Need direction on adding SysBios to existing project
Guru 20075 points
Can someone give me direction on how to add SysBios to an existing project.
I mainly want to create task - some that are timed and some that are initiated by ISRs.  Can someone point me in a direction that will quickly get me up to speed in learning that portion of the SysBios.
Stephen
  • Hi Stephen,
    SYS/BIOS ships with examples. That's probably your best place to get started. Take a look at the SYS/BIOS "Getting Started Guide" for more details.
    Todd
  • Hello Todd,
    Thanks for the reply.  I am using CCS4.2.5.
    I didn't see anything in the SYS/BIOS "Getting Started Guide" that describes how to add Sys/Bios to an existing project.
    When I tried to add DSP/BIOS v5.x configuration file, a dialog box displayed showing "The selected project does not have DSP/BIOS support".
    Stephen
  • Are you wanting to use DSP/BIOS or SYS/BIOS? and which version do you want to use?
    If you want to use DSP/BIOS, look at the <dspbios_install_dir>/docs/SetupGuide.html.
    If you want to use SYS/BIOS, look at the <sysbios_install_dir>/docs/Bios_Getting_Started_Guide.pdf.
    Todd
