Other Parts Discussed in Thread: TVP5158
Hi all
Following is the code I used to Initialize the VDEC Link
#define MAX_DVR_CHANNELS 4
VSYS_PARAMS_S vsysParams;
VDEC_PARAMS_S vdecParams;
VDIS_PARAMS_S vdisParams;
VDIS_MOSAIC_S sVdMosaicParam;
UInt32 i,status;
Bool forceLowCostScale = FALSE;
UInt32 startChID;
UInt64 wallTimeBase;
gDemo_info.maxVdecChannels = MAX_DVR_CHANNELS;
vdecParams.numChn = MAX_DVR_CHANNELS;
Vdec_params_init(&vdecParams);
vdecParams.forceUseDecChannelParams = TRUE;
for (i=0; i < vdecParams.numChn; i++)
vdecParams.decChannelParams[i].dynamicParam.frameRate = 30; // NOT USED
vdecParams.decChannelParams[i].dynamicParam.targetBitRate = 2 * 1000 * 1000; // NOT USED
vdecParams.decChannelParams[i].maxVideoWidth = 1920;
vdecParams.decChannelParams[i].maxVideoHeight = 1080;
vdecParams.decChannelParams[i].isCodec = VDEC_CHN_H264;
vdecParams.decChannelParams[i].displayDelay = 6;
vdecParams.decChannelParams[i].numBufPerCh = 10;
Vdec_init(&vdecParams);
/* Start components in reverse order */
Vdis_start();
return 0;
Then a use following code to get available bistream buffer;
emptyBufList.numBufs = 0;
reqInfo.numBufs = 1;
reqInfo.reqType = VDEC_BUFREQTYPE_CHID;
reqInfo.u[0].chNum = 0;
reqInfo.u[0].minBufSize = 1036800;
Vdec_requestBitstreamBuffer(&reqInfo, &emptyBufList, 0);
pEmptyBuf = &emptyBufList.bitsBuf[0];
OSA_printf("bufSize = %d\n",pEmptyBuf->bufSize);
Everytime the pEmptyBuf->bufSize equal to 0.
The log msg:
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
numid=101,iface=MIXER,name='Left DAC Mux'
; type=ENUMERATED,access=rw------,values=1,items=3
; Item #0 'DAC_L1'
; Item #1 'DAC_L3'
; Item #2 'DAC_L2'
: values=2
numid=99,iface=MIXER,name='Right DAC Mux'
; Item #0 'DAC_R1'
; Item #1 'DAC_R3'
; Item #2 'DAC_R2'
: values=2
[c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
[m3video] Remote Debug Shared Memory @ 0xbf005020
[m3vpss ] Remote Debug Shared Memory @ 0xbf00a040
SysLink version : 2.10.02.17
SysLink module created on Date:Oct 9 2012 Time:15:10:35
Trace enabled
Trace SetFailureReason enabled
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
*** TVP5158 probe : START ***
TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
TI DVR : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f
Device found : I2C (0xXX): 0x08 = 0x51
I2C (0xXX): 0x09 = 0x58
Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5c): 0x08 = 0x51
I2C (0x5c): 0x09 = 0x58
I2C (0x5d): 0x08 = 0x51
I2C (0x5d): 0x09 = 0x58
I2C (0x5e): 0x08 = 0x51
I2C (0x5e): 0x09 = 0x58
I2C (0x5f): 0x08 = 0x51
I2C (0x5f): 0x09 = 0x58
*** TVP5158 probe : END ***
/opt/dvr_rdk/ti816x
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 560000 Khz ***
[m3vpss ]
[m3vpss ] 43: SYSTEM : System Common Init in progress !!!
[m3vpss ] 43: SYSTEM: IPC init in progress !!!
[m3vpss ] 43: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1043: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1045: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1045: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x097d2000]
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000
[m3vpss ] 2044: SYSTEM: Attaching to [DSP] ...
[m3video]
[m3video] *** UTILS: CPU KHz = 560000 Khz ***
[m3video]
[m3video] 1260: SYSTEM : System Common Init in progress !!!
[m3video] 1261: SYSTEM: IPC init in progress !!!
[m3video] 1261: SYSTEM: Attaching to [HOST] ...
[m3video] 2260: SYSTEM: Attaching to [HOST] ...
[m3video] 2262: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 2262: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x00000000]
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 800000000
[m3video] 3262: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 3044: SYSTEM: Attaching to [DSP] ...
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 800000 Khz ***
[c6xdsp ]
[c6xdsp ] 5: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 5: SYSTEM: IPC init in progress !!!
[c6xdsp ] 5: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1012: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1014: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1014: SYSTEM: AttachDMA: Module install successful, device major num = 251
ing to [VIDEO-M3DRV: Module install successful
After IpDRV: Module built on Dec 3 2012 14:01:47
[m3vpss ] 4044: SYSTEM: Attaching to [DSP] ...
[m3video] 4262: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2021: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 5044: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2902: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 5262: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2902: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 5262: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 5262: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 6044: SYSTEM: Attaching to [DSP] ...
[m3video] 6262: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 3909: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4684: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 7044: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4684: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 7044: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 7044: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 7262: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 8044: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 8044: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 8044: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 8044: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 8045: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 8044: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8045: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 8044: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3video] 8046: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3vpss ] 8045: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3video] 8047: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3vpss ] 8046: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3video] 8047: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3vpss ] 8046: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3video] 8047: SYSTEM: IPC init DONE !!!
[m3vpss ] 8047: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[m3vpss ] 8047: SYSTEM: IPC init DONE !!!
[c6xdsp ] 5691: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8052: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
[m3vpss ] 8052: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
[c6xdsp ] 5691: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[m3video] 8053: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d000000 (208 MB)
[m3vpss ] 8052: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d000000 (208 MB)
[c6xdsp ] 5691: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[m3video] 8054: SYSTEM : System Common Init Done !!!
[m3vpss ] 8054: SYSTEM : System Common Init Done !!!
[c6xdsp ] 5692: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3video] 8054: SYSTEM : System Video Init in progress !!!
[m3vpss ] 8054: SYSTEM : System VPSS Init in progress !!!
[c6xdsp ] 5692: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[m3video] 8055: SYSTEM : System Video Init Done !!!
[m3vpss ] === HDVPSS Clocks are enabled ===
[c6xdsp ] 5692: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3video] 8055: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] === HDVPSS is fully functional ===
[c6xdsp ] 5692: SYSTEM: IPC init DONE !!!
[m3video] 8055: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3vpss ] === HDVPSS module is not in standby ===
[c6xdsp ] 5694: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
[m3video] 8055: SYSTEM: ListElem Shared Addr = 0xbf18b680
[m3vpss ] === I2C1 Clk is active ===
[c6xdsp ] 5694: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d000000 (208 MB)
[m3video] 8057: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3vpss ] 8059: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 5694: SYSTEM : System Common Init Done !!!
[m3video] 8057: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3vpss ] 8059: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 5649: SYSTEM : System DSP Init in progress !!!
[m3video] 8057: SYSTEM: ListElem Shared Addr = 0xbf1ae580
[m3vpss ] 8060: SYSTEM: ListElem Shared Addr = 0xbf1f1400
[c6xdsp ] 5649: SYSTEM : RpeServer_init() done... Ret Val 0!!!
[c6xdsp ] 5697: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
[c6xdsp ] 5697: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
[c6xdsp ] 5697: SYSTEM: ListElem Shared Addr = 0xbf18f100
[c6xdsp ] 5698: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
[c6xdsp ] 5698: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
[c6xdsp ] 5698: SYSTEM: ListElem Shared Addr = 0xbf1b1a80
[c6xdsp ] 5699: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
[c6xdsp ] 5699: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
[c6xdsp ] 5699: SYSTEM: ListElem Shared Addr = 0xbf1d1480
[c6xdsp ] 5700: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 5700: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[m3vpss ] Received character 's'
[m3video] 8062: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
[m3vpss ] 8061: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[c6xdsp ] 5700: SYSTEM: ListElem Shared Addr = 0xbf1f4380
[m3video] 8063: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
[m3vpss ] 8062: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[c6xdsp ] 5700: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[m3video] 8063: SYSTEM: ListElem Shared Addr = 0xbf232e80
[m3vpss ] 8062: SYSTEM: ListElem Shared Addr = 0xbf22f980
[c6xdsp ] 5700: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[m3video] 8065: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
[m3vpss ] 8073: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
[c6xdsp ] 5700: SYSTEM: ListElem Shared Addr = 0xbf211e80
[m3video] 8065: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
[m3vpss ] 8073: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 5655: SYSTEM : Initializing Links !!!
[m3video] 8065: SYSTEM: ListElem Shared Addr = 0xbf252880
[m3vpss ] 8073: SYSTEM: ListElem Shared Addr = 0xbf291c80
[m3video] 8067: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
[m3vpss ] 8075: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
[c6xdsp ] 5701: SYSTEM : FREE SPACE : System Heap = 10268448 B, Mbx = 10240 msgs)
[m3video] 8068: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
[m3vpss ] 8075: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
[m3video] 8068: SYSTEM: ListElem Shared Addr = 0xbf272280
[m3vpss ] 8075: SYSTEM: ListElem Shared Addr = 0xbf2b1680
[c6xdsp ] 5664: SYSTEM : Initializing Links ... DONE !!!
[m3video] 8078: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 8077: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
[m3video] 8078: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 8078: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
[c6xdsp ] 5664: SYSTEM : System DSP Init Done !!!
[m3video] 8079: SYSTEM: ListElem Shared Addr = 0xbf2f0a80
[m3vpss ] 8078: SYSTEM: ListElem Shared Addr = 0xbf2d1080
[m3video] 8080: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 8079: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3video] 8081: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 8080: SYSTEM : FVID2 Init in progress !!!
[m3video] 8081: SYSTEM: ListElem Shared Addr = 0xbf30e580
[m3vpss ] 8163: SYSTEM : FVID2 Init in progress DONE !!!
[m3video] 8082: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 8163: SYSTEM : Device Init in progress !!!
[m3video] 8082: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3video] 8082: HDVICP: Doing PRCM for IVAHD[1] ...
[m3vpss ] initPrms.isI2cInitReq = 0
[m3video] 8083: HDVICP: PRCM for IVAHD[1] ... DONE.
[m3video] 8083: HDVICP: Doing PRCM for IVAHD[2] ...
[m3video] 8083: HDVICP: PRCM for IVAHD[2] ... DONE.
[m3vpss ] 8166: SYSTEM : Device Init in progress DONE !!!
[m3video] 8083: SYSTEM : Initializing Links !!!
[m3vpss ] 8285: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 8285: UTILS: DMA: HWI Create for INT63 !!!
[m3video] 8083: SYSTEM : FREE SPACE : System Heap = 6280232 B, Mbx = 10240 msgs)
[m3vpss ] 8286: SYSTEM : Initializing Links !!!
[m3video] 8083: SYSTEM : FREE SPACE : SR0 Heap = 13452672 B (12 MB)
[m3vpss ] 8286: SYSTEM : FREE SPACE : System Heap = 13024 B, Mbx = 10240 msgs)
[m3video] Received character 's'
[m3video] 8083: SYSTEM : FREE SPACE : Frame Buffer = 245104512 B (233 MB)
[m3vpss ] 8286: SYSTEM : FREE SPACE : SR0 Heap = 13452672 B (12 MB)
[m3video] 8084: SYSTEM : FREE SPACE : Bitstream Buffer = 218103680 B [module] vpss probe done.
(207 MB)
[m3vpss ] 8286: SYSTEM : FREE SPACE : Frame Buffer = 240794496 B (229 MB)
[c6xdsp ] Received character 's'
/opt/dvr_rdk/ti816x
[m3video] 8084: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m[module] ti81xxfb probe done.
3vpss ] 8286: SYSTEM : FREE SPACE : Bitstream Buffer = 218103680 B (207 MB)
[m3video] 8084: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 8286:HDMI W1 rev 2.0
SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) [module] ti81xx_hdmi probe done.
- TILER ON
[m3video] 8085: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 8286: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3video] 8114: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 8386: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 8386: SYSTEM : Set Static L3 pressure for HDVPSS as High
ORG 0x46c00524: 0
NEW 0x46c00524: 2
0: SYSTEM: System Common Init in progress !!!
0: SYSTEM: IPC init in progress !!!
12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
15: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
16: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
16: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
17: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
18: SYSTEM: Notify register to [DSP] line 0, event 15 ...
18: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
19: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
20: SYSTEM: IPC init DONE !!!
22: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
25: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
27: SYSTEM: ListElem Shared Addr = 0x2eb7f080
28: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
31: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
33: SYSTEM: ListElem Shared Addr = 0x2eb9cb80
35: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
38: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
40: SYSTEM: ListElem Shared Addr = 0x2ebba680
41: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
43: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
45: SYSTEM: ListElem Shared Addr = 0x2ebda080
46: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
48: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
49: SYSTEM: ListElem Shared Addr = 0x2ebf9a80
65: SYSTEM: System Common Init Done !!!
