We are using the following architecture. root@ti-omap3-am3517-evm:~# cat /proc/cpuinfo Processor : ARMv7 Processor rev 7 (v7l) BogoMIPS : 597.64 Features : swp half thumb fastmult vfp edsp neon vfpv3 CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x1 CPU part : 0xc08 CPU revision : 7
Hardware : OMAP3517/AM3517 EVM Revision : 0020 Serial : 0000000000000000
We are using Linux kernel version 2.6.32 root@ti-omap3-am3517-evm:~# uname -a Linux ti-omap3-am3517-evm 2.6.32.8 #71 PREEMPT Mon Nov 5 15:37:19 EST 2012 armv7l unknown
The issue (HW FIFO over flow) we are facing is with serial driver (driver/serial/8250.c) uart_rx_char(). The serial port has 64 bytes FIFO and it is configured to generate interrupt upon receiving 32 bytes.
We are reading/writing data from/to serial port at 460800 baud rate. The regression test runs over the period of 7-8 hours in which we send and receive data to/from the serial port. After a couple of hours what we see is that HWFIFO over flow happens and we have no clue why it is happening. We are assuming that either one of the following two things are happening.
1) The serial interrupt is skipped because other interrupts (Ethernet/ i2c and MMC (out of which we don't use MMC and i2c during the regression test ) in the systems takes too long that serial interrupts are skipped and by the time the serial ISR gets a chance to run the HW FIFO is already full.
2) The other assumption is that we must process the ISR in less than 1msec (one milisecond) as such 460800 bits per second => 460800/1000 ms ~= 460 bits/ms ~= 52bytes/ms and since we have configured serial port to generate interrupt at every 32 bytes it gives us 32/50 ms ~= 0.64 ms to complete ISR. ( I have ignred start and stop bit) but it gives rough estimated ball park.
How do I confirm the point 1 and point 2 I mentioned above? Any pointers will be appreciated.
We also assume that the 8250.c (serial driver) is fairly old and robust and it shouldn't behave the way it is for us.
Let me know if you need more information.
The 8250.c driver can be found at this weblink. http://lxr.free-electrons.com/source/drivers/serial/8250.c?v=2.6.32;a=arm
One more question I have is that the serial port used on our target board is ST16654 based which has following configuration.
[PORT_16654] = { .name = "ST16654", .fifo_size = 64, .tx_loadsz = 32, .fcr = UART_FCR_ENABLE_FIFO | UART_FCR_R_TRIG_01 | UART_FCR_T_TRIG_10, .flags = UART_CAP_FIFO | UART_CAP_EFR | UART_CAP_SLEEP }
I checked the code and to me it looks rx trigger is set for 16 bytes wheres as tx trigger is set to 32 bytes (defined at http://lxr.free-electrons.com/source/include/linux/serial_reg.h?v=2.6.32;a=arm#L62).
I recompiled the kernel with FTRACE support. Also, I made changes in 8250.c so that serial port rx and tx interrupt happens when the FIFO is 8 bytes full. (It was 16 bytes in rx direction and 32 bytes in tx direction). I observed that the HW FIFO overflow happened followed by 64k buffer over flow and I had a program that triggered the cat trace. Below is the out put of the trace. Does any one know why this HW over flow and 64k buffer over flow are happening? As far as 64K buffer over run is concerned I found that flush_to_ldisc keeps requesting buffers for a long time , but why I don't understand. Any pointers? root@ti-omap3-am3517-evm:/debug/tracing# hrtimer: interrupt took 610352 ns
HWFIFO OVERFLOW
[12/03/2012|23:04:27.899] : checkOverRun : buf_overrun(0) overrun(1) frame(0) parity(0) brk(0) buffer(-820453800)
[12/03/2012|23:04:27.906] : Begin Dump)
# tracer: preemptoff
# preemptoff latency trace v1.1.5 on 2.6.32.8
# latency: 2288 us, #713/713, CPU#0 | (M:preempt VP:0, KP:0, SP:0 HP:0)
# | task: -1251 (uid:0 nice:0 policy:0 rt_prio:0)
# => started at: schedule
# => ended at: schedule
# _------=> CPU#
# / _-----=> irqs-off
# | / _----=> need-resched
# || / _---=> hardirq/softirq
# ||| / _--=> preempt-depth
# |||| /_--=> lock-depth
# |||||/ delay
# cmd pid |||||| time | caller
<...>-1252 0d..1. 0us : enqueue_hrtimer <-__hrtimer_start_range_ns
<...>-1252 0...1. 0us : __hrtimer_start_range_ns
<...>-1252 0...1. 0us : trace_preempt_on <-__hrtimer_start_range_ns
<...>-1252 0...1. 0us : schedule
<...>-1252 0d..1. 0us : add_preempt_count <-schedule
<...>-1252 0d..2. 0us : omap34xx_32k_read <-sched_clock
<...>-1252 0d..2. 0us : omap_readl <-omap34xx_32k_read
<...>-1252 0d..2. 0us+: deactivate_task <-schedule
<...>-1252 0d..2. 31us : dequeue_task <-deactivate_task
<...>-1252 0d..2. 31us : update_avg <-dequeue_task
<...>-1252 0d..2. 31us : dequeue_task_fair <-dequeue_task
<...>-1252 0d..2. 31us : dequeue_entity <-dequeue_task_fair
<...>-1252 0d..2. 31us : update_curr <-dequeue_entity
<...>-1252 0d..2. 31us : update_min_vruntime <-update_curr
<...>-1252 0d..2. 31us : clear_buddies <-dequeue_entity
<...>-1252 0d..2. 31us : update_min_vruntime <-dequeue_entity
<...>-1252 0d..2. 31us : put_prev_task_fair <-schedule
<...>-1252 0d..2. 31us+: check_spread <-put_prev_task_fair
<...>-1252 0d..2. 61us : update_curr <-put_prev_task_fair
<...>-1252 0d..2. 61us : calc_delta_mine <-update_curr
<...>-1252 0d..2. 61us : update_min_vruntime <-update_curr
<...>-1252 0d..2. 61us : check_spread <-put_prev_task_fair
<...>-1252 0d..2. 61us : __enqueue_entity <-put_prev_task_fair
<...>-1252 0d..2. 61us : pick_next_task_fair <-schedule
<...>-1252 0d..2. 61us : __pick_next_entity <-pick_next_task_fair
<...>-1252 0d..2. 61us : clear_buddies <-pick_next_task_fair
<...>-1252 0d..2. 61us : set_next_entity <-pick_next_task_fair
<...>-1252 0d..2. 61us : update_stats_wait_end <-set_next_entity
<...>-1252 0d..2. 61us+: __dequeue_entity <-set_next_entity
<...>-1252 0d..2. 92us : __pick_next_entity <-pick_next_task_fair
<...>-1252 0d..2. 92us : clear_buddies <-pick_next_task_fair
<...>-1252 0d..2. 92us : set_next_entity <-pick_next_task_fair
<...>-1252 0d..2. 92us : update_stats_wait_end <-set_next_entity
<...>-1252 0d..2. 92us : __dequeue_entity <-set_next_entity
<...>-1252 0d..3. 92us : asm_do_IRQ <-__irq_svc
<...>-1252 0d..3. 92us : irq_enter <-asm_do_IRQ
<...>-1252 0d..3. 92us : rcu_irq_enter <-irq_enter
<...>-1252 0d..3. 92us+: idle_cpu <-irq_enter
<...>-1252 0d..3. 122us : add_preempt_count <-irq_enter
<...>-1252 0d.h3. 122us : irq_to_desc <-asm_do_IRQ
<...>-1252 0d.h3. 122us : handle_level_irq <-asm_do_IRQ
<...>-1252 0d.h3. 122us : add_preempt_count <-handle_level_irq
<...>-1252 0d.h4. 122us : omap_mask_irq <-handle_level_irq
<...>-1252 0d.h4. 122us : intc_bank_write_reg <-omap_mask_irq
<...>-1252 0d.h4. 122us : omap_mask_ack_irq <-handle_level_irq
<...>-1252 0d.h4. 122us : omap_mask_irq <-omap_mask_ack_irq
<...>-1252 0d.h4. 122us : omap_ack_irq <-omap_mask_ack_irq
<...>-1252 0d.h4. 122us+: intc_bank_write_reg <-omap_ack_irq
<...>-1252 0d.h4. 153us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h3. 153us : handle_IRQ_event <-handle_level_irq
<...>-1252 0d.h3. 153us : omap2_gp_timer_interrupt <-handle_IRQ_event
<...>-1252 0d.h3. 153us : omap_dm_timer_write_status <-omap2_gp_timer_interrupt
<...>-1252 0d.h3. 153us : omap_dm_timer_write_reg <-omap_dm_timer_write_status
<...>-1252 0d.h3. 153us : hrtimer_interrupt <-omap2_gp_timer_interrupt
<...>-1252 0d.h3. 153us+: ktime_get <-hrtimer_interrupt
<...>-1252 0d.h3. 183us : omap34xx_32k_read <-ktime_get
<...>-1252 0d.h3. 183us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h3. 183us : ktime_add_ns <-ktime_get
<...>-1252 0d.h3. 183us : add_preempt_count <-hrtimer_interrupt
<...>-1252 0d.h4. 183us : __run_hrtimer <-hrtimer_interrupt
<...>-1252 0d.h4. 183us : __remove_hrtimer <-__run_hrtimer
<...>-1252 0d.h4. 183us : sub_preempt_count <-__run_hrtimer
<...>-1252 0d.h3. 183us : hrtimer_wakeup <-__run_hrtimer
<...>-1252 0d.h3. 183us : wake_up_process <-hrtimer_wakeup
<...>-1252 0d.h3. 183us+: try_to_wake_up <-wake_up_process
<...>-1252 0d.h3. 214us : add_preempt_count <-try_to_wake_up
<...>-1252 0d.h4. 214us : task_rq_lock <-try_to_wake_up
<...>-1252 0d.h4. 214us : add_preempt_count <-task_rq_lock
<...>-1252 0d.h5. 214us : omap34xx_32k_read <-sched_clock
<...>-1252 0d.h5. 214us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h5. 214us : activate_task <-try_to_wake_up
<...>-1252 0d.h5. 214us : enqueue_task <-activate_task
<...>-1252 0d.h5. 214us : enqueue_task_fair <-enqueue_task
<...>-1252 0d.h5. 214us+: enqueue_entity <-enqueue_task_fair
<...>-1252 0d.h5. 244us : update_curr <-enqueue_entity
<...>-1252 0d.h5. 244us : update_min_vruntime <-update_curr
<...>-1252 0d.h5. 244us : place_entity <-enqueue_entity
<...>-1252 0d.h5. 244us : check_spread <-enqueue_entity
<...>-1252 0d.h5. 244us : __enqueue_entity <-enqueue_entity
<...>-1252 0d.h5. 244us : check_preempt_wakeup <-try_to_wake_up
<...>-1252 0d.h5. 244us : update_curr <-check_preempt_wakeup
<...>-1252 0d.h5. 244us : wakeup_preempt_entity <-check_preempt_wakeup
<...>-1252 0d.h5. 244us+: resched_task <-check_preempt_wakeup
<...>-1252 0d.h5. 275us : sub_preempt_count <-try_to_wake_up
<...>-1252 0d.h4. 275us : sub_preempt_count <-try_to_wake_up
<...>-1252 0d.h3. 275us : add_preempt_count <-__run_hrtimer
<...>-1252 0d.h4. 275us : sub_preempt_count <-hrtimer_interrupt
<...>-1252 0d.h3. 275us : tick_program_event <-hrtimer_interrupt
<...>-1252 0d.h3. 275us : tick_dev_program_event <-tick_program_event
<...>-1252 0d.h3. 275us : ktime_get <-tick_dev_program_event
<...>-1252 0d.h3. 275us : omap34xx_32k_read <-ktime_get
<...>-1252 0d.h3. 275us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h3. 275us+: ktime_add_ns <-ktime_get
<...>-1252 0d.h3. 305us : clockevents_program_event <-tick_dev_program_event
<...>-1252 0d.h3. 305us : omap2_gp_timer_set_next_event <-clockevents_program_event
<...>-1252 0d.h3. 305us : omap_dm_timer_set_load_start <-omap2_gp_timer_set_next_event
<...>-1252 0d.h3. 305us : omap_dm_timer_write_reg <-omap_dm_timer_set_load_start
<...>-1252 0d.h3. 305us : note_interrupt <-handle_level_irq
<...>-1252 0d.h3. 305us : add_preempt_count <-handle_level_irq
<...>-1252 0d.h4. 305us : omap_unmask_irq <-handle_level_irq
<...>-1252 0d.h4. 305us+: intc_bank_write_reg <-omap_unmask_irq
<...>-1252 0d.h4. 336us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h3. 336us : irq_exit <-asm_do_IRQ
<...>-1252 0d.h3. 336us : sub_preempt_count <-irq_exit
<...>-1252 0d..4. 336us : rcu_irq_exit <-irq_exit
<...>-1252 0d..4. 336us : idle_cpu <-irq_exit
<...>-1252 0d..4. 336us : sub_preempt_count <-irq_exit
<...>-1252 0d..3. 336us : asm_do_IRQ <-__irq_svc
<...>-1252 0d..3. 336us : irq_enter <-asm_do_IRQ
<...>-1252 0d..3. 336us : rcu_irq_enter <-irq_enter
<...>-1252 0d..3. 336us+: idle_cpu <-irq_enter
<...>-1252 0d..3. 366us : add_preempt_count <-irq_enter
<...>-1252 0d.h3. 366us : irq_to_desc <-asm_do_IRQ
<...>-1252 0d.h3. 366us : handle_level_irq <-asm_do_IRQ
<...>-1252 0d.h3. 366us : add_preempt_count <-handle_level_irq
<...>-1252 0d.h4. 366us : omap_mask_irq <-handle_level_irq
<...>-1252 0d.h4. 366us : intc_bank_write_reg <-omap_mask_irq
<...>-1252 0d.h4. 366us : omap_mask_ack_irq <-handle_level_irq
<...>-1252 0d.h4. 366us : omap_mask_irq <-omap_mask_ack_irq
<...>-1252 0d.h4. 366us : omap_ack_irq <-omap_mask_ack_irq
<...>-1252 0d.h4. 366us+: intc_bank_write_reg <-omap_ack_irq
<...>-1252 0d.h4. 397us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h3. 397us : handle_IRQ_event <-handle_level_irq
<...>-1252 0d.h4. 397us : add_preempt_count <-serial8250_handle_port
<...>-1252 0d.h5. 397us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 397us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 427us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 427us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 458us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 458us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 488us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 488us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 519us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 519us : sub_preempt_count <-serial8250_handle_port
<...>-1252 0d.h4. 519us : tty_flip_buffer_push <-serial8250_handle_port
<...>-1252 0d.h4. 519us : add_preempt_count <-tty_flip_buffer_push
<...>-1252 0d.h5. 519us+: sub_preempt_count <-tty_flip_buffer_push
<...>-1252 0d.h4. 549us : schedule_delayed_work <-tty_flip_buffer_push
<...>-1252 0d.h4. 549us : queue_delayed_work <-schedule_delayed_work
<...>-1252 0d.h4. 549us : queue_delayed_work_on <-queue_delayed_work
<...>-1252 0d.h4. 549us : add_timer <-queue_delayed_work_on
<...>-1252 0d.h4. 549us : mod_timer <-add_timer
<...>-1252 0d.h4. 549us : lock_timer_base <-mod_timer
<...>-1252 0d.h4. 549us : add_preempt_count <-lock_timer_base
<...>-1252 0d.h5. 549us : internal_add_timer <-mod_timer
<...>-1252 0d.h5. 549us : sub_preempt_count <-mod_timer
<...>-1252 0d.h4. 549us+: add_preempt_count <-serial8250_handle_port
<...>-1252 0d.h5. 580us : check_modem_status <-serial8250_handle_port
<...>-1252 0d.h5. 580us : mem_serial_in <-check_modem_status
<...>-1252 0d.h5. 580us : transmit_chars <-serial8250_handle_port
<...>-1252 0d.h3. 580us : note_interrupt <-handle_level_irq
<...>-1252 0d.h3. 580us : add_preempt_count <-handle_level_irq
<...>-1252 0d.h4. 580us : omap_unmask_irq <-handle_level_irq
<...>-1252 0d.h4. 580us : intc_bank_write_reg <-omap_unmask_irq
<...>-1252 0d.h4. 580us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h3. 580us+: irq_exit <-asm_do_IRQ
<...>-1252 0d.h3. 610us : sub_preempt_count <-irq_exit
<...>-1252 0d..4. 610us : rcu_irq_exit <-irq_exit
<...>-1252 0d..4. 610us : idle_cpu <-irq_exit
<...>-1252 0d..4. 610us : sub_preempt_count <-irq_exit
<...>-1252 0d..3. 610us : asm_do_IRQ <-__irq_svc
<...>-1252 0d..3. 610us : irq_enter <-asm_do_IRQ
<...>-1252 0d..3. 610us : rcu_irq_enter <-irq_enter
<...>-1252 0d..3. 610us : idle_cpu <-irq_enter
<...>-1252 0d..3. 610us : add_preempt_count <-irq_enter
<...>-1252 0d.h3. 610us : irq_to_desc <-asm_do_IRQ
<...>-1252 0d.h3. 610us+: handle_level_irq <-asm_do_IRQ
<...>-1252 0d.h3. 641us : add_preempt_count <-handle_level_irq
<...>-1252 0d.h4. 641us : omap_mask_irq <-handle_level_irq
<...>-1252 0d.h4. 641us : intc_bank_write_reg <-omap_mask_irq
<...>-1252 0d.h4. 641us : omap_mask_ack_irq <-handle_level_irq
<...>-1252 0d.h4. 641us : omap_mask_irq <-omap_mask_ack_irq
<...>-1252 0d.h4. 641us : omap_ack_irq <-omap_mask_ack_irq
<...>-1252 0d.h4. 641us : intc_bank_write_reg <-omap_ack_irq
<...>-1252 0d.h4. 641us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h3. 641us+: handle_IRQ_event <-handle_level_irq
<...>-1252 0d.h3. 671us : omap2_gp_timer_interrupt <-handle_IRQ_event
<...>-1252 0d.h3. 671us : omap_dm_timer_write_status <-omap2_gp_timer_interrupt
<...>-1252 0d.h3. 671us : omap_dm_timer_write_reg <-omap_dm_timer_write_status
<...>-1252 0d.h3. 671us : hrtimer_interrupt <-omap2_gp_timer_interrupt
<...>-1252 0d.h3. 671us : ktime_get <-hrtimer_interrupt
<...>-1252 0d.h3. 671us : omap34xx_32k_read <-ktime_get
<...>-1252 0d.h3. 671us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h3. 671us : ktime_add_ns <-ktime_get
<...>-1252 0d.h3. 671us : add_preempt_count <-hrtimer_interrupt
<...>-1252 0d.h4. 671us+: __run_hrtimer <-hrtimer_interrupt
<...>-1252 0d.h4. 702us : __remove_hrtimer <-__run_hrtimer
<...>-1252 0d.h4. 702us : sub_preempt_count <-__run_hrtimer
<...>-1252 0d.h3. 702us : hrtimer_wakeup <-__run_hrtimer
<...>-1252 0d.h3. 702us : wake_up_process <-hrtimer_wakeup
<...>-1252 0d.h3. 702us : try_to_wake_up <-wake_up_process
<...>-1252 0d.h3. 702us : add_preempt_count <-try_to_wake_up
<...>-1252 0d.h4. 702us : task_rq_lock <-try_to_wake_up
<...>-1252 0d.h4. 702us : add_preempt_count <-task_rq_lock
<...>-1252 0d.h5. 702us+: omap34xx_32k_read <-sched_clock
<...>-1252 0d.h5. 732us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h5. 732us : activate_task <-try_to_wake_up
<...>-1252 0d.h5. 732us : enqueue_task <-activate_task
<...>-1252 0d.h5. 732us : enqueue_task_fair <-enqueue_task
<...>-1252 0d.h5. 732us : enqueue_entity <-enqueue_task_fair
<...>-1252 0d.h5. 732us : update_curr <-enqueue_entity
<...>-1252 0d.h5. 732us : update_min_vruntime <-update_curr
<...>-1252 0d.h5. 732us : place_entity <-enqueue_entity
<...>-1252 0d.h5. 732us+: check_spread <-enqueue_entity
<...>-1252 0d.h5. 763us : __enqueue_entity <-enqueue_entity
<...>-1252 0d.h5. 763us : check_preempt_wakeup <-try_to_wake_up
<...>-1252 0d.h5. 763us : sub_preempt_count <-try_to_wake_up
<...>-1252 0d.h4. 763us : sub_preempt_count <-try_to_wake_up
<...>-1252 0d.h3. 763us : add_preempt_count <-__run_hrtimer
<...>-1252 0d.h4. 763us : sub_preempt_count <-hrtimer_interrupt
<...>-1252 0d.h3. 763us : tick_program_event <-hrtimer_interrupt
<...>-1252 0d.h3. 763us : tick_dev_program_event <-tick_program_event
<...>-1252 0d.h3. 763us : ktime_get <-tick_dev_program_event
<...>-1252 0d.h3. 763us+: omap34xx_32k_read <-ktime_get
<...>-1252 0d.h3. 793us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h3. 793us : ktime_add_ns <-ktime_get
<...>-1252 0d.h3. 793us : clockevents_program_event <-tick_dev_program_event
<...>-1252 0d.h3. 793us : omap2_gp_timer_set_next_event <-clockevents_program_event
<...>-1252 0d.h3. 793us : omap_dm_timer_set_load_start <-omap2_gp_timer_set_next_event
<...>-1252 0d.h3. 793us : omap_dm_timer_write_reg <-omap_dm_timer_set_load_start
<...>-1252 0d.h3. 793us : note_interrupt <-handle_level_irq
<...>-1252 0d.h3. 793us+: add_preempt_count <-handle_level_irq
<...>-1252 0d.h4. 824us : omap_unmask_irq <-handle_level_irq
<...>-1252 0d.h4. 824us : intc_bank_write_reg <-omap_unmask_irq
<...>-1252 0d.h4. 824us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h3. 824us : irq_exit <-asm_do_IRQ
<...>-1252 0d.h3. 824us : sub_preempt_count <-irq_exit
<...>-1252 0d..4. 824us : rcu_irq_exit <-irq_exit
<...>-1252 0d..4. 824us : idle_cpu <-irq_exit
<...>-1252 0d..4. 824us : sub_preempt_count <-irq_exit
<...>-1252 0d..3. 824us : asm_do_IRQ <-__irq_svc
<...>-1252 0d..3. 824us+: irq_enter <-asm_do_IRQ
<...>-1252 0d..3. 854us : rcu_irq_enter <-irq_enter
<...>-1252 0d..3. 854us : idle_cpu <-irq_enter
<...>-1252 0d..3. 854us : add_preempt_count <-irq_enter
<...>-1252 0d.h3. 854us : irq_to_desc <-asm_do_IRQ
<...>-1252 0d.h3. 854us : handle_level_irq <-asm_do_IRQ
<...>-1252 0d.h3. 854us : add_preempt_count <-handle_level_irq
<...>-1252 0d.h4. 854us : omap_mask_irq <-handle_level_irq
<...>-1252 0d.h4. 854us : intc_bank_write_reg <-omap_mask_irq
<...>-1252 0d.h4. 854us : omap_mask_ack_irq <-handle_level_irq
<...>-1252 0d.h4. 854us : omap_mask_irq <-omap_mask_ack_irq
<...>-1252 0d.h4. 854us+: intc_bank_write_reg <-omap_mask_irq
<...>-1252 0d.h4. 885us : omap_ack_irq <-omap_mask_ack_irq
<...>-1252 0d.h4. 885us : intc_bank_write_reg <-omap_ack_irq
<...>-1252 0d.h4. 885us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h3. 885us : handle_IRQ_event <-handle_level_irq
<...>-1252 0d.h4. 885us : add_preempt_count <-serial8250_handle_port
<...>-1252 0d.h5. 885us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 885us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 916us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 916us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 946us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 946us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 977us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 977us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1007us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1007us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1038us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1038us : sub_preempt_count <-serial8250_handle_port
<...>-1252 0d.h4. 1038us : tty_flip_buffer_push <-serial8250_handle_port
<...>-1252 0d.h4. 1038us : add_preempt_count <-tty_flip_buffer_push
<...>-1252 0d.h5. 1038us : sub_preempt_count <-tty_flip_buffer_push
<...>-1252 0d.h4. 1038us+: schedule_delayed_work <-tty_flip_buffer_push
<...>-1252 0d.h4. 1068us : queue_delayed_work <-schedule_delayed_work
<...>-1252 0d.h4. 1068us : queue_delayed_work_on <-queue_delayed_work
<...>-1252 0d.h4. 1068us : add_preempt_count <-serial8250_handle_port
<...>-1252 0d.h5. 1068us : check_modem_status <-serial8250_handle_port
<...>-1252 0d.h5. 1068us : mem_serial_in <-check_modem_status
<...>-1252 0d.h5. 1068us : transmit_chars <-serial8250_handle_port
<...>-1252 0d.h6. 1068us : asm_do_IRQ <-__irq_svc
<...>-1252 0d.h6. 1068us : irq_enter <-asm_do_IRQ
<...>-1252 0d.h6. 1068us : rcu_irq_enter <-irq_enter
<...>-1252 0d.h6. 1068us : idle_cpu <-irq_enter
<...>-1252 0d.h6. 1068us+: add_preempt_count <-irq_enter
<...>-1252 0d.h6. 1099us : irq_to_desc <-asm_do_IRQ
<...>-1252 0d.h6. 1099us : handle_level_irq <-asm_do_IRQ
<...>-1252 0d.h6. 1099us : add_preempt_count <-handle_level_irq
<...>-1252 0d.h7. 1099us : omap_mask_irq <-handle_level_irq
<...>-1252 0d.h7. 1099us : intc_bank_write_reg <-omap_mask_irq
<...>-1252 0d.h7. 1099us : omap_mask_ack_irq <-handle_level_irq
<...>-1252 0d.h7. 1099us : omap_mask_irq <-omap_mask_ack_irq
<...>-1252 0d.h7. 1099us : omap_ack_irq <-omap_mask_ack_irq
<...>-1252 0d.h7. 1099us+: intc_bank_write_reg <-omap_ack_irq
<...>-1252 0d.h7. 1129us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h6. 1129us : handle_IRQ_event <-handle_level_irq
<...>-1252 0d.h6. 1129us : omap2_gp_timer_interrupt <-handle_IRQ_event
<...>-1252 0d.h6. 1129us : omap_dm_timer_write_status <-omap2_gp_timer_interrupt
<...>-1252 0d.h6. 1129us : omap_dm_timer_write_reg <-omap_dm_timer_write_status
<...>-1252 0d.h6. 1129us : hrtimer_interrupt <-omap2_gp_timer_interrupt
<...>-1252 0d.h6. 1129us : ktime_get <-hrtimer_interrupt
<...>-1252 0d.h6. 1129us : omap34xx_32k_read <-ktime_get
<...>-1252 0d.h6. 1129us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h6. 1129us+: ktime_add_ns <-ktime_get
<...>-1252 0d.h6. 1160us : add_preempt_count <-hrtimer_interrupt
<...>-1252 0d.h7. 1160us : __run_hrtimer <-hrtimer_interrupt
<...>-1252 0d.h7. 1160us : __remove_hrtimer <-__run_hrtimer
<...>-1252 0d.h7. 1160us : sub_preempt_count <-__run_hrtimer
<...>-1252 0d.h6. 1160us : tick_sched_timer <-__run_hrtimer
<...>-1252 0d.h6. 1160us : ktime_get <-tick_sched_timer
<...>-1252 0d.h6. 1160us : omap34xx_32k_read <-ktime_get
<...>-1252 0d.h6. 1160us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h6. 1160us+: ktime_add_ns <-ktime_get
<...>-1252 0d.h6. 1190us : tick_do_update_jiffies64 <-tick_sched_timer
<...>-1252 0d.h6. 1190us : add_preempt_count <-tick_do_update_jiffies64
<...>-1252 0d.h7. 1190us : do_timer <-tick_do_update_jiffies64
<...>-1252 0d.h7. 1190us : update_wall_time <-do_timer
<...>-1252 0d.h7. 1190us : omap34xx_32k_read <-update_wall_time
<...>-1252 0d.h7. 1190us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h7. 1190us : calc_global_load <-do_timer
<...>-1252 0d.h7. 1190us+: sub_preempt_count <-tick_do_update_jiffies64
<...>-1252 0d.h6. 1221us : update_process_times <-tick_sched_timer
<...>-1252 0d.h6. 1221us : account_process_tick <-update_process_times
<...>-1252 0d.h6. 1221us : account_system_time <-account_process_tick
<...>-1252 0d.h6. 1221us : run_local_timers <-update_process_times
<...>-1252 0d.h6. 1221us : hrtimer_run_queues <-run_local_timers
<...>-1252 0d.h6. 1221us : raise_softirq <-run_local_timers
<...>-1252 0d.h6. 1221us : softlockup_tick <-run_local_timers
<...>-1252 0d.h6. 1221us : get_timestamp <-softlockup_tick
<...>-1252 0d.h6. 1221us+: omap34xx_32k_read <-sched_clock
<...>-1252 0d.h6. 1251us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h6. 1251us : rcu_check_callbacks <-update_process_times
<...>-1252 0d.h6. 1251us : __rcu_pending <-rcu_check_callbacks
<...>-1252 0d.h6. 1251us : cpu_has_callbacks_ready_to_invoke <-__rcu_pending
<...>-1252 0d.h6. 1251us : cpu_needs_another_gp <-__rcu_pending
<...>-1252 0d.h6. 1251us : rcu_gp_in_progress <-__rcu_pending
<...>-1252 0d.h6. 1251us+: cpu_has_callbacks_ready_to_invoke <-__rcu_pending
<...>-1252 0d.h6. 1282us : cpu_needs_another_gp <-__rcu_pending
<...>-1252 0d.h6. 1282us : rcu_gp_in_progress <-__rcu_pending
<...>-1252 0d.h6. 1282us : printk_tick <-update_process_times
<...>-1252 0d.h6. 1282us : scheduler_tick <-update_process_times
<...>-1252 0d.h6. 1282us : add_preempt_count <-scheduler_tick
<...>-1252 0d.h7. 1282us : omap34xx_32k_read <-sched_clock
<...>-1252 0d.h7. 1282us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h7. 1282us : task_tick_fair <-scheduler_tick
<...>-1252 0d.h7. 1282us+: update_curr <-task_tick_fair
<...>-1252 0d.h7. 1312us : update_min_vruntime <-update_curr
<...>-1252 0d.h7. 1312us : sched_slice <-task_tick_fair
<...>-1252 0d.h7. 1312us : calc_delta_mine <-sched_slice
<...>-1252 0d.h7. 1312us : __pick_next_entity <-task_tick_fair
<...>-1252 0d.h7. 1312us : resched_task <-task_tick_fair
<...>-1252 0d.h7. 1312us : update_curr <-task_tick_fair
<...>-1252 0d.h7. 1312us : calc_delta_mine <-update_curr
<...>-1252 0d.h7. 1312us+: sub_preempt_count <-scheduler_tick
<...>-1252 0d.h6. 1343us : run_posix_cpu_timers <-update_process_times
<...>-1252 0d.h6. 1343us : profile_tick <-tick_sched_timer
<...>-1252 0d.h6. 1343us : hrtimer_forward <-tick_sched_timer
<...>-1252 0d.h6. 1343us : ktime_add_safe <-hrtimer_forward
<...>-1252 0d.h6. 1343us : add_preempt_count <-__run_hrtimer
<...>-1252 0d.h7. 1343us : enqueue_hrtimer <-__run_hrtimer
<...>-1252 0d.h7. 1343us : sub_preempt_count <-hrtimer_interrupt
<...>-1252 0d.h6. 1343us+: tick_program_event <-hrtimer_interrupt
<...>-1252 0d.h6. 1373us : tick_dev_program_event <-tick_program_event
<...>-1252 0d.h6. 1373us : ktime_get <-tick_dev_program_event
<...>-1252 0d.h6. 1373us : omap34xx_32k_read <-ktime_get
<...>-1252 0d.h6. 1373us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.h6. 1373us : ktime_add_ns <-ktime_get
<...>-1252 0d.h6. 1373us : clockevents_program_event <-tick_dev_program_event
<...>-1252 0d.h6. 1373us : omap2_gp_timer_set_next_event <-clockevents_program_event
<...>-1252 0d.h6. 1373us : omap_dm_timer_set_load_start <-omap2_gp_timer_set_next_event
<...>-1252 0d.h6. 1373us+: omap_dm_timer_write_reg <-omap_dm_timer_set_load_start
<...>-1252 0d.h6. 1404us : omap_dm_timer_write_reg <-omap_dm_timer_set_load_start
<...>-1252 0d.h6. 1404us : note_interrupt <-handle_level_irq
<...>-1252 0d.h6. 1404us : add_preempt_count <-handle_level_irq
<...>-1252 0d.h7. 1404us : omap_unmask_irq <-handle_level_irq
<...>-1252 0d.h7. 1404us : intc_bank_write_reg <-omap_unmask_irq
<...>-1252 0d.h7. 1404us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h6. 1404us : irq_exit <-asm_do_IRQ
<...>-1252 0d.h6. 1404us : sub_preempt_count <-irq_exit
<...>-1252 0d.h7. 1404us : rcu_irq_exit <-irq_exit
<...>-1252 0d.h7. 1404us+: idle_cpu <-irq_exit
<...>-1252 0d.h7. 1434us : sub_preempt_count <-irq_exit
<...>-1252 0d.h4. 1434us : add_preempt_count <-serial8250_handle_port
<...>-1252 0d.h5. 1434us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1434us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1465us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1465us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1495us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1495us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1526us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1526us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1556us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1556us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1587us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.h5. 1587us : sub_preempt_count <-serial8250_handle_port
<...>-1252 0d.h4. 1587us : tty_flip_buffer_push <-serial8250_handle_port
<...>-1252 0d.h4. 1587us : add_preempt_count <-tty_flip_buffer_push
<...>-1252 0d.h5. 1587us : sub_preempt_count <-tty_flip_buffer_push
<...>-1252 0d.h4. 1587us+: schedule_delayed_work <-tty_flip_buffer_push
<...>-1252 0d.h4. 1617us : queue_delayed_work <-schedule_delayed_work
<...>-1252 0d.h4. 1617us : queue_delayed_work_on <-queue_delayed_work
<...>-1252 0d.h4. 1617us : add_preempt_count <-serial8250_handle_port
<...>-1252 0d.h5. 1617us : check_modem_status <-serial8250_handle_port
<...>-1252 0d.h5. 1617us : mem_serial_in <-check_modem_status
<...>-1252 0d.h5. 1617us : transmit_chars <-serial8250_handle_port
<...>-1252 0d.h3. 1617us : note_interrupt <-handle_level_irq
<...>-1252 0d.h3. 1617us : add_preempt_count <-handle_level_irq
<...>-1252 0d.h4. 1617us : omap_unmask_irq <-handle_level_irq
<...>-1252 0d.h4. 1617us+: intc_bank_write_reg <-omap_unmask_irq
<...>-1252 0d.h4. 1648us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.h3. 1648us : irq_exit <-asm_do_IRQ
<...>-1252 0d.h3. 1648us : sub_preempt_count <-irq_exit
<...>-1252 0d..4. 1648us : __do_softirq <-irq_exit
<...>-1252 0d..4. 1648us : __local_bh_disable <-__do_softirq
<...>-1252 0d.s5. 1648us : asm_do_IRQ <-__irq_svc
<...>-1252 0d.s5. 1648us : irq_enter <-asm_do_IRQ
<...>-1252 0d.s5. 1648us : rcu_irq_enter <-irq_enter
<...>-1252 0d.s5. 1648us+: idle_cpu <-irq_enter
<...>-1252 0d.s5. 1678us : add_preempt_count <-irq_enter
<...>-1252 0d.H5. 1678us : irq_to_desc <-asm_do_IRQ
<...>-1252 0d.H5. 1678us : handle_level_irq <-asm_do_IRQ
<...>-1252 0d.H5. 1678us : add_preempt_count <-handle_level_irq
<...>-1252 0d.H6. 1678us : omap_mask_irq <-handle_level_irq
<...>-1252 0d.H6. 1678us : intc_bank_write_reg <-omap_mask_irq
<...>-1252 0d.H6. 1678us : omap_mask_ack_irq <-handle_level_irq
<...>-1252 0d.H6. 1678us : omap_mask_irq <-omap_mask_ack_irq
<...>-1252 0d.H6. 1678us : omap_ack_irq <-omap_mask_ack_irq
<...>-1252 0d.H6. 1678us+: intc_bank_write_reg <-omap_ack_irq
<...>-1252 0d.H6. 1709us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.H5. 1709us : handle_IRQ_event <-handle_level_irq
<...>-1252 0d.H5. 1709us : omap2_gp_timer_interrupt <-handle_IRQ_event
<...>-1252 0d.H5. 1709us : omap_dm_timer_write_status <-omap2_gp_timer_interrupt
<...>-1252 0d.H5. 1709us : omap_dm_timer_write_reg <-omap_dm_timer_write_status
<...>-1252 0d.H5. 1709us : hrtimer_interrupt <-omap2_gp_timer_interrupt
<...>-1252 0d.H5. 1709us : ktime_get <-hrtimer_interrupt
<...>-1252 0d.H5. 1709us : omap34xx_32k_read <-ktime_get
<...>-1252 0d.H5. 1709us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.H5. 1709us+: ktime_add_ns <-ktime_get
<...>-1252 0d.H5. 1740us : add_preempt_count <-hrtimer_interrupt
<...>-1252 0d.H6. 1740us : __run_hrtimer <-hrtimer_interrupt
<...>-1252 0d.H6. 1740us : __remove_hrtimer <-__run_hrtimer
<...>-1252 0d.H6. 1740us : sub_preempt_count <-__run_hrtimer
<...>-1252 0d.H5. 1740us : hrtimer_wakeup <-__run_hrtimer
<...>-1252 0d.H5. 1740us : wake_up_process <-hrtimer_wakeup
<...>-1252 0d.H5. 1740us : try_to_wake_up <-wake_up_process
<...>-1252 0d.H5. 1740us : add_preempt_count <-try_to_wake_up
<...>-1252 0d.H6. 1740us : task_rq_lock <-try_to_wake_up
<...>-1252 0d.H6. 1740us+: add_preempt_count <-task_rq_lock
<...>-1252 0d.H7. 1770us : omap34xx_32k_read <-sched_clock
<...>-1252 0d.H7. 1770us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.H7. 1770us : activate_task <-try_to_wake_up
<...>-1252 0d.H7. 1770us : enqueue_task <-activate_task
<...>-1252 0d.H7. 1770us : enqueue_task_fair <-enqueue_task
<...>-1252 0d.H7. 1770us : enqueue_entity <-enqueue_task_fair
<...>-1252 0d.H7. 1770us : update_curr <-enqueue_entity
<...>-1252 0d.H7. 1770us : update_min_vruntime <-update_curr
<...>-1252 0d.H7. 1770us : place_entity <-enqueue_entity
<...>-1252 0d.H7. 1770us+: check_spread <-enqueue_entity
<...>-1252 0d.H7. 1801us : __enqueue_entity <-enqueue_entity
<...>-1252 0d.H7. 1801us : check_preempt_wakeup <-try_to_wake_up
<...>-1252 0d.H7. 1801us : sub_preempt_count <-try_to_wake_up
<...>-1252 0d.H6. 1801us : sub_preempt_count <-try_to_wake_up
<...>-1252 0d.H5. 1801us : add_preempt_count <-__run_hrtimer
<...>-1252 0d.H6. 1801us : sub_preempt_count <-hrtimer_interrupt
<...>-1252 0d.H5. 1801us+: tick_program_event <-hrtimer_interrupt
<...>-1252 0d.H5. 1831us : tick_dev_program_event <-tick_program_event
<...>-1252 0d.H5. 1831us : ktime_get <-tick_dev_program_event
<...>-1252 0d.H5. 1831us : omap34xx_32k_read <-ktime_get
<...>-1252 0d.H5. 1831us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.H5. 1831us : ktime_add_ns <-ktime_get
<...>-1252 0d.H5. 1831us : clockevents_program_event <-tick_dev_program_event
<...>-1252 0d.H5. 1831us : omap2_gp_timer_set_next_event <-clockevents_program_event
<...>-1252 0d.H5. 1831us : omap_dm_timer_set_load_start <-omap2_gp_timer_set_next_event
<...>-1252 0d.H5. 1831us : omap_dm_timer_write_reg <-omap_dm_timer_set_load_start
<...>-1252 0d.H5. 1831us+: omap_dm_timer_write_reg <-omap_dm_timer_set_load_start
<...>-1252 0d.H5. 1862us : note_interrupt <-handle_level_irq
<...>-1252 0d.H5. 1862us : add_preempt_count <-handle_level_irq
<...>-1252 0d.H6. 1862us : omap_unmask_irq <-handle_level_irq
<...>-1252 0d.H6. 1862us : intc_bank_write_reg <-omap_unmask_irq
<...>-1252 0d.H6. 1862us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.H5. 1862us : irq_exit <-asm_do_IRQ
<...>-1252 0d.H5. 1862us : sub_preempt_count <-irq_exit
<...>-1252 0d.s6. 1862us : rcu_irq_exit <-irq_exit
<...>-1252 0d.s6. 1862us : idle_cpu <-irq_exit
<...>-1252 0d.s6. 1862us+: sub_preempt_count <-irq_exit
<...>-1252 0d.s5. 1892us : asm_do_IRQ <-__irq_svc
<...>-1252 0d.s5. 1892us : irq_enter <-asm_do_IRQ
<...>-1252 0d.s5. 1892us : rcu_irq_enter <-irq_enter
<...>-1252 0d.s5. 1892us : idle_cpu <-irq_enter
<...>-1252 0d.s5. 1892us : add_preempt_count <-irq_enter
<...>-1252 0d.H5. 1892us : irq_to_desc <-asm_do_IRQ
<...>-1252 0d.H5. 1892us : handle_level_irq <-asm_do_IRQ
<...>-1252 0d.H5. 1892us : add_preempt_count <-handle_level_irq
<...>-1252 0d.H6. 1892us : omap_mask_irq <-handle_level_irq
<...>-1252 0d.H6. 1892us+: intc_bank_write_reg <-omap_mask_irq
<...>-1252 0d.H6. 1923us : omap_mask_ack_irq <-handle_level_irq
<...>-1252 0d.H6. 1923us : omap_mask_irq <-omap_mask_ack_irq
<...>-1252 0d.H6. 1923us : intc_bank_write_reg <-omap_mask_irq
<...>-1252 0d.H6. 1923us : omap_ack_irq <-omap_mask_ack_irq
<...>-1252 0d.H6. 1923us : intc_bank_write_reg <-omap_ack_irq
<...>-1252 0d.H6. 1923us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.H5. 1923us : handle_IRQ_event <-handle_level_irq
<...>-1252 0d.H5. 1923us : add_preempt_count <-lock_timer_base
<...>-1252 0d.H6. 1923us+: internal_add_timer <-mod_timer
<...>-1252 0d.H6. 1953us : add_preempt_count <-serial8250_handle_port
<...>-1252 0d.H7. 1953us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.H7. 1953us+: mem_serial_in <-serial8250_handle_port
<...>-1252 0d.H7. 1984us : mem_serial_in <-serial8250_handle_port
<...>-1252 0d.H7. 1984us+: sub_preempt_count <-serial8250_handle_port
<...>-1252 0d.H6. 2014us : tty_flip_buffer_push <-serial8250_handle_port
<...>-1252 0d.H6. 2014us : add_preempt_count <-tty_flip_buffer_push
<...>-1252 0d.H7. 2014us : sub_preempt_count <-tty_flip_buffer_push
<...>-1252 0d.H6. 2014us : schedule_delayed_work <-tty_flip_buffer_push
<...>-1252 0d.H6. 2014us : queue_delayed_work <-schedule_delayed_work
<...>-1252 0d.H6. 2014us : queue_delayed_work_on <-queue_delayed_work
<...>-1252 0d.H6. 2014us : add_preempt_count <-serial8250_handle_port
<...>-1252 0d.H7. 2014us : check_modem_status <-serial8250_handle_port
<...>-1252 0d.H7. 2014us : mem_serial_in <-check_modem_status
<...>-1252 0d.H7. 2014us+: transmit_chars <-serial8250_handle_port
<...>-1252 0d.H5. 2045us : note_interrupt <-handle_level_irq
<...>-1252 0d.H5. 2045us : add_preempt_count <-handle_level_irq
<...>-1252 0d.H6. 2045us : omap_unmask_irq <-handle_level_irq
<...>-1252 0d.H6. 2045us : intc_bank_write_reg <-omap_unmask_irq
<...>-1252 0d.H6. 2045us : sub_preempt_count <-handle_level_irq
<...>-1252 0d.H5. 2045us : irq_exit <-asm_do_IRQ
<...>-1252 0d.H5. 2045us : sub_preempt_count <-irq_exit
<...>-1252 0d.s6. 2045us : rcu_irq_exit <-irq_exit
<...>-1252 0d.s6. 2045us : idle_cpu <-irq_exit
<...>-1252 0d.s6. 2045us+: sub_preempt_count <-irq_exit
<...>-1252 0d.s4. 2075us : add_preempt_count <-run_timer_softirq
<...>-1252 0d.s4. 2075us : add_preempt_count <-__queue_work
<...>-1252 0d.s5. 2075us : insert_work <-__queue_work
<...>-1252 0d.s6. 2075us : add_preempt_count <-probe_workqueue_insertion
<...>-1252 0d.s7. 2075us : sub_preempt_count <-probe_workqueue_insertion
<...>-1252 0d.s5. 2075us : __wake_up <-insert_work
<...>-1252 0d.s5. 2075us+: add_preempt_count <-__wake_up
<...>-1252 0d.s6. 2106us : __wake_up_common <-__wake_up
<...>-1252 0d.s6. 2106us : autoremove_wake_function <-__wake_up_common
<...>-1252 0d.s6. 2106us : default_wake_function <-autoremove_wake_function
<...>-1252 0d.s6. 2106us : try_to_wake_up <-default_wake_function
<...>-1252 0d.s6. 2106us : add_preempt_count <-try_to_wake_up
<...>-1252 0d.s7. 2106us : task_rq_lock <-try_to_wake_up
<...>-1252 0d.s7. 2106us : add_preempt_count <-task_rq_lock
<...>-1252 0d.s8. 2106us : omap34xx_32k_read <-sched_clock
<...>-1252 0d.s8. 2106us : omap_readl <-omap34xx_32k_read
<...>-1252 0d.s8. 2106us+: activate_task <-try_to_wake_up
<...>-1252 0d.s8. 2136us : enqueue_task <-activate_task
<...>-1252 0d.s8. 2136us : enqueue_task_fair <-enqueue_task
<...>-1252 0d.s8. 2136us : enqueue_entity <-enqueue_task_fair
<...>-1252 0d.s8. 2136us : update_curr <-enqueue_entity
<...>-1252 0d.s8. 2136us : update_min_vruntime <-update_curr
<...>-1252 0d.s8. 2136us : place_entity <-enqueue_entity
<...>-1252 0d.s8. 2136us : check_spread <-enqueue_entity
<...>-1252 0d.s8. 2136us : __enqueue_entity <-enqueue_entity
<...>-1252 0d.s8. 2136us : check_preempt_wakeup <-try_to_wake_up
<...>-1252 0d.s8. 2136us+: sub_preempt_count <-try_to_wake_up
<...>-1252 0d.s7. 2167us : sub_preempt_count <-try_to_wake_up
<...>-1252 0d.s6. 2167us : sub_preempt_count <-__wake_up
<...>-1252 0d.s4. 2167us : add_preempt_count <-run_timer_softirq
<...>-1252 0d.s4. 2167us : _local_bh_enable <-__do_softirq
<...>-1252 0d.s4. 2167us : sub_preempt_count <-_local_bh_enable
<...>-1252 0d..4. 2167us : rcu_irq_exit <-irq_exit
<...>-1252 0d..4. 2167us : idle_cpu <-irq_exit
<...>-1252 0d..4. 2167us+: sub_preempt_count <-irq_exit
llrpserv-1248 0dN.1. 2197us : add_preempt_count <-schedule
llrpserv-1248 0dN.2. 2197us : omap34xx_32k_read <-sched_clock
llrpserv-1248 0dN.2. 2197us : omap_readl <-omap34xx_32k_read
llrpserv-1248 0d..2. 2197us : update_avg <-schedule
llrpserv-1248 0d..2. 2197us : put_prev_task_fair <-schedule
llrpserv-1248 0d..2. 2197us : update_curr <-put_prev_task_fair
llrpserv-1248 0d..2. 2197us : update_min_vruntime <-update_curr
llrpserv-1248 0d..2. 2197us+: check_spread <-put_prev_task_fair
llrpserv-1248 0d..2. 2228us : __enqueue_entity <-put_prev_task_fair
llrpserv-1248 0d..2. 2228us : update_curr <-put_prev_task_fair
llrpserv-1248 0d..2. 2228us : calc_delta_mine <-update_curr
llrpserv-1248 0d..2. 2228us : update_min_vruntime <-update_curr
llrpserv-1248 0d..2. 2228us : check_spread <-put_prev_task_fair
llrpserv-1248 0d..2. 2228us : pick_next_task_rt <-schedule
llrpserv-1248 0d..2. 2228us : pick_next_task_fair <-schedule
llrpserv-1248 0d..2. 2228us : __pick_next_entity <-pick_next_task_fair
llrpserv-1248 0d..2. 2228us+: clear_buddies <-pick_next_task_fair
llrpserv-1248 0d..2. 2258us : set_next_entity <-pick_next_task_fair
llrpserv-1248 0d..2. 2258us : u#err64k
#noroom
#buf_overrun
llrpserv-1248 0d..2. 2258us : __dequeue_entity <-set_next_entity
llrpserv-1248 0d..2. 2258us : __pick_next_entity <-pick_next_task_fair
llrpserv-1248 0d..2. 2258us : clear_buddies <-pick_next_task_fair
llrpserv-1248 0d..2. 2258us : update_stats_wait_end <-set_next_entity
llrpserv-1248 0d..2. 2258us+: __dequeue_entity <-set_next_entity
llrpserv-1251 0...1. 2289us : schedule
llrpserv-1251 0...1. 2289us : trace_preempt_on <-schedule
[12/03/2012|23:04:33.195] : End Dump)
[12/03/2012|23:04:33.326] Detect CRC Error
[12/03/2012|23:04:33.331] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.333] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.337] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.345] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.347] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.349] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.352] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.354] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.356] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.358] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.361] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.364] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.368] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.374] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.375] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.376] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.379] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.381] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.384] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.385] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.387] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.388] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.390] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.391] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.393] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.395] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.397] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.399] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.404] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.408] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.409] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.411] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.412] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.414] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.417] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.419] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.420] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.422] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.423] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.425] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.427] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.428] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.437] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.438] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.440] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.441] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.443] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.445] Sync : non-synched in first SOF byte
[12/03/2012|23:04:33.865] : checkOverRun : buf_overrun(5187) overrun(1) frame(0) parity(0) brk(0) buffer(-820453800)
[12/03/2012|23:04:33.866] : Begin Dump)
# latency: 3021 us, #966/966, CPU#0 | (M:preempt VP:0, KP:0, SP:0 HP:0)
# | task: -5 (uid:0 nice:0 policy:0 rt_prio:0)
# => started at: flush_to_ldisc
# => ended at: flush_to_ldisc
# _------=> CPU#
# |||||/ delay
events/0-5 0...1. 0us : trace_preempt_on <-worker_thread
events/0-5 0d..1. 0us : tty_ldisc_try
events/0-5 0...1. 0us : tty_ldisc_try
events/0-5 0...1. 0us : trace_preempt_on <-tty_ldisc_try
events/0-5 0d..1. 0us : flush_to_ldisc
events/0-5 0d..1. 0us+: schedule_delayed_work <-flush_to_ldisc
events/0-5 0d..1. 31us : queue_delayed_work <-schedule_delayed_work
events/0-5 0d..1. 31us : queue_delayed_work_on <-queue_delayed_work
events/0-5 0d..1. 31us : add_timer <-queue_delayed_work_on
events/0-5 0d..1. 31us : mod_timer <-add_timer
events/0-5 0d..1. 31us : lock_timer_base <-mod_timer
events/0-5 0d..1. 31us : add_preempt_count <-lock_timer_base
events/0-5 0d..2. 31us : internal_add_timer <-mod_timer
events/0-5 0d..2. 31us+: sub_preempt_count <-mod_timer
events/0-5 0d..2. 61us : asm_do_IRQ <-__irq_svc
events/0-5 0d..2. 61us : irq_enter <-asm_do_IRQ
events/0-5 0d..2. 61us : rcu_irq_enter <-irq_enter
events/0-5 0d..2. 61us : idle_cpu <-irq_enter
events/0-5 0d..2. 61us : add_preempt_count <-irq_enter
events/0-5 0d.h2. 61us : irq_to_desc <-asm_do_IRQ
events/0-5 0d.h2. 61us : handle_level_irq <-asm_do_IRQ
events/0-5 0d.h2. 61us : add_preempt_count <-handle_level_irq
events/0-5 0d.h3. 61us : omap_mask_irq <-handle_level_irq
events/0-5 0d.h3. 61us+: intc_bank_write_reg <-omap_mask_irq
events/0-5 0d.h3. 92us : omap_mask_ack_irq <-handle_level_irq
events/0-5 0d.h3. 92us : omap_mask_irq <-omap_mask_ack_irq
events/0-5 0d.h3. 92us : intc_bank_write_reg <-omap_mask_irq
events/0-5 0d.h3. 92us : omap_ack_irq <-omap_mask_ack_irq
events/0-5 0d.h3. 92us : intc_bank_write_reg <-omap_ack_irq
events/0-5 0d.h3. 92us : sub_preempt_count <-handle_level_irq
events/0-5 0d.h2. 92us : handle_IRQ_event <-handle_level_irq
events/0-5 0d.h3. 92us : add_preempt_count <-serial8250_handle_port
events/0-5 0d.h4. 92us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 122us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 122us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 122us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 122us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 122us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 122us+: tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 153us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 153us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 153us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 153us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 153us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 153us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 183us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 183us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 183us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 183us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 183us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 183us+: add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 214us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 214us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 214us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 214us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 214us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 214us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 244us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 244us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 244us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 244us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 244us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 244us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 275us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 275us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 275us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 275us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 275us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h5. 275us+: sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 305us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 305us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 305us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 305us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 305us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 305us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 336us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 336us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 336us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 336us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 336us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 336us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 366us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 366us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 366us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 366us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 366us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h5. 366us+: sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 397us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 397us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 397us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 397us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 397us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 397us+: add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 427us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 427us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 427us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 427us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 427us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 427us+: tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 458us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 458us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 458us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 458us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 458us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 458us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 488us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 488us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 488us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 488us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 488us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 488us+: tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 519us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 519us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 519us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 519us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 519us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 519us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 549us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 549us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 549us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 549us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 549us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 549us+: sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 580us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 580us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 580us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 580us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 580us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 580us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 610us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 610us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 610us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 610us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 610us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 610us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 641us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 641us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 641us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 641us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 641us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h5. 641us+: sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 671us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 671us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 671us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 671us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 671us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 671us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 702us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 702us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 702us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 702us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 702us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 702us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 732us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 732us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 732us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 732us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 732us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h5. 732us+: sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 763us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 763us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 763us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 763us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 763us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 763us+: add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 793us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 793us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 793us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 793us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 793us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 793us+: tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 824us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 824us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 824us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 824us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 824us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 824us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 854us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 854us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 854us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 854us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 854us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 854us+: add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 885us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 885us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 885us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 885us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 885us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 885us+: tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 916us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 916us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 916us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 916us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 916us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 916us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 946us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 946us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 946us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 946us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 946us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 946us+: sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 977us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 977us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 977us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 977us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 977us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 977us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 1007us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 1007us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1007us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1007us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1007us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h5. 1007us+: sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1038us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1038us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1038us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 1038us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 1038us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1038us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 1068us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 1068us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1068us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1068us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1068us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 1068us+: tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1099us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 1099us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 1099us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1099us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1099us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1099us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1129us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1129us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1129us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 1129us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 1129us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1129us+: add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 1160us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1160us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1160us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1160us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 1160us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1160us+: tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1190us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 1190us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 1190us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1190us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1190us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1190us+: mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1221us : mem_serial_in <-serial8250_handle_port
events/0-5 0d.h4. 1221us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0d.h4. 1221us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0d.h4. 1221us : add_preempt_count <-tty_buffer_request_room
events/0-5 0d.h5. 1221us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0d.h4. 1221us : sub_preempt_count <-serial8250_handle_port
events/0-5 0d.h3. 1221us : tty_flip_buffer_push <-serial8250_handle_port
events/0-5 0d.h3. 1221us : add_preempt_count <-tty_flip_buffer_push
events/0-5 0d.h4. 1221us+: sub_preempt_count <-tty_flip_buffer_push
events/0-5 0d.h3. 1251us : schedule_delayed_work <-tty_flip_buffer_push
events/0-5 0d.h3. 1251us : queue_delayed_work <-schedule_delayed_work
events/0-5 0d.h3. 1251us : queue_delayed_work_on <-queue_delayed_work
events/0-5 0d.h3. 1251us : add_preempt_count <-serial8250_handle_port
events/0-5 0d.h4. 1251us : check_modem_status <-serial8250_handle_port
events/0-5 0d.h4. 1251us : mem_serial_in <-check_modem_status
events/0-5 0d.h4. 1251us : transmit_chars <-serial8250_handle_port
events/0-5 0d.h5. 1251us : asm_do_IRQ <-__irq_svc
events/0-5 0d.h5. 1251us : irq_enter <-asm_do_IRQ
events/0-5 0d.h5. 1251us+: rcu_irq_enter <-irq_enter
events/0-5 0d.h5. 1282us : idle_cpu <-irq_enter
events/0-5 0d.h5. 1282us : add_preempt_count <-irq_enter
events/0-5 0d.h5. 1282us : irq_to_desc <-asm_do_IRQ
events/0-5 0d.h5. 1282us : handle_level_irq <-asm_do_IRQ
events/0-5 0d.h5. 1282us : add_preempt_count <-handle_level_irq
events/0-5 0d.h6. 1282us : omap_mask_irq <-handle_level_irq
events/0-5 0d.h6. 1282us : intc_bank_write_reg <-omap_mask_irq
events/0-5 0d.h6. 1282us : omap_mask_ack_irq <-handle_level_irq
events/0-5 0d.h6. 1282us : omap_mask_irq <-omap_mask_ack_irq
events/0-5 0d.h6. 1282us+: omap_ack_irq <-omap_mask_ack_irq
events/0-5 0d.h6. 1312us : intc_bank_write_reg <-omap_ack_irq
events/0-5 0d.h6. 1312us : sub_preempt_count <-handle_level_irq
events/0-5 0d.h5. 1312us : handle_IRQ_event <-handle_level_irq
events/0-5 0d.h6. 1312us : asm_do_IRQ <-__irq_svc
events/0-5 0d.h6. 1312us : irq_enter <-asm_do_IRQ
events/0-5 0d.h6. 1312us : rcu_irq_enter <-irq_enter
events/0-5 0d.h6. 1312us : idle_cpu <-irq_enter
events/0-5 0d.h6. 1312us : add_preempt_count <-irq_enter
events/0-5 0d.h6. 1312us : irq_to_desc <-asm_do_IRQ
events/0-5 0d.h6. 1312us+: handle_level_irq <-asm_do_IRQ
events/0-5 0d.h6. 1343us : add_preempt_count <-handle_level_irq
events/0-5 0d.h7. 1343us : omap_mask_irq <-handle_level_irq
events/0-5 0d.h7. 1343us : intc_bank_write_reg <-omap_mask_irq
events/0-5 0d.h7. 1343us : omap_mask_ack_irq <-handle_level_irq
events/0-5 0d.h7. 1343us : omap_mask_irq <-omap_mask_ack_irq
events/0-5 0d.h7. 1343us : omap_ack_irq <-omap_mask_ack_irq
events/0-5 0d.h7. 1343us : intc_bank_write_reg <-omap_ack_irq
events/0-5 0d.h7. 1343us : sub_preempt_count <-handle_level_irq
events/0-5 0d.h6. 1343us+: handle_IRQ_event <-handle_level_irq
events/0-5 0d.h6. 1373us : omap2_gp_timer_interrupt <-handle_IRQ_event
events/0-5 0d.h6. 1373us : omap_dm_timer_write_status <-omap2_gp_timer_interrupt
events/0-5 0d.h6. 1373us : omap_dm_timer_write_reg <-omap_dm_timer_write_status
events/0-5 0d.h6. 1373us : hrtimer_interrupt <-omap2_gp_timer_interrupt
events/0-5 0d.h6. 1373us : ktime_get <-hrtimer_interrupt
events/0-5 0d.h6. 1373us : omap34xx_32k_read <-ktime_get
events/0-5 0d.h6. 1373us : omap_readl <-omap34xx_32k_read
events/0-5 0d.h6. 1373us : ktime_add_ns <-ktime_get
events/0-5 0d.h6. 1373us+: add_preempt_count <-hrtimer_interrupt
events/0-5 0d.h7. 1404us : __run_hrtimer <-hrtimer_interrupt
events/0-5 0d.h7. 1404us : __remove_hrtimer <-__run_hrtimer
events/0-5 0d.h7. 1404us : sub_preempt_count <-__run_hrtimer
events/0-5 0d.h6. 1404us : hrtimer_wakeup <-__run_hrtimer
events/0-5 0d.h6. 1404us : wake_up_process <-hrtimer_wakeup
events/0-5 0d.h6. 1404us : try_to_wake_up <-wake_up_process
events/0-5 0d.h6. 1404us : add_preempt_count <-try_to_wake_up
events/0-5 0d.h7. 1404us : task_rq_lock <-try_to_wake_up
events/0-5 0d.h7. 1404us+: add_preempt_count <-task_rq_lock
events/0-5 0d.h8. 1434us : omap34xx_32k_read <-sched_clock
events/0-5 0d.h8. 1434us : omap_readl <-omap34xx_32k_read
events/0-5 0d.h8. 1434us : activate_task <-try_to_wake_up
events/0-5 0d.h8. 1434us : enqueue_task <-activate_task
events/0-5 0d.h8. 1434us : enqueue_task_fair <-enqueue_task
events/0-5 0d.h8. 1434us : enqueue_entity <-enqueue_task_fair
events/0-5 0d.h8. 1434us : update_curr <-enqueue_entity
events/0-5 0d.h8. 1434us : update_min_vruntime <-update_curr
events/0-5 0d.h8. 1434us+: place_entity <-enqueue_entity
events/0-5 0d.h8. 1465us : check_spread <-enqueue_entity
events/0-5 0d.h8. 1465us : __enqueue_entity <-enqueue_entity
events/0-5 0d.h8. 1465us : check_preempt_wakeup <-try_to_wake_up
events/0-5 update_curr
events/0-5 0dNh8. 1923us : place_entity <-enqueue_entity
events/0-5 0dNh8. 1923us : check_spread <-enqueue_entity
events/0-5 0dNh8. 1923us+: __enqueue_entity <-enqueue_entity
events/0-5 0dNh8. 1953us : check_preempt_wakeup <-try_to_wake_up
events/0-5 0dNh8. 1953us : sub_preempt_count <-try_to_wake_up
events/0-5 0dNh7. 1953us : preempt_schedule <-try_to_wake_up
events/0-5 0dNh7. 1953us : sub_preempt_count <-try_to_wake_up
events/0-5 0dNh6. 1953us : preempt_schedule <-try_to_wake_up
events/0-5 0dNh6. 1953us : add_preempt_count <-__run_hrtimer
events/0-5 0dNh7. 1953us : sub_preempt_count <-hrtimer_interrupt
events/0-5 0dNh6. 1953us : preempt_schedule <-hrtimer_interrupt
events/0-5 0dNh6. 1953us : tick_program_event <-hrtimer_interrupt
events/0-5 0dNh6. 1953us : tick_dev_program_event <-tick_program_event
events/0-5 0dNh6. 1953us+: ktime_get <-tick_dev_program_event
events/0-5 0dNh6. 1984us : omap34xx_32k_read <-ktime_get
events/0-5 0dNh6. 1984us : omap_readl <-omap34xx_32k_read
events/0-5 0dNh6. 1984us : ktime_add_ns <-ktime_get
events/0-5 0dNh6. 1984us : clockevents_program_event <-tick_dev_program_event
events/0-5 0dNh6. 1984us : omap2_gp_timer_set_next_event <-clockevents_program_event
events/0-5 0dNh6. 1984us : omap_dm_timer_set_load_start <-omap2_gp_timer_set_next_event
events/0-5 0dNh6. 1984us : omap_dm_timer_write_reg <-omap_dm_timer_set_load_start
events/0-5 0dNh6. 1984us+: omap_dm_timer_write_reg <-omap_dm_timer_set_load_start
events/0-5 0dNh6. 2014us : note_interrupt <-handle_level_irq
events/0-5 0dNh6. 2014us : add_preempt_count <-handle_level_irq
events/0-5 0dNh7. 2014us : omap_unmask_irq <-handle_level_irq
events/0-5 0dNh7. 2014us : intc_bank_write_reg <-omap_unmask_irq
events/0-5 0dNh7. 2014us : sub_preempt_count <-handle_level_irq
events/0-5 0dNh6. 2014us : preempt_schedule <-handle_level_irq
events/0-5 0dNh6. 2014us : irq_exit <-asm_do_IRQ
events/0-5 0dNh6. 2014us : sub_preempt_count <-irq_exit
events/0-5 0dNh7. 2014us : rcu_irq_exit <-irq_exit
events/0-5 0dNh7. 2014us : idle_cpu <-irq_exit
events/0-5 0dNh7. 2014us+: sub_preempt_count <-irq_exit
events/0-5 0dNh5. 2045us : add_preempt_count <-lock_timer_base
events/0-5 0dNh6. 2045us : internal_add_timer <-mod_timer
events/0-5 0dNh6. 2045us : add_preempt_count <-serial8250_handle_port
events/0-5 0dNh7. 2045us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh7. 2045us : check_modem_status <-serial8250_handle_port
events/0-5 0dNh7. 2045us : mem_serial_in <-check_modem_status
events/0-5 0dNh7. 2045us+: transmit_chars <-serial8250_handle_port
events/0-5 0dNh7. 2075us : mem_serial_out <-transmit_chars
events/0-5 0dNh5. 2075us : note_interrupt <-handle_level_irq
events/0-5 0dNh5. 2075us+: add_preempt_count <-handle_level_irq
events/0-5 0dNh6. 2106us : omap_unmask_irq <-handle_level_irq
events/0-5 0dNh6. 2106us : intc_bank_write_reg <-omap_unmask_irq
events/0-5 0dNh6. 2106us : sub_preempt_count <-handle_level_irq
events/0-5 0dNh5. 2106us : preempt_schedule <-handle_level_irq
events/0-5 0dNh5. 2106us : irq_exit <-asm_do_IRQ
events/0-5 0dNh5. 2106us : sub_preempt_count <-irq_exit
events/0-5 0dNh6. 2106us : rcu_irq_exit <-irq_exit
events/0-5 0dNh6. 2106us : idle_cpu <-irq_exit
events/0-5 0dNh6. 2106us+: sub_preempt_count <-irq_exit
events/0-5 0dNh3. 2136us : add_preempt_count <-serial8250_handle_port
events/0-5 0dNh4. 2136us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2136us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2136us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2136us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2136us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2136us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2136us+: mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2167us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2167us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2167us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2167us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2167us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2167us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2167us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2197us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2197us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2197us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2197us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2197us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2197us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2197us+: mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2228us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2228us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2228us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2228us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2228us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2228us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2228us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2258us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2258us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2258us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2258us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2258us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2258us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2258us+: mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2289us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2289us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2289us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2289us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2289us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2289us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2289us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2319us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2319us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2319us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2319us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2319us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2319us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2319us+: preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2350us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2350us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2350us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2350us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2350us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2350us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2350us+: tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2380us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2380us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2380us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2380us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2380us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2380us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2380us+: preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2411us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh4. 2411us : tty_insert_flip_string_flags <-serial8250_handle_port
events/0-5 0dNh4. 2411us : tty_buffer_request_room <-tty_insert_flip_string_flags
events/0-5 0dNh4. 2411us : add_preempt_count <-tty_buffer_request_room
events/0-5 0dNh5. 2411us : sub_preempt_count <-tty_buffer_request_room
events/0-5 0dNh4. 2411us : preempt_schedule <-tty_buffer_request_room
events/0-5 0dNh4. 2411us : sub_preempt_count <-serial8250_handle_port
events/0-5 0dNh3. 2411us : preempt_schedule <-serial8250_handle_port
events/0-5 0dNh3. 2411us+: tty_flip_buffer_push <-serial8250_handle_port
events/0-5 0dNh3. 2441us : add_preempt_count <-tty_flip_buffer_push
events/0-5 0dNh4. 2441us : sub_preempt_count <-tty_flip_buffer_push
events/0-5 0dNh3. 2441us : preempt_schedule <-tty_flip_buffer_push
events/0-5 0dNh3. 2441us : schedule_delayed_work <-tty_flip_buffer_push
events/0-5 0dNh3. 2441us : queue_delayed_work <-schedule_delayed_work
events/0-5 0dNh3. 2441us : queue_delayed_work_on <-queue_delayed_work
events/0-5 0dNh3. 2441us : add_preempt_count <-serial8250_handle_port
events/0-5 0dNh4. 2441us : check_modem_status <-serial8250_handle_port
events/0-5 0dNh4. 2441us : mem_serial_in <-check_modem_status
events/0-5 0dNh4. 2441us+: transmit_chars <-serial8250_handle_port
events/0-5 0dNh5. 2472us : asm_do_IRQ <-__irq_svc
events/0-5 0dNh5. 2472us : irq_enter <-asm_do_IRQ
events/0-5 0dNh5. 2472us : rcu_irq_enter <-irq_enter
events/0-5 0dNh5. 2472us : idle_cpu <-irq_enter
events/0-5 0dNh5. 2472us : add_preempt_count <-irq_enter
events/0-5 0dNh5. 2472us : irq_to_desc <-asm_do_IRQ
events/0-5 0dNh5. 2472us : handle_level_irq <-asm_do_IRQ
events/0-5 0dNh5. 2472us : add_preempt_count <-handle_level_irq
events/0-5 0dNh6. 2472us : omap_mask_irq <-handle_level_irq
events/0-5 0dNh6. 2472us : intc_bank_write_reg <-omap_mask_irq
events/0-5 0dNh6. 2472us+: omap_mask_ack_irq <-handle_level_irq
events/0-5 0dNh6. 2502us : omap_mask_irq <-omap_mask_ack_irq
events/0-5 0dNh6. 2502us : intc_bank_write_reg <-omap_mask_irq
events/0-5 0dNh6. 2502us : omap_ack_irq <-omap_mask_ack_irq
events/0-5 0dNh6. 2502us : intc_bank_write_reg <-omap_ack_irq
events/0-5 0dNh6. 2502us : sub_preempt_count <-handle_level_irq
events/0-5 0dNh5. 2502us : preempt_schedule <-handle_level_irq
events/0-5 0dNh5. 2502us : handle_IRQ_event <-handle_level_irq
events/0-5 0dNh5. 2502us : omap2_gp_timer_interrupt <-handle_IRQ_event
events/0-5 0dNh5. 2502us : omap_dm_timer_write_status <-omap2_gp_timer_interrupt
events/0-5 0dNh5. 2502us : omap_dm_timer_write_reg <-omap_dm_timer_write_status
events/0-5 0dNh5. 2502us+: hrtimer_interrupt <-omap2_gp_timer_interrupt
events/0-5 0dNh5. 2533us : ktime_get <-hrtimer_interrupt
events/0-5 0dNh5. 2533us : omap34xx_32k_read <-ktime_get
events/0-5 0dNh5. 2533us : omap_readl <-omap34xx_32k_read
events/0-5 0dNh5. 2533us : ktime_add_ns <-ktime_get
events/0-5 0dNh5. 2533us : add_preempt_count <-hrtimer_interrupt
events/0-5 0dNh6. 2533us : __run_hrtimer <-hrtimer_interrupt
events/0-5 0dNh6. 2533us : __remove_hrtimer <-__run_hrtimer
events/0-5 0dNh6. 2533us : sub_preempt_count <-__run_hrtimer
events/0-5 0dNh5. 2533us : preempt_schedule <-__run_hrtimer
events/0-5 0dNh5. 2533us+: hrtimer_wakeup <-__run_hrtimer
events/0-5 0dNh5. 2563us : wake_up_process <-hrtimer_wakeup
events/0-5 0dNh5. 2563us : try_to_wake_up <-wake_up_process
events/0-5 0dNh5. 2563us : add_preempt_count <-try_to_wake_up
events/0-5 0dNh6. 2563us : task_rq_lock <-try_to_wake_up
events/0-5 0dNh6. 2563us : add_preempt_count <-task_rq_lock
events/0-5 0dNh7. 2563us : omap34xx_32k_read <-sched_clock
events/0-5 0dNh7. 2563us : omap_readl <-omap34xx_32k_read
events/0-5 0dNh7. 2563us : activate_task <-try_to_wake_up
events/0-5 0dNh7. 2563us : enqueue_task <-activate_task
events/0-5 0dNh7. 2563us+: enqueue_task_fair <-enqueue_task
events/0-5 0dNh7. 2594us : enqueue_entity <-enqueue_task_fair
events/0-5 0dNh7. 2594us : update_curr <-enqueue_entity
events/0-5 0dNh7. 2594us : update_min_vruntime <-update_curr
events/0-5 0dNh7. 2594us : place_entity <-enqueue_entity
events/0-5 0dNh7. 2594us : check_spread <-enqueue_entity
events/0-5 0dNh7. 2594us : __enqueue_entity <-enqueue_entity
events/0-5 0dNh7. 2594us : check_preempt_wakeup <-try_to_wake_up
events/0-5 0dNh7. 2594us+: sub_preempt_count <-try_to_wake_up
events/0-5 0dNh6. 2625us : preempt_schedule <-try_to_wake_up
events/0-5 0dNh6. 2625us : sub_preempt_count <-try_to_wake_up
events/0-5 0dNh5. 2625us : preempt_schedule <-try_to_wake_up
events/0-5 0dNh5. 2625us : add_preempt_count <-__run_hrtimer
events/0-5 0dNh6. 2625us : __run_hrtimer <-hrtimer_interrupt
events/0-5 0dNh6. 2625us : __remove_hrtimer <-__run_hrtimer
events/0-5 0dNh6. 2625us : sub_preempt_count <-__run_hrtimer
events/0-5 0dNh5. 2625us : preempt_schedule <-__run_hrtimer
events/0-5 0dNh5. 2625us : hrtimer_wakeup <-__run_hrtimer
events/0-5 0dNh5. 2625us+: wake_up_process <-hrtimer_wakeup
events/0-5 0dNh5. 2655us : try_to_wake_up <-wake_up_process
events/0-5 0dNh5. 2655us : add_preempt_count <-try_to_wake_up
events/0-5 0dNh6. 2655us : task_rq_lock <-try_to_wake_up
events/0-5 0dNh6. 2655us : add_preempt_count <-task_rq_lock
events/0-5 0dNh7. 2655us : omap34xx_32k_read <-sched_clock
events/0-5 0dNh7. 2655us : omap_readl <-omap34xx_32k_read
events/0-5 0dNh7. 2655us : activate_task <-try_to_wake_up
events/0-5 0dNh7. 2655us : enqueue_task <-activate_task
events/0-5 0dNh7. 2655us : enqueue_task_fair <-enqueue_task
events/0-5 0dNh7. 2655us+: enqueue_entity <-enqueue_task_fair
events/0-5 0dNh7. 2686us : update_curr <-enqueue_entity
events/0-5 0dNh7. 2686us : update_min_vruntime <-update_curr
events/0-5 0dNh7. 2686us : place_entity <-enqueue_entity
events/0-5 0dNh7. 2686us : check_spread <-enqueue_entity
events/0-5 0dNh7. 2686us : __enqueue_entity <-enqueue_entity
events/0-5 0dNh7. 2686us : check_preempt_wakeup <-try_to_wake_up
events/0-5 0dNh7. 2686us : sub_preempt_count <-try_to_wake_up
events/0-5 0dNh6. 2686us : preempt_schedule <-try_to_wake_up
events/0-5 0dNh6. 2686us : sub_preempt_count <-try_to_wake_up
events/0-5 0dNh5. 2686us+: preempt_schedule <-try_to_wake_up
events/0-5 0dNh5. 2716us : add_preempt_count <-__run_hrtimer
events/0-5 0dNh6. 2716us : sub_preempt_count <-hrtimer_interrupt
events/0-5 0dNh5. 2716us : preempt_schedule <-hrtimer_interrupt
events/0-5 0dNh5. 2716us : tick_program_event <-hrtimer_interrupt
events/0-5 0dNh5. 2716us : tick_dev_program_event <-tick_program_event
events/0-5 0dNh5. 2716us : ktime_get <-tick_dev_program_event
events/0-5 0dNh5. 2716us : omap34xx_32k_read <-ktime_get
events/0-5 0dNh5. 2716us : omap_readl <-omap34xx_32k_read
events/0-5 0dNh5. 2716us : ktime_add_ns <-ktime_get
events/0-5 0dNh5. 2716us : clockevents_program_event <-tick_dev_program_event
events/0-5 0dNh5. 2716us+: omap2_gp_timer_set_next_event <-clockevents_program_event
events/0-5 0dNh5. 2747us : omap_dm_timer_set_load_start <-omap2_gp_timer_set_next_event
events/0-5 0dNh5. 2747us : omap_dm_timer_write_reg <-omap_dm_timer_set_load_start
events/0-5 0dNh5. 2747us : note_interrupt <-handle_level_irq
events/0-5 0dNh5. 2747us : add_preempt_count <-handle_level_irq
events/0-5 0dNh6. 2747us : omap_unmask_irq <-handle_level_irq
events/0-5 0dNh6. 2747us : intc_bank_write_reg <-omap_unmask_irq
events/0-5 0dNh6. 2747us : sub_preempt_count <-handle_level_irq
events/0-5 0dNh5. 2747us+: preempt_schedule <-handle_level_irq
events/0-5 0dNh5. 2777us : irq_exit <-asm_do_IRQ
events/0-5 0dNh5. 2777us : sub_preempt_count <-irq_exit
events/0-5 0dNh6. 2777us : rcu_irq_exit <-irq_exit
events/0-5 0dNh6. 2777us : idle_cpu <-irq_exit
events/0-5 0dNh6. 2777us : sub_preempt_count <-irq_exit
events/0-5 0dNh5. 2777us : asm_do_IRQ <-__irq_svc
events/0-5 0dNh5. 2777us : irq_enter <-asm_do_IRQ
events/0-5 0dNh5. 2777us : rcu_irq_enter <-irq_enter
events/0-5 0dNh5. 2777us : idle_cpu <-irq_enter
events/0-5 0dNh5. 2777us : add_preempt_count <-irq_enter
events/0-5 0dNh5. 2777us+: irq_to_desc <-asm_do_IRQ
events/0-5 0dNh5. 2808us : handle_level_irq <-asm_do_IRQ
events/0-5 0dNh5. 2808us : add_preempt_count <-handle_level_irq
events/0-5 0dNh6. 2808us : omap_mask_irq <-handle_level_irq
events/0-5 0dNh6. 2808us : intc_bank_write_reg <-omap_mask_irq
events/0-5 0dNh6. 2808us : omap_mask_ack_irq <-handle_level_irq
events/0-5 0dNh6. 2808us : omap_mask_irq <-omap_mask_ack_irq
events/0-5 0dNh6. 2808us : omap_ack_irq <-omap_mask_ack_irq
events/0-5 0dNh6. 2808us : intc_bank_write_reg <-omap_ack_irq
events/0-5 0dNh6. 2808us : sub_preempt_count <-handle_level_irq
events/0-5 0dNh5. 2808us+: preempt_schedule <-handle_level_irq
events/0-5 0dNh5. 2838us : handle_IRQ_event <-handle_level_irq
events/0-5 0dNh6. 2838us : add_preempt_count <-serial8250_handle_port
events/0-5 0dNh7. 2838us : mem_serial_in <-serial8250_handle_port
events/0-5 0dNh7. 2838us : check_modem_status <-serial8250_handle_port
events/0-5 0dNh7. 2838us : mem_serial_in <-check_modem_status
events/0-5 0dNh7. 2838us : transmit_chars <-serial8250_handle_port
events/0-5 0dNh7. 2838us : mem_serial_out <-transmit_chars
events/0-5 0dNh7. 2838us+: mem_serial_out <-transmit_chars
events/0-5 0dNh7. 2869us : mem_serial_out <-transmit_chars
events/0-5 0dNh5. 2869us : note_interrupt <-handle_level_irq
events/0-5 0dNh5. 2869us : add_preempt_count <-handle_level_irq
events/0-5 0dNh6. 2869us : omap_unmask_irq <-handle_level_irq
events/0-5 0dNh6. 2869us : intc_bank_write_reg <-omap_unmask_irq
events/0-5 0dNh6. 2869us+: sub_preempt_count <-handle_level_irq
events/0-5 0dNh5. 2899us : preempt_schedule <-handle_level_irq
events/0-5 0dNh5. 2899us : irq_exit <-asm_do_IRQ
events/0-5 0dNh5. 2899us : sub_preempt_count <-irq_exit
events/0-5 0dNh6. 2899us : rcu_irq_exit <-irq_exit
events/0-5 0dNh6. 2899us : idle_cpu <-irq_exit
events/0-5 0dNh6. 2899us : sub_preempt_count <-irq_exit
events/0-5 0dNh2. 2899us : note_interrupt <-handle_level_irq
events/0-5 0dNh2. 2899us : add_preempt_count <-handle_level_irq
events/0-5 0dNh3. 2899us : omap_unmask_irq <-handle_level_irq
events/0-5 0dNh3. 2899us+: intc_bank_write_reg <-omap_unmask_irq
events/0-5 0dNh3. 2930us : sub_preempt_count <-handle_level_irq
events/0-5 0dNh2. 2930us : preempt_schedule <-handle_level_irq
events/0-5 0dNh2. 2930us : irq_exit <-asm_do_IRQ
events/0-5 0dNh2. 2930us : sub_preempt_count <-irq_exit
events/0-5 0dN.3. 2930us : __do_softirq <-irq_exit
events/0-5 0dN.3. 2930us : __local_bh_disable <-__do_softirq
events/0-5 0dNs3. 2930us+: add_preempt_count <-run_timer_softirq
events/0-5 0dNs3. 2960us : add_preempt_count <-__queue_work
events/0-5 0dNs4. 2960us : insert_work <-__queue_work
events/0-5 0dNs5. 2960us : add_preempt_count <-probe_workqueue_insertion
events/0-5 0dNs6. 2960us : sub_preempt_count <-probe_workqueue_insertion
events/0-5 0dNs5. 2960us : preempt_schedule <-probe_workqueue_insertion
events/0-5 0dNs4. 2960us : preempt_schedule <-insert_work
events/0-5 0dNs4. 2960us : __wake_up <-insert_work
events/0-5 0dNs4. 2960us : add_preempt_count <-__wake_up
events/0-5 0dNs5. 2960us+: __wake_up_common <-__wake_up
events/0-5 0dNs5. 2991us : sub_preempt_count <-__wake_up
events/0-5 0dNs4. 2991us : preempt_schedule <-__wake_up
events/0-5 0dNs3. 2991us : add_preempt_count <-run_timer_softirq
events/0-5 0dNs3. 2991us : _local_bh_enable <-__do_softirq
events/0-5 0dNs3. 2991us : sub_preempt_count <-_local_bh_enable
events/0-5 0dN.3. 2991us : rcu_irq_exit <-irq_exit
events/0-5 0dN.3. 2991us : idle_cpu <-irq_exit
events/0-5 0dN.3. 2991us : sub_preempt_count <-irq_exit
events/0-5 0.N.1. 2991us+: flush_to_ldisc
events/0-5 0.N.1. 3021us : trace_preempt_on <-flush_to_ldisc
[12/03/2012|23:04:41.298] : End Dump)
[12/03/2012|23:04:41.305] Sync : non-synched in first SOF byte
Also, the kernel is compiled with the following config options.
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.32.8
# Thu Dec 6 11:41:30 2012
CONFIG_ARM=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_GENERIC_GPIO=y
CONFIG_GENERIC_TIME=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_GENERIC_HARDIRQS=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_HAVE_LATENCYTOP_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_RWSEM_GENERIC_SPINLOCK=y
CONFIG_ARCH_HAS_CPUFREQ=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
CONFIG_OPROFILE_ARMV7=y
CONFIG_VECTORS_BASE=0xffff0000
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_CONSTRUCTORS=y
# General setup
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_LOCK_KERNEL=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_LOCALVERSION=""
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_BSD_PROCESS_ACCT=y
# CONFIG_BSD_PROCESS_ACCT_V3 is not set
# CONFIG_TASKSTATS is not set
# CONFIG_AUDIT is not set
# RCU Subsystem
CONFIG_TREE_RCU=y
# CONFIG_TREE_PREEMPT_RCU is not set
# CONFIG_TINY_RCU is not set
# CONFIG_RCU_TRACE is not set
CONFIG_RCU_FANOUT=32
# CONFIG_RCU_FANOUT_EXACT is not set
# CONFIG_TREE_RCU_TRACE is not set
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=14
# CONFIG_HAVE_GET_CYCLES is not set
CONFIG_HAVE_TRACE_CLOCK=y
# CONFIG_HAVE_TRACE_CLOCK_GENERIC is not set
CONFIG_HAVE_TRACE_CLOCK_32_TO_64=y
# CONFIG_HAVE_UNSYNCHRONIZED_TSC is not set
CONFIG_GROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
# CONFIG_RT_GROUP_SCHED is not set
CONFIG_USER_SCHED=y
# CONFIG_CGROUP_SCHED is not set
# CONFIG_CGROUPS is not set
# CONFIG_SYSFS_DEPRECATED_V2 is not set
CONFIG_RELAY=y
# CONFIG_NAMESPACES is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
# CONFIG_RD_BZIP2 is not set
# CONFIG_RD_LZMA is not set
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_EMBEDDED=y
CONFIG_UID16=y
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
CONFIG_KALLSYMS_EXTRA_PASS=y
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
CONFIG_EVENT_PROFILE=y
# CONFIG_PERF_COUNTERS is not set
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_COMPAT_BRK=y
CONFIG_SLAB=y
# CONFIG_SLUB is not set
# CONFIG_SLOB is not set
CONFIG_PROFILING=y
CONFIG_TRACEPOINTS=y
CONFIG_MARKERS=y
CONFIG_OPROFILE=m
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_CLK=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
# CONFIG_SLOW_WORK is not set
CONFIG_LTT=y
CONFIG_LTT_FILTER=m
CONFIG_HAVE_LTT_DUMP_TABLES=y
CONFIG_LTT_RELAY=y
CONFIG_LTT_RELAY_LOCKLESS=y
# CONFIG_LTT_RELAY_IRQOFF is not set
# CONFIG_LTT_RELAY_LOCKED is not set
CONFIG_LTT_SERIALIZE=y
CONFIG_LTT_FAST_SERIALIZE=y
CONFIG_LTT_TRACEPROBES=m
CONFIG_LTT_TRACE_CONTROL=y
CONFIG_LTT_TRACER=y
CONFIG_LTT_ALIGNMENT=y
CONFIG_LTT_CHECK_ARCH_EFFICIENT_UNALIGNED_ACCESS=y
# CONFIG_LTT_DEBUG_EVENT_SIZE is not set
CONFIG_LTT_USERSPACE_EVENT=m
CONFIG_LTT_VMCORE=y
CONFIG_LTT_STATEDUMP=m
# CONFIG_LTT_ASCII is not set
# CONFIG_HAVE_IMMEDIATE is not set
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL=y
CONFIG_BLOCK=y
CONFIG_LBDAF=y
# CONFIG_BLK_DEV_BSG is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
# CONFIG_INLINE_SPIN_TRYLOCK is not set
# CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK is not set
# CONFIG_INLINE_SPIN_LOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK_IRQ is not set
# CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
# CONFIG_INLINE_SPIN_UNLOCK is not set
# CONFIG_INLINE_SPIN_UNLOCK_BH is not set
# CONFIG_INLINE_SPIN_UNLOCK_IRQ is not set
# CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_READ_TRYLOCK is not set
# CONFIG_INLINE_READ_LOCK is not set
# CONFIG_INLINE_READ_LOCK_BH is not set
# CONFIG_INLINE_READ_LOCK_IRQ is not set
# CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
# CONFIG_INLINE_READ_UNLOCK is not set
# CONFIG_INLINE_READ_UNLOCK_BH is not set
# CONFIG_INLINE_READ_UNLOCK_IRQ is not set
# CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_WRITE_TRYLOCK is not set
# CONFIG_INLINE_WRITE_LOCK is not set
# CONFIG_INLINE_WRITE_LOCK_BH is not set
# CONFIG_INLINE_WRITE_LOCK_IRQ is not set
# CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
# CONFIG_INLINE_WRITE_UNLOCK is not set
# CONFIG_INLINE_WRITE_UNLOCK_BH is not set
# CONFIG_INLINE_WRITE_UNLOCK_IRQ is not set
# CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
# CONFIG_MUTEX_SPIN_ON_OWNER is not set
CONFIG_FREEZER=y
# System Type
CONFIG_MMU=y
# CONFIG_ARCH_AAEC2000 is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_VERSATILE is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_CLPS711X is not set
# CONFIG_ARCH_GEMINI is not set
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_STMP3XXX is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_H720X is not set
# CONFIG_ARCH_NOMADIK is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP23XX is not set
# CONFIG_ARCH_IXP2000 is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_L7200 is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_KIRKWOOD is not set
# CONFIG_ARCH_LOKI is not set
# CONFIG_ARCH_MV78XX0 is not set
# CONFIG_ARCH_ORION5X is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_NS9XXX is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_PNX4008 is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_MSM is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C2410 is not set
# CONFIG_ARCH_S3C64XX is not set
# CONFIG_ARCH_S5PC1XX is not set
# CONFIG_ARCH_SHARK is not set
# CONFIG_ARCH_LH7A40X is not set
# CONFIG_ARCH_U300 is not set
# CONFIG_ARCH_DAVINCI is not set
CONFIG_ARCH_OMAP=y
# CONFIG_ARCH_BCMRING is not set
# CONFIG_ARCH_U8500 is not set
# TI OMAP Implementations
CONFIG_ARCH_OMAP_OTG=y
# CONFIG_ARCH_OMAP1 is not set
# CONFIG_ARCH_OMAP2 is not set
CONFIG_ARCH_OMAP3=y
# CONFIG_ARCH_OMAP4 is not set
# OMAP Feature Selections
CONFIG_OMAP_RESET_CLOCKS=y
CONFIG_OMAP_MUX=y
# CONFIG_OMAP_MUX_DEBUG is not set
CONFIG_OMAP_MUX_WARNINGS=y
CONFIG_OMAP_MCBSP=y
# CONFIG_OMAP_MBOX_FWK is not set
# CONFIG_OMAP_MPU_TIMER is not set
CONFIG_OMAP_32K_TIMER=y
# CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set
# CONFIG_OMAP3_DEBOBS is not set
CONFIG_OMAP_32K_TIMER_HZ=128
CONFIG_OMAP_DM_TIMER=y
# CONFIG_OMAP_LL_DEBUG_UART1 is not set
# CONFIG_OMAP_LL_DEBUG_UART2 is not set
CONFIG_OMAP_LL_DEBUG_UART3=y
# CONFIG_OMAP_LL_DEBUG_NONE is not set
# CONFIG_OMAP_PM_NONE is not set
CONFIG_OMAP_PM_NOOP=y
# CONFIG_OMAP_PM_SRF is not set
CONFIG_ARCH_OMAP34XX=y
CONFIG_ARCH_OMAP3430=y
CONFIG_OMAP_PACKAGE_CBB=y
# OMAP Board Type
# CONFIG_MACH_OMAP3_BEAGLE is not set
# CONFIG_MACH_OMAP_LDP is not set
# CONFIG_MACH_OVERO is not set
# CONFIG_MACH_OMAP3EVM is not set
CONFIG_MACH_OMAP3517EVM=y
CONFIG_PMIC_TPS65023=y
# CONFIG_MACH_OMAP3_PANDORA is not set
# CONFIG_MACH_OMAP3_TOUCHBOOK is not set
# CONFIG_MACH_OMAP_3430SDP is not set
# CONFIG_MACH_NOKIA_RX51 is not set
# CONFIG_MACH_OMAP_ZOOM2 is not set
# CONFIG_MACH_OMAP_ZOOM3 is not set
# CONFIG_MACH_CM_T35 is not set
# CONFIG_MACH_IGEP0020 is not set
# CONFIG_MACH_OMAP_3630SDP is not set
# CONFIG_OMAP3_EMU is not set
# CONFIG_OMAP3_SDRC_AC_TIMING is not set
# Processor Type
CONFIG_CPU_32=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_V7=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
CONFIG_ARM_THUMB=y
# CONFIG_ARM_THUMBEE is not set
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_HAS_TLS_REG=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_CPU_HAS_PMU=y
# CONFIG_ARM_ERRATA_430973 is not set
# CONFIG_ARM_ERRATA_458693 is not set
# CONFIG_ARM_ERRATA_460075 is not set
CONFIG_COMMON_CLKDEV=y
# Bus support
# CONFIG_PCI_SYSCALL is not set
# CONFIG_ARCH_SUPPORTS_MSI is not set
# CONFIG_PCCARD is not set
# Kernel Features
CONFIG_TICK_ONE_SHOT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
#CONFIG_HZ is not set
# CONFIG_THUMB2_KERNEL is not set
CONFIG_AEABI=y
CONFIG_OABI_COMPAT=y
CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
# CONFIG_HIGHMEM is not set
CONFIG_HW_PERF_EVENTS=y
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_DISCONTIGMEM_MANUAL is not set
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=4
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=0
CONFIG_VIRT_TO_BUS=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
# CONFIG_LEDS is not set
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
# Boot options
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_CMDLINE="root=/dev/nfs nfsroot=192.168.0.1:/home/user/buildroot ip=192.168.0.2:192.168.0.1:192.168.0.1:255.255.255.0:tgt:eth0:off rw console=ttyS2,115200n8"
# CONFIG_XIP_KERNEL is not set
# CONFIG_KEXEC is not set
# CPU Power Management
# CONFIG_CPU_FREQ is not set
# CONFIG_CPU_IDLE is not set
# Floating point emulation
# At least one emulation must be selected
CONFIG_FPE_NWFPE=y
# CONFIG_FPE_NWFPE_XP is not set
# CONFIG_FPE_FASTFPE is not set
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
# Userspace binary formats
CONFIG_BINFMT_ELF=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
CONFIG_HAVE_AOUT=y
# CONFIG_BINFMT_AOUT is not set
CONFIG_BINFMT_MISC=y
# Power management options
CONFIG_PM=y
CONFIG_PM_DEBUG=y
# CONFIG_PM_VERBOSE is not set
CONFIG_CAN_PM_TRACE=y
CONFIG_PM_SLEEP=y
CONFIG_SUSPEND=y
# CONFIG_PM_TEST_SUSPEND is not set
CONFIG_SUSPEND_FREEZER=y
# CONFIG_APM_EMULATION is not set
# CONFIG_PM_RUNTIME is not set
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_UNIX=y
CONFIG_XFRM=y
CONFIG_XFRM_USER=y
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
CONFIG_XFRM_IPCOMP=y
CONFIG_NET_KEY=y
# CONFIG_NET_KEY_MIGRATE is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
CONFIG_NET_IPIP=y
# CONFIG_NET_IPGRE is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=y
CONFIG_INET_XFRM_MODE_TRANSPORT=y
CONFIG_INET_XFRM_MODE_TUNNEL=y
CONFIG_INET_XFRM_MODE_BEET=y
# CONFIG_INET_LRO is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IPV6=y
# CONFIG_IPV6_PRIVACY is not set
# CONFIG_IPV6_ROUTER_PREF is not set
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
CONFIG_INET6_AH=y
CONFIG_INET6_ESP=y
CONFIG_INET6_IPCOMP=y
# CONFIG_IPV6_MIP6 is not set
CONFIG_INET6_XFRM_TUNNEL=y
CONFIG_INET6_TUNNEL=y
CONFIG_INET6_XFRM_MODE_TRANSPORT=y
CONFIG_INET6_XFRM_MODE_TUNNEL=y
CONFIG_INET6_XFRM_MODE_BEET=y
# CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
CONFIG_IPV6_SIT=y
# CONFIG_IPV6_SIT_6RD is not set
CONFIG_IPV6_NDISC_NODETYPE=y
CONFIG_IPV6_TUNNEL=y
CONFIG_IPV6_MULTIPLE_TABLES=y
# CONFIG_IPV6_SUBTREES is not set
# CONFIG_IPV6_MROUTE is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_BRIDGE is not set
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_NET_DROP_MONITOR is not set
# CONFIG_HAMRADIO is not set
CONFIG_CAN=y
CONFIG_CAN_RAW=y
CONFIG_CAN_BCM=y
# CAN Device Drivers
CONFIG_CAN_VCAN=y
CONFIG_CAN_DEV=y
CONFIG_CAN_CALC_BITTIMING=y
CONFIG_CAN_TI_HECC=y
# CONFIG_CAN_SJA1000 is not set
# CAN USB interfaces
# CONFIG_CAN_EMS_USB is not set
CONFIG_CAN_DEBUG_DEVICES=y
# CONFIG_IRDA is not set
CONFIG_BT=y
CONFIG_BT_L2CAP=y
# CONFIG_BT_SCO is not set
CONFIG_BT_RFCOMM=y
# CONFIG_BT_RFCOMM_TTY is not set
# CONFIG_BT_BNEP is not set
CONFIG_BT_HIDP=y
# Bluetooth device drivers
CONFIG_BT_HCIBTUSB=y
# CONFIG_BT_HCIBTSDIO is not set
# CONFIG_BT_HCIUART is not set
# CONFIG_BT_HCIBCM203X is not set
# CONFIG_BT_HCIBPA10X is not set
# CONFIG_BT_HCIBFUSB is not set
# CONFIG_BT_HCIVHCI is not set
# CONFIG_BT_MRVL is not set
# CONFIG_AF_RXRPC is not set
CONFIG_FIB_RULES=y
CONFIG_WIRELESS=y
# CONFIG_CFG80211 is not set
# CONFIG_LIB80211 is not set
# CFG80211 needs to be enabled for MAC80211
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
# CONFIG_DEVTMPFS is not set
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# CONFIG_FW_LOADER is not set
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_CONNECTOR is not set
CONFIG_MTD=y
# CONFIG_MTD_DEBUG is not set
# CONFIG_MTD_TESTS is not set
CONFIG_MTD_CONCAT=y
CONFIG_MTD_PARTITIONS=y
# CONFIG_MTD_REDBOOT_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_AR7_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_CHAR=y
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_MTD_OOPS is not set
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=y
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_GEN_PROBE=y
# CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
# CONFIG_MTD_CFI_INTELEXT is not set
# CONFIG_MTD_CFI_AMDSTD is not set
# CONFIG_MTD_CFI_STAA is not set
CONFIG_MTD_CFI_UTIL=y
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PHYSMAP is not set
# CONFIG_MTD_ARM_INTEGRATOR is not set
CONFIG_MTD_OMAP_NOR=y
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOC2000 is not set
# CONFIG_MTD_DOC2001 is not set
# CONFIG_MTD_DOC2001PLUS is not set
CONFIG_MTD_NAND=y
# CONFIG_MTD_NAND_VERIFY_WRITE is not set
# CONFIG_MTD_NAND_ECC_SMC is not set
# CONFIG_MTD_NAND_MUSEUM_IDS is not set
# CONFIG_MTD_NAND_GPIO is not set
CONFIG_MTD_NAND_OMAP2=y
CONFIG_MTD_NAND_OMAP_HWECC=y
CONFIG_MTD_NAND_OMAP_PREFETCH=y
CONFIG_MTD_NAND_OMAP_PREFETCH_DMA=y
CONFIG_MTD_NAND_IDS=y
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_NAND_NANDSIM is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# CONFIG_MTD_ALAUDA is not set
# CONFIG_MTD_ONENAND is not set
# LPDDR flash memory drivers
# CONFIG_MTD_LPDDR is not set
# UBI - Unsorted block images
# CONFIG_MTD_UBI is not set
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
# DRBD disabled because PROC_FS, INET or CONNECTOR not selected
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_UB is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=32768
# CONFIG_BLK_DEV_XIP is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_MG_DISK is not set
# CONFIG_MISC_DEVICES is not set
CONFIG_HAVE_IDE=y
# CONFIG_IDE is not set
# SCSI device support
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_TGT is not set
# CONFIG_SCSI_NETLINK is not set
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_MULTI_LUN is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
CONFIG_SCSI_WAIT_SCAN=m
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_LIBFC is not set
# CONFIG_LIBFCOE is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# CONFIG_SCSI_OSD_INITIATOR is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
CONFIG_NETDEVICES=y
# CONFIG_DUMMY is not set
# CONFIG_BONDING is not set
# CONFIG_MACVLAN is not set
# CONFIG_EQUALIZER is not set
CONFIG_TUN=m
# CONFIG_VETH is not set
CONFIG_PHYLIB=y
# MII PHY device drivers
# CONFIG_MARVELL_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_ICPLUS_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_FIXED_PHY is not set
# CONFIG_MDIO_BITBANG is not set
CONFIG_NET_ETHERNET=y
CONFIG_MII=y
# CONFIG_AX88796 is not set
# CONFIG_SMC91X is not set
CONFIG_TI_DAVINCI_EMAC=y
# CONFIG_DM9000 is not set
# CONFIG_ETHOC is not set
# CONFIG_SMC911X is not set
# CONFIG_SMSC911X is not set
# CONFIG_DNET is not set
# CONFIG_IBM_NEW_EMAC_ZMII is not set
# CONFIG_IBM_NEW_EMAC_RGMII is not set
# CONFIG_IBM_NEW_EMAC_TAH is not set
# CONFIG_IBM_NEW_EMAC_EMAC4 is not set
# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
# CONFIG_B44 is not set
# CONFIG_KS8842 is not set
# CONFIG_KS8851_MLL is not set
# CONFIG_NETDEV_1000 is not set
# CONFIG_NETDEV_10000 is not set
CONFIG_WLAN=y
# CONFIG_USB_ZD1201 is not set
# CONFIG_HOSTAP is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# USB Network Adapters
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
CONFIG_USB_USBNET=y
CONFIG_USB_NET_AX8817X=y
CONFIG_USB_NET_CDCETHER=y
# CONFIG_USB_NET_CDC_EEM is not set
# CONFIG_USB_NET_DM9601 is not set
# CONFIG_USB_NET_SMSC95XX is not set
# CONFIG_USB_NET_GL620A is not set
# CONFIG_USB_NET_NET1080 is not set
# CONFIG_USB_NET_PLUSB is not set
# CONFIG_USB_NET_MCS7830 is not set
# CONFIG_USB_NET_RNDIS_HOST is not set
# CONFIG_USB_NET_CDC_SUBSET is not set
# CONFIG_USB_NET_ZAURUS is not set
# CONFIG_USB_NET_INT51X1 is not set
# CONFIG_WAN is not set
CONFIG_PPP=y
# CONFIG_PPP_MULTILINK is not set
# CONFIG_PPP_FILTER is not set
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
CONFIG_PPP_DEFLATE=y
# CONFIG_PPP_BSDCOMP is not set
# CONFIG_PPP_MPPE is not set
CONFIG_PPPOE=m
# CONFIG_PPPOL2TP is not set
# CONFIG_SLIP is not set
CONFIG_SLHC=y
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_ISDN is not set
# CONFIG_PHONE is not set
# Input device support
CONFIG_INPUT=y
# CONFIG_INPUT_FF_MEMLESS is not set
# CONFIG_INPUT_POLLDEV is not set
# CONFIG_INPUT_SPARSEKMAP is not set
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
# CONFIG_INPUT_KEYBOARD is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
# CONFIG_INPUT_MISC is not set
# Hardware I/O ports
# CONFIG_SERIO is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
# CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_DEVKMEM=y
# CONFIG_SERIAL_NONSTANDARD is not set
# Serial drivers
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_NR_UARTS=32
CONFIG_SERIAL_8250_RUNTIME_UARTS=4
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_MANY_PORTS=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
CONFIG_SERIAL_8250_DETECT_IRQ=y
CONFIG_SERIAL_8250_RSA=y
# Non-8250 serial port support
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_UNIX98_PTYS=y
# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
# CONFIG_LEGACY_PTYS is not set
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOPCA=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_DESIGNWARE is not set
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_OCORES is not set
CONFIG_I2C_OMAP=y
# CONFIG_I2C_SIMTEC is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
CONFIG_I2C_PCA_PLATFORM=y
# CONFIG_I2C_STUB is not set
# Miscellaneous I2C Chip support
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# CONFIG_I2C_DEBUG_CHIP is not set
# CONFIG_SPI is not set
# PPS support
# CONFIG_PPS is not set
CONFIG_ARCH_REQUIRE_GPIOLIB=y
CONFIG_GPIOLIB=y
# CONFIG_DEBUG_GPIO is not set
# CONFIG_GPIO_SYSFS is not set
# Memory mapped GPIO expanders:
# I2C GPIO expanders:
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# PCI GPIO expanders:
# SPI GPIO expanders:
# AC97 GPIO expanders:
CONFIG_DIO_MOTO=y
# CONFIG_W1 is not set
# CONFIG_POWER_SUPPLY is not set
# CONFIG_HWMON is not set
# CONFIG_THERMAL is not set
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_NOWAYOUT=y
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
CONFIG_OMAP_WATCHDOG=y
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
# Multifunction device drivers
# CONFIG_MFD_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_HTC_EGPIO is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_TPS65010 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_AB3100_CORE is not set
# CONFIG_MFD_88PM8607 is not set
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
# CONFIG_REGULATOR_FIXED_VOLTAGE is not set
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_BQ24022 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_LP3971 is not set
CONFIG_REGULATOR_TPS65023=y
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_MEDIA_SUPPORT is not set
# Graphics support
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
# CONFIG_FB is not set
# CONFIG_OMAP2_DSS is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# Console display driver support
# CONFIG_VGA_CONSOLE is not set
CONFIG_DUMMY_CONSOLE=y
# CONFIG_SOUND is not set
CONFIG_HID_SUPPORT=y
CONFIG_HID=y
# CONFIG_HIDRAW is not set
# USB Input Devices
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
# CONFIG_USB_HIDDEV is not set
# Special HID drivers
# CONFIG_HID_A4TECH is not set
# CONFIG_HID_APPLE is not set
# CONFIG_HID_BELKIN is not set
# CONFIG_HID_CHERRY is not set
# CONFIG_HID_CHICONY is not set
# CONFIG_HID_CYPRESS is not set
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EZKEY is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_TWINHAN is not set
# CONFIG_HID_KENSINGTON is not set
# CONFIG_HID_LOGITECH is not set
# CONFIG_HID_MICROSOFT is not set
# CONFIG_HID_MONTEREY is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_ZEROPLUS is not set
CONFIG_USB_SUPPORT=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
# CONFIG_USB_DEVICEFS is not set
# CONFIG_USB_DEVICE_CLASS is not set
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_SUSPEND is not set
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_MON is not set
# CONFIG_USB_WUSB is not set
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1760_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
# CONFIG_USB_OHCI_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HWA_HCD is not set
CONFIG_USB_MUSB_HDRC=y
CONFIG_USB_MUSB_SOC=y
# OMAP 343x high speed USB support
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_PERIPHERAL is not set
CONFIG_USB_MUSB_OTG=y
CONFIG_USB_GADGET_MUSB_HDRC=y
CONFIG_USB_MUSB_HDRC_HCD=y
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_TI_CPPI_DMA is not set
CONFIG_USB_TI_CPPI41_DMA=y
CONFIG_USB_MUSB_DEBUG=y
# USB Device Class drivers
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_ONETOUCH is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
# CONFIG_USB_LIBUSUAL is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# USB port drivers
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_BERRY_CHARGE is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
CONFIG_USB_TEST=y
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_VST is not set
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_SELECTED=y
# CONFIG_USB_GADGET_AT91 is not set
# CONFIG_USB_GADGET_ATMEL_USBA is not set
# CONFIG_USB_GADGET_FSL_USB2 is not set
# CONFIG_USB_GADGET_LH7A40X is not set
# CONFIG_USB_GADGET_OMAP is not set
# CONFIG_USB_GADGET_PXA25X is not set
# CONFIG_USB_GADGET_R8A66597 is not set
# CONFIG_USB_GADGET_PXA27X is not set
# CONFIG_USB_GADGET_S3C_HSOTG is not set
# CONFIG_USB_GADGET_IMX is not set
# CONFIG_USB_GADGET_S3C2410 is not set
# CONFIG_USB_GADGET_M66592 is not set
# CONFIG_USB_GADGET_AMD5536UDC is not set
# CONFIG_USB_GADGET_FSL_QE is not set
# CONFIG_USB_GADGET_CI13XXX is not set
# CONFIG_USB_GADGET_NET2280 is not set
# CONFIG_USB_GADGET_GOKU is not set
# CONFIG_USB_GADGET_LANGWELL is not set
# CONFIG_USB_GADGET_DUMMY_HCD is not set
CONFIG_USB_GADGET_DUALSPEED=y
# CONFIG_USB_ZERO is not set
# CONFIG_USB_AUDIO is not set
CONFIG_USB_ETH=y
CONFIG_USB_ETH_RNDIS=y
# CONFIG_USB_ETH_EEM is not set
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FILE_STORAGE is not set
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_G_SERIAL is not set
# CONFIG_USB_MIDI_GADGET is not set
# CONFIG_USB_G_PRINTER is not set
# CONFIG_USB_CDC_COMPOSITE is not set
# CONFIG_USB_G_MULTI is not set
# OTG and related infrastructure
CONFIG_USB_OTG_UTILS=y
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_ISP1301_OMAP is not set
# CONFIG_USB_ULPI is not set
CONFIG_NOP_USB_XCEIV=y
CONFIG_MMC=y
# CONFIG_MMC_DEBUG is not set
CONFIG_MMC_UNSAFE_RESUME=y
# MMC/SD/SDIO Card Drivers
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_BOUNCE=y
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_SDHCI is not set
CONFIG_MMC_OMAP=y
CONFIG_MMC_OMAP_HS=y
# CONFIG_MMC_AT91 is not set
# CONFIG_MMC_ATMELMCI is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# LED drivers
# CONFIG_LEDS_PCA9532 is not set
# CONFIG_LEDS_GPIO is not set
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_BD2802 is not set
# LED Triggers
# CONFIG_LEDS_TRIGGERS is not set
# CONFIG_ACCESSIBILITY is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_DS1307 is not set
CONFIG_RTC_DRV_DS1339=y
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# SPI RTC drivers
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# on-CPU RTC drivers
# CONFIG_DMADEVICES is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# TI VLYNQ
# CONFIG_STAGING is not set
# CBUS support
# CONFIG_CBUS is not set
# File systems
CONFIG_FS_JOURNAL_INFO=y
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR=y
# CONFIG_EXT2_FS_POSIX_ACL is not set
# CONFIG_EXT2_FS_SECURITY is not set
# CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
# CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set
CONFIG_EXT3_FS_XATTR=y
# CONFIG_EXT3_FS_POSIX_ACL is not set
# CONFIG_EXT3_FS_SECURITY is not set
# CONFIG_EXT4_FS is not set
CONFIG_JBD=y
# CONFIG_JBD_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_FS_POSIX_ACL is not set
CONFIG_XFS_FS=y
CONFIG_XFS_QUOTA=y
# CONFIG_XFS_POSIX_ACL is not set
# CONFIG_XFS_RT is not set
# CONFIG_XFS_DEBUG is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
CONFIG_FILE_LOCKING=y
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_QUOTA=y
# CONFIG_QUOTA_NETLINK_INTERFACE is not set
CONFIG_PRINT_QUOTA_WARNING=y
CONFIG_QUOTA_TREE=y
# CONFIG_QFMT_V1 is not set
CONFIG_QFMT_V2=y
CONFIG_QUOTACTL=y
# CONFIG_AUTOFS_FS is not set
CONFIG_AUTOFS4_FS=y
# CONFIG_FUSE_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_STATIC_FILES=y
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_HUGETLB_PAGE is not set
# CONFIG_CONFIGFS_FS is not set
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
CONFIG_UNION_FS=y
# CONFIG_UNION_FS_XATTR is not set
# CONFIG_UNION_FS_DEBUG is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_YAFFS_FS=y
CONFIG_YAFFS_YAFFS1=y
# CONFIG_YAFFS_9BYTE_TAGS is not set
# CONFIG_YAFFS_DOES_ECC is not set
CONFIG_YAFFS_YAFFS2=y
CONFIG_YAFFS_AUTO_YAFFS2=y
# CONFIG_YAFFS_DISABLE_TAGS_ECC is not set
# CONFIG_YAFFS_DISABLE_LAZY_LOAD is not set
# CONFIG_YAFFS_DISABLE_WIDE_TNODES is not set
# CONFIG_YAFFS_ALWAYS_CHECK_CHUNK_ERASED is not set
CONFIG_YAFFS_SHORT_NAMES_IN_RAM=y
# CONFIG_YAFFS_EMPTY_LOST_AND_FOUND is not set
CONFIG_JFFS2_FS=y
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
CONFIG_JFFS2_SUMMARY=y
# CONFIG_JFFS2_FS_XATTR is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
# CONFIG_JFFS2_LZO is not set
CONFIG_JFFS2_RTIME=y
# CONFIG_JFFS2_RUBIN is not set
CONFIG_CRAMFS=y
CONFIG_SQUASHFS=y
# CONFIG_SQUASHFS_EMBEDDED is not set
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
# CONFIG_NFS_V3_ACL is not set
CONFIG_NFS_V4=y
# CONFIG_NFS_V4_1 is not set
CONFIG_ROOT_NFS=y
CONFIG_NFSD=m
CONFIG_NFSD_V3=y
# CONFIG_NFSD_V3_ACL is not set
# CONFIG_NFSD_V4 is not set
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_EXPORTFS=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
CONFIG_RPCSEC_GSS_KRB5=y
# CONFIG_RPCSEC_GSS_SPKM3 is not set
# CONFIG_SMB_FS is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
# CONFIG_EFI_PARTITION is not set
# CONFIG_SYSV68_PARTITION is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
CONFIG_NLS_ASCII=m
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=m
# CONFIG_DLM is not set
# Kernel hacking
# CONFIG_PRINTK_TIME is not set
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
CONFIG_MAGIC_SYSRQ=y
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_UNUSED_SYMBOLS is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_CHECK is not set
CONFIG_DEBUG_KERNEL=y
# CONFIG_DEBUG_SHIRQ is not set
CONFIG_DETECT_SOFTLOCKUP=y
# CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC is not set
CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC_VALUE=0
CONFIG_DETECT_HUNG_TASK=y
# CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0
CONFIG_SCHED_DEBUG=y
CONFIG_SCHEDSTATS=y
CONFIG_TIMER_STATS=y
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_DEBUG_SLAB is not set
# CONFIG_DEBUG_KMEMLEAK is not set
CONFIG_DEBUG_PREEMPT=y
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_RT_MUTEX_TESTER is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_PSRWLOCK is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
CONFIG_TRACE_IRQFLAGS=y
# CONFIG_DEBUG_SPINLOCK_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
CONFIG_STACKTRACE=y
# CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
CONFIG_DEBUG_INFO=y
# CONFIG_DEBUG_VM is not set
# CONFIG_DEBUG_WRITECOUNT is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_RCU_HEAD is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
CONFIG_FRAME_POINTER=y
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_RCU_CPU_STALL_DETECTOR is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_HAVE_PSRWLOCK_ASM_CALL is not set
CONFIG_LATENCYTOP=y
# CONFIG_SYSCTL_SYSCALL_CHECK is not set
# CONFIG_PAGE_POISONING is not set
CONFIG_NOP_TRACER=y
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_TRACER_MAX_TRACE=y
CONFIG_RING_BUFFER=y
CONFIG_EVENT_TRACING=y
CONFIG_CONTEXT_SWITCH_TRACER=y
CONFIG_RING_BUFFER_ALLOW_SWAP=y
CONFIG_TRACING=y
CONFIG_GENERIC_TRACER=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
CONFIG_FUNCTION_TRACER=y
CONFIG_IRQSOFF_TRACER=y
CONFIG_PREEMPT_TRACER=y
CONFIG_SCHED_TRACER=y
# CONFIG_BOOT_TRACER is not set
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_PROFILE_ALL_BRANCHES is not set
CONFIG_STACK_TRACER=y
# CONFIG_KMEMTRACE is not set
CONFIG_WORKQUEUE_TRACER=y
# CONFIG_BLK_DEV_IO_TRACE is not set
CONFIG_FUNCTION_PROFILER=y
# CONFIG_FTRACE_STARTUP_TEST is not set
# CONFIG_RING_BUFFER_BENCHMARK is not set
# CONFIG_DYNAMIC_DEBUG is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
CONFIG_ARM_UNWIND=y
CONFIG_DEBUG_USER=y
CONFIG_DEBUG_ERRORS=y
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_LL is not set
# CONFIG_OC_ETM is not set
# CONFIG_DEBUG_TRACE_CLOCK is not set
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
# CONFIG_DEFAULT_SECURITY_SELINUX is not set
# CONFIG_DEFAULT_SECURITY_SMACK is not set
# CONFIG_DEFAULT_SECURITY_TOMOYO is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_PCOMP=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_GF128MUL is not set
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_WORKQUEUE=y
# CONFIG_CRYPTO_CRYPTD is not set
CONFIG_CRYPTO_AUTHENC=y
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_SEQIV is not set
# Block modes
CONFIG_CRYPTO_CBC=y
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=m
# CONFIG_CRYPTO_LRW is not set
CONFIG_CRYPTO_PCBC=m
# CONFIG_CRYPTO_XTS is not set
# Hash modes
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_GHASH is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
# CONFIG_CRYPTO_SHA256 is not set
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_ANUBIS is not set
# CONFIG_CRYPTO_ARC4 is not set
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=y
# CONFIG_CRYPTO_ZLIB is not set
# CONFIG_CRYPTO_LZO is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_HW=y
CONFIG_BINARY_PRINTF=y
# Library routines
CONFIG_BITREVERSE=y
CONFIG_GENERIC_FIND_LAST_BIT=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC7 is not set
CONFIG_LIBCRC32C=y
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_DECOMPRESS_GZIP=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
CONFIG_NLATTR=y
CONFIG_GENERIC_ATOMIC64=y
