hi
WCDMA test has been completed with the following code.
* Copyright (C) 2009 Texas Instruments Incorporated. *
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <c6x.h>
#include <ti/csl/src/intc/csl_intc.h>
#include <sfp\BSLC667X_sfp.h>
#include <ti\csl\csl_pscAux.h>
#include <control/BSLC667X_control.h>
#include "..\src\Aif2_config.h"
#define DEBUG_NON_RP1_TIMING 1
//Users should use 16 bytes aligned(Quad word) data for Aif2 and PktDMA data flow
#pragma DATA_ALIGN (dio_data, 16)
Uint32 dio_data[16 * 4 * 32];
#pragma DATA_ALIGN (dio_result, 16)
Uint32 dio_result[16 * 4 * 32];
/* Intc variable declarartion */
CSL_IntcObj intcObj;
CSL_IntcHandle hIntc;
CSL_IntcEventHandlerRecord EventHandler[8];
CSL_IntcGlobalEnableState state;
/* Global structures and variables */
CSL_Aif2Obj Aif2Obj;// Aif2 CSL object
CSL_Aif2Handle hAif2;// Aif2 handle
Bool ctrlArg; // Ctrl Argument;
CSL_Aif2Context Aif2Context;//Aif2 context
CSL_Aif2Param aif2Param;//AIF2 module specific parameters
CSL_Status status; // CSL status
CSL_Aif2Setup aif2Setup;//Aif2 HW setup
CSL_Aif2LinkSetup linkSetup;// Setup for links
CSL_Aif2GlobalSetup globalSetup;// global config for AIF2
CSL_Aif2CommonSetup commonSetup; // Setup for common params
CSL_Aif2SdCommonSetup SdCommonSetup;//SERDES common setup
CSL_Aif2PdCommonSetup PdCommonSetup;//PD common setup
CSL_Aif2PeCommonSetup PeCommonSetup;//PE common setup
CSL_Aif2IngrDbSetup IngrDbSetup;// Ingress data buffer setup
CSL_Aif2EgrDbSetup EgrDbSetup;// Egress data buffer setup
CSL_Aif2AdCommonSetup AdCommonSetup;// Aif2 DMA common setup
CSL_Aif2AdDioSetup AdDioSetup;// Aif2 DIO common setup
CSL_Aif2AtCommonSetup AtCommonSetup; // Aif2 Timer common setup
CSL_Aif2AtEventSetup AtEventSetup; // Aif2 Timer external and internal event setup
CSL_Aif2AtCountObj PhyTimerTc;// AT Phy Terminal Count setup
CSL_Aif2AtCountObj RadTimerTc;// AT Rad Terminal Count setup
CSL_Aif2AtCountObj PhyTimerInit;// AT Phy Init value setup
CSL_Aif2AtCountObj RadTimerInit;// AT Rad Init value setup
CSL_Aif2AtCountObj UlRadTimerInit;// AT Rad Init value setup
CSL_Aif2CommonLinkSetup ComLinkSetup; // Aif2 link common setup
CSL_Aif2SdLinkSetup SdLinkSetup; //SERDES link setup
CSL_Aif2RmLinkSetup RmLinkSetup; //RM link setup
CSL_Aif2TmLinkSetup TmLinkSetup; //TM link setup
CSL_Aif2PdLinkSetup PdLinkSetup; //PD link setup
CSL_Aif2PeLinkSetup PeLinkSetup; //PE link setup
CSL_Aif2RtLinkSetup RtLinkSetup; //RT link setup
CSL_Aif2AtLinkSetup AtLinkSetup; // Aif2 timer link setup (Pi, Delta, PE signal)
volatile unsigned int int4_result;
interrupt void int4_isr(){
int4_result++;
void Intc_config(void)
CSL_IntcParam vectId;
CSL_IntcContext context;
//! GEM0 Intc Configuration !//
/* Setup the global Interrupt */
context.numEvtEntries = 8;
context.eventhandlerRecord = EventHandler;
CSL_intcInit(&context);
/* Enable NMIs */
CSL_intcGlobalNmiEnable();
/* Enable Global Interrupts */
CSL_intcGlobalEnable(&state);
/* VectorID for the Global Edma Event */
vectId = CSL_INTC_VECTID_4;
/* Opening a handle for the Fsync->EDMA Interrupt Event */
hIntc = CSL_intcOpen(&intcObj,
AIF2_EVENT7_INTSEL_MAP, // Event7
&vectId,
NULL);
//Hook the ISRs
CSL_intcHookIsr(vectId, &int4_isr);
// Clear the Interrupt
CSL_intcHwControl(hIntc, CSL_INTC_CMD_EVTCLEAR, NULL);
//Enable the Event & the interrupt
CSL_intcHwControl(hIntc, CSL_INTC_CMD_EVTENABLE, NULL);
void Aif2_Dio_Cpri_Tac_config(CSL_Aif2LinkIndex link)
BSLC667X_ErrorCode Err;
unsigned short usRegVal;
int i;
//////////////////Initialize Aif2 structures to avoid unwanted configuration ////////////////////////////////////////
memset(&globalSetup, 0, sizeof(globalSetup));
memset(&linkSetup, 0, sizeof(linkSetup));
memset(&commonSetup, 0, sizeof(commonSetup));
memset(&SdCommonSetup, 0, sizeof(SdCommonSetup));
memset(&PdCommonSetup, 0, sizeof(PdCommonSetup));
memset(&PeCommonSetup, 0, sizeof(PeCommonSetup));
memset(&IngrDbSetup, 0, sizeof(IngrDbSetup));
memset(&EgrDbSetup, 0, sizeof(EgrDbSetup));
memset(&AdCommonSetup, 0, sizeof(AdCommonSetup));
memset(&AdDioSetup, 0, sizeof(AdDioSetup));
memset(&AtCommonSetup, 0, sizeof(AtCommonSetup));
memset(&AtEventSetup, 0, sizeof(AtEventSetup));
memset(&PhyTimerInit, 0, sizeof(PhyTimerInit));
memset(&RadTimerInit, 0, sizeof(RadTimerInit));
memset(&UlRadTimerInit, 0, sizeof(UlRadTimerInit));
memset(&PhyTimerTc, 0, sizeof(PhyTimerTc));
memset(&RadTimerTc, 0, sizeof(RadTimerTc));
memset(&ComLinkSetup, 0, sizeof(ComLinkSetup));
memset(&SdLinkSetup, 0, sizeof(SdLinkSetup));
memset(&RmLinkSetup, 0, sizeof(RmLinkSetup));
memset(&TmLinkSetup, 0, sizeof(TmLinkSetup));
memset(&PdLinkSetup, 0, sizeof(PdLinkSetup));
memset(&PeLinkSetup, 0, sizeof(PeLinkSetup));
memset(&RtLinkSetup, 0, sizeof(RtLinkSetup));
memset(&AtLinkSetup, 0, sizeof(AtLinkSetup));
// Initialize CSL library, this step is required
CSL_aif2Init(&Aif2Context);
// Open Aif2 and get handle
hAif2 = CSL_aif2Open(&Aif2Obj, CSL_AIF, &aif2Param, &status);
if ((hAif2 == NULL) || (status != CSL_SOK))
printf ("\nError opening CSL_AIF2");
exit(1);
/////////////////populating AIF2 major setup structures //////////////////////////////////////////////////////////
aif2Setup.globalSetup = &globalSetup;
aif2Setup.commonSetup = &commonSetup;
aif2Setup.linkSetup[link] = &linkSetup;//assign only one link setup for link 0
// populate global config fields
globalSetup.ActiveLink[link] = TRUE;//Activate link 0 for this test
globalSetup.frameMode = CSL_AIF2_FRAME_MODE_NORMAL;
//populate common config fields
commonSetup.pSdCommonSetup = &SdCommonSetup;
commonSetup.pPdCommonSetup = &PdCommonSetup;
commonSetup.pPeCommonSetup = &PeCommonSetup;
commonSetup.pIngrDbSetup = &IngrDbSetup;
commonSetup.pEgrDbSetup = &EgrDbSetup;
commonSetup.pAdCommonSetup = &AdCommonSetup;
commonSetup.pAdDioSetup = &AdDioSetup;
commonSetup.pAtCommonSetup = &AtCommonSetup;
commonSetup.pAtEventSetup = &AtEventSetup;
////////////Link Setup (Do this setup repeatedly with different link setup structure if user wants to use multiple links)////////////
//populate link config fields for link 0
linkSetup.linkIndex = link;
linkSetup.pComLinkSetup = &ComLinkSetup;
linkSetup.pSdLinkSetup = &SdLinkSetup;
linkSetup.pRmLinkSetup = &RmLinkSetup;
linkSetup.pTmLinkSetup = &TmLinkSetup;
linkSetup.pPdLinkSetup = &PdLinkSetup;
linkSetup.pPeLinkSetup = &PeLinkSetup;
linkSetup.pRtLinkSetup = &RtLinkSetup;
linkSetup.pAtLinkSetup = &AtLinkSetup;
//Link Common setup
ComLinkSetup.linkProtocol = CSL_AIF2_LINK_PROTOCOL_CPRI;
ComLinkSetup.linkRate = CSL_AIF2_LINK_RATE_4x;
ComLinkSetup.IngrDataWidth = CSL_AIF2_DATA_WIDTH_15_BIT;
ComLinkSetup.EgrDataWidth = CSL_AIF2_DATA_WIDTH_15_BIT;
//SD link setup
SdLinkSetup.rxAlign = CSL_AIF2_SD_RX_COMMA_ALIGNMENT_ENABLE;
SdLinkSetup.rxLos = CSL_AIF2_SD_RX_LOS_ENABLE;
SdLinkSetup.rxCdrAlgorithm = CSL_AIF2_SD_RX_CDR_FIRST_ORDER_THRESH_17;
SdLinkSetup.rxInvertPolarity = CSL_AIF2_SD_RX_NORMAL_POLARITY;
SdLinkSetup.rxTermination = CSL_AIF2_SD_RX_TERM_COMMON_POINT_0_7 ;//for AC coupled application
SdLinkSetup.rxEqualizerConfig = CSL_AIF2_SD_RX_EQ_ADAPTIVE;//Equalizer On
SdLinkSetup.bRxEqHold = FALSE;//fixed value
SdLinkSetup.bRxOffsetComp = TRUE;//fixed value
SdLinkSetup.bEnableTxSyncMater = TRUE; //fixed value
SdLinkSetup.txInvertPolarity = CSL_AIF2_SD_TX_PAIR_NORMAL_POLARITY;
SdLinkSetup.txOutputSwing = CSL_AIF2_SD_TX_OUTPUT_SWING_14;
SdLinkSetup.txPrecursorTapWeight = CSL_AIF2_SD_TX_PRE_TAP_WEIGHT_2;// -5%
SdLinkSetup.txPostcursorTapWeight = CSL_AIF2_SD_TX_POST_TAP_WEIGHT_24;// -20%
SdLinkSetup.bTxFirFilterUpdate = TRUE;//FIR filter update on
//TM link setup
TmLinkSetup.bEnableTmLink = TRUE;
TmLinkSetup.bEnableRmLos = FALSE;
TmLinkSetup.SeedValue = 0x1;
TmLinkSetup.bEnableScrambler = FALSE;
TmLinkSetup.pCpriTmSetup.L1InbandEn = 0;//disable 9 bits mask
TmLinkSetup.pCpriTmSetup.RmLinkLosError = link;//select link 0 as source RM link
TmLinkSetup.pCpriTmSetup.RmLinkLofError = link;//select link 0 as source RM link
TmLinkSetup.pCpriTmSetup.RmLinkLosRx = link;//select link 0 as source RM link
TmLinkSetup.pCpriTmSetup.RmLinkLofRx = link;//select link 0 as source RM link
TmLinkSetup.pCpriTmSetup.RmLinkRaiRx = link;//select link 0 as source RM link
TmLinkSetup.pCpriTmSetup.TxStartup = 0;
TmLinkSetup.pCpriTmSetup.TxPointerP = 20;//for Ethernet channel
TmLinkSetup.pCpriTmSetup.TxProtocolVer = 1;
//RM link setup
RmLinkSetup.bEnableRmLink = TRUE;
RmLinkSetup.RmFifoThold = CSL_AIF2_RM_FIFO_THOLD_IMMEDIATELY;
RmLinkSetup.RmErrorSuppress = CSL_AIF2_RM_ERROR_ALLOW;
RmLinkSetup.bEnableSdAutoAlign = FALSE;
RmLinkSetup.bEnableScrambler = FALSE;
RmLinkSetup.bEnableLcvUnsync = FALSE;
RmLinkSetup.bEnableLcvControl = FALSE;
RmLinkSetup.bEnableWatchDog = FALSE;
RmLinkSetup.WatchDogWrap = 0xFF;//set watch dog wrap value
RmLinkSetup.bEnableClockQuality = FALSE;
RmLinkSetup.ClockMonitorWrap = 0;
RmLinkSetup.losDetThreshold = RM_LOS_DET_THOLD;
RmLinkSetup.SyncThreshold = RM_SYNC_THOLD;
RmLinkSetup.FrameSyncThreshold = RM_SYNC_THOLD;
RmLinkSetup.UnsyncThreshold = RM_UNSYNC_THOLD;
RmLinkSetup.FrameUnsyncThreshold = RM_UNSYNC_THOLD;
//RT link setup
RtLinkSetup.CiSelect = link;
RtLinkSetup.bEnableEmptyMsg = TRUE;
RtLinkSetup.RtConfig = CSL_AIF2_RT_MODE_TRANSMIT;// takes PE input only
//PD link setup
PdLinkSetup.bEnablePdLink = TRUE;
PdLinkSetup.CpriEnetStrip = 1;//enable ethernet strip for control channel 0
PdLinkSetup.Crc8Poly = CRC8_POLY;
PdLinkSetup.Crc8Seed = CRC8_SEED;
PdLinkSetup.CpriCwNullDelimitor = 0xFB;//K 27.7 charactor
PdLinkSetup.CpriCwPktDelimitor[0] = CSL_AIF2_CW_DELIM_NULLDELM;//4
PdLinkSetup.PdCpriCrcType[0] = CSL_AIF2_CRC_16BIT;
PdLinkSetup.bEnableCpriCrc[0] = FALSE;//enable CPRI CRC for control channel 0
PdLinkSetup.PdPackDmaCh[0] = 124;//Set DB channel 124 as a dma ch for control channel 0
PdLinkSetup.bEnablePack[0] = FALSE;//enable CPRI control channel 0 packing
PdLinkSetup.PdCpriDualBitMap.DbmX = 15;// for 4x link speed with 15 bit data. set X-1
PdLinkSetup.PdCpriDualBitMap.DbmXBubble = 1;//2 bubbles of 1 AxC sample
PdLinkSetup.PdCpriDualBitMap.Dbm1Mult = 0;//set n-1
PdLinkSetup.PdCpriDualBitMap.Dbm1Size = 0;//set n-1
PdLinkSetup.PdCpriDualBitMap.Dbm1Map[0] = 0x0;
PdLinkSetup.PdCpriDualBitMap.Dbm2Size = 0;
PdLinkSetup.PdCpriDualBitMap.Dbm2Map[0] = 0x0;
for(i=0;i<16;i++)//cpri id lut setup for X position 0 ~ 15
PdLinkSetup.CpriDmaCh[i]= i; //DbmX channel num (X position num and DB channel number is same in this test)
PdLinkSetup.bEnableCpriX[i]= TRUE; //enable CPRI X channel
PdLinkSetup.bEnableCpriPkt[i]= FALSE;//use AxC data mode
PdLinkSetup.Cpri8WordOffset[i]= 0;//word level CPRI data offset (fine AxC offset)
for(i=0;i<256;i++)//cpri cw lut setup
PdLinkSetup.CpriCwChannel[i]= 0; //set cw channel num to pack 0
PdLinkSetup.bEnableCpriCw[i]= FALSE; //disable CW sub channel
//PE link setup
PeLinkSetup.bEnablePeLink = TRUE;
PeLinkSetup.PeCppiDioSel = CSL_AIF2_DIO;
PeLinkSetup.Crc8Poly = CRC8_POLY;
PeLinkSetup.Crc8Seed = CRC8_SEED;
PeLinkSetup.PeDelay = DB_PE_DELAY_CPRI;
PeLinkSetup.PeCpriDualBitMap.DbmX = 15;// for 4x link speed with 15 bit data. set X-1
PeLinkSetup.PeCpriDualBitMap.DbmXBubble = 1;//2 bubbles of 1 AxC sample
PeLinkSetup.PeCpriDualBitMap.Dbm1Mult = 0;//set n-1
PeLinkSetup.PeCpriDualBitMap.Dbm1Size = 0;//set n-1
PeLinkSetup.PeCpriDualBitMap.Dbm1Map[0] = 0x0;
PeLinkSetup.PeCpriDualBitMap.Dbm2Size = 0;
PeLinkSetup.PeCpriDualBitMap.Dbm2Map[0] = 0x0;
PeLinkSetup.CpriAxCPack = CSL_AIF2_CPRI_15BIT_SAMPLE;
PeLinkSetup.CpriCwNullDelimitor = 0xFB;//K 27.7 charactor
PeLinkSetup.CpriCwPktDelimitor[0] = CSL_AIF2_CW_DELIM_NULLDELM;
PeLinkSetup.PePackDmaCh[0] = 124;
PeLinkSetup.bEnablePack[0] = FALSE;
PeLinkSetup.CpriCwChannel[i]= 0; //set cw channel num to pack 0
PeLinkSetup.bEnableCpriCw[i]= FALSE; //disable CPRI CW
//AT link setup
AtLinkSetup.PE1Offset = 470;
AtLinkSetup.PE2Offset = 490;
AtLinkSetup.DeltaOffset = 560;//TAC delay(230) + CPRI Egress 4 chip DMA delay(240) + 90
AtLinkSetup.PiMin = 560;
AtLinkSetup.PiMax = 580;
AtLinkSetup.IsNegativeDelta = FALSE;//positive delta
//////////////////// Common Setup ///////////////////////////////////////////////////////
//SD common setup
SdCommonSetup.bEnablePllB8 = TRUE;
SdCommonSetup.CLKBYP_B8 = CSL_AIF2_PLL_CLOCK_NO_BYPASS;
SdCommonSetup.LB_B8 = CSL_AIF2_PLL_LOOP_BAND_MID;//High BW is also fine
SdCommonSetup.VoltRangeB8 = CSL_AIF2_PLL_VOLTAGE_LOW;//fixed factor
SdCommonSetup.SleepPllB8 = CSL_AIF2_PLL_AWAKE;
SdCommonSetup.pllMpyFactorB8 = CSL_AIF2_PLL_MUL_FACTOR_20X;//for CPRI when reference clock is 122.88 Mhz
SdCommonSetup.SysClockSelect = CSL_AIF2_SD_BYTECLOCK_FROM_B8;
SdCommonSetup.DisableLinkClock[0] = FALSE;//enable LINK0 clock
SdCommonSetup.DisableLinkClock[1] = FALSE;//enable LINK1 clock
SdCommonSetup.DisableLinkClock[2] = FALSE;//enable LINK2 clock
SdCommonSetup.DisableLinkClock[3] = TRUE;//disable LINK3 clock
SdCommonSetup.DisableLinkClock[4] = TRUE;//disable LINK4 clock
SdCommonSetup.DisableLinkClock[5] = TRUE;//disable LINK5 clock
//PD common setup
PdCommonSetup.PdCppiDioSel = CSL_AIF2_DIO;//DIO
PdCommonSetup.AxCOffsetWin = AXC_OFFSET_WIN;//only used for OBSAI
PdCommonSetup.PdRadtTC = 2457599;// Radio frame size for CPRI
PdCommonSetup.PdFrameTC[0].FrameIndexSc = 0;//start index
PdCommonSetup.PdFrameTC[0].FrameIndexTc = 0;//teminal index
PdCommonSetup.PdFrameTC[0].FrameSymbolTc = 14;//15 slots for WCDMA
for(i=0;i<16;i++)//for channel 0 ~ 15
PdCommonSetup.PdChConfig[i].bChannelEn = TRUE;//Channel enable
PdCommonSetup.PdChConfig[i].DataFormat = CSL_AIF2_LINK_DATA_TYPE_NORMAL;//Data format
PdCommonSetup.AxCOffset[i] = 0;//Ingress AxC offset is not used for CPRI DIO
PdCommonSetup.PdChConfig1[i].bTsWatchDogEn = FALSE;//disable watchdog
PdCommonSetup.PdChConfig1[i].DataFormat = CSL_AIF2_GSM_DATA_OTHER;//Non GSM data
PdCommonSetup.PdChConfig1[i].FrameCounter = 0;//framing counter group number
PdCommonSetup.PdChConfig1[i].DioOffset = 0;//Use zero offset for simple test
PdCommonSetup.PdChConfig1[i].TddEnable = 0xFFFF;//enables all symbols(FDD)
PdCommonSetup.TddEnable1[i] = 0xFFFFFFFF;//enables all symbols(FDD)
PdCommonSetup.TddEnable2[i] = 0xFFFFFFFF;//enables all symbols(FDD)
PdCommonSetup.TddEnable3[i] = 0xFFFFFFFF;//enables all symbols(FDD)
PdCommonSetup.TddEnable4[i] = 0xFFFFFFFF;//enables all symbols(FDD)
PdCommonSetup.PdFrameMsgTc[0] = 639; // 640 CPRI quad samples (16 byte) are in WCDMA slot time
//PE common setup
PeCommonSetup.PeTokenPhase = 0;//Phase alignment for scheduling DMA. normally set to zero
PeCommonSetup.EnetHeaderSelect = 1;//bit order for Ethernet preamble and SOF
PeCommonSetup.GlobalDioLen = CSL_AIF2_DB_DIO_LEN_128;
PeCommonSetup.PeFrameTC[0].FrameIndexSc = 0;//start index
PeCommonSetup.PeFrameTC[0].FrameIndexTc = 0;//teminal index
PeCommonSetup.PeFrameTC[0].FrameSymbolTc = 14;//Set 14 for WCDMA
PeCommonSetup.bEnableCh[i] = TRUE;//Enable PE channel
PeCommonSetup.PeDmaCh0[i].bCrcEn = FALSE;//disable CRC
PeCommonSetup.PeDmaCh0[i].FrameTC = 0;//use framing terminal count 0
PeCommonSetup.PeDmaCh0[i].RtControl = CSL_AIF2_PE_RT_INSERT;//use PE insert option
PeCommonSetup.PeDmaCh0[i].CrcType = CSL_AIF2_CRC_8BIT;//CRC type
PeCommonSetup.PeDmaCh0[i].isEthernet = FALSE;//AxC data
PeCommonSetup.PeInFifo[i].SyncSymbol = 0;//Sync symbol offset
PeCommonSetup.PeInFifo[i].MFifoWmark = 2;//Message FIFO water mark
PeCommonSetup.PeInFifo[i].MFifoFullLevel = 3;//Message FIFO full level
PeCommonSetup.PeAxcOffset[i] = 490;//same to PE2 offset when there's no external offset
PeCommonSetup.PeFrameMsgTc[0] = 2559;//2560 CPRI samples (4 byte) are in WCDMA slot time
//PE Channel LUT setup and link routing selection (ChIndex number is matched with link number)
for (i=0; i<16; i++)
switch(link)
case CSL_AIF2_LINK_0:
PeCommonSetup.ChIndex0[i] = i; //channel 0 ~ 15
PeCommonSetup.bEnableChIndex0[i] = TRUE;//Route egress channel 0 ~ 15 dbm rule to modulo rule 0
PeCommonSetup.CpriPktEn0[i] = FALSE;
break;
case CSL_AIF2_LINK_1:
PeCommonSetup.ChIndex1[i] = i; //channel 0 ~ 15
PeCommonSetup.bEnableChIndex1[i] = TRUE;//Route egress channel 0 ~ 15 dbm rule to modulo rule 0
PeCommonSetup.CpriPktEn1[i] = FALSE;
break;
case CSL_AIF2_LINK_2:
PeCommonSetup.ChIndex2[i] = i; //channel 0 ~ 15
PeCommonSetup.bEnableChIndex2[i] = TRUE;//Route egress channel 0 ~ 15 dbm rule to modulo rule 0
PeCommonSetup.CpriPktEn2[i] = FALSE;
break;
default:
printf("Link %d is not connected on this card\n", link);
//Ingress DB setup
IngrDbSetup.bEnableIngrDb = TRUE; //Enable Ingress DB
IngrDbSetup.DioBufferLen = CSL_AIF2_DB_DIO_LEN_128; //Ingress DB DIO buffer length
IngrDbSetup.bEnableChannel[i] = TRUE; //Enable 16 Ingress DB channel
IngrDbSetup.IngrDbChannel[i].BaseAddress = (AIF2_DB_BASE_ADDR_I_FIFO_0 + i); //Set DB FIFO base address every 8 QW
IngrDbSetup.IngrDbChannel[i].DataSwap = CSL_AIF2_DB_WORD_SWAP; //DL
IngrDbSetup.IngrDbChannel[i].IQOrder = CSL_AIF2_DB_IQ_NO_SWAP; //No Order change
//Egress DB setup
EgrDbSetup.bEnableEgrDb = TRUE; //Enable Egress DB
EgrDbSetup.DioBufferLen = CSL_AIF2_DB_DIO_LEN_128; //Egress DB DIO buffer length
EgrDbSetup.PmControl = CSL_AIF2_DB_PM_TOKEN_FIFO;//for normal packet performance
EgrDbSetup.bEnableChannel[i] = TRUE; //Enable 16 Egress DB channel
EgrDbSetup.EgrDbChannel[i].BaseAddress = (AIF2_DB_BASE_ADDR_E_FIFO_0 + i); //Set DB FIFO base address every 8 QW
EgrDbSetup.EgrDbChannel[i].DataSwap = CSL_AIF2_DB_WORD_SWAP; //DL
EgrDbSetup.EgrDbChannel[i].IQOrder = CSL_AIF2_DB_IQ_NO_SWAP; //No Order change
EgrDbSetup.EgrDbChannel[i].EgressDioOffset = 0;//set zero for simple test
//AD Common and DIO setup
AdCommonSetup.IngrGlobalEnable = TRUE;
AdCommonSetup.EgrGlobalEnable = TRUE;
AdCommonSetup.IngrGlobalDioEnable = TRUE;
AdCommonSetup.EgrGlobalDioEnable = TRUE;
AdCommonSetup.FailMode = CSL_AIF2_AD_DROP;//drop fail packet
AdCommonSetup.IngrPriority = CSL_AIF2_AD_DIO_PRI;
AdCommonSetup.EgrPriority = CSL_AIF2_AD_AXC_PRI;
AdDioSetup.IngrDioEngineEnable[0] = TRUE;//Enable DIO Engine
AdDioSetup.IngrDioEngine[0].BcnTableSelect = CSL_AIF2_AD_DIO_BCN_TABLE_0;
AdDioSetup.IngrDioEngine[0].NumQuadWord = CSL_AIF2_AD_1QUAD;//Use 1 QW per channel
AdDioSetup.IngrDioEngine[0].NumAxC = 15;//Use 16 AxC.
AdDioSetup.IngrDioEngine[0].bEnDmaChannel = TRUE; //Enable Dma channel
AdDioSetup.IngrDioEngine[0].DmaNumBlock = 31;//32 block wrap value (n-1)
AdDioSetup.IngrDioEngine[0].DmaBurstLen = CSL_AIF2_AD_4QUAD;//4 max QW burst per one transfer
AdDioSetup.IngrDioEngine[0].DmaBaseAddr = (Uint32)&dio_result[0];//DMA destination base address (use high 28 bits)
AdDioSetup.IngrDioEngine[0].DmaBurstAddrStride = 4;//DMA burst stride to 4 (wrap1)
AdDioSetup.IngrDioEngine[0].DmaBlockAddrStride = 16;//DMA block stride to 4 (wrap2)
AdDioSetup.IngrDioEngine[0].DBCN[i] = i; //set ingress table DBCN for 16 channels
AdDioSetup.EgrDioEngineEnable[0] = TRUE;//Enable DIO Engine
AdDioSetup.EgrDioEngine[0].BcnTableSelect = CSL_AIF2_AD_DIO_BCN_TABLE_0;
AdDioSetup.EgrDioEngine[0].NumQuadWord = CSL_AIF2_AD_1QUAD;//Use 1 QW per channel
AdDioSetup.EgrDioEngine[0].NumAxC = 15;//Use 16 AxC
AdDioSetup.EgrDioEngine[0].bEnDmaChannel = TRUE; //Enable Dma channel
AdDioSetup.EgrDioEngine[0].bEnEgressRsaFormat = FALSE;
AdDioSetup.EgrDioEngine[0].DmaNumBlock = 31;//31 block wrap value (n-1)
AdDioSetup.EgrDioEngine[0].DmaBurstLen = CSL_AIF2_AD_4QUAD;//4 max QW burst per one transfer
AdDioSetup.EgrDioEngine[0].DmaBaseAddr = (Uint32)&dio_data[0];//DMA source base address (use high 28 bits)
AdDioSetup.EgrDioEngine[0].DmaBurstAddrStride = 4;//DMA burst stride to 4 (wrap1)
AdDioSetup.EgrDioEngine[0].DmaBlockAddrStride = 16;//DMA block stride to 4 (wrap2)
AdDioSetup.EgrDioEngine[0].DBCN[i] = i; //set egress table DBCN for 16 channels
#if DEBUG_NON_RP1_TIMING
AtCommonSetup.PhySyncSel = CSL_AIF2_SW_SYNC;;//Select chip input sync for Phy timer trigger
AtCommonSetup.RadSyncSel = CSL_AIF2_SW_SYNC;;//Select chip input sync for Rad timer trigger
#else
AtCommonSetup.PhySyncSel = CSL_AIF2_CHIP_INPUT_SYNC;//CSL_AIF2_SW_SYNC;//Select chip input sync for Phy timer trigger
AtCommonSetup.RadSyncSel = CSL_AIF2_CHIP_INPUT_SYNC;//CSL_AIF2_SW_SYNC;//Select chip input sync for Rad timer trigger
#endif
AtCommonSetup.SyncMode = CSL_AIF2_NON_RP1_MODE;
AtCommonSetup.AutoResyncMode = CSL_AIF2_AUTO_RESYNC_MODE;
AtCommonSetup.CrcMode = CSL_AIF2_AT_CRC_DONT_USE;//Do not use RP1 CRC in this test
AtCommonSetup.AtInit.pPhyTimerInit = &PhyTimerInit;
AtCommonSetup.AtInit.pRadTimerInit = &RadTimerInit;
AtCommonSetup.AtInit.pUlRadTimerInit = &UlRadTimerInit;
AtCommonSetup.WcdmaDivTC = 63; //64 is default divide value for WCDMA CPRI
PhyTimerInit.ClockNum = 0;
PhyTimerInit.FrameLsbNum = 0;
PhyTimerInit.FrameMsbNum = 0;
RadTimerInit.ClockNum = 0;
RadTimerInit.SymbolNum = 0;
RadTimerInit.FrameLsbNum = 0;
RadTimerInit.FrameMsbNum = 0;
UlRadTimerInit.ClockNum = 162844;// 163840 - 996(Ingress first DIO DMA offset)
UlRadTimerInit.SymbolNum = 14;
UlRadTimerInit.FrameLsbNum = 0;
UlRadTimerInit.FrameMsbNum = 0;
AtCommonSetup.AtTerminalCount.pPhyTimerTc = &PhyTimerTc;
AtCommonSetup.AtTerminalCount.pRadTimerTc = &RadTimerTc;
PhyTimerTc.FrameLsbNum = FRAME_COUNT_TC_PHY_TIMER;//set phy Frame TC to 4095
PhyTimerTc.ClockNum = CLOCK_COUNT_TC_PHY_TIMER_CPRI; //set phy clock TC to 2457599
RadTimerTc.FrameLsbNum = FRAME_COUNT_TC_WCDMA_FDD;//set WCDMA Frame TC to 4095
RadTimerTc.SymbolNum = SLOT_COUNT_TC_WCDMA_FDD; //set WCDMA Slot TC to 14
AtCommonSetup.AtTerminalCount.RadClockCountTc[0] = CLOCK_COUNT_TC_WCDMA_FDD_CPRI;
//AT Event setup for test debug purpose (Event 7)
AtEventSetup.AtRadEvent[7].EventSelect = CSL_AIF2_EVENT_7;//Select Event 7 just for this test program
AtEventSetup.AtRadEvent[7].EventOffset = 0; //fine offset could be tuned. main offset is already applied to ulradt clock num init value.
AtEventSetup.AtRadEvent[7].EvtStrobeSel = CSL_AIF2_ULRADT_FRAME;
AtEventSetup.AtRadEvent[7].EventModulo = 32767; // CPRI 2 hyper frame size
AtEventSetup.AtRadEvent[7].EventMaskLsb = 0xFFFFFFFF; //set all mask to 1's for WCDMA FDD
AtEventSetup.AtRadEvent[7].EventMaskMsb = 0xFFFFFFFF; //set all mask to 1's for WCDMA FDD
AtEventSetup.bEnableRadEvent[7] = TRUE;//Enable Event
//AT Event setup for generating 4 chip trigger for TAC (Event 8 is specified for this purpose)
AtEventSetup.AtRadEvent[8].EventSelect = CSL_AIF2_EVENT_8;
AtEventSetup.AtRadEvent[8].EventOffset = 0;
AtEventSetup.AtRadEvent[8].EvtStrobeSel = CSL_AIF2_RADT_FRAME;
AtEventSetup.AtRadEvent[8].EventModulo = 255; //set Modulus count (WCDMA 4 chip time)
AtEventSetup.AtRadEvent[8].EventMaskLsb = 0xFFFFFFFF;
AtEventSetup.AtRadEvent[8].EventMaskMsb = 0xFFFFFFFF;
AtEventSetup.bEnableRadEvent[8] = TRUE;//Enable Event
//AT Event setup (In DIO 4chip Event)
AtEventSetup.AtIngrDioEvent[0].EventSelect = CSL_AIF2_IN_DIO_EVENT_0;//Select In DIO Event 0
AtEventSetup.AtIngrDioEvent[0].EventOffset = 0;//fine offset value
AtEventSetup.AtIngrDioEvent[0].EvtStrobeSel = CSL_AIF2_RADT_FRAME;
AtEventSetup.AtIngrDioEvent[0].EventModulo = 255; //set Modulus count for In DIO event 0 (WCDMA 4 chip time)
AtEventSetup.AtIngrDioEvent[0].DioFrameEventOffset = 1016;//Pi Max(580) + 4 WCDMA chip time(256) + PD delay and fuzzy factors(180)
AtEventSetup.AtIngrDioEvent[0].DioFrameStrobeSel = CSL_AIF2_RADT_FRAME; //frame event strobe selection
AtEventSetup.bEnableIngrDioEvent[0] = TRUE;//Enable In DIO Event 0
//AT Event setup (E DIO 4chip Event)
AtEventSetup.AtEgrDioEvent[0].EventSelect = CSL_AIF2_E_DIO_EVENT_0;//Select E DIO Event 0
AtEventSetup.AtEgrDioEvent[0].EventOffset = 230;//delay for TAC operation time
AtEventSetup.AtEgrDioEvent[0].EvtStrobeSel = CSL_AIF2_RADT_FRAME;
AtEventSetup.AtEgrDioEvent[0].EventModulo = 255; //set Modulus count for E DIO event 0 (WCDMA 4 chip time)
AtEventSetup.AtEgrDioEvent[0].DioFrameEventOffset = 0;
AtEventSetup.AtEgrDioEvent[0].DioFrameStrobeSel = CSL_AIF2_RADT_FRAME; //frame event strobe selection
AtEventSetup.bEnableEgrDioEvent[0] = TRUE;//Enable E DIO Event 0
/****** Do AIF2 HW setup (set all MMRs above) **********************************************************************/
CSL_aif2HwSetup(hAif2, &aif2Setup);
ctrlArg = TRUE;
hAif2->arg_link = link;
//Enable Serdes loopback for link 0
// CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_ENABLE_DISABLE_LINK_LOOPBACK, (void *)&ctrlArg);
// Enable Tx/Rx
CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_ENABLE_DISABLE_TX_LINK, (void *)&ctrlArg);
CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_ENABLE_DISABLE_RX_LINK, (void *)&ctrlArg);
for(i=0; i<1000; i++)asm (" NOP 9 ");//delay for aif2 MMR configuration
//AT Arm timer
CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AT_ARM_TIMER, (void *)&ctrlArg);
//Trigger the SW debug frame sync
CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AT_DEBUG_SYNC, (void *)&ctrlArg);
//Start_timer0();
#else
usRegVal = 4800;
/* Generate 10ms pulse */
Err = BSLC667X_ControlRegWrite (
BSLC667X_CONTROL_NUM_0,
BSLC667X_CONTROL_HDR_GLUE_TYPE_FPGA1,
0xF8,
&usRegVal,
sizeof( unsigned short ) );
if(Err)
printf("BSLC667X_ControlRegWrite failed, Err=0x%x\n", Err);
#endif
BSLC667X_ErrorCode BSLC667X_AIF_init()
/* Default configuration will only be used if FRU read fails from DSP */
BSLC667X_Libconfig_s LibConfig = {BSLC667X_CPU_CLK_FREQ_1000_MHZ,BSLC667X_BOARD_CFG_DEFAULT_AMC2C6670,TRUE,TRUE};
/* Initialise PLLC, DDR2 and BSLC667X Library */
Err = BSLC667X_Initialise(&LibConfig);
if (Err)
printf("BSLC667X_Initialise() failed!!, ErrorCode = 0x%x\n",Err);
return;
/* Initialise SFP module */
if(BSLC667X_SfpInitialise(NULL))
printf("BSLC667X_SfpInitialise() failed!!");
return;
printf("SFP Interface Initialised\n");
Err = BSLC667X_SfpTxEnable(BSLC667X_SFP0_CHANNEL);
Err |= BSLC667X_SfpTxEnable(BSLC667X_SFP1_CHANNEL);
Err |= BSLC667X_SfpTxEnable(BSLC667X_SFP2_CHANNEL);
if(Err)
printf("BSLC667XSfpTxEnable failed, Err=0x%x\n", Err);
/* Turn on the Hyperlink power domain */
if (CSL_PSC_getPowerDomainState (CSL_PSC_PD_AI) != PSC_PDSTATE_ON) {
/* Enable the domain */
CSL_PSC_enablePowerDomain (CSL_PSC_PD_AI);
/* Enable MDCTL */
CSL_PSC_setModuleNextState (CSL_PSC_LPSC_AI, PSC_MODSTATE_ENABLE);
/* Apply the domain */
CSL_PSC_startStateTransition (CSL_PSC_PD_AI);
/* Wait for it to finish */
while (! CSL_PSC_isStateTransitionDone (CSL_PSC_PD_AI));
} else {
printf ("Power domain is already enabled. You probably re-ran without device reset (which is OK)\n");
void main(void)
Uint32 idx, idx2,axc =0;
Uint16 testpass;
CSL_Aif2LinkIndex link;// = CSL_AIF2_LINK_1;
BSLC667X_AIF_init();
for(link=CSL_AIF2_LINK_0;link<=CSL_AIF2_LINK_2;link++)
printf("Beginning AIF2 WCDMA CPRI DIO test for TAC: Link %d\n",link);
int4_result = 0;
Intc_config();
memset(dio_result, 0xFF, 8192);//clear dest buffer
//bit 31 ~ 24 : Symbol number bit 23~ 16 : AXC number bit15 ~ 0 :sample count
for(idx =0; idx < 32; idx++){
for (idx2 = 0; idx2 < 64; idx2 ++) {
dio_data[(64*idx) + idx2] = idx2;
dio_data[(64*idx) + idx2] |= (axc/4) << 16; axc++;
dio_data[(64*idx) + idx2] |= idx << 24;
axc = 0;
* Enable PKTDMA Tx and Rx channels. (channel 128 for DIO)**/
enable_disable_loopback(0);//disable PKTDMA loopback for normal data transfer
enable_tx_chan(AIF_PKTDMA_TX_CHAN_REGION, 128, 0x80000000);
enable_rx_chan(AIF_PKTDMA_RX_CHAN_REGION, 128, 0x80000000);
Aif2_Dio_Cpri_Tac_config(link);//Aif2 configuration for DIO RAC test
* Enable AIF and wait for completion.
while(1)
asm (" NOP 5 ");
if(int4_result == 500)// Wait until 500 CPRI hyper frame time (more than two frames)
//AT disable all events and halt timer
ctrlArg = TRUE;
CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AT_DISABLE_ALL_EVENTS, (void *)&ctrlArg);
CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AT_HALT_TIMER, (void *)&ctrlArg);
ctrlArg = FALSE;//disable AD DIO and Rx, Tx Link
CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AD_E_ENABLE_DISABLE_DIO_GLOBAL, (void *)&ctrlArg);
CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AD_IN_ENABLE_DISABLE_DIO_GLOBAL, (void *)&ctrlArg);
// Disable pkt dma channel 128
enable_tx_chan(AIF_PKTDMA_TX_CHAN_REGION, 128, 0);//disable Tx channel 128
enable_rx_chan(AIF_PKTDMA_RX_CHAN_REGION, 128, 0);//disable Rx channel 128
CSL_aif2Reset(hAif2);//reset all aif2 modules
break;
* Compare the data in the destination buffers.
testpass = 0;
idx = 0;
/* Compare the DIO loopback data */
testpass |= memcmp(&dio_data[idx], &dio_result[idx], 8192);
if (testpass == 0)
printf("DIO CPRI Loopback Test for WCDMA: PASS\n");
else
printf("DIO CPRI Loopback Test for WCDMA: FAIL\n");
printf("Ending AIF2 WCDMA CPRI DIO tests for TAC\n");
while(1);
This LTE FDD 8x link speed(4.915G) you want to change.
What do we need to change?
Test board AMC-2C66-3AIF Card
http://www.commagility.com/amc-2c6670.php
Desperate need of help. T.T
Thanks & Best Regards
gyosun
