Video Display issue running demo on DM8168
HI all,
I am using exiting demo application for displaying the Video(720x1080 - 6 channel) use case is decode and display SD/HD.
Only mosaic is displaying on the HDMI0 interface - No video -  let me know how to do this.
my ini file name :720x300_00_6CH.ini
[file00]
path      = /data/720x300_00.h264
width     = 720
height    = 300
enable    = 1
codec     = h264
numbuf    = 16
displaydelay    = 10
[file01]
width     = 720
height    = 300
enable    = 1
codec     = h264
numbuf    = 16
displaydelay    = 10
[file02]
width     = 720
height    = 300
enable    = 1
codec     = h264
numbuf    = 16
displaydelay    = 10
[file03]
width     = 720
height    = 300
enable    = 1
codec     = h264
numbuf    = 16
displaydelay    = 10
[file04]
width     = 720
height    = 300
enable    = 1
codec     = h264
numbuf    = 16
displaydelay    = 10
[file04]
width     = 720
height    = 300
enable    = 1
codec     = h264
numbuf    = 16
displaydelay    = 10
[file05]
width     = 720
height    = 300
enable    = 1
codec     = h264
numbuf    = 16
displaydelay    = 10
After genarting the header:
ERRORR:
[m3vpss ]  *** [SWMS1] Mosaic Parameters ***
 [m3vpss ]
 [m3vpss ]  Output FPS: 30
 [m3vpss ]
 [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Dat|
 [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | For|
 [m3vpss ]  -----------------------------------------------------------------------------------------------------------------------------------------------------------
 [m3vpss ]    0 |   0 |    0,    0 |   720 x    300 |   896 /   896 | NON-TILED   |    0,    0 |  1920 x   1080 |  3840 /      0 | NON-TILED   |      OFF |    0 |  42|
 [m3video] 308815:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
 [m3video] ALGPROCESS FAILED:STATUS
 [m3video] outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x40401
 [m3vpss ]
 [m3video] Sequence called number 1
 [m3vpss ]  308666: DISPLAY: Start in progress !!!
 [m3video]  308816: DECODE: CH0: Decoder flush needed (263169)!!!
 [m3vpss ]  308712: DISPLAY: Start Done !!!
 [m3video]  308816: DECODE: CH0: Decoder Flushing !!!
 [m3vpss ]  308712: DISPLAY: HDDAC(BP0) : 43 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
With Regards
Mahesh Kalmeshwar
  • Are you seeing issue with only this particular stream. If so can share the stream for analysis. Height of 300 is not aligned to 16 . Can you try mentioning widthxheight in ini file as 720x480 and check if there is any change in behaviour
  • Hi Badri,
    I first recored the video file form Demo's only Resl:352x288_00_4CH.ini
    later i ran Decode tand Display it is displaying on EVM kit,But same thing is not working on our Custom baord.
    Please let me know how to proceed further.
    Log:
    QMetaObject::connectSlotsByName: No matching signal for on_btn_clicked(int)
     [m3vpss ] Unhandled Exception:
     [m3vpss ] Exception occurred in ThreadType_Task
     [m3vpss ] handle: 0x9e49368c.
     [m3vpss ] stack base: 0x3f0ed4e0.
     [m3vpss ] stack size: 0x4000.
     [m3vpss ] R0 = 0x9e49735c  R8  = 0xffffffff
     [m3vpss ] R1 = 0x00000002  R9  = 0xffffffff
     [m3vpss ] R2 = 0x00000001  R10 = 0xffffffff
     [m3vpss ] R3 = 0x00000001  R11 = 0xffffffff
     [m3vpss ] R4 = 0x10b07600  R12 = 0x00000001
     [m3vpss ] R5 = 0x00000000  SP(R13) = 0x3f0f1470
     [m3vpss ] R6 = 0x00000000  LR(R14) = 0x9df01e45
     [m3vpss ] R7 = 0xffffffff  PC(R15) = 0x9df1bfe4
     [m3vpss ] PSR = 0x41000200
     [m3vpss ] ICSR = 0x00400803
     [m3vpss ] MMFSR = 0x00
     [m3vpss ] BFSR = 0x82
     [m3vpss ] UFSR = 0x0000
     [m3vpss ] HFSR = 0x40000000
     [m3vpss ] DFSR = 0x00000000
     [m3vpss ] MMAR = 0x10b07608
     [m3vpss ] BFAR = 0x10b07608
     [m3vpss ] AFSR = 0x00000000
     [m3vpss ] Terminating Execution...
    64463:!!!SLAVE CORE [VPSS-M3] DOWN!!!
    SystemLink_copySlaveCoreExceptionContext:120
    mmap of [0xbe9e0000:36864]
    mmap virt addresss:0x2ab5c000
    munmap of [0x2ab5c000:36864]
    SystemLink_copySlaveCoreExceptionContext:127
    With Regards
    Mahesh Kalmeshwar.
  • Can you register for event handler for system event SLAVE_CORE_DOWN and provide the log file (Refer demo_eventHandler for reference).Pls also share your .xem3 along with slave core dump log
  • Hi ,
    /media/rootfs/opt/dvr_rdk/ti816x/CCS_CRASH_DUMP_VIDEO-M3.txt
    521177 14
    R R0 0x0000000B 0x9d437c20
    R R1 0x0000000B 0x992266f1
    R R2 0x0000000B 0x00000001
    R R3 0x0000000B 0x9d4378a4
    R R4 0x0000000B 0x9d437d78
    R R5 0x0000000B 0x9922674c
    R R6 0x0000000B 0x00000000
    R R7 0x0000000B 0x00000000
    R R8 0x0000000B 0x9d1eda2c
    R R9 0x0000000B 0x0000000f
    R R10 0x0000000B 0x00000000
    R R11 0x0000000B 0x9d1eda30
    R R12 0x0000000B 0x9d434808
    R SP 0x0000000B 0x3ddce418
    R LR 0x0000000B 0x9d21a073
    R PC 0x0000000B 0x99226704
    R PSR 0x0000000B 0x4100a80f
    R ICSR 0x0000000B 0x00400003
    R MMFSR 0x0000000B 0x00000000
    R BFSR 0x0000000B 0x00000000
    R UFSR 0x0000000B 0x00000001
    R HFSR 0x0000000B 0x40000000
    R DFSR 0x0000000B 0x00000000
    R MMAR 0x0000000B 0xe000ed34
    R BFAR 0x0000000B 0xe000ed38
    R AFSR 0x0000000B 0x00000000
    M 0 0x3ddca4f4 0x00004000
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0x10
    0x00
    0x00
    0x00
    0x68
    0xe0
    0xdc
    0x3d
    0xdd
    0xe7
    0x1f
    0x9d
    0x00
    0x00
    0x00
    0x00
    0x10
    0x00
    0x00
    0x00
    0x78
    0x00
    0x00
    0x00
    0x64
    0xe0
    0xdc
    0x3d
    0x9c
    0xe0
    0xdc
    0x3d
    0x68
    0xe0
    0xdc
    0x3d
    0x10
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x98
    0xe0
    0xdc
    0x3d
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    /media/rootfs/opt/dvr_rdk/ti816x/CCS_CRASH_DUMP_VPSS-M3.txt
    521177 14
    R R0 0x0000000B 0x3ef2eaec
    R R1 0x0000000B 0x3ef2ea6c
    R R2 0x0000000B 0x00000000
    R R3 0x0000000B 0x00000000
    R R4 0x0000000B 0x00000000
    R R5 0x0000000B 0x00000000
    R R6 0x0000000B 0x3ef2ea6c
    R R8 0x0000000B 0x00000000
    R R9 0x0000000B 0x00000000
    R R10 0x0000000B 0x3ef34d88
    R R11 0x0000000B 0x00000000
    R R12 0x0000000B 0x9ded42a5
    R SP 0x0000000B 0x9e49b300
    R LR 0x0000000B 0x00425363
    R PC 0x0000000B 0x9ded42c6
    R PSR 0x0000000B 0x6100003d
    R BFSR 0x0000000B 0x00000082
    R UFSR 0x0000000B 0x00000000
    R MMAR 0x0000000B 0x7de5d558
    R BFAR 0x0000000B 0x7de5d558
    M 0 0x9e4974dc 0x00004000
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0xbe
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x20
    0x30
    0x00
    0x0c
    0x16
    0xb4
    0xb1
    0x49
    0x9e
    0x00
    0x08
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0xf0
    0xb1
    0x49
    0x9e
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x28
    0xb2
    0x49
    0x9e
    0xc9
    0x1f
    0xf1
    0x9d
    0xd3
    0x1f
    0xf1
    0x9d
    0xd0
    0x64
    0xea
    0x9d
    0x94
    0x07
    0x49
    0x9e
    0xff
    0x07
    0x00
    0x00
    0x18
    0x00
    0x00
    0x00
    0x7c
    0x07
    0x49
    0x9e
    0x74
    0x07
    0x49
    0x9e
    0x1b
    0x88
    0xf0
    0x9d
    0x00
    0x00
    0x00
    0x00
    0x00
    0xe0
    0x00
    0xe0
    0x00
    0x00
    0x00
    0x00
    0x58
    0x35
    0x49
    0x9e
    0xdb
    0x2e
    0x00
    0x00
    0x00
    0xe0
    0x00
    0xe0
    0xdb
    0x2e
    0x00
    0x00
    0x02
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x9e
    0xbe
    0xf1
    0xff
    0xff
    0xff
    0x44
    0x71
    0x49
    0x9e
    0x00
    0x00
    0x00
    0x00
    0x58
    0x35
    0x49
    0x9e
    0xf1
    0xff
    0xff
    0xff
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x88
    0x4d
    0xf3
    0x3e
    0x00
    0x00
    0x00
    0x00
    0x8d
    0x28
    0xef
    0x9d
    0x00
    0xb4
    0x49
    0x9e
    0xb0
    0x92
    0x04
    0x3f
    0xdc
    0x74
    0x49
    0x9e
    0x00
    0x40
    0x00
    0x00
    0xec
    0xea
    0xf2
    0x3e
    0x6c
    0xea
    0xf2
    0x3e
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x6c
    0xea
    0xf2
    0x3e
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x88
    0x4d
    0xf3
    0x3e
    0x00
    0x00
    0x00
    0x00
    0xa5
    0x42
    0xed
    0x9d
    0x00
    0xb3
    0x49
    0x9e
    0x63
    0x53
    0x42
    0x00
    0xc6
    0x42
    0xed
    0x9d
    0x3d
    0x00
    0x00
    0x61
    0x03
    0x00
    0x40
    0x00
    0x00
    0x00
    0x00
    0x00
    0x82
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x40
    0x00
    0x00
    0x00
    0x00
    0x58
    0xd5
    0xe5
    0x7d
    0x58
    0xd5
    0xe5
    0x7d
    0x00
    0x00
    0x00
    0x00
    0x10
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x6c
    0xea
    0xf2
    0x3e
    0x00
    0x00
    0x00
    0x00
    0xad
    0xd8
    0xf1
    0x9d
    0x00
    0x00
    0x00
    0x00
    0xf1
    0xff
    0xff
    0xff
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x6c
    0xea
    0xf2
    0x3e
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x88
    0x4d
    0xf3
    0x3e
    0x00
    0x00
    0x00
    0x00
    0xec
    0xea
    0xf2
    0x3e
    0x6c
    0xea
    0xf2
    0x3e
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0xa5
    0x42
    0xed
    0x9d
    0x63
    0x53
    0x42
    0x00
    0xc6
    0x42
    0xed
    0x9d
    0x3d
    0x00
    0x00
    0x61
    0x01
    0x00
    0x00
    0x00
    0x35
    0xbc
    0xf0
    0x9d
    0x00
    0x04
    0x00
    0x00
    0x48
    0xaa
    0xb6
    0x3e
    0x5c
    0xfe
    0x02
    0x00
    0x45
    0x30
    0x41
    0x00
    0x00
    0xd0
    0x48
    0x9e
    0xc8
    0xe2
    0x48
    0x9e
    0x00
    0x00
    0x00
    0x00
    0x30
    0xb0
    0xb7
    0x3e
    0x00
    0x00
    0x00
    0x00
    0x11
    0x99
    0x41
    0x00
    0x10
    0x00
    0x00
    0x00
    0x94
    0xaf
    0x00
    0x00
    0x98
    0x0a
    0xf1
    0x3e
    0x00
    0x00
    0x00
    0x00
    0xa4
    0xea
    0xf2
    0x3e
    0x6c
    0xea
    0xf2
    0x3e
    0x01
    0x00
    0x00
    0x00
    0xac
    0x4e
    0xf3
    0x3e
    0x30
    0xb0
    0xb7
    0x3e
    0x00
    0x00
    0x00
    0x00
    0xb4
    0xea
    0xf2
    0x3e
    0x63
    0x53
    0x42
    0x00
    0xe4
    0x53
    0x42
    0x00
    0x01
    0x00
    0x00
    0x00
    0x80
    0x51
    0x0f
    0x3f
    0x3d
    0xc8
    0xf1
    0x9d
    0x0b
    0xbd
    0x82
    0x52
    0xa4
    0xea
    0xf2
    0x3e
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x5c
    0x86
    0xee
    0x9d
    0x10
    0xc9
    0x0f
    0x3f
    0x00
    0x00
    0x00
    0x00
    0xc0
    0x49
    0x44
    0x9e
    0x01
    0x00
    0x00
    0x00
    0x0b
    0xbd
    0x82
    0x52
    0x00
    0x00
    0x00
    0x00
    0x1f
    0x85
    0xeb
    0x51
    0x38
    0xff
    0xff
    0xff
    0xa7
    0x66
    0x42
    0x00
    0x14
    0x67
    0x42
    0x00
    0x07
    0x00
    0x00
    0x00
    0xa4
    0xa1
    0xb6
    0x3e
    0x43
    0xeb
    0xf0
    0x9d
    0xcc
    0xf1
    0x43
    0x9e
    0xe4
    0xed
    0x43
    0x9e
    0x74
    0x48
    0x44
    0x9e
    0x8c
    0xef
    0x43
    0x9e
    0x1c
    0xe3
    0xf2
    0x9d
    0x00
    0x00
    0x00
    0x00
    0x1f
    0x85
    0xeb
    0x51
    0x17
    0x6f
    0x42
    0x00
    0x48
    0x33
    0x49
    0x9e
    0xb0
    0x92
    0x04
    0x3f
    0xe4
    0xdf
    0xf2
    0x9d
    0x00
    0x00
    0x00
    0x00
    0x24
    0xe3
    0xf2
    0x9d
    0x1c
    0xe3
    0xf2
    0x9d
    0x3d
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x20
    0xe3
    0xf2
    0x9d
    0x93
    0x65
    0xef
    0x9d
    0x33
    0x00
    0x00
    0x00
    0x68
    0xe4
    0xf2
    0x9d
    0x01
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x02
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x02
    0x00
    0x00
    0x00
    0xff
    0xff
    0xff
    0xff
    0x01
    0x00
    0x00
    0x00
    0xf4
    0xdf
    0xf2
    0x9d
    0x00
    0x00
    0x00
    0x00
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xff
    0xbd
    0x1d
    0xf0
    0x9d
    0xfd
    0xff
    0xff
    0xff
    0x00
    0x00
    0x00
    0x00
    0x01
    0x00
    0x00
    0x00
    0x18
    0xb3
    0x48
    0x9e
    0x18
    0xb3
    0x48
    0x9e
    0x01
    0x00
    0x00
    0x00
    0x01
    0x00
    0x00
    0x00
    0x2c
    0xb4
    0x49
    0x9e
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x10
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x45
    0x1e
    0xf0
    0x9d
    0x58
    0x1e
    0xf0
    0x9d
    0x00
    0x14
    0x00
    0x01
    0x00
    0x00
    0x00
    0x00
    0x9c
    0x74
    0x49
    0x9e
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0xd8
    0xb4
    0x49
    0x9e
    0x00
    0x00
    0x00
    0x00
    0x2b
    0xb9
    0xf1
    0x9d
    0x00
    0x00
    0x00
    0x00
    0x7d
    0xd8
    0xf1
    0x9d
    0x00
    0x00
    0x00
    0x00
    0x43
    0x7a
    0xf1
    0x9d
    0x00
    0x00
    0x00
    0x00
    0xa9
    0x92
    0xf1
    0x9d
    0x00
    0x00
    0x00
    0x00
    With Regards
    Mahesh Kalmeshwar.
  • Does both Video M3 and VPSS M3 crash ? Your original log indicated only VPSS M3 crashed but the crash log is present for both cores. Also pls attach the .xem3 of the core that crashed.
  • Hi ,
    Only Vpss comes while playback video .
    encode and decode than displaying - it is getting video3 exception .
    With Regards
    Mahesh Kalmeshwar.
  • Ok.Pls share he zip of .xem3 of video m3 and vpss m3 and the corresponding .map file. Looks like some serious issue with memory. Have you run memory tests on your board. How much memory is present in your board. Did you have to modify the memory map when porting the RDK to your board. If so please share the memory map changes.
    I have not change any memory map.
    As per the porting guide line we are tested DDR3(it fine in that) and ours DDR3 is 2 GB.
    With Regards
    Mahesh Kalmeshwar
  • Here is tar file vpss and video3 FYI.
    Let me know some points how to proceed further .
    Mahesh Kalmeshwar
    5661.dvr_rdk_fw_m3vpssxem3.tar.gzlmeshwar.0820.dvr_rdk_fw_m3videoxem3.tar.gz
  • The firmware binaries appear to be the stripped version. Can you attach the original .xem3 (present under dvr_rdk\build\dvr_rdk\bin\ti816x-evm\ folder.Firmware should be around 13MB each if symbols are not stripped.
  • We analyzed the crash dump and we saw that the logs you have shared are incomplete. The stack is of length 0x4000 which means 0x4000 bytes of memory should have been printed by the exception handler but the log only has 1372 lines with a gap at line number 187.Pls attach the original exception log.Pls dont copy paste the log which may result in info getting missed.
    Based on the preliminary analysis HDVPSS display ISR is crashing in an ISR , in a function which should never get invoked since you dont use VCOMP module. This again points to memory corruption.Are you sure enture 2G is addressable and your DMM LISA mapping is correct  ? Can you write a test code in u boot which writes increasing number is different address range in entire 2G and reads it back and compares with original value.
    On the video M3 crash is again happening from within an ISR but since the log you have shared is incomplete we are unable to locate the function in the ISR where crash is occuring.
    Pls also share your kernel bootargs and the map file of the .xem3
  • Hi Badri,
    Here I am attaching videom3 text file FYI.
    Let me DDR3 test one more time in boot-loader.
    8625.CCS_CRASH_DUMP_VIDEO-M3.txt
    With Regards
    Mahesh Kalmeshwar.
    I have tested 4GDDR3 in uboot  - the tests are passed.
    Please let me know how to proceed ?
    Mahesh Kalmeshwar
