hello,everyone ,I am using linux kernel 2.6.37,but I can't use nfs to boot the filesystem.The boot information is as follows:
Loading from NAND 128MiB 3,3V 8-bit, offset 0x400000
Image Name: Linux-2.6.37_IPNC_DM365_4.0.0
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4061504 Bytes = 3.9 MB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Linux version 2.6.37_IPNC_DM365_4.0.0 (root@ubuntu) (gcc version 4.3.3 (GCC) ) #1 PREEMPT Tue Dec 11 10:10:15 HKT 2012
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x IPNC
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 12192
[ 0.000000] Kernel command line: console=ttyS0,115200n8 noinitrd rw ip=192.168.1.99:192.168.1.99:192.168.1.1:255.255.255.0:::off eth=EE:0C:0C:BE:19:02 root=/dev/nfs nfsroot=192.168.1.93:/home/davinci/IPNC_4.0/Source/ipnc_rdk/target/filesys,nolock mem=48M cmemk.phys_start="0x83000000" cmemk.phys_end="0x88000000" cmemk.phys_start_1="0x00001000" cmemk.phys_end_1="0x00008000" cmemk.pools_1="1x28672" cmemk.allowOverlap=1 eth=$(ethaddr) lpj=1077248 nohz=off highres=off
[ 0.000000] TI DaVinci EMAC: kernel boot params Ethernet address: EE:0C:0C:BE:19:02
[ 0.000000] TI DaVinci EMAC: kernel boot params Ethernet address: $(ethaddr)
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44560k/44560k available, 4592k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB)
[ 0.000000] vmalloc : 0xc3800000 - 0xfea00000 ( 946 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3000000 ( 48 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc002a000 ( 136 kB)
[ 0.000000] .text : 0xc002a000 - 0xc03bf000 (3668 kB)
[ 0.000000] .data : 0xc03c0000 - 0xc03e7940 ( 159 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptable hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000292] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000350] pid_max: default: 32768 minimum: 301
[ 0.000656] Mount-cache hash table entries: 512
[ 0.001445] CPU: Testing write buffer coherency: ok
[ 0.005931] DaVinci: 8 gpio irqs
[ 0.006543] NET: Registered protocol family 16
[ 0.021666] EVM: (null) video input
[ 0.104172] bio: create slab <bio-0> at 0
[ 0.108930] SCSI subsystem initialized
[ 0.113131] usbcore: registered new interface driver usbfs
[ 0.114474] usbcore: registered new interface driver hub
[ 0.115384] usbcore: registered new device driver usb
[ 0.118635] vpss vpss: dm365_vpss vpss probed
[ 0.118702] vpss vpss: dm365_vpss vpss probe success
[ 0.120985] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.122927] Switching to clocksource timer0_1
[ 0.186307] NET: Registered protocol family 2
[ 0.186609] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.187393] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.187533] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.187623] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.187656] TCP reno registered
[ 0.187697] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.187762] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.188270] NET: Registered protocol family 1
[ 0.189323] RPC: Registered udp transport module.
[ 0.189366] RPC: Registered tcp transport module.
[ 0.189396] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.263589] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.263637] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.264359] JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.268108] msgmni has been set to 87
[ 0.272414] io scheduler noop registered (default)
[ 0.273898] CSL: Module install successful, device major num = 254
[ 0.273943] CSL: Module version 0.10.00, built on Dec 10 2012 16:09:23
[ 0.273996] I2C: Module install successful, device major num = 253
[ 0.274037] DMA: Module install successful, device major num = 252
[ 0.274065] DRV: Module install successful
[ 0.274090] DRV: Module built on Dec 10 2012 16:09:25
[ 0.274117] DRV: EDMACC.QUEPRI = 00002777
[ 0.274140] DRV: SYSTEM.MSTPRI0 = 00440011
[ 0.274163] DRV: SYSTEM.MSTPRI1 = 00000444
[ 0.274186] DRV: ISP.BCR = 00000002
[ 0.274208] DRV: SYSTEM.MISC = 00000399
[ 0.274232] EDMAK module: built on Dec 10 2012 at 16:09:01
[ 0.274262] Reference Linux version 2.6.37
[ 0.275771] IRQK module: built on Dec 10 2012 at 16:09:00
[ 0.275819] Reference Linux version 2.6.37
[ 0.277351] irqk initialized
[ 0.277424] CMEMK module: built on Dec 10 2012 at 16:08:57
[ 0.277461] Reference Linux version 2.6.37
[ 0.282542] allocated heap buffer 0xc4000000 of size 0x5000000
[ 0.282591] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 0.282628] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 0.282800] cmemk initialized
[ 0.282853] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.306923] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.853358] console [ttyS0] enabled
[ 0.878805] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 0.889007] brd: module loaded
[ 0.901064] NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung )
[ 0.909051] Bad block table not found for chip 0
[ 0.915182] Bad block table not found for chip 0
[ 0.919825] Scanning device for bad blocks
[ 0.995738] Creating 7 MTD partitions on "davinci_nand.0":
[ 1.001354] 0x000000000000-0x000000300000 : "bootloader"
[ 1.010734] 0x000000300000-0x000000500000 : "params"
[ 1.019712] 0x000000500000-0x000000900000 : "kernel"
[ 1.028947] 0x000000900000-0x000003100000 : "filesystem1"
[ 1.038848] 0x000003100000-0x000003300000 : "data1"
[ 1.048208] 0x000003300000-0x000005b00000 : "filesystem2"
[ 1.058155] 0x000005b00000-0x000008000000 : "data2"
[ 1.067536] davinci_nand davinci_nand.0: controller rev. 2.3
[ 1.130119] davinci_mdio davinci_mdio.0: davinci mdio revision 1.4
[ 1.136332] davinci_mdio davinci_mdio.0: detected phy mask fffffffd
[ 1.144123] davinci_mdio.0: probed
[ 1.147573] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver Davicom DM9161A
[ 1.156167] i2c /dev entries driver
[ 1.161869] Linux media interface: v0.10
[ 1.166503] Linux video capture interface: v2.00
[ 1.173402] vpbe-osd vpbe-osd: OSD sub device probe success
[ 1.179853] vpbe-venc vpbe-venc: VENC sub device probe success
[ 1.186713] vpbe-v4l2 vpbe-v4l2: vpbe v4l2 device registered
[ 1.192897] Setting default output to Composite
[ 1.197455] Setting default mode to ntsc
[ 1.201617] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
[ 1.208340] vpbe-v4l2 vpbe-v4l2: layer=c28db200,layer->video_dev=c28db2e8
[ 1.216056] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
[ 1.222996] vpbe-v4l2 vpbe-v4l2: layer=c2941000,layer->video_dev=c29410e8
[ 1.231640] watchdog watchdog: heartbeat 60 sec
[ 1.241570] Error: Driver 'davinci-mcbsp' is already registered, aborting...
[ 1.251557] asoc: cq93vc-hifi <-> davinci-vcif mapping ok
[ 1.260517] ALSA device list:
[ 1.263518] #0: DaVinci DM365 EVM
[ 1.268480] TCP cubic registered
[ 1.271957] NET: Registered protocol family 17
[ 1.276575] Registering the dns_resolver key type
[ 1.290568] net eth0: attached PHY driver [Davicom DM9161A] (mii_bus:phy_addr=0:01, id=181b8a0)
[ 1.310862] IP-Config: Complete:
[ 1.313946] device=eth0, addr=192.168.1.99, mask=255.255.255.0, gw=192.168.1.1,
[ 1.321788] host=192.168.1.99, domain=, nis-domain=(none),
[ 1.327729] bootserver=192.168.1.99, rootserver=192.168.1.93, rootpath=
[ 4.290355] PHY: 0:01 - Link is Up - 100/Full
[ 4.340994] VFS: Unable to mount root fs via NFS, trying floppy.
[ 4.348106] VFS: Cannot open root device "nfs" or unknown-block(2,0)
[ 4.355298] Please append a correct "root=" boot option; here are the available partitions:
[ 4.364185] 1f00 3072 mtdblock0 (driver?)
[ 4.369543] 1f01 2048 mtdblock1 (driver?)
[ 4.374746] 1f02 4096 mtdblock2 (driver?)
[ 4.380410] 1f03 40960 mtdblock3 (driver?)
[ 4.385743] 1f04 2048 mtdblock4 (driver?)
[ 4.391321] 1f05 40960 mtdblock5 (driver?)
[ 4.396571] 1f06 37888 mtdblock6 (driver?)
[ 4.401759] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[ 4.410118] Backtrace:
[ 4.412596] Function entered at [<c002e500>] from [<c0340c28>]
[ 4.418445] r7:00008000 r6:c2813000 r5:c0023988 r4:c03e80a0
[ 4.424221] Function entered at [<c0340c10>] from [<c0340c94>]
[ 4.430375] Function entered at [<c0340c2c>] from [<c0008fd0>]
[ 4.436454] r3:00000000 r2:00000000 r1:c2825f58 r0:c036217b
[ 4.442259] Function entered at [<c0008dec>] from [<c00090c4>]
[ 4.448348] Function entered at [<c0009018>] from [<c0009248>]
[ 4.454523] r4:c03e79a8
[ 4.457090] Function entered at [<c00090e8>] from [<c00084b4>]
[ 4.463005] r5:c0023124 r4:c03e7958
[ 4.466936] Function entered at [<c00083a4>] from [<c0042e0c>]
[ 4.472859] r5:c00083a4 r4:00000000
The parameters transfered to the kernel from the uboot are :
setenv bootargs 'console=ttyS0,115200n8 noinitrd rw ip=192.168.1.99:192.168.1.99:192.168.1.1:255.255.255.0:::off eth=EE:0C:0C:BE:19:02 root=/dev/nfs nfsroot=192.168.1.93:/home/davinci/IPNC_4.0/Source/ipnc_rdk/target/filesys,nolock mem=48M cmemk.phys_start="0x83000000" cmemk.phys_end="0x88000000" cmemk.phys_start_1="0x00001000" cmemk.phys_end_1="0x00008000" cmemk.pools_1="1x28672" cmemk.allowOverlap=1 eth=$(ethaddr) lpj=1077248 nohz=off highres=off';saveenv;reset;
My configuration of the nfs for the linux kernel is:
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
CONFIG_NFS_V4_1=y
CONFIG_ROOT_NFS=y
CONFIG_NFSD=y
CONFIG_NFSD_DEPRECATED=y
# CONFIG_NFSD_V3 is not set
# CONFIG_NFSD_V4 is not set
CONFIG_LOCKD=y
CONFIG_NFS_COMMON=y
I use another linux kernel 2.6.18 ,and it can mount the nfs through the following command:
mount –t nfs 192.168.1.93:/home/davinci/IPNC_4.0/Source/ipnc_rdk/target/filesys /mnt/upan –o nolock
So I think the host configuration has no problem.
Who can help me ?Thank you a lot!!
