8148 apk download issues
Other Parts Discussed in Thread: PMP
Hello
when we are downloading the apk application  it is giving the following error.
init: untracked pid 160 exited
init: untracked pid 223 exited
init: untracked pid 263 exited
init: untracked pid 237 exited
init: untracked pid 250 exited
init: untracked pid 277 exited
init: untracked pid 301 exited
init: untracked pid 312 exited
init: untracked pid 322 exited
init: untracked pid 162 exited
 we are using JFFS2 file system  / ext 3 the problem is same when we are using nfs file system it is working fine.
enclosing  message and logcat information.
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37 (asif@asif-laptop) (gcc version 4.4.0 (GCC) ) #1 Thu Nov 29 19:37:24 2
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148evm
vram size = 67108864 at 0
reserved size = 67108864 at 0
FB: Reserving 67108864 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 48640
Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 noinitrd init=/init 2
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 192MB = 192MB total
Memory: 188420k/188420k available, 73724k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0038000   ( 192 kB)
      .text : 0xc0038000 - 0xc04d5000   (4724 kB)
      .data : 0xc04d6000 - 0xc0519860   ( 271 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 398.95 BogoMIPS (lpj=1994752)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
registered ti814x_vpss device
registered TI814x on-chip HDMI device
pm_dbg_init: only OMAP3 supported
Registered ti81xx_fb device
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
pcf857x: probe of 1-0021 failed with error -121
i2c i2c-1: Failed to register i2c client PCF_8575 at 0x21 (-16)
i2c i2c-1: Can't create device at 0x21
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at d080c000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at d081e800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
ashmem: initialized
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 368
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
ahci ahci.0: forcing PORTS_IMPL to 0x1
ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xcc (Micron )
Creating 6 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x000017dc0000 : "File System"
0x000017dc0000-0x000020000000 : "Reserved"
usb 1-1: new full speed USB device using musb-hdrc and address 2
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
qt602240_ts 1-004a: __qt602240_read_reg: i2c transfer failed
qt602240_ts: probe of 1-004a failed with error -5
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
ata1: SATA link down (SStatus 0 SControl 300)
device-mapper: ioctl: 4.18.0-ioctl (2010-06-29) initialised: dm-devel@redhat.com
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 64K log 'log_main'
logger: created 256K log 'log_events'
logger: created 64K log 'log_radio'
logger: created 64K log 'log_system'
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbf900000
usbcore: registered new interface driver snd-usb-audio
----> asif--> sound-->aic3x_probe
-->asif-->sound-->soc-->soc_core.c-->soc_new_pcm--> Able to Create pcm for codec tlv320aic8
-->asif-->sound-->soc-->soc_core.c-->soc_new_pcm--> Able to create platform pcm constructor
---> asif-->sound->soc->soc-cor.c->soc_new_pcm--> asoc: tlv320aic3x-hifi <-> davinci-mcaspk
soc-audio soc-audio.0: -->asif-->sound-->soc-->soc_core.c-->soc_probe-->Able to Register t
-->Asif-->sound-->last.c-->alsa_sound_last_init-->ALSA device list:
  #0: TI81XX EVM
 --> Asif-->sound-->last.c--> Sound card found
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Detected MACID=0:0:0:0:0:0
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
usb 1-1: New USB device found, idVendor=03eb, idProduct=0902
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usb 1-1.4: new low speed USB device using musb-hdrc and address 3
usb 1-1.4: New USB device found, idVendor=0458, idProduct=003a
usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.4: Product: Optical Mouse
usb 1-1.4: Manufacturer: Genius
input: Genius Optical Mouse as /devices/platform/musb-ti81xx.0/musb-hdrc.0/usb1/1-1/1-1.4/0
generic-usb 0003:0458:003A.0001: input: USB HID v1.11 Mouse [Genius Optical Mouse] on usb-0
Empty flash at 0x04ade7cc ends at 0x04ade800
VFS: Mounted root (jffs2 filesystem) on device 31:4.
devtmpfs: mounted
Freeing init memory: 192K
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
# SysLink version : 2.00.02.80
SysLink module created on Date:May 17 2012 Time:15:33:48
parc technology asif@parctech.co.in HDMI W1 rev 4.0
usb 1-1.4: USB disconnect, address 3
# usb 1-1.4: new low speed USB device using musb-hdrc and address 4
input: Genius Optical Mouse as /devices/platform/musb-ti81xx.0/musb-hdrc.0/usb1/1-1/1-1.4/1
generic-usb 0003:0458:003A.0002: input: USB HID v1.11 Mouse [Genius Optical Mouse] on usb-0
# ifconfig eth0 192.168.1.74
CPSW phy found : id is : 0x4dd074
# PHY: 0:00 - Link is Up - 1000/Full
# ifwarning: `zygote' uses 32-bit capabilities (legacy support in use)
alarm_set_rtc: no RTC, time will be lost on reboot
config
# ifconfig eth0
eth0: ip 192.168.1.74 mask 255.255.255.0 flags [up broadcast running multicast]
# ata1: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen
ata1: irq_stat 0x00000040, connection status changed
ata1: SError: { CommWake DevExch }
ata1: hard resetting link
ata1: SATA link down (SStatus 1 SControl 300)
ata1: EH complete
binder: 152: binder_alloc_buf, no vma
binder: 102:108 transaction failed 29201, size 4-0
binder: send failed reply for transaction 570 to 152:152
alarm_release: clear alarm, pending 0
request_suspend_state: wakeup (3->0) at 113213232952 (1970-01-02 00:00:36.047197650 UTC)
 OMAPLFBManualSync Not Supported
logcat
/BootReceiver(  101): Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
E/ApplicationContext(  101): Couldn't rename file /data/system/shared_prefs/log_files.xml k
E/DropBoxManagerService(  101): Can't write: SYSTEM_TOMBSTONE
E/DropBoxManagerService(  101): java.io.FileNotFoundException: /data/system/dropbox/drop53)
E/DropBoxManagerService(  101):         at org.apache.harmony.luni.platform.OSFileSystem.o)
E/DropBoxManagerService(  101):         at dalvik.system.BlockGuard$WrappedFileSystem.open)
E/DropBoxManagerService(  101):         at java.io.FileOutputStream.<init>(FileOutputStrea)
E/DropBoxManagerService(  101):         at com.android.server.DropBoxManagerService.add(Dr)
E/DropBoxManagerService(  101):         at android.os.DropBoxManager.addText(DropBoxManage)
E/DropBoxManagerService(  101):         at com.android.server.BootReceiver.addFileToDropBo)
E/DropBoxManagerService(  101):         at com.android.server.BootReceiver.logBootEvents(B)
E/DropBoxManagerService(  101):         at com.android.server.BootReceiver.access$000(Boot)
E/DropBoxManagerService(  101):         at com.android.server.BootReceiver$1.run(BootRecei)
I/BootReceiver(  101): Copying /data/tombstones/tombstone_08 to DropBox (SYSTEM_TOMBSTONE)
D/dalvikvm(  101): GC_FOR_MALLOC freed 219K, 45% free 4264K/7687K, external 1916K/2516K, ps
I/BootReceiver(  101): Copying /data/tombstones/tombstone_07 to DropBox (SYSTEM_TOMBSTONE)
D/dalvikvm(  101): GC_FOR_MALLOC freed 145K, 45% free 4234K/7687K, external 1916K/2516K, ps
I/dalvikvm-heap(  101): Grow heap (frag case) to 8.447MB for 62217-byte allocation
D/dalvikvm(  101): GC_FOR_MALLOC freed <1K, 45% free 4295K/7751K, external 1916K/2516K, pas
D/dalvikvm(  101): GC_FOR_MALLOC freed <1K, 45% free 4335K/7751K, external 1916K/2516K, pas
I/dalvikvm-heap(  101): Grow heap (frag case) to 8.565MB for 82948-byte allocation
D/dalvikvm(  101): GC_FOR_MALLOC freed 0K, 44% free 4416K/7879K, external 1916K/2516K, paus
D/dalvikvm(  101): GC_FOR_MALLOC freed 81K, 45% free 4376K/7879K, external 1916K/2516K, pas
I/dalvikvm-heap(  101): Grow heap (frag case) to 8.684MB for 165880-byte allocation
D/dalvikvm(  101): GC_FOR_MALLOC freed 0K, 44% free 4538K/8071K, external 1916K/2516K, paus
D/dalvikvm(  101): GC_FOR_MALLOC freed 222K, 46% free 4396K/8071K, external 1916K/2516K, ps
I/BootReceiver(  101): Copying /data/tombstones/tombstone_06 to DropBox (SYSTEM_TOMBSTONE)
D/dalvikvm(  101): GC_FOR_MALLOC freed 470K, 47% free 4287K/8071K, external 1916K/2516K, ps
I/BootReceiver(  101): Copying /data/tombstones/tombstone_05 to DropBox (SYSTEM_TOMBSTONE)
I/BootReceiver(  101): Copying /data/tombstones/tombstone_04 to DropBox (SYSTEM_TOMBSTONE)
I/BootReceiver(  101): Copying /data/tombstones/tombstone_03 to DropBox (SYSTEM_TOMBSTONE)
I/BootReceiver(  101): Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
D/dalvikvm(  101): GC_FOR_MALLOC freed 765K, 48% free 4236K/8071K, external 1916K/2516K, ps
I/BootReceiver(  101): Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
I/BootReceiver(  101): Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
D/MediaScanner(  248):  prescan time: 4703ms
D/MediaScanner(  248):     scan time: 3080ms
D/MediaScanner(  248): postscan time: 1ms
D/MediaScanner(  248):    total time: 7784ms
D/MediaScannerService(  248): done scanning volume internal
I/ActivityManager(  101): Start proc com.cooliris.media for broadcast com.cooliris.media/c}
I/ActivityThread(  311): Pub com.cooliris.picasa.contentprovider: com.cooliris.picasa.Picar
D/dalvikvm(  311): GC_CONCURRENT freed 606K, 53% free 2798K/5831K, external 716K/1038K, pas
I/BootReceiver(  311): Got intent with action android.intent.action.MEDIA_SCANNER_FINISHED
E/DropBoxManagerService(  101): Can't write: system_app_strictmode
E/DropBoxManagerService(  101): java.io.FileNotFoundException: /data/system/dropbox/drop56)
E/DropBoxManagerService(  101):         at com.android.server.am.ActivityManagerService$10)
ata1: EH complete
JFFS2 notice: (49) check_node_data: wrong data CRC in data node at 0x148bf708: read 0x2b9a.
ata1: EH complete
D/AndroidRuntime(  326):
D/AndroidRuntime(  326): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<
D/AndroidRuntime(  326): CheckJNI is ON
D/dalvikvm(  326): creating instr width table
D/AndroidRuntime(  326): Calling main entry com.android.commands.pm.Pm
I/ActivityManager(  101): Start proc com.android.defcontainer for service com.android.defc}
D/dalvikvm(  334): GC_EXPLICIT freed 289K, 51% free 2736K/5511K, external 716K/1038K, pauss
W/ActivityManager(  101): No content provider found for:
W/dalvikvm(  101): threadid=12: thread exiting with uncaught exception (group=0x40204560)
E/PackageManager(  101): Couldn't create temp file for downloaded package file.
E/AndroidRuntime(  101): *** FATAL EXCEPTION IN SYSTEM PROCESS: PackageManager
E/AndroidRuntime(  101): java.lang.NullPointerException
E/AndroidRuntime(  101):        at com.android.server.PackageManagerService$FileInstallArg0
java:4983)
E/Analarm_release: clear alarm, pending 0
droidRuntime(  1alarm_release: clear alarm, pending 0
01):    at com.android.server.PackageManagerService$FileInstallArgs.copyApk(PackageManager)
E/AndroidRuntime(  101):        at com.android.server.PackageManagerService$InstallParams.)
E/AndroidRuntime(  101):        at crequest_suspend_state: wakeup (3->0) at 178708019152 ()
om.android.server.PackageManagerService$HandlerParams.startCopy(PackageManagerService.java)
E/AndroidRuntime(  101):        at com.android.server.PackageManagerService$PackageHandler)
E/AndroidRuntime(  101):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime(  101):        at android.os.Looper.loop(Looper.java:130)
E/AndroidRuntime(  101):        at android.os.HandlerThread.run(HandlerThread.java:60)
I/Process (  101): Sending signal. PID: 101 SIG: 9
E/DropBoxManagerService(  101): Can't write: system_server_crash
E/DropBoxManagerService(  101): java.io.FileNotFoundException: /data/system/dropbox/drop15)
E/DropBoxManagerService(  101):         at java.io.FileOutputStream.<iinit: untracked pid d
nit>(FileOutputSinit: untracked pid 181 exited
tream.java:94)
E/DropBoxManagerService(  101):         at com.android.server.am.ActivityManagerService$11)
E/DropBoxManagerService(  101):         at com.android.server.am.ActivityManagerService.ad)
E/DropBoxManagerService(  101):         at com.androiinit: untracked pid 183 exited
d.server.am.Actiinit: untracked pid 213 exited
vityManagerService.handleApplicationCrash(ActivityManagerService.java:6492)
E/DropBoxManagerService(  101):         at com.android.internal.os.RuntimeInit$UncaughtHan)
E/DropBoxManagerService(  101):         at java.lang.ThreadGroup.uncaughtException(ThreadG)
E/DropBoxManagerinit: untracked pid 236 exited
Service(  101): init: untracked pid 248 exited
        at java.lang.Thinit: untracked pid 260 exited
readGroup.uncaughtException(ThreadGroup.java:851)
I/Zygote  (   62): Exit zygote because system server (101) has terminated
E/installd(   65): eof
E/installd(   65): failed to read size
I/installd(   65): closing connection
E/InputQueue-JNI(  183): channel '4081a288 com.android.launcher/com.android.launcher2.Laun
red.  events=0x8
I/ServiceManager(   57): service 'audio' died
I/ServiceManager(   57): service 'usb' died
I/ServiceManager(   57): service 'uimode' died
I/ServiceManager(   57): service 'backup' died
I/ServiceManager(   57): service 'appwidget' died
I/ServiceManageinit: untracked pid 273 exited
r(   57): servicinit: untracked pid 290 exited
e 'diskstats' died
I/ServiceManager(   57): service 'telephony.registry' died
I/ServiceManager(   57): service 'usagestats' died
I/ServiceManager(   57): service 'SurfaceFlinger' died
I/ServiceManager(   57): service 'sensorservice' died
I/ServiceManager(   57): service 'entropy' died
I/ServiceManager(   57): service 'power' dieinit: untracked pid 299 exited
d
I/ServiceManainit: untracked pid 311 exited
ger(   57): servinit: untracked pid 334 exited
ice 'batteryinfo' died
I/ServiceManager(   57): service 'activity' died
I/ServiceManager(   57): service 'meminfo' died
I/ServiceManager(   57): service 'cpuinfo' died
I/ServiceManager(   57): service 'permission' died
I/ServiceManager(   57): service 'package' died
I/ServiceManager(   57): service 'content' died
I/ServiceManager(   57): service 'account' died
I/ServiceManager(   57): service 'vibrator' died
I/ServiceManager(   57): service 'hardware' died
I/ServiceManager(   57): service 'battery' died
I/ServiceManager(   57): service 'alarm' died
I/ServiceManager(   57): service 'window' died
I/ServiceManager(   57): service 'bluetooth' died
I/ServiceManager(   57): service 'bluetooth_a2dp' died
I/ServiceManager(   57): service 'device_policy' died
I/ServiceManager(   57): service 'statusbar' died
I/ServiceManager(   57): service 'clipboard' died
I/ServiceManager(   57): service 'network_management' died
I/ServiceManager(   57): service 'input_method' died
I/ServiceManager(   57): service 'netstat' died
I/ServiceManager(   57): service 'wifi' died
I/ServiceManager(   57): service 'connectivity' died
I/ServiceManager(   57): service 'throttle' died
I/ServiceManager(   57): service 'accessibility' died
I/ServiceManager(   57): service 'mount' died
I/ServiceManager(   57): service 'notification' died
I/ServiceManager(   57): service 'devicestoragemonitor' died
I/ServiceManager(   57): service 'location' died
I/ServiceManager(   57): service 'wallpaper' died
I/ServiceManager(   57): service 'search' died
I/ActivityThread(  334): Removing dead content provider: settings
I/ActivityThread(  181): Removing dead content provider: settings
E/InputQueue-JNI(  181): channel '4083b008 StatusBar (client)' ~ Publisher closed input ch8
E/InputQueue-JNI(  181): channel '4085b008 TrackingView (client)' ~ Publisher closed input8
E/InputQueue-JNI(  181): channel '407c7540 StatusBarExpanded (client)' ~ Publisher closed 8
I/ServiceManager(   57): service 'dropbox' died
I/ActivityThread(  236): Removing dead content provider: settings
I/ActivityThread(  152): Removing dead content provider: settings
D/AndroidRuntime(  345):
D/AndroidRuntime(  345): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<
D/AndroidRuntime(  345): CheckJNI is ON
D/dalvikvm(  345): creating instr width table
I/        (  344): ServiceManager: 0xad50
E/ALSALib (  344): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_noupdate) Invk
W/AudioHardwareALSA(  344): Unable to attach mixer to device AndroidPlayback: No such filey
E/ALSALib (  344): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_noupdate) Inve
W/AudioHardwareALSA(  344): Unable to attach mixer to device AndroidCapture: No such file y
D/TIALSAModule(  344): TI ALSA module opened
D/TIALSAModule(  344): Initializing devices for TI ALSA module
E/ServiceManager(   57): add_service('media.audio_flinger',0x5) uid=1013 - ALREADY REGISTED
E/ServiceManager(   57): add_service('media.player',0x5) uid=1013 - ALREADY REGISTERED
I/CameraService(  344): CameraService started (pid=344)
E/ServiceManager(   57): add_service('media.camera',0x5) uid=1013 - ALREADY REGISTERED
I/SamplingProfilerIntegration(  345): Profiler is disabled.
I/Zygote  (  345): Preloading classes...
D/dalvikvm(  345): GC_EXPLICIT freed 47K, 78% free 232K/1024K, external 0K/0K, paused 24ms
D/dalvikvm(  345): GC_EXPLICIT freed 1K, 73% free 282K/1024K, external 0K/0K, paused 24ms
D/dalvikvm(  345): GC_EXPLICIT freed 20K, 70% free 315K/1024K, external 0K/0K, paused 25ms
D/dalvikvm(  345): GC_EXPLICIT freed 17K, 66% free 353K/1024K, external 0K/0K, paused 5ms
D/dalvikvm(  345): GC_EXPLICIT freed 26K, 63% free 381K/1024K, external 0K/0K, paused 6ms
D/dalvikvm(  345): GC_EXPLICIT freed 22K, 58% free 440K/1024K, external 0K/0K, paused 27ms
W/MediaProfiles(  345): could not find media config xml file
D/dalvikvm(  345): GC_EXPLICIT freed 98K, 48% free 542K/1024K, external 0K/0K, paused 28ms
D/dalvikvm(  345): GC_EXPLICIT freed 271K, 24% free 881K/1155K, external 0K/0K, paused 58ms
D/dalvikvm(  345): GC_EXPLICIT freed 21K, 20% free 929K/1155K, external 0K/0K, paused 36ms
D/RenderScript_jni(  345): RenderScript JNI library not found!
D/dalvikvm(  345): GC_EXPLICIT freed 24K, 21% free 970K/1219K, external 0K/0K, paused 56ms
D/dalvikvm(  345): GC_EXPLICIT freed 24K, 6% free 1276K/1347K, external 0K/0K, paused 63ms
^C
Asif
