TI-Android-ICS-4.0.3_AM37x_3.0.0.bin
We have downloaded the Prepackaged Dev Kit sources from the following link.
Then we tried extract the source using the following command
./TI-Android-ICS-4.0.3_AM37x_3.0.0.bin
After some time we got the following error
Files extracted successfully.
Path :: /home/Autolinux5/Linux_Kernel/TI-Android-ICS-4.0.3_AM37x_3.0.0
Populating Sources...!!!
Checking out files: 100% (2584/2584), done.
Checking out files: 100% (18905/18905), done. files:   1% (262/18905)
Checking out files: 100% (4556/4556), done.
Checking out files: 100% (4664/4664), done.ut files:  11% (552/4664)
Checking out files: 100% (9386/9386), done.out files:  13% (1235/9386)
Checking out files: 100% (5365/5365), done.
Checking out files: 100% (1146/1146), done.out files:  26% (305/1146)
Checking out files: 100% (12/12), done.ing out files:  50% (6/12)
Checking out files: 100% (4876/4876), done.out files:   3% (161/4876)
Checking out files: 100% (65/65), done.ing out files:  32% (21/65)
Checking out files: 100% (46/46), done.ing out files:  39% (18/46)
Checking out files: 100% (745/745), done.g out files:  22% (167/745)
Checking out files: 100% (8311/8311), done.out files:   3% (282/8311)
Checking out files: 100% (36/36), done.ing out files:  44% (16/36)
Checking out files: 100% (705/705), done.g out files:  42% (300/705)
Checking out files: 100% (644/644), done.ng out files:  20% (135/644)
Checking out files: 100% (860/860), done.ng out files:  15% (136/860)
Checking out files: 100% (65/65), done.king out files:  29% (19/65)
Checking out files: 100% (1421/1421), done. out files:  34% (489/1421)
Checking out files: 100% (24603/24603), done.ut files:   5% (1238/24603)
Checking out files: 100% (18774/18774), done.ut files:   1% (191/18774)
Checking out files: 100% (247/247), done.ng out files:  13% (33/247)
Checking out files: 100% (353/353), done.ng out files:  16% (59/353)
Checking out files: 100% (345/345), done.
Checking out files: 100% (35638/35638), done.ut files:   0% (192/35638)
Checking out files: 100% (4253/4253), done.
Checking out files: 100% (2051/2051), done. out files:   6% (126/2051)
Checking out files: 100% (643/643), done.ng out files:  27% (178/643)
Checking out files: 100% (132/132), done.
Checking out files: 100% (877/877), done.ng out files:  50% (441/877)
Checking out files: 100% (641/641), done.ng out files:  35% (229/641)
Checking out files: 100% (138/138), done.ng out files:  34% (47/138)
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-nm
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-objcopy
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-objdump
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-ranlib
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-readelf
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-run
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-size
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-strings
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-strip
error: git checkout-index: unable to write file linux-x86/toolchain/arm-eabi-4.4.3/bin/xmlwf
fatal: cannot create directory at linux-x86/toolchain/arm-eabi-4.4.3/include
Traceback (most recent call last):
  File "/home/Autolinux5/Linux_Kernel/TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/repo/main.py", line 385, in <module>
    _Main(sys.argv[1:])
  File "/home/Autolinux5/Linux_Kernel/TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/repo/main.py", line 365, in _Main
    result = repo._Run(argv) or 0
  File "/home/Autolinux5/Linux_Kernel/TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/repo/main.py", line 137, in _Run
    result = cmd.Execute(copts, cargs)
  File "/home/Autolinux5/Linux_Kernel/TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/repo/subcmds/sync.py", line 466, in Execute
    project.Sync_LocalHalf(syncbuf)
  File "/home/Autolinux5/Linux_Kernel/TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/repo/project.py", line 983, in Sync_LocalHalf
    self._InitWorkTree()
  File "/home/Autolinux5/Linux_Kernel/TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/repo/project.py", line 1770, in _InitWorkTree
    raise GitError("cannot initialize work tree")
error.GitError: cannot initialize work tree
Kindly guide us to proceed further
G.Vetrivel.
  • Ensure that the sources are ok by verifying the md5sum.
    Also make sure that you have atleast 10-15 GB of hard disk space available before starting installation of sources.
  • Comment;
    Other thing to check is if the Linux distribution is allowing executable in home directories, or extraction directory has execution permission.
    The files that present an error are binaries.
    http://software-dl.ti.com/dsps/dsps_public_sw/sdo_tii/TI_Android_DevKit/TI_Android_ICS_4_0_3_DevKit_3_0_0/exports/TI-Android-ICS-4.0.3_AM37x_3.0.0.bin
    After some time we got the following errors,
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/markdown.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/neven.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/neven.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/iw.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/iw.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/jdiff.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/jdiff.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/jpeg.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/jpeg.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/v8.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/v8.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/wpa_supplicant_8.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/wpa_supplicant_8.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/libgsm.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/libgsm.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/javasqlite.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/javasqlite.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/elfutils.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/elfutils.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/tremolo.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/tremolo.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/esd.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/esd.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/embunit.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/embunit.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/easymock.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/easymock.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/tinyalsa.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/tinyalsa.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/speex.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/speex.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/doclava.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/doclava.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/mksh.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/mksh.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/giflib.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/giflib.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/libphonenumber.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/libphonenumber.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/sonivox.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/sonivox.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/oauth.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/oauth.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/tcpdump.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/external/tcpdump.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Contacts.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Contacts.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/VideoEditor.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/VideoEditor.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/MusicFX.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/MusicFX.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Gallery.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Gallery.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Stk.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Stk.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/KeyChain.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/KeyChain.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/TemperatureWidget.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/TemperatureWidget.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/FileManager.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/FileManager.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Music.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Music.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Gallery2.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Gallery2.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Protips.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Protips.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/DeskClock.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/DeskClock.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Mms.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Mms.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Provision.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Provision.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Bluetooth.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Bluetooth.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Camera.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Camera.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Calendar.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Calendar.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Exchange.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Exchange.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Settings.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Settings.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Browser.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Browser.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/CertInstaller.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/CertInstaller.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Calculator.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Calculator.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/CellBroadcastReceiver.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/CellBroadcastReceiver.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Amazed.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Amazed.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Launcher2.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Launcher2.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Nfc.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Nfc.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/BasicSmsReceiver.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/BasicSmsReceiver.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/SoundRecorder.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/SoundRecorder.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/VoiceDialer.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/VoiceDialer.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/QuickSearchBox.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/QuickSearchBox.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/PackageInstaller.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/PackageInstaller.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/HTMLViewer.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/HTMLViewer.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Email.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Email.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Tag.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Tag.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/SpareParts.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/SpareParts.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Phone.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/Phone.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/SpeechRecorder.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps/SpeechRecorder.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/apps: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/experimental.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/experimental.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/inputmethods/PinyinIME.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/inputmethods/PinyinIME.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/inputmethods/LatinIME.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/inputmethods/LatinIME.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/inputmethods/OpenWnn.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/inputmethods/OpenWnn.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/inputmethods: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/DrmProvider.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/DrmProvider.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/ApplicationsProvider.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/ApplicationsProvider.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/ContactsProvider.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/ContactsProvider.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/UserDictionaryProvider.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/UserDictionaryProvider.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/CalendarProvider.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/CalendarProvider.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/MediaProvider.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/MediaProvider.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/DownloadProvider.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/DownloadProvider.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/TelephonyProvider.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/TelephonyProvider.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/GoogleContactsProvider.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers/GoogleContactsProvider.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/providers: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/LivePicker.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/LivePicker.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/Galaxy4.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/Galaxy4.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/Basic.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/Basic.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/HoloSpiral.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/HoloSpiral.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/MusicVisualization.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/MusicVisualization.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/NoiseField.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/NoiseField.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/PhaseBeam.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/PhaseBeam.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/MagicSmoke.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers/MagicSmoke.git: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages/wallpapers: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/packages: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/u-boot.git/hooks: Directory renamed before its status could be extracted
    tar: TI-Android-ICS-4.0.3_AM37x_3.0.0/.repo/projects/u-boot.git: Directory renamed before its status could be extracted
    tar: Exiting with failure status due to previous errors
    ERROR: Couldn't extract files.
    Kindly help us to further proceed
    Raja.N
    Please try to download sources from our gitorious rowboat project. Follow below link for instructions.
    http://processors.wiki.ti.com/index.php/TI-Android-ICS-4.0.3-DevKit-3.0.0_DevelopersGuide#Using_Rowboat_Gitorious
    Thanks and Regards,
    Pankaj Bharadiya
  • TI-Android-ICS-4.0.3_AM37x_3.0.0.bin doen't have support for BeagleBoard xM rev C4.
    Does the link above have the updated support?
