tftp maximum limit
Guru 20755 points
Is there a maximum limitation on file size when using tftp with u-boot.
Thank you,
Ran
  • Ran,
    There is a limit of 32MB in the first version of TFTP implementation and later they've extended the protocol to support more. Generally what I've seen u-boot implementation is that if the file size crosses 32MB it will split into multiple chunks of 32MB and transfer. The only constraint is device memory available.
