [c6xdsp ]  3779: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
 [m3video]  32223: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
 [c6xdsp ]  3779: SYSTEM: ListElem Shared Addr = 0xbf18f100
 [m3video]  32223: SYSTEM: ListElem Shared Addr = 0xbf18b680
 [m3vpss ]  32227: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
 [c6xdsp ]  3779: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
 [m3video]  32225: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
 [m3vpss ]  32227: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
 [c6xdsp ]  3780: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
 [m3video]  32225: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
 [m3vpss ]  32227: SYSTEM: ListElem Shared Addr = 0xbf1f0e80
 [c6xdsp ]  3780: SYSTEM: ListElem Shared Addr = 0xbf1b1a80
 [m3video]  32225: SYSTEM: ListElem Shared Addr = 0xbf1ae580
 [m3vpss ]  32229: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
 [c6xdsp ]  3780: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
 [m3video]  32230: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
 [m3vpss ]  32229: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
 [c6xdsp ]  3780: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
 [m3video]  32231: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
 [m3vpss ]  32230: SYSTEM: ListElem Shared Addr = 0xbf22f980
 [c6xdsp ]  3780: SYSTEM: ListElem Shared Addr = 0xbf1d1480
 [m3video]  32231: SYSTEM: ListElem Shared Addr = 0xbf232e80
 [m3vpss ]  32240: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
 [c6xdsp ]  3781: SYSTEM: Creating ListMP [DMA: Module install successful, device major num = 251
DSP_IPC_OUT_24] DRV: Module install successful
 [m3video]  32233: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
 [m3vpss ]  32240: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
 [c6xdsp ]  3781: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
 [m3video]  32233: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
 [m3vpss ]  32241: SYSTEM: ListElem Shared Addr = 0xbf291c80
 [c6xdsp ]  3781: SYSTEM: ListElem Shared Addr = 0xbf1f4380
 [m3video]  32233: SYSTEM: ListElem Shared Addr = 0xbf252880
 [m3vpss ]  32243: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
 [c6xdsp ]  3782: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
 [m3video]  32235: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
 [m3vpss ]  32243: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
 [c6xdsp ]  3782: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
 [m3video]  32235: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
 [m3vpss ]  32243: SYSTEM: ListElem Shared Addr = 0xbf2b1680
 [c6xdsp ]  3782: SYSTEM: ListElem Shared Addr = 0xbf211e80
 [m3video]  32236: SYSTEM: ListElem Shared Addr = 0xbf272280
 [m3vpss ]  32245: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
 [c6xdsp ]  3750: SYSTEM  : Initializing Links !!!
 [m3video]  32246: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
 [m3vpss ]  32245: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
 [m3video]  32246: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
 [m3vpss ]  32245: SYSTEM: ListElem Shared Addr = 0xbf2d1080
 [c6xdsp ]  3782: SYSTEM  : FREE SPACE : System Heap      = 10268448 B, Mbx = 10240 msgs)
 [m3video]  32246: SYSTEM: ListElem Shared Addr = 0xbf2f0a80
 [m3vpss ]  32247: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
 [m3video]  32248: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
 [m3vpss ]  32247: SYSTEM  : FVID2 Init in progress !!!
 [c6xdsp ]  3759: SYSTEM  : Initializing Links ... DONE !!!
 [m3video]  32248: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
 [m3vpss ]  32330: SYSTEM  : FVID2 Init in progress DONE !!!
 [m3video]  32249: SYSTEM: ListElem Shared Addr = 0xbf30e580
 [m3vpss ]  32330: SYSTEM  : Device Init in progress !!!
 [c6xdsp ]  3760: SYSTEM  : System DSP Init Done !!!
 [m3video]  32250: HDVICP: Doing PRCM for IVAHD[0] ...
 [m3video]  32250: HDVICP: PRCM for IVAHD[0] ... DONE.
 [m3video]  32250: HDVICP: Doing PRCM for IVAHD[1] ...
 [m3video]  32250: HDVICP: PRCM for IVAHD[1] ... DONE.
 [m3video]  32250: HDVICP: Doing PRCM for IVAHD[2] ...
 [m3vpss ]  32333: SYSTEM  : Device Init in progress DONE !!!
 [m3video]  32251: HDVICP: PRCM for IVAHD[2] ... DONE.
 [m3vpss ]  32451: SYSTEM  : System VPSS Init Done !!!
 [m3video]  32251: SYSTEM  : Initializing Links !!!
 [m3vpss ]  32451: UTILS: DMA: HWI Create for INT63 !!!
 [m3vpss ]  32451: SYSTEM  : Initializing Links !!!
 [m3video]  32251: SYSTEM  : FREE SPACE : System Heap      = 6280232 B, Mbx = 10240 msgs)
 [m3vpss ]  32451: SYSTEM  : FREE SPACE : System Heap      = 13024 B, Mbx = 10240 msgs)
 [m3video]  32251: SYSTEM  : FREE SPACE : SR0 Heap         = 13452672 B (12 MB)
 [m3vpss ]  32451: SYSTEM  : FREE SPACE : SR0 Heap         = 13452672 B (12 MB)
 [m3video]  32251: SYSTEM  : FREE SPACE : Frame Buffer     = 245104512 B (233 MB)
 [m3vpss ]  32452: SYSTEM  : FREE SPACE : Frame Buffer     = 240794496 B (229 MB)
 [m3video]  32251: SYSTEM  : FREE SPACE : Bitstream Buffer = 352321408 B (335 MB)
 [m3vpss ]  32452: SYSTEM  : FREE SPACE : Bitstream Buffer = 352321408 B (335 MB)
 [m3video]  32252: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [m3video]  32252: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
 [m3vpss ]  32452: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
 [m3video]  32252: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
 [m3vpss ]  32452: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
 [m3video]  32281: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ]  32551: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ]  32551: SYSTEM  : Set Static L3 pressure for HDVPSS as High
HDMI W1 rev 2.0
 ORG 0x46c00524: 0
 NEW 0x46c00524: 2
After loading my-built firmwares, the Demo app ( @ ./run.sh ) is abnormal in most demo case.
I can make sure it's firmware issue because everything turns good after replacing the three files with the prebuilt one.
Does anyone ever met this issue? or any advise can provide?
Just let me know if you need more logs for analysis.
  • The firmware size are different because we run strip utility after building to strip out debug info. Can you let us know from which folder you loaded the firmware.There is one under dvr_rdk/bin/ti816x/firmware and one under dvr_rdk/../target/rfs_816x/opt/dvr_rdk/ti816x/firmware. The under target will have symbols stripped.
    Regarding the load issue did you make any change when building. Is it a 2G memory map build you are trying. Pls share your rules.make and kernel bootargs. Pls share full logs from boot onwards to load firmware.
  • Hello, Badri
        Thanks for your reply.
        OK, let me describe the firmware files I tested more specifically.
        There are 3 case in my test:
    case 1:
         There is already file system existing in the NAND flash when we got DVRRDK box.
         We got the firmware files in /opt/dvr_rdk/ti816x/firmware
          => Test result: Good
    case 2:
         I downloaded DM8168_DVRRDK_V03.00.00.00 package and un-tar.
         There already exist prebuilt firmware files in DM8168_DVRRDK_V03.00.00.00/target/rfs_816x/opt/dvr_rdk/ti816x/firmware
          => Test result: Fail
    case 3:
         I build the firmware by myself.
         The files are in DM8168_DVRRDK_V03.00.00.00/dvr_rdk/bin/ti816x/firmware
      All three cases are tested with my-built kernel which is loaded through TFTP, and file system thr NFS.
      I did not make any modification in firmware source code when building.
      The Rules.make is attached for your reference.  (I rename it as Rules.txt when post.)
    # Copyright Texas Instruments
    ifeq ($(dvr_rdk_PATH), )
    # Board type can be one of the following
    #	1. DM816X_DVR
    #	2. DM816X_EVM
    #	3. DM814X_EVM
    #	4. DM810X_EVM
    #	5. DM810X_DVR
    ifeq ($(DVR_RDK_BOARD_TYPE ), )
      DVR_RDK_BOARD_TYPE := DM816X_DVR
    endif
    # Default build environment, windows or linux
    ifeq ($(OS), )
      OS := Linux
    endif
    dvr_rdk_RELPATH = dvr_rdk
    ifeq ($(OS),Windows_NT)
      dvr_rdk_BASE     := $(CURDIR)/..
      TI_SW_ROOT       := D:/ti_software
    endif
    ifeq ($(OS),Linux)
      dvr_rdk_BASE     := $(shell pwd)/..
      TI_SW_ROOT       := $(dvr_rdk_BASE)/ti_tools
      SC_SCRIPTS_BASE_DIR := /datalocal/user/ipnc_tools/Coding_Guidelines_for_RDK/Tools/scripts
    endif
    dvr_rdk_PATH     := $(dvr_rdk_BASE)/$(dvr_rdk_RELPATH)
    # CODEGEN_PATH_A8  := /opt/CodeSourcery  # John override
    CODEGEN_PATH_A8  := /home/john/CodeSourcery/Sourcery_G++_Lite
    CODEGEN_PREFIX   := $(CODEGEN_PATH_A8)/bin/arm-none-linux-gnueabi-
    CODEGEN_PATH_DSP := $(TI_SW_ROOT)/cgt_dsp/cgt6x_7_3_5/
    CODEGEN_PATH_M3  := $(TI_SW_ROOT)/cgt_m3/cgt470_4_9_5/
    bios_PATH        := $(TI_SW_ROOT)/bios/bios_6_33_05_46
    xdc_PATH         := $(TI_SW_ROOT)/xdc/xdctools_3_23_03_53
    syslink_PATH     := $(TI_SW_ROOT)/syslink/syslink_2_10_02_17_patched
    hdvpss_PATH      := $(TI_SW_ROOT)/hdvpss/hdvpss_01_00_01_37_patched
    ifeq ($(DVR_RDK_BOARD_TYPE),DM810X_EVM)
    syslink_PATH     := $(TI_SW_ROOT)/syslink/syslink_2_10_02_17_ti810x_patched
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM810X_DVR)
    endif
    iss_PATH		 := $(TI_SW_ROOT)/iss/iss_02_00_00_08
    ipc_PATH         := $(TI_SW_ROOT)/ipc/ipc_1_24_03_32
    fc_PATH          := $(TI_SW_ROOT)/framework_components/framework_components_3_22_02_08
    xdais_PATH       := $(TI_SW_ROOT)/xdais/xdais_7_22_00_03
    h264dec_DIR      := $(TI_SW_ROOT)/codecs/REL.500.V.H264AVC.D.HP.IVAHD.02.00.05.00
    h264enc_DIR      := $(TI_SW_ROOT)/codecs/REL.500.V.H264AVC.E.IVAHD.02.00.02.02
    h264dec_PATH     := $(h264dec_DIR)/500.V.H264AVC.D.HP.IVAHD.02.00/IVAHD_001
    h264enc_PATH     := $(h264enc_DIR)/500.V.H264AVC.E.IVAHD.02.00/IVAHD_001
    jpegdec_DIR      := $(TI_SW_ROOT)/codecs/REL.500.V.MJPEG.D.IVAHD.01.00.05.00
    jpegenc_DIR      := $(TI_SW_ROOT)/codecs/REL.500.V.MJPEG.E.IVAHD.01.00.04.00
    jpegdec_PATH     := $(jpegdec_DIR)/500.V.MJPEG.D.IVAHD.01.00/IVAHD_001
    jpegenc_PATH     := $(jpegenc_DIR)/500.V.MJPEG.E.IVAHD.01.00/IVAHD_001
    mpeg4dec_DIR     := $(TI_SW_ROOT)/codecs/REL.500.V.MPEG4.D.IVAHD.01.00.08.00
    mpeg4dec_PATH    := $(mpeg4dec_DIR)/500.V.MPEG4.D.ASP.IVAHD.01.00/IVAHD_001
    hdvicplib_PATH   := $(TI_SW_ROOT)/ivahd_hdvicp/hdvicp20
    linuxdevkit_PATH := $(TI_SW_ROOT)/linux_devkit/arm-none-linux-gnueabi
    edma3lld_PATH    := $(TI_SW_ROOT)/edma3lld/edma3_lld_02_11_02_04
    # Audio framework (RPE) and Codecs
    rpe_PATH         := $(TI_SW_ROOT)/rpe/remote-processor-execute
    aaclcdec_PATH    := $(TI_SW_ROOT)/codecs/c674x_aaclcdec_01_41_00_00_elf
    aaclcenc_PATH    := $(TI_SW_ROOT)/codecs/c674x_aaclcenc_01_00_01_00_elf_patched
    dvrapp_PATH      := $(dvr_rdk_PATH)/dvrapp/ti810x
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM816X_DVR)
    dvrapp_PATH      := $(dvr_rdk_PATH)/dvrapp/ti816x
    #dvrapp_PATH      := $(dvr_rdk_PATH)/dvrapp
    endif
    live555_PATH     := $(dvr_rdk_PATH)/module/live555
    qt_PATH          := /usr/local/Trolltech/QtEmbedded-4.8.1-arm
    mtdutils_PATH    := $(TI_SW_ROOT)/mtd_utils
    #TFTP_HOME     := /tftproot    # john modify
    TFTP_HOME      	 := $(dvr_rdk_BASE)/tftphome
    TARGET_FS     := $(dvr_rdk_BASE)/target/rfs
    TARGET_FS_DIR := $(dvr_rdk_PATH)/bin/ti816x
    ROOTDIR := $(dvr_rdk_PATH)
    ifeq ($(DVR_RDK_BOARD_TYPE),DM814X_EVM)
    TARGET_FS_DIR := $(dvr_rdk_PATH)/bin/ti814x
    TARGET_FS     := $(dvr_rdk_BASE)/target/rfs_814x
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM814X_DVR)
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM816X_EVM)
    TARGET_FS     := $(dvr_rdk_BASE)/target/rfs_816x
    endif
    endif
    TARGET_FS_DIR := $(dvr_rdk_PATH)/bin/ti810x
    TARGET_FS     := $(dvr_rdk_BASE)/target/rfs_810x
    endif
    endif
    # Default DDR Size
    ifeq ($(DDR_MEM), )
    #  DDR_MEM := DDR_MEM_1024M   # john modify
      DDR_MEM := DDR_MEM_2048M
    endif
    endif
    ifeq ($(DEMOTYPE), )
    #  DEMOTYPE = link_api_sd_demo
    endif
    endif
    DVR_RDK_BOARD := DVR_RDK_BOARD_TYPE
      DVR_RDK_BOARD := ud816x_dvr
    endif
      DVR_RDK_BOARD := ud810x_dvr
    endif
    ifeq ($(CORE), )
      CORE := m3vpss
    endif
    # Default platform
    ifeq ($(PLATFORM), )
      PLATFORM := ti816x-evm
      PLATFORM := ti814x-evm
    endif
    endif
      PLATFORM := ti810x-evm
    endif
    endif
    endif
    # Default linux mem
    ifeq ($(LINUX_MEM), )
    ifeq ($(PLATFORM), ti814x-evm)
      LINUX_MEM := LINUX_MEM_128M
    endif
    ifeq ($(PLATFORM), ti810x-evm)
    else
      LINUX_MEM := LINUX_MEM_256M
    endif
    endif
    # VS_CARD can be one of the following
    #	1. WITH_VS_CARD
    #	2. WITHOUT_VS_CARD
      DDR_MEM := DDR_MEM_512M
      VS_CARD := WITH_VS_CARD
    #  VS_CARD := WITHOUT_VS_CARD
    endif
    #       1. WITH_VS_CARD
    #  DDR_MEM := DDR_MEM_256M
    endif
    # Default profile
    ifeq ($(PROFILE_m3video), )
      PROFILE_m3video := release
    #  PROFILE_m3video := debug
    endif
    ifeq ($(PROFILE_m3vpss), )
      PROFILE_m3vpss := release
    #  PROFILE_m3vpss := debug
    endif
    ifneq ($(PLATFORM), ti810x-evm)
    ifeq ($(PROFILE_c6xdsp), )
      PROFILE_c6xdsp := debug
    endif
    endif
    # Default klockwork build flag
    ifeq ($(KW_BUILD), )
      KW_BUILD := no
    endif
    USE_SYSLINK_NOTIFY=0
    XDCPATH = $(bios_PATH)/packages;$(xdc_PATH)/packages;$(ipc_PATH)/packages;$(hdvpss_PATH)/packages;$(fc_PATH)/packages;$(dvr_rdk_PATH);$(syslink_PATH)/packages;$(xdais_PATH)/packages;$(edma3lld_PATH)/packages;
    ifeq ($(PLATFORM),ti816x-evm)
    LSPDIR        := $(TI_SW_ROOT)/linux_lsp/linux-psp-dvr-04.04.00.01/src
    KERNELDIR     := $(LSPDIR)/linux-04.04.00.01
    UBOOTDIR      := $(LSPDIR)/u-boot-04.04.00.01
    endif
    ifeq ($(PLATFORM),ti814x-evm)
    LSPDIR        := $(TI_SW_ROOT)/linux_lsp/TI81XX-LINUX-PSP-04.04.00.01/src
    KERNELDIR     := $(LSPDIR)/kernel/linux-04.04.00.01
    UBOOTDIR      := $(LSPDIR)/u-boot/u-boot-04.04.00.01
    endif
    ifeq ($(PLATFORM),ti810x-evm)
    endif
    ifeq ($(DISABLE_AUDIO), )
      DISABLE_AUDIO := no
    endif
    TREAT_WARNINGS_AS_ERROR=yes
    DVR_RDK_ISS_LIB_PATH=$(dvr_rdk_BASE)/dvr_rdk/mcfw/src_bios6/alg/simcop/lib
    DVR_RDK_ISS_INC_PATH=$(dvr_rdk_BASE)/dvr_rdk/mcfw/src_bios6/alg/simcop/inc
    endif
    RPE_BUILD_VARS = ipc_PATH="${ipc_PATH}" \
    	bios_PATH="${bios_PATH}" \
    	xdc_PATH="${xdc_PATH}" \
    	xdais_PATH="${xdais_PATH}" \
    	syslink_PATH="${syslink_PATH}" \
    	kernel_PATH="${KERNELDIR}" \
    	CODESOURCERY_PATH="${CODEGEN_PATH_A8}" \
    	CGT_ARM_PREFIX="${CSTOOL_PREFIX}" \
    	CODEGEN_PATH_DSP="${CODEGEN_PATH_DSP}" \
    	CODEGEN_PATH_DSPELF="${CODEGEN_PATH_DSP}" \
    	ROOTDIR="${rpe_PATH}" \
    	aaclcdec_PATH="${aaclcdec_PATH}" \
    	aaclcenc_PATH="${aaclcenc_PATH}"
    -include $(ROOTDIR)/makerules/build_config.mk
    -include $(ROOTDIR)/makerules/env.mk
    -include $(ROOTDIR)/makerules/platform.mk
    -include $(dvr_rdk_PATH)/component.mk
    export OS
    export PLATFORM
    export CORE
    export PROFILE_m3vpss
    export PROFILE_m3video
    export PROFILE_c6xdsp
    export CODEGEN_PATH_M3
    export CODEGEN_PREFIX
    export CODEGEN_PATH_A8
    export CODEGEN_PATH_DSP
    export bios_PATH
    export xdc_PATH
    export hdvpss_PATH
    export dvr_rdk_PATH
    export ipc_PATH
    export fc_PATH
    export xdais_PATH
    export h264dec_PATH
    export h264enc_PATH
    export jpegdec_PATH
    export mpeg4dec_PATH
    export jpegenc_PATH
    export hdvicplib_PATH
    export linuxdevkit_PATH
    export edma3lld_PATH
    export ROOTDIR
    export XDCPATH
    export KW_BUILD
    export syslink_PATH
    export KERNELDIR
    export TARGET_FS_DIR
    export UBOOTDIR
    export DVR_RDK_BOARD_TYPE
    export USE_SYSLINK_NOTIFY
    export DEST_ROOT
    export dvr_rdk_BASE
    export TFTP_HOME
    export LINUX_MEM
    export DDR_MEM
    export DISABLE_AUDIO
    export dvrapp_PATH
    export live555_PATH
    export qt_PATH
    export TREAT_WARNINGS_AS_ERROR
    export VS_CARD
    export SC_SCRIPTS_BASE_DIR
    export iss_PATH
    export SYSTEM_SIMCOP_ENABLE
    export SYSTEM_SIMCOP_VIDEOM3
    export DVR_RDK_ISS_LIB_PATH
    export DVR_RDK_ISS_INC_PATH
    export DEMOTYPE
    export rpe_PATH
    export RPE_BUILD_VARS
    export aaclcdec_PATH
    export aaclcenc_PATH
    export mtdutils_PATH
     Here is my bootargs in Uboot.
    bootargs=mem=256M console=ttyO2,115200n8 root=/dev/nfs rw rootfstype=jffs2 nfsroot=10.2.50.113:/home/john/arec/DVRRDK/DVRRDK/DM8168_DVRRDK_V03.00.00.00/target/rfs_816x ip=10.2.50.115:10.2.50.113:10.2.50.254:255.255.255.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBEE00000
    Here I post the logs from boot -> run.sh -> load.sh for your reference.
    UBOOT # boot
    NAND read: device 0 offset 0x280000, size 0x300000
     3145728 bytes read: OK
    VPDMA Firmware Version = 0x4d0001b2
    Connect speed 100M Full
    Using DaVinci EMAC device
    TFTP from server 10.2.50.113; our IP address is 10.2.50.115
    Filename 'uImage_ud816x_dvr'.
    Load address: 0x81000000
    Loading: #################################################################
             #####################################################T ############
    done
    Bytes transferred = 2563260 (0x271cbc)
    ## Booting kernel from Legacy Image at 81000000 ...
       Image Name:   Linux-2.6.37
       Created:      2012-08-21   3:13:02 UTC
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    2563196 Bytes = 2.4 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    OK
    Starting kernel ...
    Linux version 2.6.37 (hwjun@localhost.localdomain) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Tue Aug 21 12:12:53 KST 2012
    CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
    CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Machine: ti8168_dvr
    vram size = 20971520 at 0x0
    reserved size = 20971520 at 0x0
    FB: Reserving 20971520 bytes SDRAM for VRAM
    Memory policy: ECC disabled, Data cache writeback
    OMAP chip is TI8168 2.0
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 59904
    Kernel command line: mem=256M console=ttyO2,115200n8 root=/dev/nfs rw rootfstype=jffs2 nfsroot=10.2.50.113:/home/john/arec/DVRRDK/DVRRDK/DM8168_DVRRDK_V03.00.00.00/target/rfs_816x ip=10.2.50.115:10.2.50.113:10.2.50.254:255.255.255.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBEE00000
    PID hash table entries: 1024 (order: 0, 4096 bytes)
    Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    Memory: 236MB = 236MB total
    Memory: 233884k/233884k available, 28260k reserved, 0K highmem
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
        DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
        vmalloc : 0x90800000 - 0xf8000000   (1656 MB)
        lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
        pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
        modules : 0x7f000000 - 0x7fe00000   (  14 MB)
          .init : 0x80008000 - 0x8003b000   ( 204 kB)
          .text : 0x8003b000 - 0x804d9000   (4728 kB)
          .data : 0x804da000 - 0x80522e40   ( 292 kB)
    SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    NR_IRQS:407
    IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    Total of 128 interrupts on 1 active controller
    GPMC revision 6.0
    Trying to install interrupt handler for IRQ400
    Trying to install interrupt handler for IRQ401
    Trying to install interrupt handler for IRQ402
    Trying to install interrupt handler for IRQ403
    Trying to install interrupt handler for IRQ404
    Trying to install interrupt handler for IRQ405
    Trying to install interrupt handler for IRQ406
    Trying to install type control for IRQ407
    Trying to set irq flags for IRQ407
    OMAP clockevent source: GPTIMER1 at 27000000 Hz
    Console: colour dummy device 80x30
    Calibrating delay loop... 999.42 BogoMIPS (lpj=4997120)
    pid_max: default: 32768 minimum: 301
    Security Framework initialized
    Mount-cache hash table entries: 512
    CPU: Testing write buffer coherency: ok
    devtmpfs: initialized
    omap_voltage_early_init: voltage driver support not added
    regulator: core version 0.5
    regulator: dummy:
    NET: Registered protocol family 16
    omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
    omap_voltage_add_dev: VDD specified does not exist!
    OMAP GPIO hardware version 0.1
    omap_mux_init: Add partition: #1: core, flags: 0
    3-wired eeprom init done. (H/W ver:60)
    _omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
    _omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
    registered ti816x_sr device
    pm_dbg_init: only OMAP3 supported
    registered ti81xx_vpss device
    registered ti81xx_vidout device
    registered ti81xx on-chip HDMI device
    registered ti81xx_fb device
    bio: create slab <bio-0> at 0
    vgaarb: loaded
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    USBSS revision 4ea20809
    registerd cppi-dma Intr @ IRQ 17
    Cppi41 Init Done
    omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
    regulator: pmbus_vr: 800 <--> 1050 mV at 992 mV
    regulator: tps40400 probe done.
    omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
    Advanced Linux Sound Architecture Driver Version 1.0.23.
    Switching to clocksource gp timer
    musb-hdrc: version 6.0, host, debug=0
    musb-hdrc musb-hdrc.0: dma type: dma-cppi41
    MUSB controller-0 revision 4ea20800
    musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: MUSB HDRC host driver
    usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
    usb usb1: SerialNumber: musb-hdrc.0
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    musb-hdrc musb-hdrc.0: USB Host mode controller at 9081e000 using DMA, IRQ 18
    musb-hdrc musb-hdrc.1: dma type: dma-cppi41
    MUSB controller-1 revision 4ea20800
    musb-hdrc musb-hdrc.1: MUSB HDRC host driver
    musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
    usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
    usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb2: Product: MUSB HDRC host driver
    usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
    usb usb2: SerialNumber: musb-hdrc.1
    hub 2-0:1.0: USB hub found
    hub 2-0:1.0: 1 port detected
    musb-hdrc musb-hdrc.1: USB Host mode controller at 90828800 using DMA, IRQ 19
    NET: Registered protocol family 2
    IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    TCP: Hash tables configured (established 8192 bind 8192)
    TCP reno registered
    UDP hash table entries: 256 (order: 0, 4096 bytes)
    UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    NetWinder Floating Point Emulator V0.97 (double precision)
    PMU: registered new PMU device of type 0
    omap-iommu omap-iommu.0: ducati registered
    omap-iommu omap-iommu.1: sys registered
    JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    msgmni has been set to 456
    io scheduler noop registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
    omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    console [ttyO2] enabled
    brd: module loaded
    loop: module loaded
    ahci ahci.0: forcing PORTS_IMPL to 0x3
    ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
    ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc
    scsi0 : ahci_platform
    scsi1 : ahci_platform
    ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
    ata2: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16
    omap2-nand driver initializing
    NAND device: Maf ID: 0xec, Chip ID: 0xda (Samsung, )
     erasesize: 0x20000, writesize: 2048, oobsize: 64
    Creating 6 MTD partitions on "omap2-nand.0":
    0x000000000000-0x000000240000 : "U-Boot"
    0x000000240000-0x000000280000 : "U-Boot Env"
    0x000000280000-0x000000580000 : "U-Boot Logo"
    0x000000580000-0x0000009c0000 : "Kernel"
    0x0000009c0000-0x00000d1e0000 : "File System"
    0x00000d1e0000-0x000010000000 : "Reserved"
    davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
    davinci_mdio davinci_mdio.0: detected phy mask fffffff8
    davinci_mdio.0: probed
    davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
    davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
    davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver unknown
    usbcore: registered new interface driver cdc_ether
    usbcore: registered new interface driver dm9601
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    mice: PS/2 mouse device common for all mice
    usb 2-1: new high speed USB device using musb-hdrc and address 2
    rtc-ds1307 1-0068: rtc core: registered ds1337 as rtc0
    omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc1
    i2c /dev entries driver
    Linux video capture interface: v2.00
    usbcore: registered new interface driver uvcvideo
    USB Video Class driver (v1.0.0)
    OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbee00000
    usbcore: registered new interface driver snd-usb-audio
    Registered tvp5158 audio codec
    asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok
    asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
    asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
    ALSA device list:
      #0: TI81XX SOUND0
      #1: TI81XX SOUND1
    TCP cubic registered
    NET: Registered protocol family 17
    VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    omap_voltage_late_init: Voltage driver support not added
    Power Management for TI81XX.
    smartreflex-ti816x: ti816x_sr_probe done!
    rtc-ds1307 1-0068: setting system clock to 2012-11-21 20:06:01 UTC (1353528361)
    usb 2-1: New USB device found, idVendor=17ef, idProduct=383c
    usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    usb 2-1: Product: USB Flash Drive
    usb 2-1: Manufacturer: Lenovo
    usb 2-1: SerialNumber: BNJ85U5V
    scsi2 : usb-storage 2-1:1.0
    davinci_mdio davinci_mdio.0: resetting idled controller
    net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=1cc914)
    scsi 2:0:0:0: Direct-Access     Lenovo   USB Flash Drive  8.01 PQ: 0 ANSI: 2
    sd 2:0:0:0: Attached scsi generic sg0 type 0
    sd 2:0:0:0: [sda] 3983358 512-byte logical blocks: (2.03 GB/1.89 GiB)
    sd 2:0:0:0: [sda] Write Protect is off
    sd 2:0:0:0: [sda] Assuming drive cache: write through
    IP-Config: Complete:
         device=eth0, addr=10.2.50.115, mask=255.255.255.0, gw=10.2.50.254,
         host=10.2.50.115, domain=, nis-domain=(none),
         bootserver=10.2.50.113, rootserver=10.2.50.113, rootpath=
     sda: sda1
    sd 2:0:0:0: [sda] Attached SCSI removable disk
    PHY: 0:01 - Link is Up - 100/Full
    ata1: SATA link down (SStatus 0 SControl 300)
    ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    ata2.15: Port Multiplier 1.2, 0x197b:0x3215 r0, 5 ports, feat 0x5/0xf
    ata2.00: hard resetting link
    ata2.00: SATA link down (SStatus 0 SControl 320)
    ata2.01: hard resetting link
    ata2.01: SATA link down (SStatus 0 SControl 320)
    ata2.02: hard resetting link
    ata2.02: SATA link down (SStatus 0 SControl 320)
    ata2.03: hard resetting link
    ata2.03: SATA link down (SStatus 0 SControl 320)
    ata2.04: hard resetting link
    ata2.04: SATA link down (SStatus 0 SControl 320)
    ata2: EH complete
    VFS: Mounted root (nfs filesystem) on device 0:15.
    devtmpfs: mounted
    Freeing init memory: 204K
    INIT: version 2.86 booting
    Error opening /dev/fb0: No such file or directory
    Please wait: booting...
    Starting udev
    udevd (85): /proc/85/oom_adj is deprecated, please use /proc/85/oom_score_adj instead.
    udev: starting version 141
    Root filesystem already rw, not remounting
    Caching udev devnodes
    Populating dev cache
    FAT: invalid media value (0x00)
    VFS: Can't find a valid FAT filesystem on dev sda.
    EXT3-fs (sda): error: can't find ext3 filesystem on dev sda.
    EXT2-fs (sda): error: can't find an ext2 filesystem on dev sda.
    ISOFS: Unable to identify CD-ROM format.
    ALSA: Restoring mixer settings...
    EXT3-fs: barriers not enabled
    kjournald starting.  Commit interval 5 seconds
    EXT3-fs (sda1): warning: maximal mount count reached, running e2fsck is recommended
    EXT3-fs (sda1): using internal journal
    EXT3-fs (sda1): mounted filesystem with writeback data mode
    NOT configuring network interfaces: / is an NFS mount
    INIT: Entering runlevel: 5
    Starting system message bus: dbus.
    Starting telnet daemon.
    Starting syslogd/klogd: done
    Starting thttpd.
     _   _ ___  _   _         _
    | | | |    | ||| |___ ___| | _ ___
    | |_| | |) |  ~  | . |  _| |/_|  -|
    |_____|___ /____/ ___|_| |_| _|-__|
    DVR_DM816x Board (2012.08)
    dvr login: root
     _   _ ___  _   _         _
    root@dvr:~#
    root@dvr:~# cd dvr_rdk/ti816x_john/
    root@dvr:~/dvr_rdk/ti816x_john#
    root@dvr:~/dvr_rdk/ti816x_john# ./init.sh
    *** Bootargs Validated for mem param ***
    *** Bootargs Validated for notifyk.vpssm3 params ***
    Kernel bootargs validated
    numid=101,iface=MIXER,name='Left DAC Mux'
      ; type=ENUMERATED,access=rw------,values=1,items=3
      ; Item #0 'DAC_L1'
      ; Item #1 'DAC_L3'
      ; Item #2 'DAC_L2'
      : values=2
    numid=99,iface=MIXER,name='Right DAC Mux'
      ; Item #0 'DAC_R1'
      ; Item #1 'DAC_R3'
      ; Item #2 'DAC_R2'
      : values=2
    SysLink version : 2.10.02.17
    SysLink module created on Date:Oct 31 2012 Time:18:22:41
    Trace enabled
    Trace SetFailureReason enabled
     Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
     Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
     Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
     Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
     *** TVP5158 probe : START ***
     TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
     TI DVR    : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f
     Device found     : I2C (0xXX): 0x08 = 0x51
                        I2C (0xXX): 0x09 = 0x58
     Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5c): 0x08 = 0x51
     I2C (0x5c): 0x09 = 0x58
     I2C (0x5d): 0x08 = 0x51
     I2C (0x5d): 0x09 = 0x58
     I2C (0x5e): 0x08 = 0x51
     I2C (0x5e): 0x09 = 0x58
     I2C (0x5f): 0x08 = 0x51
     I2C (0x5f): 0x09 = 0x58
     *** TVP5158 probe : END ***
    root@dvr:~/dvr_rdk/ti816x_john# ./load.sh
     syslink
    Backtrace:
    r4:00000002
     r7:8deafe28 r6:00000001 r5:8deafd48 r4:908fe000
     r8:8deafe28 r7:8deafe28 r6:00000001 r5:9302e000 r4:90abd000
     r7:00000004 r6:7f0fb920 r5:c014f497 r4:7ebebafc
     r6:00000004 r5:8dcfc480 r4:00000000
     r8:80045f48 r7:00000036 r6:0007e478 r5:c014f497 r4:7ebebafc
    ---[ end trace 869b7a02edb84d01 ]---
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  210: SYSTEM  : System Common Init in progress !!!
     [m3vpss ]  210: SYSTEM: IPC init in progress !!!
     [m3vpss ]  1209: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  2211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  3211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  4211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  5211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  6211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  7211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  8211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  9211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  10211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  11211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  12211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  13211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  14211: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  15211: SYSTEM: Attaching to [DSP] ...
     [m3video]
     [m3video]
     [m3video]  15471: SYSTEM  : System Common Init in progress !!!
     [m3video]  15471: SYSTEM: IPC init in progress !!!
     [m3video]  15471: SYSTEM: Attaching to [HOST] ...
     [m3video]  16471: SYSTEM: Attaching to [HOST] ...
     [m3video]  16473: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [m3video]  16473: SYSTEM: Attaching to [DSP] ...
     [m3video]  17473: SYSTEM: Attaching to [DSP] ...
     [m3video]  18473: SYSTEM: Attaching to [DSP] ...
     [m3video]  19473: SYSTEM: Attaching to [DSP] ...
     [m3video]  20473: SYSTEM: Attaching to [DSP] ...
     [m3video]  21473: SYSTEM: Attaching to [DSP] ...
     [m3video]  22473: SYSTEM: Attaching to [DSP] ...
     [m3video]  23473: SYSTEM: Attaching to [DSP] ...
     [m3video]  24473: SYSTEM: Attaching to [DSP] ...
     [m3video]  25473: SYSTEM: Attaching to [DSP] ...
     [m3video]  26473: SYSTEM: Attaching to [DSP] ...
     [m3video]  27473: SYSTEM: Attaching to [DSP] ...
     [m3video]  28473: SYSTEM: Attaching to [DSP] ...
     [m3video]  29473: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]
     [c6xdsp ]
     [c6xdsp ]  1012: SYSTEM: Attaching to [HOST] ...
     [c6xdsp ]  1015: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [c6xdsp ]  1015: SYSTEM: Attaching to [VIDEO-M3] ...
     [m3video]  30473: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  2021: SYSTEM: Attaching to [VIDEO-M3] ...
     [c6xdsp ]  2513: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [m3video]  31473: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  2513: SYSTEM: Attaching to [VPSS-M3] ...
     [m3video]  31473: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [m3video]  31473: SYSTEM: Attaching to [VPSS-M3] ...
     [m3vpss ]  32212: SYSTEM: Attaching to [DSP] ...
    DRV: Module built on Nov 12 2012 09:38:53
     [m3video]  32473: SYSTEM: Attaching to [VPSS-M3] ...
     [c6xdsp ]  3520: SYSTEM: Attaching to [VPSS-M3] ...
     [c6xdsp ]  4252: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3vpss ]  33212: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  4252: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3vpss ]  33212: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [m3vpss ]  33212: SYSTEM: Attaching to [VIDEO-M3] ...
     [m3video]  33473: SYSTEM: Attaching to [VPSS-M3] ...
     [c6xdsp ]  5259: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3video]  34212: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3vpss ]  34212: SYSTEM: Attaching to [VIDEO-M3] ...
     [c6xdsp ]  5259: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
     [m3video]  34212: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3vpss ]  34212: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [c6xdsp ]  5259: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
     [m3video]  34212: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  34212: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [c6xdsp ]  5260: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3video]  34213: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
     [m3vpss ]  34212: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
     [c6xdsp ]  5260: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [m3video]  34214: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3vpss ]  34212: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
     [c6xdsp ]  5260: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [m3video]  34214: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3vpss ]  34214: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [c6xdsp ]  5260: SYSTEM: IPC init DONE !!!
     [m3video]  34214: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [m3vpss ]  34214: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3video]  34215: SYSTEM: IPC init DONE !!!
     [m3vpss ]  34214: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [m3video]  34220: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
     [m3vpss ]  34214: SYSTEM: IPC init DONE !!!
     [m3video]  34220: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
     [m3vpss ]  34220: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
     [m3vpss ]  34220: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
     [c6xdsp ]  5262: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
     [m3video]  34222: SYSTEM  : System Common Init Done !!!
     [m3vpss ]  34222: SYSTEM  : System Common Init Done !!!
     [c6xdsp ]  5262: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
     [m3video]  34222: SYSTEM  : System Video Init in progress !!!
     [m3vpss ]  34222: SYSTEM  : System VPSS Init in progress !!!
     [c6xdsp ]  5262: SYSTEM  : System Common Init Done !!!
     [m3video]  34222: SYSTEM  : System Video Init Done !!!
     [m3vpss ]  34222: SYSTEM: All VPDMA Free !!!
     [c6xdsp ]  5220: SYSTEM  : System DSP Init in progress !!!
     [m3video]  34223: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
     [c6xdsp ]  5220: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
     [m3video]  34223: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
     [c6xdsp ]  5265: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
     [m3video]  34223: SYSTEM: ListElem Shared Addr = 0xbf18b680
     [c6xdsp ]  5265: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
     [m3video]  34225: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
     [c6xdsp ]  5265: SYSTEM: ListElem Shared Addr = 0xbf18ee80
     [m3video]  34225: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
     [m3vpss ]  34227: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
     [c6xdsp ]  5266: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
     [m3video]  34225: SYSTEM: ListElem Shared Addr = 0xbf1ae580
     [m3vpss ]  34227: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
     [c6xdsp ]  5266: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
     [m3video]  34230: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
     [m3vpss ]  34227: SYSTEM: ListElem Shared Addr = 0xbf1f1100
     [c6xdsp ]  5266: SYSTEM: ListElem Shared Addr = 0xbf1b1a80
     [m3video]  34231: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
     [m3vpss ]  34229: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
     [c6xdsp ]  5267: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
     [m3video]  34231: SYSTEM: ListElem Shared Addr = 0xbf232e80
     [m3vpss ]  34229: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
     [c6xdsp ]  5267: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
     [m3video]  34233: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
     [m3vpss ]  34230: SYSTEM: ListElem Shared Addr = 0xbf22f980
     [c6xdsp ]  5267: SYSTEM: ListElem Shared Addr = 0xbf1d1480
     [m3video]  34233: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
     [m3vpss ]  34241: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
     [c6xdsp ]  5268: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
     [m3video]  34233: SYSTEM: ListElem Shared Addr = 0xbf252880
     [m3vpss ]  34241: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
     [c6xdsp ]  5268: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
     [m3video]  34236: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
     [m3vpss ]  34241: SYSTEM: ListElem Shared Addr = 0xbf291c80
     [c6xdsp ]  5268: SYSTEM: ListElem Shared Addr = 0xbf1f4380
     [m3video]  34236: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
     [m3vpss ]  34243: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
     [c6xdsp ]  5268: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
     [m3video]  34236: SYSTEM: ListElem Shared Addr = 0xbf272280
     [m3vpss ]  34243: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
     [c6xdsp ]  5268: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
     [m3video]  34246: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
     [m3vpss ]  34243: SYSTEM: ListElem Shared Addr = 0xbf2b1680
     [c6xdsp ]  5268: SYSTEM: ListElem Shared Addr = 0xbf211e80
     [m3video]  34246: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
     [m3vpss ]  34245: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
     [c6xdsp ]  5226: SYSTEM  : Initializing Links !!!
     [m3video]  34247: SYSTEM: ListElem Shared Addr = 0xbf2f0a80
     [m3vpss ]  34246: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
     [m3video]  34248: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
     [m3vpss ]  34246: SYSTEM: ListElem Shared Addr = 0xbf2d1080
     [c6xdsp ]  5269: SYSTEM  : FREE SPACE : System Heap      = 10268448 B, Mbx = 10240 msgs)
     [m3video]  34249: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
     [m3vpss ]  34247: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
     [m3video]  34249: SYSTEM: ListElem Shared Addr = 0xbf30e580
     [m3vpss ]  34248: SYSTEM  : FVID2 Init in progress !!!
     [c6xdsp ]  5235: SYSTEM  : Initializing Links ... DONE !!!
     [m3video]  34250: HDVICP: Doing PRCM for IVAHD[0] ...
     [m3vpss ]  34331: SYSTEM  : FVID2 Init in progress DONE !!!
     [m3video]  34251: HDVICP: PRCM for IVAHD[0] ... DONE.
     [m3vpss ]  34331: SYSTEM  : Device Init in progress !!!
     [c6xdsp ]  5236: SYSTEM  : System DSP Init Done !!!
     [m3video]  34251: HDVICP: Doing PRCM for IVAHD[1] ...
     [m3video]  34251: HDVICP: PRCM for IVAHD[1] ... DONE.
     [m3video]  34251: HDVICP: Doing PRCM for IVAHD[2] ...
     [m3video]  34251: HDVICP: PRCM for IVAHD[2] ... DONE.
     [m3video]  34251: SYSTEM  : Initializing Links !!!
     [m3vpss ]  34334: SYSTEM  : Device Init in progress DONE !!!
     [m3vpss ]  34451: SYSTEM  : System VPSS Init Done !!!
     [m3video]  34251: SYSTEM  : FREE SPACE : System Heap      = 6280232 B, Mbx = 10240 msgs)
     [m3vpss ]  34452: UTILS: DMA: HWI Create for INT63 !!!
     [m3vpss ]  34452: SYSTEM  : Initializing Links !!!
     [m3video]  34252: SYSTEM  : FREE SPACE : SR0 Heap         = 13452672 B (12 MB)
     [m3vpss ]  34452: SYSTEM  : FREE SPACE : System Heap      = 13024 B, Mbx = 10240 msgs)
     [m3video]  34252: SYSTEM  : FREE SPACE : Frame Buffer     = 245104512 B (233 MB)
     [m3vpss ]  34452: SYSTEM  : FREE SPACE : SR0 Heap         = 13452672 B (12 MB)
     [m3video]  34252: SYSTEM  : FREE SPACE : Bitstream Buffer = 352321408 B (335 MB)
     [m3vpss ]  34452: SYSTEM  : FREE SPACE : Frame Buffer     = 240794496 B (229 MB)
     [m3video]  34252: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3video]  34253: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
     [m3vpss ]  34452: SYSTEM  : FREE SPACE : Bitstream Buffer = 352321408 B (335 MB)
     [m3video]  34253: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
     [m3vpss ]  34453: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
     [m3video]  34281: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ]  34453: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
     [m3vpss ]  34551: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ]  34552: SYSTEM  : Set Static L3 pressure for HDVPSS as High
    HDMI W1 rev 2.0
     ORG 0x46c00524: 0
     NEW 0x46c00524: 2
    It seems takes long time in the below step when load firmware.
    Hope the informations could help.
    If any other information or logs are needed, just let me know.
    - JohnWang
    Regards.
  • Looks like you have changed DDR_MEM=.Can you set it back to 1024M and try.Make sure you clean,delete dvr_rdk/build and dvr_rdk/lib folder and re-build and also make sure to delete /target/rfs_816x/opt/dvr_rdk/ti816x folder before trying with new binaries.
  • OK, I'll try it and report the result ASAP.
    Do you mean rebuild all? (I mean @ make -s sys_all )
    Or only rebuild firmware is okay?
  • Rebuild firmware
    rm -rf target/rfs_816x/opt/dvr_rdk/ti816x
    rm -rf bin/ti816x/firmware
    rm -rf bin/ti816x/env*.sh
    rm -rfv build
    rm -rfv lib
    make clean
    Modify Rules.make
    make dvr_rdk
  • Hello, Badri
           The problem is resolved by modifying the DDM_MEM back to 1024M.
           I really appreciate it.
           But, one question comes to my mind.
           I currently have 2G DDR RAM installed physically in my DVRRDM box.
           Why we need to set the DDR_MEM to 1024M in building procedure?
           Sorry I don't have much idea about this, can you explain it in more detailed?
           Will 1G RAM be wasted in 1024M setting?
  • The 1GB from 0xC000_0000 to 0xFFFF_FFFF is available for linux .You can use it by setting mem=512M@0xC0000000 in your kernel bootargs. For using the 2G for video frame buffers you need to use the 2G build configuration. Can you share the config_2G.bld file in your codebase. I want to check if there is any issue with the memory map.
  • Hello, Badri
    OK, here is the config_2G.bld in my codebase for your reference.
     *  ======== config.bld ========
     *  Build configuration script for HDVPSS drivers
    /* load the required modules for the configuration */
    var M3 = xdc.useModule('ti.targets.arm.elf.M3');
    var C674 = xdc.useModule('ti.targets.elf.C674');
    var buildReleaseConfig = true;
    /* configure  the options for the M3 targets     */
    /* M3 compiler directory path                    */
    M3.rootDir = java.lang.System.getenv("CGTOOLS");
    /* linker options */
    M3.lnkOpts.suffix += " --zero_init=off ";
    M3.lnkOpts.suffix += " --dynamic --retain=_Ipc_ResetVector";
    /* compiler options                                */
    M3.ccOpts.suffix += " --gcc -DTI_816X_BUILD -DPLATFORM_EVM_SI -DSYSLINK_BUILD_RTOS -DUSE_SYSLINK_NOTIFY=0 -DUTILS_ASSERT_ENABLE";
    /* set default platform and list of all interested
     * platforms for M3
    M3.platforms = [
                            "ti.platforms.evmTI816X:core0",
                            "ti.platforms.evmTI816X:core1",
    /* Select the default platform
     * Making core1 as defualt core configuration to be used
     *  Core 0 ==    Ducati.M3.VIDEO
     *  Core 1 ==    Ducati.M3.VPS
    M3.platform = M3.platforms[1];
    /* configure  the options for the C674 targets     */
    /* C674 compiler directory path                    */
    C674.rootDir = java.lang.System.getenv("CGTOOLS_DSP");
    C674.lnkOpts.suffix += " --zero_init=off ";
    C674.lnkOpts.suffix += " --dynamic --retain=_Ipc_ResetVector";
    C674.ccOpts.suffix += " -DTI_816X_BUILD -DPLATFORM_EVM_SI -DSYSLINK_BUILD_RTOS -DUSE_SYSLINK_NOTIFY=0";
    C674.platforms = ["ti.platforms.evmTI816X:plat"];
    C674.platform = C674.platforms[0];
    /* list interested targets in Build.targets array  */
    Build.targets = [
                        M3,
                        C674,
    var KB=1024;
    var MB=KB*KB;
    var DDR3_ADDR;
    var DDR3_SIZE;
    var OCMC0_ADDR;
    var OCMC1_ADDR;
    var OCMC_SIZE;
    var LINUX_ADDR;
    var LINUX_SIZE;
    var SR0_ADDR;
    var SR0_SIZE;
    var SR1_ADDR;
    var SR1_SIZE;
    var SR3_INTRADUCATI_IPC_ADDR;
    var SR3_INTRADUCATI_IPC_SIZE;
    var VIDEO_M3_CODE_ADDR;
    var VIDEO_M3_CODE_SIZE;
    var VIDEO_M3_DATA_ADDR;
    var VIDEO_M3_DATA_SIZE;
    var SR2_FRAME_BUFFER_ADDR;
    var SR2_FRAME_BUFFER_SIZE;
    var DSS_M3_CODE_ADDR;
    var DSS_M3_CODE_SIZE;
    var DSS_M3_DATA_ADDR;
    var DSS_M3_DATA_SIZE;
    var DSP_CODE_ADDR;
    var DSP_CODE_SIZE;
    var DSP_M3_DATA_ADDR;
    var DSP_M3_DATA_SIZE;
    var TILER_ADDR;
    var TILER_SIZE;
    var HDVPSS_DESC_ADDR;
    var HDVPSS_DESC_SIZE;
    var HDVPSS_SHARED_ADDR;
    var HDVPSS_SHARED_SIZE;
    var NOTIFY_SHARED_ADDR;
    var NOTIFY_SHARED_SIZE;
    var REMOTE_DEBUG_ADDR;
    var REMOTE_DEBUG_SIZE;
    DDR3_ADDR                  = 0x80000000;
    DDR3_SIZE                  = 2048*MB;
    OCMC0_ADDR                 = 0x40300000;
    OCMC1_ADDR                 = 0x40400000;
    OCMC0_RUN_ADDR             = 0x00300000;
    OCMC1_RUN_ADDR             = 0x00400000;
    OCMC_SIZE                  = 256*KB;
    L2_SRAM_ADDR               = 0x55024000;
    L2_SRAM_SIZE               = 128*KB;
    L2_SRAM_RUN_ADDR           = 0x20004000;
    DUCATI_WB_WA_ADDR          = 0x20000000;
    /* first 512MB */
    LINUX_SIZE                 = 128*MB;
    SR1_SIZE                   = 336*MB;
    SR3_INTRADUCATI_IPC_SIZE   =          124*KB;
    VIDEO_M3_CODE_SIZE         =  2*MB  + 512*KB;
    VIDEO_M3_BSS_SIZE          =  9*MB  + 512*KB;
    VIDEO_M3_DATA_SIZE         =  2*MB  + 512*KB;
    DSS_M3_CODE_SIZE           =  1*MB  + 512*KB;
    DSS_M3_BSS_SIZE            = 11*MB  + 512*KB;
    DSS_M3_DATA_SIZE           =  5*MB  + 512*KB;
    DSP_CODE_SIZE              =  1*MB;
    DSP_DATA_SIZE              = 13*MB  + 900*KB;
    /* second 512MB */
    /* Tiler Buffers in the bottom 512MB */
    TILER_SIZE                  = 256*MB; /* (128+128) - MUST be aligned on 128MB boundary */
    SR2_FRAME_BUFFER_SIZE       = 234*MB - 256*KB;
    SR0_SIZE                    = 15*MB;
    VIDEO_M3_EXCEPTION_CTX_SIZE = 128*KB;
    VPSS_M3_EXCEPTION_CTX_SIZE  = 128*KB;
    HDVPSS_DESC_SIZE            = 2*MB;
    HDVPSS_SHARED_SIZE          = 2*MB;
    NOTIFY_SHARED_SIZE          = 2*MB;
    REMOTE_DEBUG_SIZE           = 1*MB;
    /* third and fourth 512 MB */
    LINUX_SIZE_SEGMENT2        = 1024*MB;
    print ("Memory Map - 2GB DDR, > 1GB Linux in 2 segments");
    print ("  0x80000000     +-------------------+");
    print ("         ^       |                   |");
    print ("         |       |  " + (LINUX_SIZE / MB) + " MB           | Linux");
    print ("         |       |                   |");
    print ("         |       +-------------------+");
    print ("         |       |  " + (SR1_SIZE / MB) + "MB          | (SR1) Bitstream buffer");
    print ("         |       |                   | Cached on A8. Cached on M3, although access by DMAs");
    print ("         |       +-------------------+ ");
    print ("         |       |   " + (SR3_INTRADUCATI_IPC_SIZE / KB) + " KB          | (SR3)InterDucati IPC ListMP .Cached on M3 ");
    print ("         +       |   " + (VIDEO_M3_CODE_SIZE / MB) + " MB          | Video M3 Code");
    print ("       512 MB    +-------------------+");
    print ("         +       |   " + (VIDEO_M3_BSS_SIZE / MB) + " MB         | Video M3 BSS");
    print ("         |       |   " + (VIDEO_M3_DATA_SIZE / MB) + " MB          | Video  M3 Data");
    print ("         |       |   " + (DSS_M3_CODE_SIZE/ MB) + " MB          | VPSS  M3 Code");
    print ("         |       |   " + (DSS_M3_BSS_SIZE/ MB) + " MB         | VPSS  M3 BSS");
    print ("         |       |   " + (DSS_M3_DATA_SIZE/ MB) + " MB           | VPSS  M3 Data");
    print ("         |       |   " + ( DSP_CODE_SIZE / KB) + " KB          | DSP Code");
    print ("         v       |   " + (DSP_DATA_SIZE / MB) + " MB         | DSP Data");
    print ("  0xA0000000     +-------------------+");
    print ("         ^       |   " + (TILER_SIZE / MB) + " MB          | Tiled 8-bit + 16-bit region");
    print ("         |       |  " + (SR2_FRAME_BUFFER_SIZE / MB) + " MB        | (SR2) Frame Buffer Region - <VPSS - Video M3 Frame Buf>");
    print ("         +       |                   |");
    print ("       512 MB    |  " + (SR0_SIZE / MB) + " MB            | (SR0) Syslink MsgQ/IPC List MP - <Non-cached on M3>");
    print ("         +       +-------------------+");
    print ("         |       |  " + (VIDEO_M3_EXCEPTION_CTX_SIZE / KB) + " KB           | Video M3 exception context");
    print ("         |       |  " + (VPSS_M3_EXCEPTION_CTX_SIZE / KB) + "KB            | Vpss M3 exception context");
    print ("         |       |  " + (HDVPSS_DESC_SIZE / MB) + " MB             | VPSS M3 - VPDMA Descriptor");
    print ("         |       |  " + (HDVPSS_SHARED_SIZE / MB) + " MB             | VPSS M3 - FBDev Shared Memory");
    print ("         |       |  " + (NOTIFY_SHARED_SIZE / MB) + " MB             | Host - VPSS M3 Notify(For FBDev)");
    print ("         v       |  " + (REMOTE_DEBUG_SIZE / MB) + " MB             | Remote Debug Print");
    print ("   0xC0000000    +-------------------+");
    print ("         ^       |                   |");
    print ("         |       |                   |");
    print ("         |       |  " + (LINUX_SIZE_SEGMENT2 / MB) + " MB          | Memory for Linux Kernel");
    print ("         |       |                   |" + " Available only in split of linux kernel");
    print ("         |       |                   |");
    print ("         v       |                   |");
    print ("   0xFFFFFFFF    +-------------------+");
    /* first 512MB */
    LINUX_ADDR                 = DDR3_ADDR;
    SR1_ADDR                   = LINUX_ADDR						 + LINUX_SIZE;
    SR3_INTRADUCATI_IPC_ADDR   = SR1_ADDR						 + SR1_SIZE;
    VIDEO_M3_CODE_ADDR         = SR3_INTRADUCATI_IPC_ADDR		 + SR3_INTRADUCATI_IPC_SIZE;
    VIDEO_M3_DATA_ADDR         = VIDEO_M3_CODE_ADDR				 + VIDEO_M3_CODE_SIZE;
    VIDEO_M3_BSS_ADDR          = VIDEO_M3_DATA_ADDR				 + VIDEO_M3_DATA_SIZE;
    VIDEO_M3_BSS_MAPPED_ADDR   = (VIDEO_M3_BSS_ADDR - DDR3_ADDR) + DUCATI_WB_WA_ADDR;
    DSS_M3_CODE_ADDR           = VIDEO_M3_BSS_ADDR				 + VIDEO_M3_BSS_SIZE;
    DSS_M3_DATA_ADDR           = DSS_M3_CODE_ADDR				 + DSS_M3_CODE_SIZE;
    DSS_M3_BSS_ADDR            = DSS_M3_DATA_ADDR				 + DSS_M3_DATA_SIZE;
    DSS_M3_BSS_MAPPED_ADDR     = (DSS_M3_BSS_ADDR - DDR3_ADDR)	 + DUCATI_WB_WA_ADDR;
    DSP_CODE_ADDR              = DSS_M3_BSS_ADDR				 + DSS_M3_BSS_SIZE;
    DSP_DATA_ADDR              = DSP_CODE_ADDR					 + DSP_CODE_SIZE;
    /* second 512MB */
    TILER_ADDR                  = DDR3_ADDR						+ DDR3_SIZE/4;
    SR2_FRAME_BUFFER_ADDR       = TILER_ADDR					+ TILER_SIZE;
    VIDEO_M3_EXCEPTION_CTX_ADDR = SR2_FRAME_BUFFER_ADDR			+ SR2_FRAME_BUFFER_SIZE;
    VPSS_M3_EXCEPTION_CTX_ADDR  = VIDEO_M3_EXCEPTION_CTX_ADDR	+ VIDEO_M3_EXCEPTION_CTX_SIZE;
    HDVPSS_DESC_ADDR            = VPSS_M3_EXCEPTION_CTX_ADDR	+ VPSS_M3_EXCEPTION_CTX_SIZE;
    HDVPSS_SHARED_ADDR          = HDVPSS_DESC_ADDR				+ HDVPSS_DESC_SIZE;
    NOTIFY_SHARED_ADDR          = HDVPSS_SHARED_ADDR			+ HDVPSS_SHARED_SIZE;
    REMOTE_DEBUG_ADDR           = NOTIFY_SHARED_ADDR			+ NOTIFY_SHARED_SIZE;
    SR0_ADDR                    = REMOTE_DEBUG_ADDR			    + REMOTE_DEBUG_SIZE;
    if ((DSP_DATA_ADDR + DSP_DATA_SIZE) > TILER_ADDR)
      throw xdc.$$XDCException("MEMORY_MAP OVERFLOW ERROR ",
                               "\nRegion End: " + "0x" + java.lang.Long.toHexString(TILER_ADDR) +
                               "\nActual End: " + "0x" + java.lang.Long.toHexString(DSP_DATA_ADDR + DSP_DATA_SIZE ));
    if ((SR0_ADDR + SR0_SIZE) > DDR3_ADDR + DDR3_SIZE/2)
                               "\nRegion End: " + "0x" + java.lang.Long.toHexString(DDR3_ADDR + DDR3_SIZE) +
                               "\nActual End: " + "0x" + java.lang.Long.toHexString(SR0_ADDR + SR0_SIZE)
    Build.platformTable["ti.platforms.evmTI816X:core1"] =
        externalMemoryMap:
            ["DDR3_RAM", {
                comment: "DDR3_RAM",
                base: DDR3_ADDR,
                len:  DDR3_SIZE
            ["OCMC1_RAM", {
                comment: "OCMC1_RAM",
                base: OCMC1_ADDR,
                len:  OCMC_SIZE
            ["VIDEO_M3_BSS_MAPPED_MEM", {
                comment : "VIDEO_M3_BSS_MAPPED_MEM",
                base    : VIDEO_M3_BSS_MAPPED_ADDR,
                len     : VIDEO_M3_BSS_SIZE
            ["DSS_M3_BSS_MAPPED_MEM", {
                comment : "DSS_M3_BSS_MAPPED_MEM",
                base    : DSS_M3_BSS_MAPPED_ADDR,
                len     : DSS_M3_BSS_SIZE
        customMemoryMap:
            ["LINUX_MEM", {
                comment : "LINUX_MEM",
                base    : LINUX_ADDR,
                len     : LINUX_SIZE
            ["SR1", {
                comment : "SR1",
                base    : SR1_ADDR,
                len     : SR1_SIZE
            ["SR3_INTRADUCATI_IPC", {
                comment : "SR3_INTRADUCATI_IPC",
                base    : SR3_INTRADUCATI_IPC_ADDR,
                len     : SR3_INTRADUCATI_IPC_SIZE
            ["VIDEO_M3_CODE_MEM", {
                comment : "VIDEO_M3_CODE_MEM",
                base    : VIDEO_M3_CODE_ADDR,
                len     : VIDEO_M3_CODE_SIZE
            ["VIDEO_M3_DATA_MEM", {
                comment : "VIDEO_M3_DATA_MEM",
                base    : VIDEO_M3_DATA_ADDR,
                len     : VIDEO_M3_DATA_SIZE
            ["VIDEO_M3_BSS_MEM", {
                comment : "VIDEO_M3_BSS_MEM",
                base    : VIDEO_M3_BSS_ADDR,
            ["DSS_M3_CODE_MEM", {
                comment : "DSS_M3_CODE_MEM",
                base    : DSS_M3_CODE_ADDR,
                len     : DSS_M3_CODE_SIZE
            ["DDR3_M3", {
                comment : "DDR3_M3",
                base    : DSS_M3_DATA_ADDR,
                len     : DSS_M3_DATA_SIZE
            ["DSS_M3_BSS_MEM", {
                comment : "DSS_M3_BSS_MEM",
                base    : DSS_M3_BSS_ADDR,
            ["DSP_CODE_MEM", {
                comment : "DSP_CODE_MEM",
                base    : DSP_CODE_ADDR,
                len     : DSP_CODE_SIZE
            ["DSP_DATA_MEM", {
                comment : "DSP_DATA_MEM",
                base    : DSP_DATA_ADDR,
                len     : DSP_DATA_SIZE
            ["TILER_MEM", {
                comment : "TILER_MEM",
                base    : TILER_ADDR,
                len     : TILER_SIZE
            ["SR2_FRAME_BUFFER_MEM", {
                comment : "SR2_FRAME_BUFFER_MEM",
                base    : SR2_FRAME_BUFFER_ADDR,
                len     : SR2_FRAME_BUFFER_SIZE
            ["SR0", {
                comment : "SR0",
                base    : SR0_ADDR,
                len     : SR0_SIZE
            ["VIDEO_M3_EXCEPTION_CTX", {
                comment : "VIDEO_M3_EXCEPTION_CTX",
                base    : VIDEO_M3_EXCEPTION_CTX_ADDR,
                len     : VIDEO_M3_EXCEPTION_CTX_SIZE
            ["VPSS_M3_EXCEPTION_CTX", {
                comment : "VPSS_M3_EXCEPTION_CTX",
                base    : VPSS_M3_EXCEPTION_CTX_ADDR,
                len     : VPSS_M3_EXCEPTION_CTX_SIZE
            ["HDVPSS_DESC_MEM", {
                comment : "HDVPSS_DESC_MEM",
                base    : HDVPSS_DESC_ADDR,
                len     : HDVPSS_DESC_SIZE
            ["HDVPSS_SHARED_MEM", {
                comment : "HDVPSS_SHARED_MEM",
                base    : HDVPSS_SHARED_ADDR,
                len     : HDVPSS_SHARED_SIZE
            ["HOST_VPSS_NOTIFYMEM", {
                comment : "HOST_VPSS_NOTIFYMEM",
                base    : NOTIFY_SHARED_ADDR,
                len     : NOTIFY_SHARED_SIZE
            ["REMOTE_DEBUG_MEM", {
                comment : "REMOTE_DEBUG_MEM",
                base    : REMOTE_DEBUG_ADDR,
                len     : REMOTE_DEBUG_SIZE
            ["L2_ROM", {
                comment: "L2_ROM",
                base: 0x00000000,
                len:  0x00004000
            ["OCMC1_RAM", {
                base: OCMC1_ADDR,
                len:  OCMC_SIZE
            ["OCMC1_RAM_MAPPED", {
                base: OCMC1_RUN_ADDR,
                len:  OCMC_SIZE
    Build.platformTable["ti.platforms.evmTI816X:core0"] =
        externalMemoryMap:
            ["DDR3_RAM", {
                base: DDR3_ADDR,
                len:  DDR3_SIZE
            ["OCMC0_RAM", {
                comment: "OCMC0_RAM",
                base: OCMC0_ADDR,
                len:  OCMC_SIZE
            ["L2_SRAM", {
                comment: "L2_SRAM",
                base: L2_SRAM_ADDR,
                len:  L2_SRAM_SIZE
            ["L2_SRAM_RUN", {
                comment: "L2_SRAM_RUN",
                base: L2_SRAM_RUN_ADDR,
                len:  L2_SRAM_SIZE
        customMemoryMap:
            ["LINUX_MEM", {
                base    : LINUX_ADDR,
                len     : LINUX_SIZE
            ["SR1", {
                comment : "SR1",
                base    : SR1_ADDR,
                len     : SR1_SIZE
            ["DDR_M3", {
            ["DSS_M3_DATA_MEM", {
                comment : "DSS_M3_DATA_MEM",
            ["DSP_CODE_MEM", {
                len     : DSP_CODE_SIZE
            ["DSP_DATA_MEM", {
                len     : DSP_DATA_SIZE
            ["TILER_MEM", {
                base    : TILER_ADDR,
                len     : TILER_SIZE
            ["SR0", {
                comment : "SR0",
                base    : SR0_ADDR,
                len     : SR0_SIZE
            ["L2_SRAM", {
                comment: "L2_SRAM",
                base: L2_SRAM_ADDR,
                len:  L2_SRAM_SIZE
            ["L2_SRAM_RUN", {
                len:  L2_SRAM_SIZE
            ["L2_ROM", {
                comment: "L2_ROM",
                base: 0x00000000,
                len:  0x00004000
            ["OCMC0_RAM", {
                base: OCMC0_ADDR,
                len:  OCMC_SIZE
            ["OCMC0_RAM_MAPPED", {
                base: OCMC0_RUN_ADDR,
                len:  OCMC_SIZE
    Build.platformTable["ti.platforms.evmTI816X:plat"] =
        externalMemoryMap:
            ["DDR3_RAM", {
                base: DDR3_ADDR,
                len:  DDR3_SIZE
            ["OCMC0_RAM", {
                base: OCMC0_ADDR,
                len:  OCMC_SIZE
            ["OCMC1_RAM", {
                base: OCMC1_ADDR,
                len:  OCMC_SIZE
        customMemoryMap:
            ["LINUX_MEM", {
                base    : LINUX_ADDR,
                len     : LINUX_SIZE
            ["SR1", {
                comment : "SR1",
                base    : SR1_ADDR,
                len     : SR1_SIZE
            ["DSP_CODE_MEM", {
                len     : DSP_CODE_SIZE
            ["DSP_DATA_MEM", {
                comment : "DDR3_DSP",
                len     : DSP_DATA_SIZE
            ["TILER_MEM", {
                base    : TILER_ADDR,
                len     : TILER_SIZE
            ["SR0", {
                comment : "SR0",
                base    : SR0_ADDR,
                len     : SR0_SIZE
            ["OCMC0_RAM", {
                base: OCMC0_ADDR,
                len:  OCMC_SIZE
            ["OCMC1_RAM", {
                base: OCMC1_ADDR,
                len:  OCMC_SIZE
            ["DSP_L2_RAM", {
                comment: "DSP_L2_RAM",
                base: 0x10800000,
                len:  0x00020000
        l1PMode: "32k",
        l1DMode: "32k",
        l2Mode:  "128k"
    var addrFileGenerated = false;
    if (addrFileGenerated == false)
        xdc.loadCapsule("genaddrinfo.xs").GenAddrFile();
        addrFileGenerated = true;
    I saw LINUX_SIZE = 128*MB and LINUX_SIZE_SEGMENT2 = 1024*MB in config_2G.bld.
    What does it mean? Per my understanding, the available memory size for Linux is 256MB or 512MB depends on bootargs setting. Do I misunderstand it?
    "For using the 2G for video frame buffers". what does it exactly mean?
    Sorry for many questions and appreciate for your advise.
  • If you are using config_2G you should set your mem=128M in the kernel bootargs.I beleive this was the reason for the crash  you were seeing.THis should have been flagged as error when running init.sh which validates the kernel bootargs.Are you always deleting your target/opt/dvr_rdk/ti816x and copying from the dvr_rdk/../target/rfs_816x/opt/dvr_rdk/ti816x folder.
    There are couple of ways you can use 2G of memory:
    1. Use the regular 1G memory map and use the remaining 1G for your linux application.
    2. Use 2G  RDK memory map which allocates more memory for video frame buffers. This enables you to create new usecases which require more memory than what can fit in standard 1G memory map.For example if you want to create 16 ch 1080P decode channels
  • Hello, Badri
    In the  two ways you mentioned, please correct me as below:
        Step 1: Set DDR_MEM := DDR_MEM_1024M in Rules.make
        Step 2: Set mem=256M in bootargs.
        With these above two steps,  config_1G_256MLinux.bld will be adopted for memory mapping, right?
         What additional step do I need to use remaining 1G for my LInux application?
        Step 1: Set DDR_MEM := DDR_MEM_2048M in Rules.make
        Step 2: Set mem=128M in bootargs
        Is it correct & do I miss any step?
        With above 2G settings, How many memory are allocated for Linux kernel and application ?
    Best regards.
  • 1. Use the regular 1G memory map and use the remaining 1G for your linux application Step 1: Set DDR_MEM := DDR_MEM_1024M in Rules.make Step 2: Set mem=256M in bootargs. With these above two steps, config_1G_256MLinux.bld will be adopted for memory mapping, right? What additional step do I need to use remaining 1G for my LInux application?
       -- Yes that is correct. Additionally in your kernel bootargs set mem=128M mem=512M@0xC0000000
      - Yes that is correct. Memory for linux is 128M + 768M
  • Hello, Badri
            Thanks. It's really help.
            Few confusion as below:
          => Sorry I get a little bit confused. is mem=128M a typo?
        => I saw LINUX_SIZE = 128MBLINUX_SIZE_SEGMENT2 = 1024MB in config_2G.bld
             That's why I guess Memory for linux is 128M+1024M.  Why it's 128M+768M ?
    Best regards.
  • Sorry I get a little bit confused. is mem=128M a typo?
      - No this is not typo. In linux PSP that is shipped with RDK 3.0, the linux kernel should start at physical address 0x8000_0000.There is an option to have an additional linux memory segment by specifying mem=<memory_size>@<physical_start_address> so mem=128M mem=512M@0xC0000000 means allocate 128M for linux starting at 0x8000_0000 and additionally allocate 512M at 0xC000_0000 for linux.
      - You are right.
  • No this is not typo. In linux PSP that is shipped with RDK 3.0, the linux kernel should start at physical address 0x8000_0000.There is an option to have an additional linux memory segment by specifying mem=<memory_size>@<physical_start_address> so mem=128M mem=512M@0xC0000000 means allocate 128M for linux starting at 0x8000_0000 and additionally allocate 512M at 0xC000_0000 for linux.
    In config_1G_256MLinux.bld, LINUX_SIZE = 256MB.
    So, I need to set mem=256M mem=512M@0xC0000000 in bootargs, right?
  • Yes that is right
  • Hello, Badri
          Now I totally understand. Thanks for your patient advise.
          I'll try to use 2G configuration now.
          In our last discussion, Is it legal to set additional linux memory segment to 1024M?
          ie:  mem=256M mem=1024M@0xc0000000
  • I am doubtful mem=1024M@0xc0000000 will work. I have not  tried it.If your kernel boots up it should be fine. My concern is based on the
    http://www.arm.linux.org.uk/developer/memory.txt
    http://www.kernelport.org/defines.html (Explains the terminology)
    Based on below lowmem should end at (ff000000 - VMALLOC_SIZE). This is my understanding and I may be wrong. You can try it out and if kernel boots up there is no issue.
    Start		End		Use
    ffff8000	ffffffff	copy_user_page / clear_user_page use.
    				For SA11xx and Xscale, this is used to
    				setup a minicache mapping.
    ffff1000	ffff7fff	Reserved.
    				Platforms must not use this address range.
    ffff0000	ffff0fff	CPU vector page.
    				The CPU vectors are mapped here if the
    				CPU supports vector relocation (control
    				register V bit.)
    ffc00000	fffeffff	DMA memory mapping region.  Memory returned
    				by the dma_alloc_xxx functions will be
    				dynamically mapped here.
    ff000000	ffbfffff	Reserved for future expansion of DMA
    				mapping region.
    VMALLOC_END	feffffff	Free for platform use, recommended.
    				VMALLOC_END must be aligned to a 2MB
    				boundary.
    VMALLOC_START	VMALLOC_END-1	vmalloc() / ioremap() space.
    				Memory returned by vmalloc/ioremap will
    				be dynamically placed in this region.
    				VMALLOC_START may be based upon the value
    				of the high_memory variable.
    PAGE_OFFSET	high_memory-1	Kernel direct-mapped RAM region.
    				This maps the platforms RAM, and typically
    				maps all platform RAM in a 1:1 relationship.
    TASK_SIZE	PAGE_OFFSET-1	Kernel module space
    				Kernel modules inserted via insmod are
    				placed here using dynamic mappings.
    00001000	TASK_SIZE-1	User space mappings
    				Per-thread mappings are placed here via
    				the mmap() system call.
    00000000	00000fff	CPU vector page / null pointer trap
    				CPUs which do not support vector remapping
    				place their vector page here.  NULL pointer
    				dereferences by both the kernel and user
    				space are also caught via this mapping.
  • Hi Badri:
    you say "The firmware size are different because we run strip utility after building to strip out debug info."
    Could you tell me how to do this then?
    xavier
    best regards
