Hi all,
I am getting following errors while bootup on DM8127(GA release V3.2).
How to solve this ?
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 19
UBI: attached mtd5 to ubi0
UBI: MTD device name: "Data"
UBI: MTD device size: 12 MiB
UBI: number of good PEBs: 44
UBI: number of bad PEBs: 52
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 44
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 9/0
UBI: image sequence number: 1315690043
UBI: background thread "ubi_bgt0d" started, PID 809
UBI device number 0, total 44 LEBs (5586944 bytes, 5.3 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 87:4096, read 126976 bytes
UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 87
UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 89:4096, read 126976 bytes
UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 89
UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 36:4096, read 126976 bytes
UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 2:4096, read 126976 bytes
UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 2
UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 39:4096, read 126976 bytes
UBIFS: recovery needed
UBI error: ubi_io_read: error -74 (ECC error) while reading 2048 bytes from PEB 24:12288, read 2048 bytes
UBIFS error (pid 813): ubifs_leb_read: reading 2048 bytes from LEB 9:8192 failed, error -74
UBI error: ubi_io_read: error -74 (ECC error) while reading 2048 bytes from PEB 26:14336, read 2048 bytes
UBIFS error (pid 813): ubifs_leb_read: reading 2048 bytes from LEB 6:10240 failed, error -74
UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 11:4096, read 126976 bytes
UBI error: ubi_io_read: error -74 (ECC error) while reading 118784 bytes from PEB 30:12288, read 118784 bytes
UBI error: ubi_io_read: error -74 (ECC error) while reading 120832 bytes from PEB 35:10240, read 120832 bytes
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
UBIFS: file system size: 3682304 bytes (3596 KiB, 3 MiB, 29 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 173924 bytes (169 KiB)
ubiattach: error!: cannot attach mtd7
error 19 (No such device)
libubi: error!: cannot get information about "/dev/ubi1"
error 2 (No such file or directory)
ubimkvol: error!: error while probing "/dev/ubi1"
mount: unknown filesystem type 'ubifs'
ubidetach: error!: cannot remove ubi1
error 22 (Invalid argument)
libmtd: error!: cannot get information about "/dev/mtd7"
ubiformat: error!: cannot get information about "/dev/mtd7"
./init.sh: line 5: -f: not found
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
