Hi Ti Folks,
Well to test this LTE20MHz 8xlink cpri test code.
/****************************************************************************\ * Copyright (C) 2009 Texas Instruments Incorporated. * * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ #include <stdio.h> #include <stdlib.h> #include <string.h> #include <c6x.h> #include <ti/csl/src/intc/csl_intc.h> #include <sfp\BSLC667X_sfp.h> #include <ti\csl\csl_pscAux.h> #include <control/BSLC667X_control.h> #include <dsp\uart\BSLC667X_uart.h> #include "..\src\Aif2_config.h" #define __VERSION__ "Ver 0.10" /* Define queues for common FDQs */ #define MONO_TX_COMPLETE_Q 2000 #define MONO_RX_FDQ 2001 /* These are for the AIF test */ #define MONO_RX_Q 900 #define MONO_TX_Q 512 //Users should use 16 bytes aligned data for Aif2 and PktDMA test #pragma DATA_SECTION(mono_region,".extData_sect")//use MSMC memory for test mode #pragma DATA_ALIGN (mono_region, 16) Uint8 mono_region[32 * 8848];//payload size is 8.8K bytes for Normal cyclic prefix 20 MHz LTE Uint32 tmp[14]; /* Intc variable declarartion */ CSL_IntcObj intcObj; CSL_IntcHandle hIntc; CSL_IntcEventHandlerRecord EventHandler[8]; CSL_IntcGlobalEnableState state; /* Global structures and variables */ CSL_Aif2Obj Aif2Obj;// Aif2 CSL object CSL_Aif2Handle hAif2;// Aif2 handle Bool ctrlArg; // Ctrl Argument; CSL_Aif2Context Aif2Context;//Aif2 context CSL_Aif2Param aif2Param;//AIF2 module specific parameters CSL_Status status; // CSL status CSL_Aif2Setup aif2Setup;//Aif2 HW setup CSL_Aif2LinkSetup linkSetup;// Setup for links CSL_Aif2GlobalSetup globalSetup;// global config for AIF2 CSL_Aif2CommonSetup commonSetup; // Setup for common params CSL_Aif2SdCommonSetup SdCommonSetup;//SERDES common setup CSL_Aif2PdCommonSetup PdCommonSetup;//PD common setup CSL_Aif2PeCommonSetup PeCommonSetup;//PE common setup CSL_Aif2IngrDbSetup IngrDbSetup;// Ingress data buffer setup CSL_Aif2EgrDbSetup EgrDbSetup;// Egress data buffer setup CSL_Aif2AdCommonSetup AdCommonSetup;// Aif2 DMA common setup CSL_Aif2AtCommonSetup AtCommonSetup; // Aif2 Timer common setup CSL_Aif2AtEventSetup AtEventSetup; // Aif2 Timer external and internal event setup CSL_Aif2AtCountObj PhyTimerTc;// AT Phy Terminal Count setup CSL_Aif2AtCountObj RadTimerTc;// AT Rad Terminal Count setup CSL_Aif2AtCountObj PhyTimerInit;// AT Phy Init value setup CSL_Aif2AtCountObj RadTimerInit;// AT Rad Init value setup CSL_Aif2CommonLinkSetup ComLinkSetup; // Aif2 link common setup CSL_Aif2SdLinkSetup SdLinkSetup; //SERDES link setup CSL_Aif2RmLinkSetup RmLinkSetup; //RM link setup CSL_Aif2TmLinkSetup TmLinkSetup; //TM link setup CSL_Aif2PdLinkSetup PdLinkSetup; //PD link setup CSL_Aif2PeLinkSetup PeLinkSetup; //PE link setup CSL_Aif2RtLinkSetup RtLinkSetup; //RT link setup CSL_Aif2AtLinkSetup AtLinkSetup; // Aif2 timer link setup (Pi, Delta, PE signal) volatile unsigned int int4_result; interrupt void int4_isr() { int i; if (int4_result == 0) { for (i=0; i<14; i++) push_queue(MONO_TX_Q, 1, 0, tmp[i]); } int4_result++; } char Uart_IsKey(void); char Uart_GetKey(void); int Uart_GetString(char *string); int Uart_Printf (const char *fmt, ...); char decCmd (char *s, int *addr, unsigned int *data, int *NumData); void logo (void); void Intc_config(void) { CSL_IntcParam vectId; CSL_IntcContext context; //!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!// //! GEM0 Intc Configuration !// //!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!// /* Setup the global Interrupt */ context.numEvtEntries = 8; context.eventhandlerRecord = EventHandler; CSL_intcInit(&context); /* Enable NMIs */ CSL_intcGlobalNmiEnable(); /* Enable Global Interrupts */ CSL_intcGlobalEnable(&state); /* VectorID for the Global Edma Event */ vectId = CSL_INTC_VECTID_4; /* Opening a handle for the Fsync->EDMA Interrupt Event */ hIntc = CSL_intcOpen(&intcObj, AIF2_EVENT2_INTSEL_MAP, // Event2 &vectId, NULL); //Hook the ISRs CSL_intcHookIsr(vectId, &int4_isr); // Clear the Interrupt CSL_intcHwControl(hIntc, CSL_INTC_CMD_EVTCLEAR, NULL); //Enable the Event & the interrupt CSL_intcHwControl(hIntc, CSL_INTC_CMD_EVTENABLE, NULL); } void MNavigator_config(void) { Uint32 flow_a; Uint32 flow_d; Uint16 idx; MNAV_MonolithicPacketDescriptor *mono_pkt; /* Setup Memory Region 0 for 32 8848B Monolithic descriptors. Our * Mono descriptors will be 12 bytes plus 4 bytes protocol specific field, plus * 8832(8768) bytes of payload(symbol). so the total size is 8848 and it is dividable by 16 * 32 descriptors. (dead space is possible) */ set_memory_region(0, (Uint32) mono_region, 0, 0x02280000); /***************************************************************** * Configure Linking RAM 0 for the descriptor regions. */ set_link_ram(0, QM_LRAM_REGION, 0x3fff); //internal link ram /* Initialize descriptor regions to zero */ memset(mono_region, 0, 64 * 8848); /* Push 7 Monolithic packets into Tx Completion Queue */ for (idx = 0; idx < 14; idx ++) { mono_pkt = (MNAV_MonolithicPacketDescriptor *)(mono_region + (idx * 8848)); mono_pkt->type_id = MNAV_DESC_TYPE_MONO; mono_pkt->data_offset = 16; mono_pkt->pkt_return_qmgr = 0; mono_pkt->pkt_return_qnum = MONO_TX_COMPLETE_Q; push_queue(MONO_TX_COMPLETE_Q, 1, 0, (Uint32)(mono_pkt)); } /* Push 7 Monolithic packets to Rx FDQ */ for (idx = 16; idx < 16+14; idx ++) { mono_pkt = (MNAV_MonolithicPacketDescriptor *)(mono_region + (idx * 8848)); mono_pkt->type_id = MNAV_DESC_TYPE_MONO; mono_pkt->data_offset = 16; push_queue(MONO_RX_FDQ, 1, 0, (Uint32)(mono_pkt)); } /***************************************************************** * Configure Rx channel flows */ /* Note that when LOOPBACK_MODE is enabled, the PKTDMA will force * force the flow ID value in the Tx Streaming I/F to be equal to * the channel number. (normally, the Tx flow ID is set to 0xff). * This is a simulator special testing feature. */ //Create flow configuration 0 for the Monolithic packets flow_a = 0x28100000 | MONO_RX_Q; flow_d = MONO_RX_FDQ << 16; config_rx_flow(AIF_PKTDMA_RX_FLOW_REGION, 0, flow_a, 0, 0, flow_d, 0, 0, 0, 0); /***************************************************************** * Enable Tx and Rx channels. */ enable_disable_loopback(0);//disable PKTDMA loopback for normal data transfer config_tx_chan(AIF_PKTDMA_TX_CHAN_REGION, 0, 0x01000000); //set AIF_MONO_MODE to 1 and set PS filter to zero enable_tx_chan(AIF_PKTDMA_TX_CHAN_REGION, 0, 0x80000000); enable_rx_chan(AIF_PKTDMA_RX_CHAN_REGION, 0, 0x80000000); } void Aif2_MNAV_Cpri_config(CSL_Aif2LinkIndex link) { int i; /************ Initialize Aif2 structures to avoid unwanted configuration ************************************************/ memset(&globalSetup, 0, sizeof(globalSetup)); memset(&linkSetup, 0, sizeof(linkSetup)); memset(&commonSetup, 0, sizeof(commonSetup)); memset(&SdCommonSetup, 0, sizeof(SdCommonSetup)); memset(&PdCommonSetup, 0, sizeof(PdCommonSetup)); memset(&PeCommonSetup, 0, sizeof(PeCommonSetup)); memset(&IngrDbSetup, 0, sizeof(IngrDbSetup)); memset(&EgrDbSetup, 0, sizeof(EgrDbSetup)); memset(&AdCommonSetup, 0, sizeof(AdCommonSetup)); memset(&AtCommonSetup, 0, sizeof(AtCommonSetup)); memset(&AtEventSetup, 0, sizeof(AtEventSetup)); memset(&PhyTimerInit, 0, sizeof(PhyTimerInit)); memset(&RadTimerInit, 0, sizeof(RadTimerInit)); memset(&PhyTimerTc, 0, sizeof(PhyTimerTc)); memset(&RadTimerTc, 0, sizeof(RadTimerTc)); memset(&ComLinkSetup, 0, sizeof(ComLinkSetup)); memset(&SdLinkSetup, 0, sizeof(SdLinkSetup)); memset(&RmLinkSetup, 0, sizeof(RmLinkSetup)); memset(&TmLinkSetup, 0, sizeof(TmLinkSetup)); memset(&PdLinkSetup, 0, sizeof(PdLinkSetup)); memset(&PeLinkSetup, 0, sizeof(PeLinkSetup)); memset(&RtLinkSetup, 0, sizeof(RtLinkSetup)); memset(&AtLinkSetup, 0, sizeof(AtLinkSetup)); // Initialize CSL library, this step is required CSL_aif2Init(&Aif2Context); // Open Aif2 and get handle hAif2 = CSL_aif2Open(&Aif2Obj, CSL_AIF, &aif2Param, &status); if ((hAif2 == NULL) || (status != CSL_SOK)) { printf ("\nError opening CSL_AIF2"); exit(1); } /************** populating AIF2 major setup structures ***************************************************/ aif2Setup.globalSetup = &globalSetup; aif2Setup.commonSetup = &commonSetup; aif2Setup.linkSetup[link] = &linkSetup;//assign only one link setup for link // populate global config fields globalSetup.ActiveLink[link] = TRUE;//Activate link for this test globalSetup.frameMode = CSL_AIF2_FRAME_MODE_NORMAL; //populate common config fields commonSetup.pSdCommonSetup = &SdCommonSetup; commonSetup.pPdCommonSetup = &PdCommonSetup; commonSetup.pPeCommonSetup = &PeCommonSetup; commonSetup.pIngrDbSetup = &IngrDbSetup; commonSetup.pEgrDbSetup = &EgrDbSetup; commonSetup.pAdCommonSetup = &AdCommonSetup; commonSetup.pAtCommonSetup = &AtCommonSetup; commonSetup.pAtEventSetup = &AtEventSetup; /****Link Setup (Do this setup repeatedly with different link setup structure if user wants to use multiple links) ***/ //populate link config fields for link linkSetup.linkIndex = link; linkSetup.pComLinkSetup = &ComLinkSetup; linkSetup.pSdLinkSetup = &SdLinkSetup; linkSetup.pRmLinkSetup = &RmLinkSetup; linkSetup.pTmLinkSetup = &TmLinkSetup; linkSetup.pPdLinkSetup = &PdLinkSetup; linkSetup.pPeLinkSetup = &PeLinkSetup; linkSetup.pRtLinkSetup = &RtLinkSetup; linkSetup.pAtLinkSetup = &AtLinkSetup; //Link Common setup ComLinkSetup.linkProtocol = CSL_AIF2_LINK_PROTOCOL_CPRI; ComLinkSetup.linkRate = CSL_AIF2_LINK_RATE_8x; ComLinkSetup.IngrDataWidth = CSL_AIF2_DATA_WIDTH_15_BIT; ComLinkSetup.EgrDataWidth = CSL_AIF2_DATA_WIDTH_15_BIT; //SD link setup SdLinkSetup.rxAlign = CSL_AIF2_SD_RX_COMMA_ALIGNMENT_ENABLE; SdLinkSetup.rxLos = CSL_AIF2_SD_RX_LOS_ENABLE; SdLinkSetup.rxCdrAlgorithm = CSL_AIF2_SD_RX_CDR_FIRST_ORDER_THRESH_17; SdLinkSetup.rxInvertPolarity = CSL_AIF2_SD_RX_NORMAL_POLARITY; SdLinkSetup.rxTermination = CSL_AIF2_SD_RX_TERM_COMMON_POINT_0_7 ;//for AC coupled application SdLinkSetup.rxEqualizerConfig = CSL_AIF2_SD_RX_EQ_ADAPTIVE;//Equalizer On SdLinkSetup.bRxEqHold = FALSE;//fixed value SdLinkSetup.bRxOffsetComp = TRUE;//fixed value SdLinkSetup.bEnableTxSyncMater = TRUE; //fixed value SdLinkSetup.txInvertPolarity = CSL_AIF2_SD_TX_PAIR_NORMAL_POLARITY; SdLinkSetup.txOutputSwing = CSL_AIF2_SD_TX_OUTPUT_SWING_14; SdLinkSetup.txPrecursorTapWeight = CSL_AIF2_SD_TX_PRE_TAP_WEIGHT_2;// -5% SdLinkSetup.txPostcursorTapWeight = CSL_AIF2_SD_TX_POST_TAP_WEIGHT_24;// -20% SdLinkSetup.bTxFirFilterUpdate = TRUE;//FIR filter update on //TM link setup TmLinkSetup.bEnableTmLink = TRUE; TmLinkSetup.bEnableRmLos = FALSE; TmLinkSetup.SeedValue = 0x1; TmLinkSetup.bEnableScrambler = FALSE; TmLinkSetup.pCpriTmSetup.L1InbandEn = 0;//disable 9 bits mask TmLinkSetup.pCpriTmSetup.RmLinkLosError = link;//select link as source RM link TmLinkSetup.pCpriTmSetup.RmLinkLofError = link;//select link as source RM link TmLinkSetup.pCpriTmSetup.RmLinkLosRx = link;//select link as source RM link TmLinkSetup.pCpriTmSetup.RmLinkLofRx = link;//select link as source RM link TmLinkSetup.pCpriTmSetup.RmLinkRaiRx = link;//select link as source RM link TmLinkSetup.pCpriTmSetup.TxStartup = 0; TmLinkSetup.pCpriTmSetup.TxPointerP = 20; TmLinkSetup.pCpriTmSetup.TxProtocolVer = 1; //RM link setup RmLinkSetup.bEnableRmLink = TRUE; RmLinkSetup.RmFifoThold = CSL_AIF2_RM_FIFO_THOLD_IMMEDIATELY; RmLinkSetup.RmErrorSuppress = CSL_AIF2_RM_ERROR_ALLOW; RmLinkSetup.bEnableSdAutoAlign = FALSE; RmLinkSetup.bEnableScrambler = FALSE; RmLinkSetup.bEnableLcvUnsync = FALSE; RmLinkSetup.bEnableLcvControl = FALSE; RmLinkSetup.bEnableWatchDog = FALSE; RmLinkSetup.WatchDogWrap = 0xFF;//set watch dog wrap value RmLinkSetup.bEnableClockQuality = FALSE; RmLinkSetup.ClockMonitorWrap = 0;//disabled RmLinkSetup.losDetThreshold = RM_LOS_DET_THOLD; RmLinkSetup.SyncThreshold = RM_SYNC_THOLD; RmLinkSetup.FrameSyncThreshold = RM_SYNC_THOLD; RmLinkSetup.UnsyncThreshold = RM_UNSYNC_THOLD; RmLinkSetup.FrameUnsyncThreshold = RM_UNSYNC_THOLD; //RT link setup RtLinkSetup.CiSelect = link; RtLinkSetup.bEnableEmptyMsg = TRUE; RtLinkSetup.RtConfig = CSL_AIF2_RT_MODE_TRANSMIT;// takes PE input only //PD link setup PdLinkSetup.bEnablePdLink = TRUE; PdLinkSetup.CpriEnetStrip = 0;//disable ethernet strip for control channel PdLinkSetup.Crc8Poly = CRC8_POLY; PdLinkSetup.Crc8Seed = CRC8_SEED; PdLinkSetup.CpriCwNullDelimitor = 0xFB;//K 27.7 charactor PdLinkSetup.CpriCwPktDelimitor[0] = CSL_AIF2_CW_DELIM_NULLDELM;//4 PdLinkSetup.PdCpriCrcType[0] = CSL_AIF2_CRC_16BIT; PdLinkSetup.bEnableCpriCrc[0] = TRUE;//enable CPRI CRC for control channel 0 PdLinkSetup.PdPackDmaCh[0] = 124;//Set DB channel 124 as a dma ch for control channel 0 PdLinkSetup.bEnablePack[0] = TRUE;//enable CPRI control channel 0 packing PdLinkSetup.PdCpriDualBitMap.DbmX = 1;// set X-1 PdLinkSetup.PdCpriDualBitMap.DbmXBubble = 1;//2 bubbles of 1 AxC sample PdLinkSetup.PdCpriDualBitMap.Dbm1Mult = 0;//set n-1 PdLinkSetup.PdCpriDualBitMap.Dbm1Size = 0;//set n-1 PdLinkSetup.PdCpriDualBitMap.Dbm1Map[0] = 0x0; PdLinkSetup.PdCpriDualBitMap.Dbm2Size = 0; PdLinkSetup.PdCpriDualBitMap.Dbm2Map[0] = 0x0; PdLinkSetup.CpriDmaCh[0]= 0; //match DbmX channel 0 to DB channel 0 PdLinkSetup.bEnableCpriX[0]= TRUE; //enable CPRI X channel 0 PdLinkSetup.bEnableCpriPkt[0]= FALSE;//use AxC data for X channel 0 PdLinkSetup.Cpri8WordOffset[0]= 0;//Word level CPRI data offset for X channel 0 for(i=0;i<256;i++)//cpri cw lut setup { PdLinkSetup.CpriCwChannel[i]= 0; //set cw channel num to pack 0 PdLinkSetup.bEnableCpriCw[i]= TRUE; //enable CPRI CW sub channel } //PE link setup PeLinkSetup.bEnablePeLink = TRUE; PeLinkSetup.PeCppiDioSel = CSL_AIF2_CPPI; PeLinkSetup.TddAxc = FALSE; PeLinkSetup.PeDelay = DB_PE_DELAY_CPRI;//0 sys_clks delay between DB and PE PeLinkSetup.Crc8Poly = CRC8_POLY; PeLinkSetup.Crc8Seed = CRC8_SEED; PeLinkSetup.PeCpriDualBitMap.DbmX = 1;//set X-1 PeLinkSetup.PeCpriDualBitMap.DbmXBubble = 1;//2 bubbles of 1 AxC sample PeLinkSetup.PeCpriDualBitMap.Dbm1Mult = 0;//set n-1 PeLinkSetup.PeCpriDualBitMap.Dbm1Size = 0;//set n-1 PeLinkSetup.PeCpriDualBitMap.Dbm1Map[0] = 0x0; PeLinkSetup.PeCpriDualBitMap.Dbm2Size = 0; PeLinkSetup.PeCpriDualBitMap.Dbm2Map[0] = 0x0; PeLinkSetup.CpriAxCPack = CSL_AIF2_CPRI_15BIT_SAMPLE; PeLinkSetup.CpriCwNullDelimitor = 0xFB;//K 27.7 character PeLinkSetup.CpriCwPktDelimitor[0] = CSL_AIF2_CW_DELIM_NULLDELM; PeLinkSetup.PePackDmaCh[0] = 124; PeLinkSetup.bEnablePack[0] = TRUE; for(i=0;i<256;i++)//cpri cw lut setup { PeLinkSetup.CpriCwChannel[i]= 0; //set cw channel num to pack 0 PeLinkSetup.bEnableCpriCw[i]= TRUE; //enable CPRI CW sub channel } //AT link setup AtLinkSetup.PE1Offset = 300; AtLinkSetup.PE2Offset = 310; AtLinkSetup.DeltaOffset = 380; AtLinkSetup.PiMin = 380; AtLinkSetup.PiMax = 400; AtLinkSetup.IsNegativeDelta = FALSE;//positive delta /************** Common Setup ********************************************************************************/ //SD common setup SdCommonSetup.bEnablePllB8 = TRUE; SdCommonSetup.CLKBYP_B8 = CSL_AIF2_PLL_CLOCK_NO_BYPASS; SdCommonSetup.LB_B8 = CSL_AIF2_PLL_LOOP_BAND_MID;//High BW is also fine SdCommonSetup.VoltRangeB8 = CSL_AIF2_PLL_VOLTAGE_LOW;//fixed factor SdCommonSetup.SleepPllB8 = CSL_AIF2_PLL_AWAKE; SdCommonSetup.pllMpyFactorB8 = CSL_AIF2_PLL_MUL_FACTOR_20X;//for CPRI when reference clock is 122.88 Mhz SdCommonSetup.SysClockSelect = CSL_AIF2_SD_BYTECLOCK_FROM_B8; SdCommonSetup.DisableLinkClock[0] = FALSE;//enable LINK0 clock SdCommonSetup.DisableLinkClock[1] = FALSE;//enable LINK1 clock SdCommonSetup.DisableLinkClock[2] = FALSE;//enable LINK2 clock SdCommonSetup.DisableLinkClock[3] = TRUE;//disable LINK3 clock SdCommonSetup.DisableLinkClock[4] = TRUE;//disable LINK4 clock SdCommonSetup.DisableLinkClock[5] = TRUE;//disable LINK5 clock //PD common setup PdCommonSetup.PdCppiDioSel = CSL_AIF2_CPPI;//AxC data uses CPPI for DMA machine PdCommonSetup.AxCOffsetWin = AXC_OFFSET_WIN;//AxC offset window PdCommonSetup.PdRadtTC = 2457599;//Radio frame size for CPRI PdCommonSetup.PdFrameTC[0].FrameIndexSc = 0;//start index PdCommonSetup.PdFrameTC[0].FrameIndexTc = 6;//teminal index PdCommonSetup.PdFrameTC[0].FrameSymbolTc = 139;//140 noramal cyclic prefix symbols in one rad frame. PdCommonSetup.PdChConfig[0].bChannelEn = TRUE;//Channel enable for channel 0 PdCommonSetup.PdChConfig[0].DataFormat = CSL_AIF2_LINK_DATA_TYPE_NORMAL;//Data format for channel 0 PdCommonSetup.AxCOffset[0] = 0;//this is the number of QW level data to skip PdCommonSetup.PdChConfig1[0].DataFormat = CSL_AIF2_GSM_DATA_OTHER;//Non GSM data PdCommonSetup.PdChConfig1[0].FrameCounter = 0;//CPRI framing counter group number for channel 0 PdCommonSetup.PdChConfig1[0].TddEnable = 0xFFFF;//PD TDD, enables all symbols(FDD) for channel 0 PdCommonSetup.TddEnable1[0] = 0xFFFFFFFF;//enables all symbols(FDD) PdCommonSetup.TddEnable2[0] = 0xFFFFFFFF;//enables all symbols(FDD) PdCommonSetup.TddEnable3[0] = 0xFFFFFFFF;//enables all symbols(FDD) PdCommonSetup.TddEnable4[0] = 0xFFFFFFFF;//enables all symbols(FDD) PdCommonSetup.PdFrameMsgTc[0] = 551;//OBSAI frame message terminal count for first normal cyclic prefix symbol for(i=1;i<7;i++) PdCommonSetup.PdFrameMsgTc[i] = 547;//OBSAI frame message terminal count for ohter 6 normal cyclic prefix LTE symbols //PE common setup PeCommonSetup.PeTokenPhase = 0;//Phase alignment for scheduling DMA normally set to zero PeCommonSetup.EnetHeaderSelect = 1; PeCommonSetup.PeFrameTC[0].FrameIndexSc = 0;//start index PeCommonSetup.PeFrameTC[0].FrameIndexTc = 6;//teminal index PeCommonSetup.PeFrameTC[0].FrameSymbolTc = 139;//140 normal cyclic prefix symbols in one rad frame. PeCommonSetup.bEnableCh[0] = TRUE;//Enable PE channel for channel 0 PeCommonSetup.PeDmaCh0[0].bCrcEn = FALSE;//disable CRC for channel 0 PeCommonSetup.PeDmaCh0[0].FrameTC = 0;//use framing terminal count 0 for channel 0 PeCommonSetup.PeDmaCh0[0].RtControl = CSL_AIF2_PE_RT_INSERT;//use PE insert option for channel 0 PeCommonSetup.PeDmaCh0[0].CrcType = CSL_AIF2_CRC_8BIT;//CRC type for channel 0 PeCommonSetup.PeDmaCh0[0].isEthernet = FALSE;//AxC data PeCommonSetup.PeDmaCh0[0].CrcObsaiHeader = FALSE; PeCommonSetup.PeInFifo[0].MFifoWmark = 3;//Message FIFO water mard for channel 0 PeCommonSetup.PeInFifo[0].MFifoFullLevel = 5;//Message FIFO full level for channel 0 PeCommonSetup.PeInFifo[0].SyncSymbol = 0; PeCommonSetup.PeAxcOffset[0] = 310;// same to PE2 offset PeCommonSetup.PeFrameMsgTc[0] = 2207;//OBSAI frame message terminal count for first normal cyclic prefix symbol for(i=1;i<7;i++) PeCommonSetup.PeFrameMsgTc[i] = 2191;//OBSAI frame message terminal count for ohter 6 normal cyclic prefix LTE symbols //PE Channel LUT setup and link routing selection (ChIndex number is matched with link number) switch(link) { case CSL_AIF2_LINK_0: PeCommonSetup.ChIndex0[0] = 0; //channel 0 for link 0 PeCommonSetup.bEnableChIndex0[0] = TRUE;//Route egress channel 0 to dedicated CPRI link PeCommonSetup.CpriPktEn0[0] = FALSE; //use channel 0 for AxC break; case CSL_AIF2_LINK_1: PeCommonSetup.ChIndex1[0] = 0; //channel 0 for link 1 PeCommonSetup.bEnableChIndex1[0] = TRUE;//Route egress channel 0 to dedicated CPRI link PeCommonSetup.CpriPktEn1[0] = FALSE; //use channel 0 for AxC break; case CSL_AIF2_LINK_2: PeCommonSetup.ChIndex2[0] = 0; //channel 0 for link 2 PeCommonSetup.bEnableChIndex2[0] = TRUE;//Route egress channel 0 to dedicated CPRI link PeCommonSetup.CpriPktEn2[0] = FALSE; //use channel 0 for AxC break; default: printf("Link %d is not connected on this card\n", link); } //Ingress DB setup IngrDbSetup.bEnableIngrDb = TRUE; //Enable Ingress DB IngrDbSetup.bEnableChannel[0] = TRUE; //Enable Ingress DB channel 0 IngrDbSetup.IngrDbChannel[0].BaseAddress = AIF2_DB_BASE_ADDR_I_FIFO_0; //Set DB FIFO base address for channel 0 IngrDbSetup.IngrDbChannel[0].BufDepth = CSL_AIF2_DB_FIFO_DEPTH_QW64; //Set DB FIFO depth for channel 0 to 64 QW(Quad word) IngrDbSetup.IngrDbChannel[0].DataSwap = CSL_AIF2_DB_WORD_SWAP; //for DL IngrDbSetup.IngrDbChannel[0].IQOrder = CSL_AIF2_DB_IQ_NO_SWAP; //No Order change IngrDbSetup.IngrDbChannel[0].bEnablePsData = TRUE; //Enable 4 bytes PS data IngrDbSetup.IngrDbChannel[0].PacketType = 0; //User data //Egress DB setup EgrDbSetup.bEnableEgrDb = TRUE; //Enable Ingress DB EgrDbSetup.PmControl = CSL_AIF2_DB_AXC_TOKEN_FIFO;//to enhance CPRI performance EgrDbSetup.bEnableChannel[0] = TRUE; //Enable Egress DB channel 0 EgrDbSetup.EgrDbChannel[0].BaseAddress = AIF2_DB_BASE_ADDR_E_FIFO_0; //Set DB FIFO base address for channel 0 EgrDbSetup.EgrDbChannel[0].BufDepth = CSL_AIF2_DB_FIFO_DEPTH_QW64; //Set DB FIFO depth for channel 0 to 32 QW EgrDbSetup.EgrDbChannel[0].DataSwap = CSL_AIF2_DB_WORD_SWAP; //for DL EgrDbSetup.EgrDbChannel[0].IQOrder = CSL_AIF2_DB_IQ_NO_SWAP; //No Order change //AD Common setup AdCommonSetup.IngrGlobalEnable = TRUE; AdCommonSetup.EgrGlobalEnable = TRUE; AdCommonSetup.FailMode = CSL_AIF2_AD_DROP;//drop fail packet AdCommonSetup.IngrPriority = CSL_AIF2_AD_PKT_PRI; AdCommonSetup.EgrPriority = CSL_AIF2_AD_AXC_PRI; AdCommonSetup.Tx_QueNum = AIF2_BASE_TX_QUE_NUM;//base egress queue number setup to 512 //AT Common setup AtCommonSetup.PhySyncSel = CSL_AIF2_SW_SYNC;//Select SW sync for Phy timer trigger AtCommonSetup.RadSyncSel = CSL_AIF2_SW_SYNC;//Select SW sync for Rad timer trigger AtCommonSetup.SyncMode = CSL_AIF2_NON_RP1_MODE; AtCommonSetup.AutoResyncMode = CSL_AIF2_AUTO_RESYNC_MODE; AtCommonSetup.CrcMode = CSL_AIF2_AT_CRC_DONT_USE;//Do not use RP1 CRC in this test AtCommonSetup.PhytCompValue = 0; AtCommonSetup.AtInit.pPhyTimerInit = &PhyTimerInit; AtCommonSetup.AtInit.pRadTimerInit = &RadTimerInit; PhyTimerInit.ClockNum = 0; PhyTimerInit.FrameLsbNum = 0; PhyTimerInit.FrameMsbNum = 0; RadTimerInit.ClockNum = 0; RadTimerInit.SymbolNum = 0; RadTimerInit.FrameLsbNum = 0; RadTimerInit.FrameMsbNum = 0; AtCommonSetup.AtTerminalCount.pPhyTimerTc = &PhyTimerTc; AtCommonSetup.AtTerminalCount.pRadTimerTc = &RadTimerTc; PhyTimerTc.FrameLsbNum = FRAME_COUNT_TC_PHY_TIMER;//set phy Frame TC to 4095 PhyTimerTc.ClockNum = CLOCK_COUNT_TC_PHY_TIMER_CPRI; //set phy clock TC for CPRI RadTimerTc.FrameLsbNum = FRAME_COUNT_TC_LTE_FDD;//set LTE Frame TC to 4095 RadTimerTc.SymbolNum = SYMBOL_COUNT_TC_LTE_FDD; //set LTE Symbol TC to 9 (sub frame time) RadTimerTc.LutIndexNum = 0; //set LTE lut index TC to zero AtCommonSetup.AtTerminalCount.RadClockCountTc[0] = CLOCK_COUNT_TC_LTE_FDD_CPRI;//set LTE Clock count TC forCPRI //AT Event setup (Event 2) AtEventSetup.AtRadEvent[2].EventSelect = CSL_AIF2_EVENT_2;//Select Event 2 AtEventSetup.AtRadEvent[2].EventOffset = 614399; //offset for inserting packet in frame at third frame time AtEventSetup.AtRadEvent[2].EvtStrobeSel = CSL_AIF2_RADT_FRAME; AtEventSetup.AtRadEvent[2].EventModulo = 2457599;//LTE frame time AtEventSetup.AtRadEvent[2].EventMaskLsb = 0xFFFFFFFF; AtEventSetup.AtRadEvent[2].EventMaskMsb = 0xFFFFFFFF; AtEventSetup.bEnableRadEvent[2] = TRUE;//Enable Event 2 /****** Do AIF2 HW setup (set all MMRs above) **********************************************************************/ CSL_aif2HwSetup(hAif2, &aif2Setup); ctrlArg = TRUE; hAif2->arg_link = link;//Select link num //Enable Serdes loopback for link //CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_ENABLE_DISABLE_LINK_LOOPBACK, (void *)&ctrlArg); //Enable Tx/Rx of link CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_ENABLE_DISABLE_TX_LINK, (void *)&ctrlArg); CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_ENABLE_DISABLE_RX_LINK, (void *)&ctrlArg); for(i=0;i<100;i++)asm (" NOP 9 ");//insert time delay for aif2 configuration complete //AT Arm timer CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AT_ARM_TIMER, (void *)&ctrlArg); //Trigger the SW debug frame sync CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AT_DEBUG_SYNC, (void *)&ctrlArg); } BSLC667X_ErrorCode BSLC667X_AIF_init() { BSLC667X_ErrorCode Err; /* Default configuration will only be used if FRU read fails from DSP */ BSLC667X_Libconfig_s LibConfig = {BSLC667X_CPU_CLK_FREQ_1200_MHZ,BSLC667X_BOARD_CFG_DEFAULT_AMC2C6670,TRUE,TRUE}; /* Initialise PLLC, DDR2 and BSLC667X Library */ Err = BSLC667X_Initialise(&LibConfig); if (Err) { printf("BSLC667X_Initialise() failed!!, ErrorCode = 0x%x\n",Err); return 1; } /* Initialise SFP module */ if(BSLC667X_SfpInitialise(NULL)) { printf("BSLC667X_SfpInitialise() failed!!"); return 1; } printf("SFP Interface Initialised\n"); Err = BSLC667X_SfpTxEnable(BSLC667X_SFP0_CHANNEL); Err |= BSLC667X_SfpTxEnable(BSLC667X_SFP1_CHANNEL); Err |= BSLC667X_SfpTxEnable(BSLC667X_SFP2_CHANNEL); if(Err) { printf("BSLC667XSfpTxEnable failed, Err=0x%x\n", Err); } /* Turn on the Hyperlink power domain */ if (CSL_PSC_getPowerDomainState (CSL_PSC_PD_AI) != PSC_PDSTATE_ON) { /* Enable the domain */ CSL_PSC_enablePowerDomain (CSL_PSC_PD_AI); /* Enable MDCTL */ CSL_PSC_setModuleNextState (CSL_PSC_LPSC_AI, PSC_MODSTATE_ENABLE); /* Apply the domain */ CSL_PSC_startStateTransition (CSL_PSC_PD_AI); /* Wait for it to finish */ while (! CSL_PSC_isStateTransitionDone (CSL_PSC_PD_AI)); } else { printf ("Power domain is already enabled. You probably re-ran without device reset (which is OK)\n"); } return 0; } void test_lte_cpri(CSL_Aif2LinkIndex link) { Uint32 monoRxCount; Uint16 testpass; Uint32 *temp; Uint32 idx, idx2, value; MNAV_MonolithicPacketDescriptor *mono_pkt; //printf("Beginning AIF2 CPRI LTE test:\n\n"); //for(idx=0;idx<10000;idx++)asm (" NOP 9 ");//insert time delay for printf operation int4_result = 0; Intc_config(); MNavigator_config();//multicore navigator configuration for LTE for(idx =0; idx < 14; idx++){ //push 7 packets into Tx queue for test tmp[idx] = pop_queue(MONO_TX_COMPLETE_Q); tmp[idx] &= 0xFFFFFFF0;//set DESC_SIZE field to zero mono_pkt = (MNAV_MonolithicPacketDescriptor *)tmp[idx]; //Create Mono packet (initialize non-zero fields) mono_pkt->type_id = MNAV_DESC_TYPE_MONO; mono_pkt->data_offset = MNAV_MONO_PACKET_SIZE + 4;//16 if((idx%7) == 0) mono_pkt->packet_length = 8832;//first symbol else mono_pkt->packet_length = 8768;//other six symbols mono_pkt->ps_flags = 1; mono_pkt->epib = 0; mono_pkt->psv_word_count = 1; // 4 byte PS field length mono_pkt->pkt_return_qnum = MONO_TX_COMPLETE_Q; mono_pkt->src_tag_lo = 0; //copied to .flo_idx of streaming i/f temp = (Uint32 *)(tmp[idx] + 16); if((idx%7) == 0) { for (idx2 = 0; idx2 < 2208; idx2 ++) temp[idx2] = idx2; //payload data setup(first symbol) } else { for (idx2 = 0; idx2 < 2192; idx2 ++) temp[idx2] = idx2; //payload data setup(other six symbols) } //Create PS data temp = (Uint32 *)(tmp[idx] + MNAV_MONO_PACKET_SIZE); temp[0] = (Uint32)(0x00008000 + (idx << 7));//add symbol number into PS field tmp[idx] |= 0x00000003;//set DESC_SIZE to 3 for AIF2 mono mode //Tx queue push will be done in ISR } Aif2_MNAV_Cpri_config(link);//Aif2 configuration for M Navigator mode /***************************************************************** * Enable AIF and wait for completion. */ while(1) { asm (" NOP 9 "); asm (" NOP 9 "); if(int4_result == 4)//Wait three LTE frame time { //AT disable all events and halt timer ctrlArg = TRUE; CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AT_DISABLE_ALL_EVENTS, (void *)&ctrlArg); CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AT_HALT_TIMER, (void *)&ctrlArg); ctrlArg = FALSE;//disable AD scheduler and Rx, Tx Link CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AD_E_ENABLE_DISABLE_GLOBAL, (void *)&ctrlArg); CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_AD_IN_ENABLE_DISABLE_GLOBAL, (void *)&ctrlArg); CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_ENABLE_DISABLE_TX_LINK, (void *)&ctrlArg); CSL_aif2HwControl(hAif2, CSL_AIF2_CMD_ENABLE_DISABLE_RX_LINK, (void *)&ctrlArg); CSL_aif2Reset(hAif2);//reset all aif2 modules break; } } monoRxCount = 0; // descriptor count for monolithic RX queue while (monoRxCount == 0) { // Get current descriptor count for monolithic RX queue monoRxCount = get_descriptor_count(MONO_RX_Q); if (monoRxCount > 0) printf(" Number of monolithic packets received in RX queue: %d\n", monoRxCount); if (Uart_GetKey() == 0x1b) break; } /***************************************************************** * Compare the data in the destination buffers. */ /* Compare the Monolithic packet data */ testpass = 0; for (idx = 0; idx < monoRxCount; idx ++) { tmp[idx] = pop_queue(MONO_RX_Q); tmp[idx] &= 0xFFFFFFF0;// clean DESC_SIZE field temp = (Uint32 *)tmp[idx]; temp += 4; //skip pkt header and PS field (16 bytes) if((idx%7) == 0) { for (idx2 = 0; idx2 < 2208; idx2 ++) { if (temp[idx2] != idx2) testpass++; } } else { for (idx2 = 0; idx2 < 2192; idx2 ++) { if (temp[idx2] != idx2) testpass++; } } push_queue(MONO_RX_FDQ, 1, 0, tmp[idx]); } /* read the descriptor counts of the Monolithic queues. */ value = get_descriptor_count(MONO_TX_Q); if (value != 0) printf(" Test b1) Monolithic Packet Tx Descriptor Counts:%d FAIL\n",value); else printf(" Test b1) Monolithic Packet Tx Descriptor Counts:%d PASS\n",value); if (value != 0) testpass++; value = get_descriptor_count(MONO_TX_COMPLETE_Q); if (value != 14) printf(" Test b2) Monolithic Packet Tx Complete Descriptor Counts:%d FAIL\n",value); else printf(" Test b2) Monolithic Packet Tx Complete Descriptor Counts:%d PASS\n",value); if (value != 14) testpass++; value = get_descriptor_count(MONO_RX_Q); if (value != 0) printf(" Test b3) Monolithic Packet Rx Descriptor Counts:%d FAIL\n",value); else printf(" Test b3) Monolithic Packet Rx Descriptor Counts:%d PASS\n",value); if (value != 0) testpass++; value = get_descriptor_count(MONO_RX_FDQ); if (value != 14) printf(" Test b4) Monolithic Packet Rx Free Descriptor Counts:%d FAIL\n",value); else printf(" Test b4) Monolithic Packet Rx Free Descriptor Counts:%d PASS\n",value); if (value != 14) testpass++; if (testpass == 0) printf(" Test a) Monolithic Packet Data Send/Recv: PASS\n"); else printf(" Test a) Monolithic Packet Data Send/Recv: FAIL\n"); if (testpass == 0) Uart_Printf("Link%d Data Send/Recv: PASS\r\n", link); else Uart_Printf("Link%d Data Send/Recv: FAIL %d\r\n", link, testpass); printf("\nEnding AIF2 CPRI LTE test\n"); } void main(void) { char SelRW, command[128]; int i, addr, NumData, addr_offset=0x00000000; unsigned int data[32], tmp; int Err; BSLC667X_AIF_init(); /* Initialise UART module */ if (Err = BSLC667X_UartInitialise(NULL)) printf("BSLC667X_UartInitialise() failed!!, ErrorCode = 0x%x\n",Err); printf("Uart Interface Initialised\n"); logo(); Uart_Printf("\r\n\nCMD> "); while(1) { if (Uart_GetString(command)) { if (command[0] == 't' || command[0] == 'T') { // input link : 0~2 int cmd, link; sscanf(command, "%c %d", &cmd, &link); test_lte_cpri((CSL_Aif2LinkIndex)link); } else if (command[0] == 'a' || command[0] == 'A') { } else { SelRW = decCmd(command, &addr, data, &NumData); switch (SelRW) { case 'W': Uart_Printf ("[WRITE %d BYTE DATA from 0x%08x]\r\n", NumData, addr_offset + addr); for (i=0; i<NumData; i++) { *(volatile int *)(addr_offset + addr+4*i) = data[i]; tmp = *(volatile int *)(addr_offset + addr+4*i); Uart_Printf (" MEM[%08x] = %08x (%08x)\r\n", addr_offset + addr+4*i, data[i], tmp); } Uart_Printf ("\r\n"); break; case 'R': Uart_Printf ("[READ %d BYTE DATA from 0x%08x]\r\n", NumData, addr_offset + addr); for (i=0; i<NumData; i++) { tmp = *(volatile int *)(addr_offset + addr+4*i); Uart_Printf (" MEM[%08x] = %08x\r\n", addr_offset + addr+4*i, tmp); } Uart_Printf ("\r\n"); break; case 'O': if (NumData > 0) { addr_offset = (int)data[0]; } Uart_Printf (" * ADDRESS OFFSET : 0x%08X\r\n", addr_offset); Uart_Printf ("\r\n"); break; default: if (command[0] != 0) { Uart_Printf(" Bad Command !!!!\r\n"); Uart_Printf(" Command Format : Write Addr D1 D2 D3 ... DN\r\n"); Uart_Printf(" Read (Addr) (NumOfData)\r\n\r\n"); } break; } } Uart_Printf("CMD> "); } } } ////////////////////////////////////////////////////////////////////////////////////////////////////// //==================================================================== char Uart_IsKey(void) { /* Wait until FIFO is ready */ if( CSL_FEXT(hUart->LSR, UART_LSR_DR) == CSL_UART_LSR_DR_NOTREADY ) { /* Delay processor for 20us */ BSLC667X_MicrosecWait(20); } else { return 1; } return 0; } //==================================================================== char Uart_GetKey(void) { return (Int8)hUart->RBR; } int Uart_GetString(char *string) { static int idx=0; char *string2 = string; char c; if (Uart_IsKey()) { c = Uart_GetKey(); if (c != '\r') { if(c=='\b') { if( (int)string2 < (int)(string+idx) ) { Uart_Printf("\b \b"); idx--; } } else { *(string + idx++) = c; Uart_Printf("%c", c); } } else { *(string+idx)='\0'; Uart_Printf("\r\n"); idx = 0; return 1; } } return 0; } int Uart_Printf (const char *fmt, ...) { va_list argptr; char txbuf[512]; int cnt; va_start(argptr, fmt); cnt = vsprintf(txbuf, fmt, argptr); va_end(argptr); BSLC667X_UartPrint(txbuf); return(cnt); } char decCmd (char *s, int *addr, unsigned int *data, int *NumData) { int i=0, ptr=0; char s_cmd[128]; char cmd[32]; unsigned int data_cmd; int addr_cmd, NumData_cmd; if (sscanf (s, "%s", cmd) == EOF) return '\0'; while (s[i] == 0x20) i++; while ((s[i] != 0x20) && (s[i] != '\0')) i++; strcpy(s_cmd, s+i); if ((cmd[0]=='w') || (cmd[0]=='W')) { if (sscanf ( s_cmd, "%x", &addr_cmd) == EOF) return '\0'; while (s[i] == 0x20) i++; while ((s[i] != 0x20) && (s[i] != '\0')) i++; strcpy(s_cmd, s+i); *addr = (addr_cmd); while (sscanf (s_cmd, "%x", &data_cmd) != EOF) { data[ptr++] = data_cmd; while (s[i] == 0x20) i++; while ((s[i] != 0x20) && (s[i] != '\0')) i++; strcpy(s_cmd, s+i); } data[ptr] = '\0'; if (!ptr) return '\0'; *NumData = ptr; return 'W'; } else if ((cmd[0]=='r') || (cmd[0]=='R')) { NumData_cmd = 1; if (sscanf(s_cmd, "%x", &addr_cmd) == EOF) { *NumData = (int) NumData_cmd; return 'R'; } while (s[i] == 0x20) i++; while ((s[i] != 0x20) && (s[i] != '\0')) i++; strcpy(s_cmd, s+i); *addr = (addr_cmd); sscanf (s_cmd, "%d", &NumData_cmd); while (s[i] == 0x20) i++; while ((s[i] != 0x20) && (s[i] != '\0')) i++; strcpy(s_cmd, s+i); if (sscanf(s_cmd, "%d", &ptr) != EOF) return '\0'; *NumData = (int) NumData_cmd; return 'R'; } else if ((cmd[0]=='o') || (cmd[0]=='O')) { if (sscanf (s_cmd, "%x", &data_cmd) != EOF) { *NumData = 1; data[0] = data_cmd; } else { *NumData = 0; } return 'O'; } else { return '\0'; } } void logo (void) { Uart_Printf("\r\n"); Uart_Printf("\r\n"); Uart_Printf(" :::::::: ::::::::: ::::::::: ::::::::::: \r\n"); Uart_Printf(" :+: :+: :+: :+: :+: :+: :+: \r\n"); Uart_Printf(" +:+ +:+ +:+ +:+ +:+ +:+ \r\n"); Uart_Printf(" +#+ +#++:++#+ +#++:++#: +#+ \r\n"); Uart_Printf(" +#+ +#+ +#+ +#+ +#+ \r\n"); Uart_Printf(" #+# #+# #+# #+# #+# #+# \r\n"); Uart_Printf(" ######## ### ### ### ########### \r\n\r\n"); Uart_Printf("[ AMC-2C66-3AIF CONSOLE PROGRAM %s ]\r\n", __VERSION__); Uart_Printf("[ Coded by CleverLogic Co.,Ltd. ]\r\n"); }
Vendor specific CPRI I send data I want to be.
I do not know what to do with the code.
gyosun
