Other Parts Discussed in Thread: OMAP-L138, SYSBIOS
We are on an OMAP-L138 using CCS 5.2.1.00018, SYSBIOS 6.33.5.46.
If I connect to only the DSP, I get Log_info calls just fine on the Raw Logs console.
If I connect to only the ARM, I get Log_info calls just fine on the Raw Logs console.
If I connect to both, I only seem to get the ones from the side I connected to first. I have not found any way to rename the "Main Logger".
Also I have a logger0 defined in the cfg on both sides that doesn't seem to be used for anything. I assumed I needed to define a log but I guess I don't? True or False?
