In 8168's datasheet, we can find McAsp's PWRIDLE SYSCOFIG register, its address offset is 04. But I cannot find this register in 8168 manual. Why?
Chen
Chen
Hi Chen,
I will check with our McASP design engineers about that register. If this register is not integrated inside the DM816x McASP module, we will remove it from the DM816x Datasheet (sprs614c). If this register is integrated inside the DM816x McASP module, we will add it in the DM816x TRM (sprugx8a).
If this register is integrated inside the DM816x McASP module, it will match the description and offset (0x4) of the OMAP4430 ES2.x MCASP_SYSCONFIG register:
Description Power idle configuration register.
Bits Field Name Description Type Reset
31:2 RESERVED Reserved R 0x0
1:0 IDLE_MODE 0x0: Force-idle mode RW 0x2
0x1: No-Idle mode
0x2: Smart-idle mode - default state
0x3: Reserved
As I can read the McASP2 SYSCONFIG register reset value (at address 0x48050004) successfully, I read the value of 0x00000002 in my own DM816x EVM, most probably this register will be added in the DM816x McASP TRM. I will let know our final decision.
Pavel
