In the CSL_USB_CdcExample sample code, the input from the host is send back to the host. I modified the code(See Attachment
* Copyright (c) Texas Instruments Inc 2002, 2003, 2004, 2005, 2008, 2011
* Use of this software is controlled by the terms and conditions found in the
* license agreement under which this software has been supplied.
/** @file csl_usb_cdc_example.c
* @brief USB CDC example source file
* \page page17 CSL USB EXAMPLE DOCUMENTATION
* \section USB6 USB EXAMPLE6 - USB CDC TEST
* \subsection USB6x TEST DESCRIPTION:
* This test is to verify the operation of the CSL USB and CDC ACM module. This test runs
* in interrupt mode. USB interrupts are configured and ISR is registered using
* CSL INTC module. After initializing and configuring the USB module, the test program waits
* on a while loop. When there is any input from the USB host application
* USB ISR is triggered and the requested operation is performed inside the ISR.
* This USB CDC test can be verified by any terminal program (such as HyperTerminal) which can
* send or receive data via the virtual COM port for the USB CDC. The attached INF
* file (C5515_CDC_ACM.inf) is required. The INF file only be installed for
* the C5515 USB CDC device for the first time, when the using driver wizard of the windriver.
* This installation is required only when running this example for the first
* time.
* NOTE: IN THE CURRENT CODE EP1 IN IS CONFIGURED FOR COMMUNICATION CLASS INTERFACE
* EP2 OUT (BULK OUT) AND EP3 (BULK IN) IN ARE CONFIGURED FOR DATA CLASS INTERFACE
* THOSE CAN BE CHANGED IN CSL_CDC.H
* NOTE: THIS TEST HAS BEEN DEVELOPED TO WORK WITH CHIP VERSIONS C5505 AND
* C5515. MAKE SURE THAT PROPER CHIP VERSION MACRO IS DEFINED IN THE FILE
* c55xx_csl\inc\csl_general.h.
* \subsection USB2y TEST PROCEDURE:
* @li Connect the C5505/15 EVM with a PC via USB cable
* @li Open the CCS and connect the target (C5505/C5515 EVM)
* @li Open, build and load the USB program to the target
* @li Set the PLL frequency to 100MHz
* @li Run the program loaded on to the target
* @li Install the inf file for the USB device (Only when running for first time)
* @li After the proper USB enumeration, check the Control Panel-->System-->Hardware-->
* Device Manager-->Ports (COM & LPT) looking for C5515_CDC_ACM_device. A COM port will
* be assigned to the CDC ACM device, says COM16
* @li Run the HyperTerminal. Create a new connection to COM16
* @li Configure the new connection to the desired baud rate, parity, number of bits etc.
* @li The test program is acting as an echo device, whatever you input in the HyperTerminal,
* it will be echo them back. The user input to the HyperTerminal will be sent to the
* C5515 EVM via CSL_CDC_BULK_OUT_EP (EP2 OUT) and the data output from C5515 EVM to the
* will be sent to HyperTerminal via USB CSL_CDC_BULK_IN_EP (EP3 IN). You can change the
* actual port number in csl_cdc.h
* \subsection USB2z TEST RESULT:
* @li USB CDC ACM device should be detected by the host PC and should be accessible
* through a terminal application (HyperTerminal)
* @li Data typed in using keyborad and data displayed on the terminal window should match
* Revision History
* 17-May-2011 Created
* 31-May-2010 Updated
#include <stdio.h>
#include <string.h>
#include "soc.h"
#include "csl_usb.h"
#include "csl_usbAux.h"
#include "csl_intc.h"
#include "csl_general.h"
#include "csl_cdc.h"
#define CSL_USB_TEST_PASSED (0)
#define CSL_USB_TEST_FAILED (1)
#define CSL_USB_MAX_CURRENT (50)
#define CSL_USB_WAKEUP_DELAY (10)
#define ENABLE_DEBUG_PRINT
#ifdef ENABLE_DEBUG_PRINT
#define CSL_USB_DEBUG_PRINT printf
#else
#define CSL_USB_DEBUG_PRINT(string);
#endif
extern CSL_UsbContext gUsbContext;
extern CSL_UsbRegsOvly usbRegisters;
/* CDC Application handle */
CSL_CdcInitStructApp CDC_AppHandle;
/* CDC class data structure */
CSL_CdcClassStruct cdcClassStruct;
pCdcClassHandle pHandle;
/* TI C5515 USB Product Id and Vendor Id */
Uint16 pId = 0x9010;
Uint16 vId = 0x0451;
pUsbEpHandle hEPx;
CSL_UsbConfig usbConfig;
CSL_UsbBoolean txRxStatus;
CSL_Status status;
pUsbContext pContext = &gUsbContext;
Uint16 usbDataBufferRx[CSL_USB_CDC_DATA_BUF_SIZE];
Uint16 usbDataBufferTx[CSL_USB_CDC_DATA_BUF_SIZE];
Uint16 usbDataBufferTxWork[CSL_USB_CDC_DATA_BUF_SIZE/2];
Uint16 bytesRem;
Uint16 devAddr;
Uint16 saveIndex;
Uint16 endpt;
volatile Bool stopRunning = FALSE;
Bool usbDevDisconnect = FALSE;
void genDelay(DWORD dwMicroSeconds);
// Device Descriptor
Uint16 deviceDesc[9] = {
0x0112, // USB Device Descriptor type| descroptor size
0x0200, // USB Spec Release Number in BCD format
0x0002, // Sub-class code - 00 | Class code - 02 (CDC)
0x4000, // Maximum packet size for EP0 USB 64 | Protocol code
0x0451, // Vendor ID
0x9010, // Product ID
0x0100, // Device release number in BCD format
0x0201, // Product string index | Manufacturer string index
0x0103 // Number of Configuration | Device serial number string index
Uint16 deviceQualDesc[5] = {0x060A, 0x0200, 0x0000, 0x4000, 0x0001};
// Configuration Descriptor for USB HighSpeed
Uint16 cfgDesc[40] = {
// Configure descriptor
0x0209, // USB configure descriptor type | size of configure descriptor
0x0034, // Total length of data for this configuration
0x0102, // Index value of this configuration | number of interfaces in this configuration
0xC003, // Attributs (Bus-Powered and Self-Powered) | Configuration string index
0x0932, // Size of interface 0 | max power consumption (2X mA)
// Interface 0 descriptor
0x0004, // Interface Number | Interface descriptor type
0x0100, // Number of endpoints in this interface | Alternate setting number
0x0202, // Sub-class code (2: ACM) | Class code (2: communication interface class code)
0x0001, // Interface string index | Protocol code (V.25)
// CDC Class-Specific Descriptors
0x2404, // Descriptor type (CS_INTERFACE)| Size of this functional descriptor
0x0202, // Capabilities (D1) | ACM functional descriptor subtype
// Endpoint descriptor for communication interface (INTR EP IN)
0x0507, // USB endpoint descriptor type | Endpoint decsriptor size
0x0300|0x80|CSL_CDC_INTR_IN_EP, // Attributes (3: Interrupt) | INTR EP IN
0x0200, // Maximum packet size 512
0x0902, // Size of interface 1 | Polling interval
// Interface 1 descriptor
0x0104, // Interface Number | Interface descriptor type
0x0200, // Number of endpoints in this interface | Alternate setting number
0x000A, // Sub-class code | Class code (0x0A: Data interface)
0x0100, // Interface string index | Protocol code
// Endpoint descriptor for data interface (DATA EP IN)
0x0507, // USB endpoint descriptor type | Endpoint descriptor size
0x0200|0x80|CSL_CDC_BULK_IN_EP, // Attributes (2: Bulk) | BULK EP IN
0x0700, // Endpoint descriptor size | Polling interval
// Endpoint descriptor for data interface (BULK EP OUT)
0x0005|(CSL_CDC_BULK_OUT_EP<<8), // BULK EP OUT | USB endpoint descriptor type
0x0002, // Maximum packet size 512 (lower byte) | Attributes (2: Bulk)
0x0002 // Polling interval | Maximum packet size 512 (higher byte)
// Configuration Descriptor for USB FullSpeed
Uint16 cfgDescFS[40] = {
0x0709, // USB alternate configure descriptor type | size of configure descriptor
0x002E, // Total length of data for this configuration
0xC003, // Attributs | Configuration string index
0x0040, // Maximum packet size 64
0x4002, // Maximum packet size 64 (lower byte) | Attributes (2: Bulk)
0x0000 // Polling interval | Maximum packet size 64 (higher byte)
Uint16 strDesc[4][20] = {
// string 0 English-USA
{0x0304, 0x0409},
// string 1 "Texas Instruments"
{0x0324, 0x0054, 0x0045, 0x0058, 0x0041, 0x0053, 0x0020, 0x0049,0x004E,
0x0053, 0x0054, 0x0052, 0x0055, 0x004D, 0x0045, 0x004E, 0x0054, 0x0053},
#if (defined(CHIP_C5505_C5515) || defined(CHIP_C5504_C5514))
// string 2 "C5515"
{0x030C, 0x0043, 0x0035, 0x0035, 0x0031, 0x0035},
#else
// string 2 "C5505"
{0x030C, 0x0043, 0x0035, 0x0035, 0x0030, 0x0035},
#endif
// string 3 "00001"
{0x030C, 0x0030, 0x0030, 0x0030, 0x0030, 0x0031}
extern void VECSTART(void);
CSL_Status CSL_usbCdcTest(void);
interrupt void usb_isr(void);
void CSL_suspendCallBack(CSL_Status status);
void CSL_selfWakeupCallBack(CSL_Status status);
static void USB_delay(Uint32 mSecs);
CSL_Status CSL_startTransferCallback(void *vpContext,
void *vpeps);
CSL_Status CSL_completeTransferCallback(void *vpContext,
void *vpeps);
void appBulkInCallback(pUsbContext pContext, CSL_CdcClassStruct *hCdcClass);
void appBulkOutCallback(pUsbContext pContext, CSL_CdcClassStruct *hCdcClass);
void appIntrInCallback(pUsbContext pContext, CSL_CdcClassStruct *hCdcClass);
* \brief main function
* \param None
* \return None
/////INSTRUMENTATION FOR BATCH TESTING -- Part 1 --
///// Define PaSs_StAtE variable for catching errors as program executes.
///// Define PaSs flag for holding final pass/fail result at program completion.
volatile Int16 PaSs_StAtE = 0x0001; // Init to 1. Reset to 0 at any monitored execution error.
volatile Int16 PaSs = 0x0000; // Init to 0. Updated later with PaSs_StAtE when and if
///// program flow reaches expected exit point(s).
void main(void)
CSL_Status result;
printf("USB Interrupt Test!!\n");
result = CSL_usbCdcTest();
if(result == CSL_USB_TEST_PASSED)
printf("USB Test Passed!!\n");
else
printf("USB Test Failed!!\n");
/////INSTRUMENTATION FOR BATCH TESTING -- Part 2 --
///// Reseting PaSs_StAtE to 0 if error detected here.
PaSs_StAtE = 0x0000; // Was intialized to 1 at declaration.
/////INSTRUMENTATION FOR BATCH TESTING -- Part 3 --
///// At program exit, copy "PaSs_StAtE" into "PaSs".
PaSs = PaSs_StAtE; //If flow gets here, override PaSs' initial 0 with
///// // pass/fail value determined during program execution.
///// Note: Program should next exit to C$$EXIT and halt, where DSS, under
///// control of a host PC script, will read and record the PaSs' value.
* \brief Tests USB interrupt mode operation
* \param none
* \return Test result
CSL_IRQ_Config config;
CSL_Status result;
Uint16 uartData[80], uartDataSize = 0, retNum;
int jin = 0;
int i;
int s;
Uint16 test[80] = {0};
int j = 0x65;
result = CSL_USB_TEST_FAILED;
// clear the CDC class structure
memset((void*)&cdcClassStruct, 0x00, sizeof(cdcClassStruct));
// clear the USB data buffers
memset((void*)usbDataBufferRx, 0x00, sizeof(usbDataBufferRx));
memset((void*)usbDataBufferTx, 0x00, sizeof(usbDataBufferTx));
memset((void*)usbDataBufferTxWork, 0x00, sizeof(usbDataBufferTxWork));
/* Initializing the pointer to the CDC Handle */
CDC_AppHandle.pCdcObj = (void*)&cdcClassStruct;
pHandle = (pCdcClassHandle)(CDC_AppHandle.pCdcObj);
// Initialize the line code
pHandle->cdcHandle.lineCoding.dwBaudRate = 0x00002580;//0x0001C200; // 9600 baud
pHandle->cdcHandle.lineCoding.wCharFormat = 0; // 1 stop bit
pHandle->cdcHandle.lineCoding.wParityType = 0; // none parity
pHandle->cdcHandle.lineCoding.wDataBits = 8; // 8 bit
/* Link all the descriptors to the USB context */
pContext->deviceDescPtr = deviceDesc;
pContext->deviceQualDescPtr = deviceQualDesc;
pContext->cfgDescPtr = cfgDesc;
pContext->cfgDescFSPtr = cfgDescFS;
pContext->strDescPtr[0] = strDesc[0];
pContext->strDescPtr[1] = strDesc[1];
pContext->strDescPtr[2] = strDesc[2];
pContext->strDescPtr[3] = strDesc[3];
/* Initialize the CDC module handle */
CDC_AppHandle.rxBufferPtr = usbDataBufferRx;
CDC_AppHandle.rxStartIdx = CDC_AppHandle.rxEndIdx = 0;
CDC_AppHandle.txBufferPtr = usbDataBufferTx;
CDC_AppHandle.txStartIdx = CDC_AppHandle.txEndIdx = 0;
CDC_AppHandle.txWorkBufPtr = usbDataBufferTxWork;
CDC_AppHandle.txWorkBufIdx = 0;
CDC_AppHandle.pId = pId;
CDC_AppHandle.vId = vId;
/* All Function Handlers in the CDC module handle need to be Initialized */
CDC_AppHandle.bulkInCallback = appBulkInCallback;
CDC_AppHandle.bulkOutCallback = appBulkOutCallback;
CDC_AppHandle.intrInCallback = appIntrInCallback;
// Set up USB configuration strucrure
usbConfig.opMode = CSL_USB_OPMODE_POLLED;
usbConfig.devNum = CSL_USB0;
usbConfig.maxCurrent = CSL_USB_MAX_CURRENT;
usbConfig.appSuspendCallBack = (CSL_USB_APP_CALLBACK)CSL_suspendCallBack;
usbConfig.appWakeupCallBack = (CSL_USB_APP_CALLBACK)CSL_selfWakeupCallBack;
usbConfig.startTransferCallback = CSL_startTransferCallback;
usbConfig.completeTransferCallback = CSL_completeTransferCallback;
// Pass the endpoint object pointers from CDC handle to USB context
pContext->hEpObjArray[0] = &cdcClassStruct.ctrlHandle.ctrlOutEpObj;
pContext->hEpObjArray[1] = &cdcClassStruct.ctrlHandle.ctrlInEpObj;
pContext->hEpObjArray[2] = &cdcClassStruct.cdcHandle.bulkOutEpObj;
pContext->hEpObjArray[3] = &cdcClassStruct.cdcHandle.bulkInEpObj;
pContext->hEpObjArray[4] = &cdcClassStruct.cdcHandle.intrOutEpObj;
pContext->hEpObjArray[5] = &cdcClassStruct.cdcHandle.intrInEpObj;
/* Set the interrupt vector start address */
IRQ_setVecs((Uint32)(&VECSTART));
/* Plug the USB Isr into vector table */
config.funcAddr = &usb_isr;
IRQ_plug(USB_EVENT, config.funcAddr);
/* Enable USB Interrupts */
IRQ_enable(USB_EVENT);
/* Enable CPU Interrupts */
IRQ_globalEnable();
/* Initialize the USB module */
status = USB_init(&usbConfig);
if(status != CSL_SOK)
printf("USB init failed\n");
return(result);
/* Reset the USB device */
status = USB_resetDev(CSL_USB0);
printf("USB Reset failed\n");
return(result);
// Create a CDC handle
status = CDC_Open(&CDC_AppHandle);
if(status == CSL_ESYS_BADHANDLE)
CSL_USB_DEBUG_PRINT("Opening CDC Module Failed!\n");
CSL_USB_DEBUG_PRINT("CDC_Open Returned - BAD HANDLE\n");
} else
CSL_USB_DEBUG_PRINT("CDC Open Failed\n");
return(status);
else
CSL_USB_DEBUG_PRINT("CSL CDC Module Open Successful\n");
/* Set the parameters */
status = USB_setParams(CSL_USB0, pContext->hEpObjArray, FALSE);
printf("USB Set params failed\n");
return(result);
/* Connect the USB device */
status = USB_connectDev(CSL_USB0);
printf("USB Connect failed\n");
return(result);
// The echo loop
while(stopRunning != TRUE)
// checking for cable disconnect
if ((usbDevDisconnect == TRUE) &&
(CSL_FEXT(usbRegisters->DEVCTL, USB_DEVCTL_VBUS) !=
CSL_USB_DEVCTL_VBUS_ABOVEVBUSVALID))
printf("\nUSB Cable Disconnected!!\n");
while(CSL_FEXT(usbRegisters->DEVCTL, USB_DEVCTL_VBUS) !=
CSL_USB_DEVCTL_VBUS_ABOVEVBUSVALID);
printf("USB Cable Connection Detected!!\n");
//USB_connectDev(CSL_USB0);
// Echo the input from the host back to the host
// Get data from the host
uartDataSize = CDC_getData(pContext, &CDC_AppHandle, uartData);
// Echo it back, if there is an input
if (uartDataSize>0)
while(1)
do
// CDC_putData will return 0 if the TX is not ready for the transaction
retNum = CDC_putData(pContext, &CDC_AppHandle, uartData, uartDataSize);
} while (retNum==0);
result = CSL_USB_TEST_PASSED;
return(result);
// Some USB related counters (for debugging)
Uint32 usb_int_total = 0;
Uint32 usb_int_ep0 = 0;
Uint32 usb_int_reset = 0;
Uint32 usb_int_resume = 0;
Uint32 usb_int_suspend = 0;
Uint16 usb_income_num_bytes;
Uint32 usb_ep1in_count = 0;
Uint32 usb_ep2out_count = 0;
Uint32 usb_ep3in_count = 0;
* \brief USB interrupt service routine
* \param None
* \return None
usb_int_total++;
/* Read the masked interrupt status register */
pContext->dwIntSourceL = usbRegisters->INTMASKEDR1;
pContext->dwIntSourceH = usbRegisters->INTMASKEDR2;
/* Clear the interrupts */
if(pContext->dwIntSourceL != FALSE)
usbRegisters->INTCLRR1 = pContext->dwIntSourceL;
if(pContext->dwIntSourceH != FALSE)
usbRegisters->INTCLRR2 = pContext->dwIntSourceH;
if((pContext->dwIntSourceL != FALSE) || (pContext->dwIntSourceH != FALSE))
/* Reset interrupt */
if(pContext->dwIntSourceH & CSL_USB_GBL_INT_RESET)
usb_int_reset++;
usbRegisters->INDEX_TESTMODE = usbRegisters->INDEX_TESTMODE & 0x00ff;
if(pContext->hEpObjArray[2]->epNum == CSL_USB_IN_EP1)
CSL_FINS(usbRegisters->INDEX_TESTMODE,
USB_INDEX_TESTMODE_EPSEL, CSL_USB_EP1);
CSL_FINS(usbRegisters->PERI_CSR0_INDX,
USB_PERI_CSR0_INDX_RXPKTRDY, TRUE);
else
USB_INDEX_TESTMODE_EPSEL, CSL_USB_EP2);
/* Resume interrupt */
if(pContext->dwIntSourceH & CSL_USB_GBL_INT_RESUME)
usb_int_resume++;
USB_setRemoteWakeup(CSL_USB0, CSL_USB_TRUE);
status = USB_issueRemoteWakeup(CSL_USB0, TRUE);
/* Give 10 msecs delay before resetting resume bit */
USB_delay(CSL_USB_WAKEUP_DELAY);
status = USB_issueRemoteWakeup(CSL_USB0, FALSE);
printf("USB Resume failed\n");
/* Check end point0 interrupts */
if(pContext->dwIntSourceL & CSL_USB_TX_RX_INT_EP0)
usb_int_ep0++;
// call USB core EP0 event handler to process
USB_coreEventProcessEp0(pContext);
// call the CDC event handler for further processing
CDC_eventHandler(pContext, &cdcClassStruct);
/* Check CDC Interrupt EP IN for interrupt */
if (pContext->dwIntSourceL & (1<<CSL_CDC_INTR_IN_EP))
usb_ep1in_count++;
// call the INTR IN callback function, if there is any
if (CDC_AppHandle.intrInCallback!=NULL)
CDC_AppHandle.intrInCallback(pContext, &CDC_AppHandle);
/* Check CDC Data Out Ready */
if (pContext->dwIntSourceL & (1<<(CSL_CDC_BULK_OUT_EP+CSL_USB_IN_EP0)))
usb_ep2out_count++;
// Handle the CDC BULK OUT
CDC_bulkOutHandler(pContext, &CDC_AppHandle);
// call the CDC BULK OUT callback function, if there is any
if (CDC_AppHandle.bulkOutCallback!=NULL)
CDC_AppHandle.bulkOutCallback(pContext, &CDC_AppHandle);
/* Check CDC Data In Ready */
if (pContext->dwIntSourceL & (1<<CSL_CDC_BULK_IN_EP))
usb_ep3in_count++;
// Handle the CDC BULK IN
CDC_bulkInHandler(pContext, &CDC_AppHandle);
// call the CDC BULK IN callback function, if there is any
if (CDC_AppHandle.bulkInCallback!=NULL)
CDC_AppHandle.bulkInCallback(pContext, &CDC_AppHandle);
/* Connect interrupt */
if(pContext->dwIntSourceH & CSL_USB_GBL_INT_VBUSERR)
/* Disconnect interrupt */
if(pContext->dwIntSourceH & CSL_USB_GBL_INT_DEVDISCONN)
//status = USB_disconnectDev(CSL_USB0);
usbDevDisconnect = TRUE;
printf("USB Disconnect failed\n");
/* Suspend interrupt */
if(pContext->dwIntSourceH & CSL_USB_GBL_INT_SUSPEND)
usb_int_suspend++;
status = USB_suspendDevice(CSL_USB0);
printf("USB Suspend failed\n");
// Send out End Of Interrupt
CSL_FINS(usbRegisters->EOIR, USB_EOIR_EOI_VECTOR, CSL_USB_EOIR_RESETVAL);
* \brief USB suspend call back function
* \param none
printf("\nUSB SUSPEND Callback\n");
* \brief USB self wakeup call back function
* \param none
printf("\nUSB Self Wakeup CallBack\n");
* \brief USB delay function
* \param mSecs - Delay in millisecs
* \return None
volatile Uint32 delay;
volatile Uint32 msecCount;
volatile Uint32 sysClk; /* System clock value in KHz */
sysClk = 100000; /* It is assumed that system is running at 100MHz */
for (msecCount = 0; msecCount < mSecs; msecCount++)
for (delay = 0; delay < sysClk; delay++)
asm ("\tNOP");
* \brief Start transfer call back function
* \param vpContext - USB context structure
* \param vpeps - End point status strucure pointer
* \return CSL_Status
void *vpeps)
pUsbContext pContext;
pUsbEpStatus peps;
pUsbTransfer pTransfer;
CSL_Status status;
status = CSL_SOK;
pContext = (pUsbContext)vpContext;
peps = (pUsbEpStatus)vpeps;
if((pContext == NULL) || (peps == NULL))
return(CSL_ESYS_INVPARAMS);
if(!pContext->fMUSBIsReady)
/* The endpoint should be initialized */
if(!peps->fInitialized)
pTransfer = peps->pTransfer;
pTransfer->fComplete=FALSE;
if(pTransfer->dwFlags == CSL_USB_OUT_TRANSFER)
if(peps->dwEndpoint == CSL_USB_EP0)
status = USB_processEP0Out(pContext);
else
status = USB_handleRx(pContext, CSL_CDC_BULK_OUT_EP);
else if(pTransfer->dwFlags == CSL_USB_IN_TRANSFER)
if(peps->dwEndpoint == CSL_USB_EP0 )
status = USB_processEP0In(pContext);
else
status = USB_handleTx(pContext, CSL_CDC_BULK_IN_EP);
else
status = CSL_ESYS_INVPARAMS;
return(status);
* \brief Complete transfer call back function
* \param vpeps - End point status structure pointer
void *vpeps)
return(CSL_SOK);
* \brief Application call back function for bulk transactions
* \param None
* \return None
Uint32 bulkInCallbackCount = 0;
bulkInCallbackCount++;
* \brief Application call back function for control transactions
* \param None
* \return None
Uint32 bulkOutCallbackCount = 0;
bulkOutCallbackCount++;
* \brief Application call back function for interrupt transactions
* \param None
* \return None
Uint32 intrInCallbackCount = 0;
intrInCallbackCount++;
volatile DWORD dwmsecs;
volatile DWORD delay;
volatile DWORD looper;
dwmsecs = dwMicroSeconds;
delay = 0;
while(dwmsecs--)
/* CLOCK = 100 MHz */
for (looper = 0; looper < 5; looper++)
delay++;
If i introduce some delay in between each data send, then some more packets will be transferred correctly. The issue occurs when I try to send data continuously.
Could you please mention a solution for this issue. I need to send data continuously over usb.
Setup Details:
TMS320VC5515 EVM.
CSL Library Being used is ‘c55xx_csl_3.00’
CCS version is ‘4.1.0.02002’
XDC Tool is ‘xdctools_3_16_02_32’
Host OS is Windows XP
