I am using OMAP4 BSP. we are seeing that it takes around 2.5 to 3 minutes for reading NK.bin from SD Card to RAM.
I have increased the SD Clock rate to 25 and 50MHz, but we are still seeing the same results.
What else am I missing.
GSR
GSR
GSR,
I believe you are getting almost 500KB/sec throughput from MMC driver in EBOOT. This can be improved pretty much to more than 5MB/sec (depending on the card) and can go upto 20MB/sec(depends)
For getting this kind of throughput some optimization in the MMC driver has to performed. One simple thing you can try is to implement Multi-block read instead of single-block read.
I was looking at the code and observed that the FileIo is implemented to read single sector at a time.
I am trying to understand the FileIoReadNextSector API which will read the kernel image from the SD Card.
It calculates Cluster, Sector no and etc...But at the end why can't EBOOT read straight away multiple sectors at a time?
On sd card is the data will not be available in consecutive sectors?
GSR
GSR,
1258021 said:It calculates Cluster, Sector no and etc...But at the end why can't EBOOT read straight away multiple sectors at a time?
I can't answer this question. But you can certainly implement multi-sector read to fix this issue.
