Other Parts Discussed in Thread: AM3358, TPS65910
I am using TPS65910 for the AM3358. All the supplies for the IO domain (VDDSHVx) are set to 3.3V operation. Take as an example the Ethernet RGMII2 that uses the VDDSHV5. Am I right to assume that is ok to connect my Ethernet PHY directly to a 3.3V supply that is generated from an LDO on my card and not using the VDDSHV5 as long asd the voltage levels is the same? Any recommendation for the layout in this case?
Thanks.
Yu-Li
