Why DM8168 can't run in DDRIII ar 1600MHZ?
I designed a custom board using X8168 rev B,DDRIII using Hynix chips 1600M max.
Dm8168 can run in DDRIII at 1333MHz,but can't run in DDRIII at 1600MHz.
What's the possible causes?
First,PCB layout.
Second,I uses 51R+-5% resistor connected to 8168's VTP[x]_VTP pins.Could this be the cause?
And other causes?
Thank you in advance.
