Other Parts Discussed in Thread: DM3730, ADS7846, TVP5146M2, OMAP3530
Hello All,
I'm trying to integrate AAC (c64xplus_aacheenc_1_20_005_production release) encoder to DVSDK (ti-dvsdk_dm3730-evm_4_00_00_22) for a while but could not manage.
Please find the platform configs and error logs below.
Boot log:
Linux version 2.6.32 (berkant@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Mon Oct 1 15:27:46 EEST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 DEVKIT8500 Board
Memory policy: ECC disabled, Data cache writeback
OMAP3630/DM3730 ES1.0 (l2cache iva sgx neon isp 192mhz_clk )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
Reserving 12582912 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 111360
Kernel command line: console=ttyS2,115200n8 root=/dev/nfs rw nfsroot=192.168.7.201:/rootfs ip=dhcp mem=55M@0x80000000 mem=384M@0x88000000 omap_vout.vid1_static_vrfb_alloc=y vram=12M omapfb.vram=0:4M,1:8M mpurate=1000
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 55MB 384MB = 439MB total
Memory: 427904KB available (4368K code, 379K data, 164K init, 0K highmem)
Hierarchical RCU implementation.
NR_IRQS:402
Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
Reprogramming SDRC clock to 332000000 Hz
GPMC revision 5.0
IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP GPIO hardware version 2.5
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 506.27 BogoMIPS (lpj=1978368)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
regulator: core version 0.5
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
Unable to get DVI PUP GPIO
Target VDD1 OPP = 4, VDD2 OPP = 2
OMAP DMA hardware revision 5.0
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
regulator: VUSB1V5: 1500 mV normal standby
regulator: VUSB1V8: 1800 mV normal standby
regulator: VUSB3V1: 3100 mV normal standby
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
regulator: VMMC1: 1850 <--> 3150 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VPLL2: 1800 mV normal standby
regulator: VMMC2: 1850 <--> 3150 mV normal standby
regulator: VSIM: 1800 <--> 3000 mV normal standby
i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
Switching to clocksource 32k_counter
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
omap-iommu omap-iommu.0: isp registered
NetWinder Floating Point Emulator V0.97 (double precision)
ashmem: initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
msgmni has been set to 836
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron NAND 512MiB 1,8V 16-bit)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on "omap2-nand":
0x000000000000-0x000000080000 : "X-Loader"
0x000000080000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000680000 : "Kernel"
0x000000680000-0x000020000000 : "File System"
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPPoL2TP kernel driver, V1.0
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at e0862000,e0866400 IRQ 185 MAC: 00:11:22:33:44:55 (chip)
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver cdc_eem
usbcore: registered new interface driver dm9601
usbcore: registered new interface driver smsc95xx
usbcore: registered new interface driver gl620a
usbcore: registered new interface driver net1080
usbcore: registered new interface driver plusb
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver MOSCHIP usb-ethernet driver
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
g_ether gadget: using random self ethernet address
g_ether gadget: using random host ethernet address
usb0: MAC e6:79:77:6e:05:14
usb0: HOST MAC 2e:74:1c:c0:f1:36
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
input: TWL4030 Keypad as /devices/platform/i2c_omap.1/i2c-1/1-004a/twl4030_keypad/input/input1
ads7846 spi2.0: touchscreen, irq 187
input: ADS7846 Touchscreen as /devices/platform/omap2_mcspi.2/spi2.0/input/input2
using rtc device, twl_rtc, for alarms
twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
twl_rtc twl_rtc: Power up reset detected.
twl_rtc twl_rtc: Enabling TWL-RTC.
i2c /dev entries driver
Linux video capture interface: v2.00
tvp514x 2-005d: Registered to v4l2 master omap34xxcam!!
omap-iommu omap-iommu.0: isp: version 1.1
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
Registered led device: sys_led
Registered led device: user_ledb
Registered led device: user_led1
Registered led device: user_led2
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.21.
usb 1-1: new high speed USB device using ehci-omap and address 2
No device for DAI omap-mcbsp-dai-0
No device for DAI omap-mcbsp-dai-1
No device for DAI omap-mcbsp-dai-2
No device for DAI omap-mcbsp-dai-3
No device for DAI omap-mcbsp-dai-4
OMAP3 Devkit8500 SoC init
asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
ALSA device list:
#0: omap3devkit8500 (twl4030)
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Power Management for TI OMAP3.
Unable to set L3 frequency (400000000)
Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/1000 MHz
IVA2 clocking rate: 800 MHz
SmartReflex driver initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
Console: switching to colour frame buffer device 60x34
regulator_init_complete: incomplete constraints, leaving VDVI on
regulator_init_complete: incomplete constraints, leaving VDAC on
twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
tvp514x 2-005d: tvp5146m2 found at 0xba (OMAP I2C adapter)
omapdss DPI error: display already enabled
omap_vout omap_vout: 'lcd' Display already enabled
omap_vout omap_vout: Buffer Size = 3686400
omap_vout omap_vout: : registered and initialized video device 1
omap_vout omap_vout: : registered and initialized video device 2
eth0: link down
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Sending DHCP requests ., OK
IP-Config: Got DHCP answer from 192.168.7.1, my address is 192.168.7.4
IP-Config: Complete:
device=eth0, addr=192.168.7.4, mask=255.255.255.0, gw=192.168.7.1,
host=192.168.7.4, domain=TEKOM, nis-domain=(none),
bootserver=192.168.7.1, rootserver=192.168.7.201, rootpath=
Looking up port of RPC 100003/2 on 192.168.7.201
Looking up port of RPC 100005/1 on 192.168.7.201
VFS: Mounted root (nfs filesystem) on device 0:12.
Freeing init memory: 164K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
udev: starting version 141
Remounting root file system...
Caching udev devnodes
Populating dev cache
logger: mount: mount point /proc/bus/usb does not exist
ALSA: Restoring mixer settings...
NOT configuring network interfaces: / is an NFS mount
Sat Oct 16 01:04:00 UTC 2010
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
Starting PVR
Loading kernel modules for gstreamer-ti... Running /usr/share/ti/gst/<platform>/loadmodule.shERROR: Module cmemk does not exist in /proc/modules
ERROR: Module lpm_omap3530 does not exist in /proc/modules
ERROR: Module dsplinkk does not exist in /proc/modules
ERROR: Module sdmak does not exist in /proc/modules
CMEMK module: built on Oct 14 2010 at 13:14:41
Reference Linux version 2.6.32
File /sdk/build/DVSDK_4_00/4_00_00_22/arago-install/arago-tmp/work/dm37x-evm-none-linux-gnueabi/ti-linuxutils-1_2_25_05_11-r89d/linuxutils_2_25_05_11/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
CMEM Range Overlaps Kernel Physical - allowing overlap
CMEM phys_start (0x86300000) overlaps kernel (0x80000000 -> 0x9b700000)
allocated heap buffer 0xe2000000 of size 0x53d000
cmemk initialized
DSPLINK Module (1.65.00.02) created on Date: Oct 14 2010 Time: 13:21:09
SDMAK module: built on Oct 14 2010 at 13:14:44
File /sdk/build/DVSDK_4_00/4_00_00_22/arago-install/arago-tmp/work/dm37x-evm-none-linux-gnueabi/ti-linuxutils-1_2_25_05_11-r89d/linuxutils_2_25_05_11/packages/ti/sdo/linuxutils/sdma/src/module/sdmak.c
done
CMEM Allocation
modprobe cmemk allowOverlap=1 phys_start=0x86300000 phys_end=0x87300000 \
pools=1x5250000,6x829440,1x345600,1x691200,1x1 allowOverlap=1
codec.cfg (codec decleration)
var AACHEENC = xdc.useModule('ti.sdo.codecs.aacheenc.ce.AACHEENC');
AACHEENC.serverFxns = "AUDENC1_SKEL";
AACHEENC.stubFxns = "AUDENC1_STUBS";
AACHEENC.useCache = false;
AACHEENC.alg.watermark = false;
AACHEENC.alg.codeSection = codeSection;
AACHEENC.alg.udataSection = udataSection;
AACHEENC.alg.dataSection = dataSection;
Server.algs = [
{name: "aacheenc", mod: AACHEENC , threadAttrs: {
stackMemId: 0, priority: Server.MINPRI + 3},
groupId : 2,
package.xs (for validation)
* ======== package.xs ========
function validate() {
// Each codec is validated with the following call:
// validate_one_codec(<package name>, <module name>);
validate_one_codec( "ti.sdo.codecs.aacheenc", "AACHEENC" );
gstticodecs_omap3530.c (codec added to gstreamer)
"AAC Audio Encoder", /* String name of codec used by plugin */
"aacheenc", /* String name of codec used by CE */
codecServer /* Engine that contains this codec */
Compiled codecs, dmai and gstreamer
Copied cs.x64P and libgstticodecplugin.so to board
Run the following gstreamer pipeline (with CE_DEBUG=3)
gst-launch -v alsasrc num-buffers=1500 ! 'audio/x-raw-int' ! TIAudenc1 codecName=aacheenc engineName=codecServer numChannels=2 samplefreq=44100 bitrate=128000 ! filesink location=ses1.aac
@0,841,064us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - Global_init> This program was built with the following packages:
@0,841,369us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package gnu.targets.arm.rtsv5T (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/gnu/targets/arm/rtsv5T/) [1, 0, 0, 0]
@0,841,461us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.c6accel (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/c6accel_1_01_00_01/soc/packages/ti/c6accel/) [1, 0, 0]
@0,841,552us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.aachedec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/aachedec/) [1, 0, 0]
@0,841,613us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.deinterlacer (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/deinterlacer/) [1, 0, 0]
@0,844,573us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.g711dec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/g711dec/) [1, 0, 0]
@0,844,604us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.g711enc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/g711enc/) [1, 0, 0]
@0,844,635us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.h264dec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/h264dec/) [1, 0, 0]
@0,844,665us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.h264enc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]
@0,844,665us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.jpegdec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/jpegdec/) [1, 0, 0]
@0,844,696us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.jpegenc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/jpegenc/) [1, 0, 0]
@0,844,696us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.mpeg2dec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0]
@0,844,726us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.mpeg4dec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0]
@0,844,726us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.mpeg4enc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]
@0,844,757us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.linuxutils.sdma (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/linuxutils_2_25_05_11/packages/ti/sdo/linuxutils/sdma/) [1, 0, 0]
@0,844,787us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.linuxutils.cmem (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/linuxutils_2_25_05_11/packages/ti/sdo/linuxutils/cmem/) [2, 2, 0]
@0,844,787us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.fc.global (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/global/) [1, 0, 0]
@0,844,818us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.fc.scpy (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/scpy/) [1, 0, 0]
@0,844,818us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.global (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/global/) [1, 0, 0]
@0,844,848us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.xdais.dm (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdais_6_26_01_03/packages/ti/xdais/dm/) [1, 0, 5]
@0,844,848us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.utils.trace (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/utils/trace/) [1, 0, 0]
@0,844,879us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.utils.xdm (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]
@0,844,909us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package dsplink.gpp (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/dsplink_1_65_00_02/dsplink/gpp/) [5, 0, 0]
@0,844,940us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.bios.power (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/local-power-manager_1_24_02_09/packages/ti/bios/power/) [1, 1, 1]
@0,844,940us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.xdais (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdais_6_26_01_03/packages/ti/xdais/) [1, 2.0, 1]
@0,844,970us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.node (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/node/) [1, 0, 0]
@0,844,970us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.fc.memutils (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/memutils/) [1, 0, 0]
@0,845,001us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.fc.utils (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/utils/) [1, 0, 2]
@0,845,031us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.fc.dman3 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/dman3/) [1, 0, 4]
@0,845,031us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.fc.acpy3 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/acpy3/) [1, 0, 4]
@0,845,062us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package gnu.targets (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/gnu/targets/) [1, 0, 1]
@0,845,062us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package gnu.targets.arm (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/gnu/targets/arm/) [1, 0, 0, 0]
@0,845,092us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.catalog.arm (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/ti/catalog/arm/) [1, 0, 1, 0]
@0,845,123us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.catalog (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/ti/catalog/) [1, 0, 0]
@0,845,123us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.catalog.c6000 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/ti/catalog/c6000/) [1, 0, 0, 0]
@0,845,153us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.platforms.evm3530 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/ti/platforms/evm3530/) [1, 0, 0]
@0,845,153us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.osal (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/osal/) [2, 0, 2]
@0,845,184us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.ipc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/) [2, 0, 1]
@0,845,184us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.osal.linux (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/osal/linux/) [2, 0, 1]
@0,845,214us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.ipc.dsplink (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/dsplink/) [2, 0, 1]
@0,845,214us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.alg (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/alg/) [1, 0, 1]
@0,845,245us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/) [1, 0, 6]
@0,845,275us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.universal (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/universal/) [1, 0, 0]
@0,845,275us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.c6accel.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/c6accel_1_01_00_01/soc/packages/ti/c6accel/ce/) [1, 0, 0]
@0,845,306us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.audio1 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/audio1/) [1, 0, 1]
@0,845,306us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.aachedec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/aachedec/ce/) [1, 0, 0]
@0,845,336us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.deinterlacer.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/deinterlacer/ce/) [1, 0, 0]
@0,845,336us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.speech1 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/speech1/) [1, 0, 1]
@0,845,367us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.g711dec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/g711dec/ce/) [1, 0, 0]
@0,845,367us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.g711enc.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/g711enc/ce/) [1, 0, 0]
@0,845,397us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.video2 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/video2/) [1, 0, 2]
@0,845,428us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.h264dec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0]
@0,845,428us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.video1 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/video1/) [1, 0, 2]
@0,847,259us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.h264enc.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]
@0,847,290us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.image1 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/image1/) [1, 0, 1]
@0,847,290us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.jpegdec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/jpegdec/ce/) [1, 0, 0]
@0,847,320us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.jpegenc.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/jpegenc/ce/) [1, 0, 0]
@0,847,320us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.mpeg2dec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0]
@0,847,351us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.mpeg4dec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg4dec/ce/) [1, 0, 0]
@0,847,351us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.codecs.mpeg4enc.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]
@0,847,381us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.speech (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/speech/) [1, 0, 2]
@0,847,412us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.audio (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/audio/) [1, 0, 2]
@0,847,412us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.video (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/video/) [1, 0, 3]
@0,847,442us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.ce.image (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/image/) [1, 0, 3]
@0,847,442us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package ti.sdo.dmai (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/dmai_2_20_00_10/packages/ti/sdo/dmai/) [1, 0, 0]
@0,847,473us: [+4 T:0x4001fd00 S:0xbecd9ec4] OG - package gstticodecplugin_omap3530 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/gstreamer-ti_svnr822/src/gstticodecplugin_omap3530/) []
@0,847,503us: [+0 T:0x4001fd00 S:0xbecd9ecc] OG - Global_atexit> enter (fxn=0x40621c34)
@0,847,534us: [+0 T:0x4001fd00 S:0xbecd9ecc] OG - Global_atexit> enter (fxn=0x40621080)
@0,847,564us: [+0 T:0x4001fd00 S:0xbecd9e9c] OM - Memory_alloc> Enter(0x18)
@0,847,595us: [+0 T:0x4001fd00 S:0xbecd9e9c] OM - Memory_alloc> return (0xb0608)
@0,847,686us: [+0 T:0x4001fd00 S:0xbecd9ebc] OG - Global_atexit> enter (fxn=0x4061ef08)
@0,847,747us: [+0 T:0x4001fd00 S:0xbecd9e94] OM - Memory_alloc> Enter(0x18)
@0,847,778us: [+0 T:0x4001fd00 S:0xbecd9e94] OM - Memory_alloc> return (0xb0678)
@0,847,778us: [+0 T:0x4001fd00 S:0xbecd9eb4] OG - Global_atexit> enter (fxn=0x4061dd34)
@0,847,808us: [+0 T:0x4001fd00 S:0xbecd9ebc] OG - Global_atexit> enter (fxn=0x406206e4)
@0,847,839us: [+0 T:0x4001fd00 S:0xbecd9eb4] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,847,869us: [+0 T:0x4001fd00 S:0xbecd9e9c] OM - Memory_alloc> Enter(0x14)
@0,847,869us: [+0 T:0x4001fd00 S:0xbecd9e9c] OM - Memory_alloc> return (0xb06e8)
@0,847,900us: [+0 T:0x4001fd00 S:0xbecd9eb4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0xb06e8]
@0,847,900us: [+0 T:0x4001fd00 S:0xbecd9eb4] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,847,930us: [+0 T:0x4001fd00 S:0xbecd9e9c] OM - Memory_alloc> Enter(0x14)
@0,847,930us: [+0 T:0x4001fd00 S:0xbecd9e9c] OM - Memory_alloc> return (0xb0700)
@0,847,961us: [+0 T:0x4001fd00 S:0xbecd9eb4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0xb0700]
@0,847,991us: [+0 T:0x4001fd00 S:0xbecd9e9c] OM - Memory_alloc> Enter(0x18)
@0,847,991us: [+0 T:0x4001fd00 S:0xbecd9e9c] OM - Memory_alloc> return (0xb0718)
@0,848,022us: [+0 T:0x4001fd00 S:0xbecd9e94] OT - Thread_create> Enter (fxn=0x4061bf78, attrs=0x0)
@0,848,022us: [+0 T:0x4001fd00 S:0xbecd9e7c] OM - Memory_alloc> Enter(0x64)
@0,848,052us: [+0 T:0x4001fd00 S:0xbecd9e7c] OM - Memory_alloc> return (0xb0738)
@0,848,297us: [+0 T:0x4001fd00 S:0xbecd9e94] OT - Thread_create> Exit (task=0xb0738)
@0,848,327us: [+0 T:0x4001fd00 S:0xbecd9ebc] OG - Global_atexit> enter (fxn=0x4061d438)
@0,848,358us: [+0 T:0x4001fd00 S:0xbecd9ecc] OG - Global_atexit> enter (fxn=0x4061b990)
@0,848,388us: [+0 T:0x4001fd00 S:0xbecd9ecc] OG - Global_atexit> enter (fxn=0x4061e280)
@0,848,419us: [+0 T:0x4001fd00 S:0xbecd9eb4] ti.sdo.ce.alg - ALG_init> Enter
@0,848,449us: [+0 T:0x4001fd00 S:0xbecd9ed4] ti.sdo.ce.alg - ALG_init> Exit
@0,848,480us: [+0 T:0x4001fd00 S:0xbecd9ecc] OG - Global_atexit> enter (fxn=0x40618014)
@0,848,480us: [+0 T:0x4001fd00 S:0xbecd9ea4] OM - Memory_alloc> Enter(0x18)
@0,848,510us: [+0 T:0x4001fd00 S:0xbecd9ea4] OM - Memory_alloc> return (0xb0940)
@0,848,541us: [+0 T:0x4001fd00 S:0xbecd9ecc] OG - Global_atexit> enter (fxn=0x40620bd4)
@0,848,571us: [+6 T:0x4001fd00 S:0xbecd9ebc] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@0,848,602us: [+0 T:0x4001fd00 S:0xbecd9eac] OG - Global_atexit> enter (fxn=0x4061450c)
@0,848,632us: [+0 T:0x4001fd00 S:0xbecd9e8c] OM - Memory_alloc> Enter(0x18)
@0,848,632us: [+0 T:0x4001fd00 S:0xbecd9e8c] OM - Memory_alloc> return (0xb0980)
@0,848,663us: [+0 T:0x4001fd00 S:0xbecd9e8c] OM - Memory_alloc> Enter(0x18)
@0,848,693us: [+0 T:0x4001fd00 S:0xbecd9e8c] OM - Memory_alloc> return (0xb09a0)
@0,848,693us: [+0 T:0x4001fd00 S:0xbecd9e8c] OM - Memory_alloc> Enter(0x18)
@0,850,952us: [+0 T:0x4001fd00 S:0xbecd9e8c] OM - Memory_alloc> return (0xb09c0)
@0,851,013us: [+0 T:0x4001fd00 S:0xbecd9edc] CS - Server_init()
@0,851,043us: [+0 T:0x4001fd00 S:0xbecd9edc] CS - Server_init> Global_useLinkArbiter = 0
@0,851,074us: [+0 T:0x4001fd00 S:0xbecd9edc] OG - Global_atexit> enter (fxn=0x40611d7c)
@0,851,593us: [+1 T:0x40e7f490 S:0x40e7ed64] OP - daemon> thread created.
@0,851,623us: [+0 T:0x40e7f490 S:0x40e7ed64] OP - getCmd_d> Enter (proc=0x40e7edd8)
@0,851,654us: [+0 T:0x40e7f490 S:0x40e7ed44] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0xb06e8] timeout[0xffffffff]
Setting pipeline to PAUSED ...
/GstPipeline:pipeline0/GstAlsaSrc:alsasrc0: actual-buffer-time = 200000
/GstPipeline:pipeline0/GstAlsaSrc:alsasrc0: actual-latency-time = 10000
/GstPipeline:pipeline0/GstAlsaSrc:alsasrc0.GstPad:src: caps = audio/x-raw-int, endianness=(int)1234, signed=(boolean)true, width=(int)16, depth=(int)16, rate=(int)44100, channels=(int)2
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstAudioSrcClock
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = audio/x-raw-int, endianness=(int)1234, signed=(boolean)true, width=(int)16, depth=(int)16, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = audio/x-raw-int, endianness=(int)1234, signed=(boolean)true, width=(int)16, depth=(int)16, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstTIAudenc1:tiaudenc10.GstPad:sink: caps = audio/x-raw-int, endianness=(int)1234, signed=(boolean)true, width=(int)16, depth=(int)16, rate=(int)44100, channels=(int)2
@1,087,524us: [+0 T:0x42eb1490 S:0x42eb0c64] CE - Engine_open> Enter('codecServer', 0x0, 0x42eb0cd4)
@1,087,585us: [+0 T:0x42eb1490 S:0x42eb0c4c] OM - Memory_alloc> Enter(0x34)
@1,087,615us: [+0 T:0x42eb1490 S:0x42eb0c4c] OM - Memory_alloc> return (0xe0b98)
@1,087,646us: [+0 T:0x42eb1490 S:0x42eb0c64] CE - rserverOpen('cs.x64P'), count = 0
@1,087,646us: [+0 T:0x42eb1490 S:0x42eb0c2c] OP - Processor_create> Enter(imageName='cs.x64P', linkCfg='(null)', attrs=0x42eb0cb8)
@1,088,775us: [+0 T:0x42eb1490 S:0x42eb0c14] OM - Memory_alloc> Enter(0x24)
@1,088,806us: [+0 T:0x42eb1490 S:0x42eb0c14] OM - Memory_alloc> return (0xa6348)
@1,088,836us: [+0 T:0x42eb1490 S:0x42eb0c0c] OP - doCmd> Enter (cmdId=1, proc=0xa6348)
@1,088,867us: [+0 T:0x42eb1490 S:0x42eb0bfc] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0xb06e8]
@1,088,897us: [+0 T:0x42eb1490 S:0x42eb0c0c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0xb06e8]
@1,088,897us: [+0 T:0x42eb1490 S:0x42eb0bec] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0xb0700] timeout[0xffffffff]
@1,088,928us: [+0 T:0x40e7f490 S:0x40e7ed44] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0xb06e8] status[0]
@1,088,958us: [+0 T:0x40e7f490 S:0x40e7ed64] OP - getCmd_d> Exit (result=1)
@1,088,989us: [+0 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Enter(proc=0xa6348)
@1,089,019us: [+0 T:0x40e7f490 S:0x40e7ed44] ti.sdo.ce.ipc.Power - Power_on> Enter(handle=0xa6364)
@1,089,019us: [+2 T:0x40e7f490 S:0x40e7ed44] ti.sdo.ce.ipc.Power - Power_on> Opening Local Power Manager for the DSP on /dev/lpm0...
@1,089,111us: [+2 T:0x40e7f490 S:0x40e7ed44] ti.sdo.ce.ipc.Power - Power_on> Turning on DSP power...
@1,089,233us: [+2 T:0x40e7f490 S:0x40e7ed44] ti.sdo.ce.ipc.Power - Power_on> return (0)
@1,089,263us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Initializing DSP PROC...
@1,089,294us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'cs.x64P']
@1,089,294us: [+0 T:0x40e7f490 S:0x40e7ed4c] OM - Memory_alloc> Enter(0x1f8)
@1,089,324us: [+0 T:0x40e7f490 S:0x40e7ed4c] OM - Memory_alloc> return (0xe4200)
@1,089,355us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x87d00000, sizeInBytes=0x300000, shared=1, syncd=0
@1,089,385us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x87301000, sizeInBytes=0xff000, shared=1, syncd=0
@1,089,385us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x87300000, sizeInBytes=0x1000, shared=1, syncd=0
@1,089,416us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='L4PER', startAddress=0x49000000, sizeInBytes=0x100000, shared=0, syncd=0
@1,089,447us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Adding DSP segment #4 to Link configuration: name='IRAM', startAddress=0x5c7f8000, sizeInBytes=0x8000, shared=1, syncd=0
@1,089,477us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Adding DSP segment #5 to Link configuration: name='L1DSRAM', startAddress=0x5cf04000, sizeInBytes=0x10000, shared=1, syncd=0
@1,089,477us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Adding DSP segment #6 to Link configuration: name='DDRALGHEAP', startAddress=0x87400000, sizeInBytes=0x900000, shared=0, syncd=0
@1,089,508us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Adding DSP segment #7 to Link configuration: name='L4CORE', startAddress=0x48000000, sizeInBytes=0x1000000, shared=0, syncd=0
@1,089,538us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Found 'CMEM' entry, adjusting base and size according to CMEM_getBlock()
@1,089,569us: [+0 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Setting CMEM base to 0x86300000, size to 0x1000000
@1,089,569us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Adding DSP segment #8 to Link configuration: name='CMEM', startAddress=0x86300000, sizeInBytes=0x1000000, shared=0, syncd=0
@1,089,599us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> DODSPCTRL was=0; now=0
@1,089,630us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - LINKCFG_Object generated for PROC_setup(0x4066f574) ...
@1,089,660us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->gppObject->
@1,089,691us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "ARM9"
@1,089,721us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - maxMsgqs = 0x82
@1,089,721us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - maxChnlQueue = 0x10
@1,089,752us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - poolTableId = 0xffffffff
@1,089,752us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - numPools = 0x0
@1,089,782us: [+3 T:0x40e7f490 S:0x40e7ed04] OP -
@1,089,813us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->dspObject->
@1,089,843us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "OMAP3530"
@1,089,843us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspArch = 0x2
@1,089,874us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - loaderName = "COFF"
@1,089,874us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - autoStart = FALSE
@1,089,904us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - execName = "DEFAULT.OUT"
@1,089,935us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - doDspCtrl = DSP_BootMode_Boot_NoPwr
@1,089,935us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - resumeAddr = 0x87300020
@1,089,965us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - resetVector = 0x87300000
@1,089,965us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - resetCodeSize = 0x1000
@1,089,996us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - maduSize = 0x1
@1,090,026us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - cpuFreq = 0x6ddd0
@1,090,057us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - endian = 0x3
@1,090,057us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - wordSwap = 0x0
@1,090,087us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - memTableId = 0x0
@1,090,118us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - memEntries = 0x9
@1,090,118us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkDrvId = 0x0
@1,090,148us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg1 = 0xffffffff
@1,090,148us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg2 = 0xffffffff
@1,090,179us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg3 = 0x0
@1,090,179us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg4 = 0x0
@1,090,209us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg5 = 0xffffffff
@1,090,240us: [+3 T:0x40e7f490 S:0x40e7ed04] OP -
@1,090,240us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->linkDrvObjects->
@1,090,270us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "SHMDRV"
@1,090,270us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - hshkPollCount = 0x989680
@1,090,301us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - memEntry = 0x1
@1,090,332us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsTableId = 0x0
@1,090,332us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - numIpsEntries = 0x1
@1,090,362us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - poolTableId = 0x0
@1,090,362us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - numPools = 0x1
@1,090,393us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dataTableId = 0x0
@1,090,393us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - numDataDrivers = 0x1
@1,090,423us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - mqtId = 0x0
@1,090,454us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ringIoTableId = 0x0
@1,090,454us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - mplistTableId = 0x0
@1,090,484us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - mpcsTableId = 0x0
@1,090,515us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->memTables[0][i].
@1,090,515us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #0:
@1,090,545us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry = 0x0
@1,090,576us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "DDR2"
@1,090,576us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - physAddr = 0x87d00000
@1,090,606us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspVirtAddr = 0x87d00000
@1,090,606us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppVirtAddr = 0xffffffff
@1,090,637us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - size = 0x300000
@1,090,637us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - shared = TRUE
@1,090,667us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - syncd = FALSE
@1,090,698us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #1:
@1,090,698us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry = 0x1
@1,090,728us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "DSPLINKMEM"
@1,090,728us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - physAddr = 0x87301000
@1,090,759us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspVirtAddr = 0x87301000
@1,091,979us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppVirtAddr = 0xffffffff
@1,091,979us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - size = 0xff000
@1,092,010us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - shared = TRUE
@1,092,041us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - syncd = FALSE
@1,092,041us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #2:
@1,092,071us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry = 0x2
@1,092,071us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "RESET_VECTOR"
@1,092,102us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - physAddr = 0x87300000
@1,092,132us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspVirtAddr = 0x87300000
@1,092,132us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppVirtAddr = 0xffffffff
@1,092,163us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - size = 0x1000
@1,092,163us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - shared = TRUE
@1,092,193us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - syncd = FALSE
@1,092,224us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #3:
@1,092,224us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry = 0x3
@1,092,254us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "L4PER"
@1,092,254us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - physAddr = 0x49000000
@1,092,285us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspVirtAddr = 0x49000000
@1,092,285us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppVirtAddr = 0xffffffff
@1,092,315us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - size = 0x100000
@1,092,346us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - shared = FALSE
@1,092,346us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - syncd = FALSE
@1,092,376us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #4:
@1,092,376us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry = 0x4
@1,092,407us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "IRAM"
@1,092,407us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - physAddr = 0x5c7f8000
@1,092,437us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspVirtAddr = 0x107f8000
@1,092,468us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppVirtAddr = 0xffffffff
@1,092,468us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - size = 0x8000
@1,092,498us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - shared = TRUE
@1,092,498us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - syncd = FALSE
@1,092,529us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #5:
@1,092,529us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry = 0x5
@1,092,559us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "L1DSRAM"
@1,092,590us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - physAddr = 0x5cf04000
@1,092,590us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspVirtAddr = 0x10f04000
@1,092,620us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppVirtAddr = 0xffffffff
@1,092,620us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - size = 0x10000
@1,092,651us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - shared = TRUE
@1,092,651us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - syncd = FALSE
@1,092,681us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #6:
@1,092,712us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry = 0x6
@1,092,712us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "DDRALGHEAP"
@1,092,742us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - physAddr = 0x87400000
@1,092,742us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspVirtAddr = 0x87400000
@1,092,773us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppVirtAddr = 0xffffffff
@1,092,773us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - size = 0x900000
@1,092,803us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - shared = FALSE
@1,092,834us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - syncd = FALSE
@1,092,834us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #7:
@1,092,864us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry = 0x7
@1,092,864us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "L4CORE"
@1,092,895us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - physAddr = 0x48000000
@1,092,895us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspVirtAddr = 0x48000000
@1,092,926us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppVirtAddr = 0xffffffff
@1,092,956us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - size = 0x1000000
@1,092,956us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - shared = FALSE
@1,092,987us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - syncd = FALSE
@1,092,987us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #8:
@1,093,017us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry = 0x8
@1,093,048us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "CMEM"
@1,093,048us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - physAddr = 0x86300000
@1,093,078us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspVirtAddr = 0x86300000
@1,093,078us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppVirtAddr = 0xffffffff
@1,093,109us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - size = 0x1000000
@1,093,109us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - shared = FALSE
@1,093,139us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - syncd = FALSE
@1,093,170us: [+3 T:0x40e7f490 S:0x40e7ed04] OP -
@1,093,170us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->ipsTables[0][i].
@1,093,200us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #0:
@1,093,200us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "IPS"
@1,093,231us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - numIpsEvents = 0x20
@1,093,261us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - memEntry = 0x1
@1,093,261us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - gppIntId = 0x1a
@1,093,292us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspIntId = 0x37
@1,093,292us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - dspIntVectorId = 0x5
@1,093,322us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg1 = 0x2faf080
@1,093,322us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg2 = 0x0
@1,093,353us: [+3 T:0x40e7f490 S:0x40e7ed04] OP -
@1,093,383us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->poolTables[0][i].
@1,093,414us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->dataTables[0][i].
@1,093,414us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - entry #0:
@1,093,444us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "ZCPYDATA"
@1,093,475us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - baseChnlId = 0x0
@1,093,475us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - numChannels = 0x10
@1,093,505us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - maxBufSize = 0x4000
@1,093,505us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - memEntry = 0x1
@1,093,536us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - poolId = 0x0
@1,093,536us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - queuePerChnl = 0x1
@1,093,566us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsId = 0x0
@1,093,597us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsEventNo = 0x1
@1,093,597us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg1 = 0x0
@1,093,627us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg2 = 0x0
@1,093,658us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->mqtObjects->
@1,093,658us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "ZCPYMQT"
@1,093,688us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - memEntry = 0x1
@1,093,719us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - maxMsgSize = 0xffffffff
@1,093,719us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsId = 0x0
@1,093,750us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsEventNo = 0x0
@1,093,750us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg1 = 0x0
@1,093,780us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - arg2 = 0x0
@1,093,811us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->ringIoObjects->
@1,093,841us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "RINGIOTABLE"
@1,093,841us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - memEntry = 0x1
@1,093,872us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - maxEntries = 0x40
@1,093,872us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsId = 0x0
@1,093,902us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsEventNo = 0x2
@1,093,933us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->mplistObjects->
@1,093,963us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "MPLISTTABLE"
@1,093,963us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - memEntry = 0x1
@1,093,994us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - maxEntries = 0x40
@1,093,994us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsId = 0xffffffff
@1,094,024us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsEventNo = 0xffffffff
@1,094,055us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - linkCfg->dspConfigs[0]->mpcsObjects->
@1,094,085us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - name = "MPCS"
@1,094,085us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - memEntry = 0x1
@1,094,116us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - maxEntries = 0x100
@1,094,116us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsId = 0xffffffff
@1,094,146us: [+3 T:0x40e7f490 S:0x40e7ed04] OP - ipsEventNo = 0xffffffff
@1,094,696us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Attaching to DSP PROC...
@1,097,198us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Opening MSGQ pool...
@1,097,412us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Loading cs.x64P on DSP (1 args)...
@2,964,782us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Starting DSP PROC...
@2,988,677us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> Opening remote transport...
@2,993,469us: [+0 T:0x40e7f490 S:0x40e7ed4c] ti.sdo.ce.ipc.Power - Power_connect> Enter (handle=0xa6598)
@2,993,621us: [+2 T:0x40e7f490 S:0x40e7ed4c] ti.sdo.ce.ipc.Power - Power_connect> Calling LPM_connect to connect to the DSP power handler...
@2,993,804us: [+0 T:0x40e7f490 S:0x40e7ed4c] ti.sdo.ce.ipc.Power - Power_connect> return (0)
@2,993,927us: [+2 T:0x40e7f490 S:0x40e7ed64] OP - Processor_create_d> return (1)
@2,993,988us: [+0 T:0x40e7f490 S:0x40e7ed54] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0xb0700]
@2,994,079us: [+0 T:0x42eb1490 S:0x42eb0bec] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0xb0700] status[0]
@2,994,110us: [+0 T:0x42eb1490 S:0x42eb0c0c] OP - doCmd> Exit (result=1)
@2,994,140us: [+0 T:0x42eb1490 S:0x42eb0c2c] OP - Processor_create> return (0xa6348)
@2,994,171us: [+0 T:0x42eb1490 S:0x42eb0c64] CE - rserverOpen('cs.x64P'): 0x4066fedc done.
@2,994,201us: [+0 T:0x42eb1490 S:0x42eb0c4c] OM - Memory_alloc> Enter(0x29)
@2,994,201us: [+0 T:0x42eb1490 S:0x42eb0c4c] OM - Memory_alloc> return (0xe0bd0)
@2,994,232us: [+0 T:0x42eb1490 S:0x42eb0c3c] OC - Comm_create> Enter(queueName='codecServer_1510_0', queue=0xe0ba8, attrs=0x0)
@2,994,262us: [+0 T:0x42eb1490 S:0x42eb0c24] OM - Memory_alloc> Enter(0x4)
@2,994,293us: [+0 T:0x42eb1490 S:0x42eb0c24] OM - Memory_alloc> return (0xe03e0)
@2,994,628us: [+0 T:0x42eb1490 S:0x42eb0c3c] OC - Comm_create> return (0xe03e0)
@2,994,659us: [+0 T:0x42eb1490 S:0x42eb0c44] OM - Memory_free> Enter(0xe0bd0, 0x29)
@2,994,689us: [+0 T:0x42eb1490 S:0x42eb0c44] OM - Memory_free> return (0x1)
@2,994,720us: [+0 T:0x42eb1490 S:0x42eb0c44] OC - Comm_alloc> Enter(poolId=0x0, msg=0xe0bb4, size=1592)
@2,994,750us: [+0 T:0x42eb1490 S:0x42eb0c44] OC - Comm_alloc> msg=0x436c2880, returning (0)
@2,994,781us: [+0 T:0x42eb1490 S:0x42eb0c2c] OC - Comm_locate> Enter(queueName='rmsq', queue=0xe0ba4)
@2,995,330us: [+0 T:0x40e7f490 S:0x40e7ed64] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0xb0700]
@2,995,422us: [+0 T:0x40e7f490 S:0x40e7ed64] OP - getCmd_d> Enter (proc=0x40e7edd8)
@2,995,483us: [+0 T:0x40e7f490 S:0x40e7ed44] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0xb06e8] timeout[0xffffffff]
@2,995,635us: [+0 T:0x42eb1490 S:0x42eb0c2c] OC - Comm_locate> return (0)
@2,995,666us: [+0 T:0x42eb1490 S:0x42eb0c64] CE - checkServer(0xe0b98)
@2,995,697us: [+0 T:0x42eb1490 S:0x42eb0c34] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@2,995,758us: [+0 T:0x42eb1490 S:0x42eb0c34] OC - Comm_put> return (0)
@2,995,758us: [+0 T:0x42eb1490 S:0x42eb0c2c] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0cd0, timeout=-1)
@2,995,941us: [+0 T:0x42eb1490 S:0x42eb0c2c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@2,995,971us: [+0 T:0x42eb1490 S:0x42eb0c64] CE - rmsInit> RMS initialized(0xe0b98); CE_DEBUG on, setting DSP trace mask to *+01234567,GT_prefix=12345,GT_time=3
@2,996,002us: [+0 T:0x42eb1490 S:0x42eb0c3c] CE - Engine_setTrace> Enter(engine=0xe0b98, mask='*+01234567,GT_prefix=12345,GT_time=3')
@2,996,093us: [+1 T:0x42eb1490 S:0x42eb0c3c] CE - Engine_setTrace> Requesting DSP set trace ...
@2,996,093us: [+0 T:0x42eb1490 S:0x42eb0c0c] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@2,996,124us: [+0 T:0x42eb1490 S:0x42eb0c0c] OC - Comm_put> return (0)
@2,996,154us: [+0 T:0x42eb1490 S:0x42eb0c04] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c84, timeout=-1)
@2,998,443us: [+0 T:0x42eb1490 S:0x42eb0c04] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@2,998,504us: [+0 T:0x42eb1490 S:0x42eb0c3c] CE - Engine_setTrace> return(0)
@2,998,535us: [+4 T:0x42eb1490 S:0x42eb0c64] CE - Engine_open> engine->server = 0x4066fedc
@2,998,565us: [+0 T:0x42eb1490 S:0x42eb0bcc] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@2,998,596us: [+0 T:0x42eb1490 S:0x42eb0bcc] OC - Comm_put> return (0)
@2,998,596us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c64, timeout=-1)
@2,998,870us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @0x00000272:[T:0x00000000] server - main> Welcome to DSP server's main().
[DSP] @0,026,915tk: [+0 T:0x87f3276c S:0x87f366e4] OG - Global_setSpecialTrace> enter(mask='*+01234567,GT_prefix=12345,GT_time=3')
[DSP] @0,027,006tk: [+4 T:0x87f3276c S:0x87f366e4] OG - Global_setSpecialTrace> This program was built with the following packages:
[DSP] @0,027,083tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.targets.rts6000 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/ti/targets/rts6000/) [1, 0, 0, 0]
[DSP] @0,027,181tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.c6accel (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/c6accel_1_01_00_01/soc/packages/ti/c6accel/) [1, 0, 0]
[DSP] @0,027,273tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.aachedec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/aachedec/) [1, 0, 0]
[DSP] @0,027,376tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.aacheenc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/aacheenc/) [1, 0, 0]
[DSP] @0,027,480tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.deinterlacer (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/deinterlacer/) [1, 0, 0]
[DSP] @0,027,587tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.g711dec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/g711dec/) [1, 0, 0]
[DSP] @0,027,689tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.g711enc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/g711enc/) [1, 0, 0]
[DSP] @0,027,792tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.h264dec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/h264dec/) [1, 0, 0]
[DSP] @0,027,894tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.h264enc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]
[DSP] @0,027,997tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.jpegdec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/jpegdec/) [1, 0, 0]
[DSP] @0,028,100tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.jpegenc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/jpegenc/) [1, 0, 0]
[DSP] @0,028,202tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.mpeg2dec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0]
[DSP] @0,028,305tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.mpeg4dec (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0]
[DSP] @0,028,408tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.mpeg4enc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]
[DSP] @0,028,528tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.fc.global (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/global/) [1, 0, 0]
[DSP] @0,028,628tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.utils.trace (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/utils/trace/) [1, 0, 0]
[DSP] @0,028,730tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.xdais (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdais_6_26_01_03/packages/ti/xdais/) [1, 2.0, 1]
[DSP] @0,028,819tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.rtdx (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/dspbios_5_41_03_17/packages/ti/rtdx/) [2, 0, 0, 5]
[DSP] @0,028,908tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.psl (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/dspbios_5_41_03_17/packages/ti/psl/) [5, 0, 0, 0]
[DSP] @0,028,996tk: [+4 T:0x87f3276c @3,001,159us: [+0 T:0x42eb1490 S:0x42eb0bcc] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,001,190us: [+0 T:0x42eb1490 S:0x42eb0bcc] OC - Comm_put> return (0)
@3,001,220us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c64, timeout=-1)
@3,001,647us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
S:0x87f366e4] OG - package ti.pmi (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/dspbios_5_41_03_17/packages/ti/pmi/) [1, 0, 0, 0]
[DSP] @0,029,084tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.pscl (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/dspbios_5_41_03_17/packages/ti/pscl/) [1, 0, 0, 0]
[DSP] @0,029,172tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.bios (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/dspbios_5_41_03_17/packages/ti/bios/) [5, 2, 5, 28]
[DSP] @0,029,260tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.fc.dskt2 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/dskt2/) [1, 0, 4]
[DSP] @0,029,360tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.fc.dman3 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/dman3/) [1, 0, 4]
[DSP] @0,029,460tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.global (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/global/) [1, 0, 0]
[DSP] @0,029,557tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.xdais.dm (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdais_6_26_01_03/packages/ti/xdais/dm/) [1, 0, 5]
[DSP] @0,029,648tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.utils.xdm (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]
[DSP] @0,029,747tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.node (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/node/) [1, 0, 0]
[DSP] @0,029,842tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.ipc.dsplink.dsp (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2, 0, 1]
[DSP] @0,029,946tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.fc.memutils (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/memutils/) [1, 0, 0]
[DSP] @0,030,049tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.fc.acpy3 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/framework-components_2_25_03_07/packages/ti/sdo/fc/acpy3/) [1, 0, 4]
[DSP] @0,030,148tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package dsplink.dsp (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/dsplink_1_65_00_02/dsplink/dsp/) [1, 4, 0]
[DSP] @0,030,236tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.bios.utils (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/biosutils_1_02_02/packages/ti/bios/utils/) [2, 0, 2, 02]
[DSP] @0,030,329tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.catalog.c6000 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/ti/catalog/c6000/) [1, 0, 0, 0]
[DSP] @0,030,425tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.catalog (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/ti/catalog/) [1, 0, 0]
[DSP] @0,030,516tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.catalog.arm (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/ti/catalog/arm/) [1, 0, 1, 0]
[DSP] @0,030,610tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.platforms.evm3530 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/xdctools_3_16_03_36/packages/ti/platforms/evm3530/) [1, 0, 0]
[DSP] @0,030,709tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.osal (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/osal/) [2, 0, 2]
[DSP] @0,030,805tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.osal.bios (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/osal/bios/) [2, 0, 1]
[DSP] @0,030,905tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.ipc (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/) [2, 0, 1]
[DSP] @0,030,999tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.ipc.bios (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/bios/) [2, 0, 1]
[DSP] @0,031,097tk: [+4 T:0x87f32@3,003,906us: [+0 T:0x42eb1490 S:0x42eb0bcc] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,003,936us: [+0 T:0x42eb1490 S:0x42eb0bcc] OC - Comm_put> return (0)
@3,003,967us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c64, timeout=-1)
@3,004,119us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
76c S:0x87f366e4] OG - package ti.sdo.ce.alg (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/alg/) [1, 0, 1]
[DSP] @0,031,192tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/) [1, 0, 6]
[DSP] @0,031,282tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.bioslog (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/bioslog/) [1, 0, 1]
[DSP] @0,031,380tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.universal (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/universal/) [1, 0, 0]
[DSP] @0,031,479tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.c6accel.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/c6accel_1_01_00_01/soc/packages/ti/c6accel/ce/) [1, 0, 0]
[DSP] @0,031,574tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.audio1 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/audio1/) [1, 0, 1]
[DSP] @0,031,671tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.aachedec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/aachedec/ce/) [1, 0, 0]
[DSP] @0,031,778tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.aacheenc.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/aacheenc/ce/) [1, 0, 0]
[DSP] @0,031,883tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.deinterlacer.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/deinterlacer/ce/) [1, 0, 0]
[DSP] @0,031,993tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.speech1 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/speech1/) [1, 0, 1]
[DSP] @0,032,091tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.g711dec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/g711dec/ce/) [1, 0, 0]
[DSP] @0,032,195tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.g711enc.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/g711enc/ce/) [1, 0, 0]
[DSP] @0,032,301tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.video2 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/video2/) [1, 0, 2]
[DSP] @0,032,398tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.h264dec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0]
[DSP] @0,032,503tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.video1 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/video1/) [1, 0, 2]
[DSP] @0,032,600tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.h264enc.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]
[DSP] @0,032,705tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.ce.image1 (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codec-engine_2_26_01_09/packages/ti/sdo/ce/image1/) [1, 0, 1]
[DSP] @0,032,802tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.jpegdec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/jpegdec/ce/) [1, 0, 0]
[DSP] @0,032,908tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.jpegenc.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/jpegenc/ce/) [1, 0, 0]
[DSP] @0,033,013tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.mpeg2dec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0]
[DSP] @0,033,122tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.mpeg4dec.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00@3,006,439us: [+0 T:0x42eb1490 S:0x42eb0bcc] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,006,469us: [+0 T:0x42eb1490 S:0x42eb0bcc] OC - Comm_put> return (0)
@3,006,500us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c64, timeout=-1)
@3,008,666us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @0,033,229tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.codecs.mpeg4enc.ce (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]
[DSP] @0,033,335tk: [+4 T:0x87f3276c S:0x87f366e4] OG - package ti.sdo.server.cs (/home/berkant/ti-dvsdk_dm3730-evm_4_00_00_22/codecs-omap3530_4_00_00_00/packages/ti/sdo/server/cs/) [1, 0, 0]
[DSP] @0,033,435tk: [+0 T:0x87f3276c S:0x87f366e4] OG - Global_setSpecialTrace> return
[DSP] @0,034,591tk: [+0 T:0x87f3276c S:0x87f3672c] CR - processRmsCmd(0x873048a8, 4056): cmd = 5
[DSP] @0,034,655tk: [+0 T:0x87f3276c S:0x87f3672c] CR - remote time = 0x0, trace buffer size = 4032
[DSP] @0,042,702tk: [+0 T:0x87f3276c S:0x87f3672c] CR - processRmsCmd(0x873048a8, 4056): cmd = 5
[DSP] @0,042,770tk: [+0 T:0x87f3276c S:0x87f3672c] CR - remote time = 0x0, trace buffer size = 4032
[DSP] @0,051,314tk: [+0 T:0x87f3276c S:0x87f3672c] CR - processRmsCmd(0x873048a8, 4056): cmd = 5
[DSP] @0,051,379tk: [+0 T:0x87f3276c S:0x87f3672c] CR - remote time = 0x0, trace buffer size = 4032
[DSP] @0,059,226tk: [+0 T:0x87f3276c S:0x87f3672c] CR - processRmsCmd(0x873048a8, 4056): cmd = 5
[DSP] @0,059,291tk: [+0 T:0x87f3276c S:0x87f3672c] CR - remote time = 0x0, trace buffer size = 4032
@3,009,429us: [+0 T:0x42eb1490 S:0x42eb0bfc] CE - Engine_fwriteTrace> returning count [13849]
@3,009,490us: [+0 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer(0xe0b98)
@3,009,521us: [+0 T:0x42eb1490 S:0x42eb0bf4] CE - Engine_getNumServerAlgs(0xe0b98 0x42eb0c70)
@3,009,552us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,009,582us: [+0 T:0x42eb1490 S:0x42eb0bc4] OC - Comm_put> return (0)
@3,009,582us: [+0 T:0x42eb1490 S:0x42eb0bbc] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c3c, timeout=-1)
@3,009,674us: [+0 T:0x42eb1490 S:0x42eb0bbc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,009,704us: [+0 T:0x42eb1490 S:0x42eb0bf4] CE - Engine_getNumServerAlgs number of server algs = 13
@3,009,704us: [+0 T:0x42eb1490 S:0x42eb0bf4] CE - Engine_getNumServerAlgs exit 0
@3,009,735us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Number of remote algs statically configured in engine: 12
@3,009,765us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Allocating descriptor array for [13] server algs
@3,009,765us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x270)
@3,009,796us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xdb800)
@3,009,826us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Initializing descriptor array for [13] server algs
@3,009,857us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [0]
@3,009,857us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,009,887us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,009,918us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,010,009us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,010,009us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,010,040us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcc8e8)
@3,010,070us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,010,070us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed2f0)
@3,010,101us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1f)
@3,010,131us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcbb58)
@3,010,131us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for UNIVERSAL_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,010,162us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [1]
@3,010,192us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,010,223us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,010,223us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,010,314us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,010,345us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x9)
@3,010,345us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0x166b0)
@3,010,375us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,010,375us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xdba78)
@3,010,406us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1a)
@3,010,437us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xdfbd8)
@3,010,437us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for AUDDEC1_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,010,467us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [2]
@3,010,498us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,010,528us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,010,528us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,010,620us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,010,620us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x9)
@3,010,650us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xe0bd0)
@3,010,681us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,010,681us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xe0be0)
@3,010,711us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1a)
@3,010,711us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xa65d0)
@3,010,742us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for AUDENC1_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,010,772us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [3]
@3,010,772us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,010,803us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,010,833us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,010,894us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,010,925us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x4)
@3,010,955us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xe0bf0)
@3,010,955us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,010,986us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xa65f0)
@3,010,986us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1f)
@3,011,016us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xdf960)
@3,011,047us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for UNIVERSAL_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,011,077us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [4]
@3,011,077us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,011,108us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,011,138us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,011,199us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,011,230us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,011,230us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xdf988)
@3,011,260us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,011,291us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xa6600)
@3,011,291us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1b)
@3,011,322us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xdf998)
@3,011,352us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for SPHDEC1_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,011,352us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [5]
@3,011,383us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,011,413us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,011,444us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,011,505us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,011,505us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,011,535us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xa6610)
@3,011,566us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,011,566us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcc600)
@3,011,596us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1b)
@3,011,627us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcc610)
@3,011,627us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for SPHENC1_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,011,657us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [6]
@3,011,688us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,011,718us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,011,749us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,011,810us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,011,840us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,011,840us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcc630)
@3,011,871us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,011,901us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcc640)
@3,011,901us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1a)
@3,011,932us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcc650)
@3,011,932us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for VIDDEC2_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,011,962us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [7]
@3,011,993us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,012,023us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,012,023us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,012,115us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,012,115us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,012,145us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcc670)
@3,012,176us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,012,176us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed700)
@3,012,207us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1a)
@3,012,207us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed710)
@3,012,237us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for VIDENC1_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,012,268us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [8]
@3,012,268us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,012,298us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,012,329us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,012,390us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,012,420us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,012,451us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed730)
@3,012,451us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,012,481us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed740)
@3,012,512us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1a)
@3,012,512us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed750)
@3,012,542us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for IMGDEC1_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,012,573us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [9]
@3,012,573us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,012,603us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,012,634us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,012,695us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,012,725us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,012,725us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed770)
@3,012,756us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,012,969us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed780)
@3,013,000us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1a)
@3,013,031us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed790)
@3,013,031us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for IMGENC1_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,013,061us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [10]
@3,013,092us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,013,122us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,013,122us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,014,831us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,014,892us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x9)
@3,014,923us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed7b0)
@3,014,923us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,014,953us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed7c0)
@3,015,045us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1a)
@3,015,075us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed7d0)
@3,015,106us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for VIDDEC2_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,015,136us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [11]
@3,015,136us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,015,167us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,015,197us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,015,380us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,015,411us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x9)
@3,015,411us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xed7f0)
@3,015,441us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,015,472us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcb830)
@3,015,472us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1a)
@3,015,502us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcb840)
@3,015,502us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for VIDDEC2_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,015,533us: [+2 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Sending RMS_GETALG command for alg [12]
@3,015,563us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> Enter(queue=0x0, msg=0x436c2880)
@3,015,594us: [+0 T:0x42eb1490 S:0x42eb0bec] OC - Comm_put> return (0)
@3,015,625us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> Enter(queue=0x10000, msg=0x42eb0c74, timeout=-1)
@3,015,686us: [+0 T:0x42eb1490 S:0x42eb0be4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@3,015,716us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x9)
@3,015,747us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcb860)
@3,015,747us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x8)
@3,015,777us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcb870)
@3,015,777us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> Enter(0x1a)
@3,015,808us: [+0 T:0x42eb1490 S:0x42eb0c04] OM - Memory_alloc> return (0xcb880)
@3,015,838us: [+5 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Warning: No stub functions were found for VIDENC1_STUBS. The algorithm that requires these stub functions cannot be run remotely.
@3,015,838us: [+0 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer engine->server = 0x4066fedc
@3,015,869us: [+0 T:0x42eb1490 S:0x42eb0c1c] CE - Engine_initFromServer> Returning 0
@3,015,899us: [+0 T:0x42eb1490 S:0x42eb0c64] CE - Engine_open> return(920472)
@3,015,960us: [+0 T:0x42eb1490 S:0x42eb0bbc] ti.sdo.ce.audio1.AUDENC1 - AUDENC1_create> Enter (engine=0xe0b98, name='aacheenc', params=0x42eb0d98)
@3,015,991us: [+0 T:0x42eb1490 S:0x42eb0b8c] CV - VISA_create(0xe0b98, 'aacheenc', 0x42eb0d98, 0x480, 'ti.sdo.ce.audio1.IAUDENC1')
@3,015,991us: [+0 T:0x42eb1490 S:0x42eb0a84] CV - VISA_create2(0xe0b98, 'aacheenc', 0x42eb0d98, 0x34, 0x480, 'ti.sdo.ce.audio1.IAUDENC1')
@3,016,052us: [+6 T:0x42eb1490 S:0x42eb0a84] CV - VISA_create2> FAILED to get IALG functions.
Check Engine configuration and module name of codec class (type arg).
@3,016,052us: [+0 T:0x42eb1490 S:0x42eb0a5c] CV - VISA_delete(0x0)
@3,016,082us: [+0 T:0x42eb1490 S:0x42eb0bbc] ti.sdo.ce.audio1.AUDENC1 - AUDENC1_create> return (0x0)
@3,016,082us: [+7 T:0x42eb1490 S:0x42eb0be4] ti.sdo.dmai - [Aenc1] Failed to open audio encode algorithm: aacheenc
ERROR: from element /GstPipeline:pipeline0/GstTIAudenc1:tiaudenc10: Failed to create audio encoder: aacheenc
Additional debug info:
gsttiaudenc1.c(1017): gst_tiaudenc1_codec_start (): /GstPipeline:pipeline0/GstTIAudenc1:tiaudenc10
Execution ended after 1942291261 ns.
Setting pipeline to READY ...
/GstPipeline:pipeline0/GstTIAudenc1:tiaudenc10.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstAlsaSrc:alsasrc0.GstPad:src: caps = NULL
@3,023,895us: [+0 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> enter
@3,023,956us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x40611d7c()...
@3,024,017us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x4061450c()...
@3,024,047us: [+0 T:0x42eb1490 S:0x42eb082c] OM - Memory_free> Enter(0xb0980, 0x18)
@3,024,078us: [+0 T:0x42eb1490 S:0x42eb082c] OM - Memory_free> return (0x1)
@3,024,078us: [+0 T:0x42eb1490 S:0x42eb082c] OM - Memory_free> Enter(0xb09a0, 0x18)
@3,024,108us: [+0 T:0x42eb1490 S:0x42eb082c] OM - Memory_free> return (0x1)
@3,024,139us: [+0 T:0x42eb1490 S:0x42eb082c] OM - Memory_free> Enter(0xb09c0, 0x18)
@3,024,139us: [+0 T:0x42eb1490 S:0x42eb082c] OM - Memory_free> return (0x1)
@3,024,169us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x40620bd4()...
@3,024,169us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x40618014()...
@3,024,200us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x4061e280()...
@3,024,230us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x4061b990()...
@3,024,230us: [+0 T:0x42eb1490 S:0x42eb0834] OP - doCmd> Enter (cmdId=3, proc=0x0)
@3,024,261us: [+0 T:0x42eb1490 S:0x42eb0824] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0xb06e8]
@3,024,291us: [+0 T:0x42eb1490 S:0x42eb0834] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0xb06e8]
@3,024,322us: [+0 T:0x42eb1490 S:0x42eb0814] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0xb0700] timeout[0xffffffff]
@3,024,353us: [+0 T:0x40e7f490 S:0x40e7ed44] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0xb06e8] status[0]
@3,024,383us: [+0 T:0x40e7f490 S:0x40e7ed64] OP - getCmd_d> Exit (result=3)
@3,024,414us: [+0 T:0x40e7f490 S:0x40e7ed54] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0xb0700]
@3,024,444us: [+0 T:0x42eb1490 S:0x42eb0814] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0xb0700] status[0]
@3,024,444us: [+0 T:0x42eb1490 S:0x42eb0834] OP - doCmd> Exit (result=1)
@3,024,475us: [+0 T:0x42eb1490 S:0x42eb083c] OT - Thread_delete> Enter (task=0xb0738)
@3,024,658us: [+4 T:0x42eb1490 S:0x42eb083c] OT - Thread_delete> pthread_cancel (0x0)
@3,025,238us: [+4 T:0x42eb1490 S:0x42eb083c] OT - Thread_delete> pthread_join (0x0)
@3,025,299us: [+0 T:0x42eb1490 S:0x42eb081c] OM - Memory_free> Enter(0xb0738, 0x64)
@3,025,299us: [+0 T:0x42eb1490 S:0x42eb081c] OM - Memory_free> return (0x1)
@3,025,329us: [+0 T:0x42eb1490 S:0x42eb0854] OT - Thread_delete> Exit (task=0xb0738)
@3,025,360us: [+0 T:0x42eb1490 S:0x42eb0844] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0xb06e8]
@3,025,360us: [+0 T:0x42eb1490 S:0x42eb0824] OM - Memory_free> Enter(0xb06e8, 0x14)
@3,025,390us: [+0 T:0x42eb1490 S:0x42eb0824] OM - Memory_free> return (0x1)
@3,025,390us: [+0 T:0x42eb1490 S:0x42eb0854] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
@3,025,421us: [+0 T:0x42eb1490 S:0x42eb0844] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0xb0700]
@3,025,451us: [+0 T:0x42eb1490 S:0x42eb0824] OM - Memory_free> Enter(0xb0700, 0x14)
@3,025,451us: [+0 T:0x42eb1490 S:0x42eb0824] OM - Memory_free> return (0x1)
@3,025,482us: [+0 T:0x42eb1490 S:0x42eb0854] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
@3,025,482us: [+0 T:0x42eb1490 S:0x42eb0834] OM - Memory_free> Enter(0xb0718, 0x18)
@3,025,512us: [+0 T:0x42eb1490 S:0x42eb0834] OM - Memory_free> return (0x1)
@3,025,512us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x4061d438()...
@3,025,543us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x406206e4()...
@3,025,573us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x4061dd34()...
@3,025,573us: [+0 T:0x42eb1490 S:0x42eb0844] OM - Memory_free> Enter(0xb0678, 0x18)
@3,025,604us: [+0 T:0x42eb1490 S:0x42eb0844] OM - Memory_free> return (0x1)
@3,025,604us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x4061ef08()...
@3,025,665us: [+0 T:0x42eb1490 S:0x42eb0834] OM - Memory_free> Enter(0xb0608, 0x18)
@3,025,665us: [+0 T:0x42eb1490 S:0x42eb0834] OM - Memory_free> return (0x1)
@3,025,695us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x40621080()...
@3,025,695us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x40621c34()...
@3,025,726us: [+2 T:0x42eb1490 S:0x42eb0864] OG - Global_exit> calling function *0x40620fe0()...
I got the same warning while running gstreamer pipeline for AAC decode, but the pipeline runs without any errors.
This program was built with the following packages: (the 1st line of gst pipeline debug)
I noticed that "package ti.sdo.codecs"aacheenc" is missing. Although codecs, dmai make process done with no errors, could be the reason of error "CV - VISA_create2> FAILED to get IALG functions."
I'll appriciate any help.
Thank you.
