I'm tying to use clock() function to get the clock tick on the TI TMS320C5515 DSP board. But the value returned is always 0. Does any have an idea of this?
Qingkun
Qingkun
In order to make the clock() function work, you need to enable clock in Code Composer Studio. If you are using CCS v5, after connecting the target, go to 'Run' menu and click on 'Enable' under 'Clock' sub-menu. If you are using CCS v4, after connecting the target, go to 'Target' menu and click on 'Enable' under 'Clock' sub-menu. If you are using CCS v3, go to 'Profile' menu and select 'Enable' under 'Clock' sub-menu.
Hope this helps.
Rahul Nair
