I have build link API demos provided with DVRRDK_03.00.00.00 for DM8148 EVM.
I am trying running one of the link API's (VideoM3 local loopBack) demo on DM8148 EVM.
But this demo stuck at some point.
I am attaching logs of this demo.
./iniroot@dm814x:/opt/dvr_rdk/ti814x# ./init.sh *** Bootargs Validated for mem param *** *** Bootargs Validated for notifyk.vpssm3 params *** Kernel bootargs validated numid=1,iface=MIXER,name='PCM Playback Volume' ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0 : values=127,127 | dBscale-min=-63.50dB,step=0.50dB,mute=0 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 SysLink version : 2.10.02.17 SysLink module created on Date:Dec 5 2012 Time:16:07:28 Trace enabled Trace SetFailureReason enabled Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 ) Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a ) *** TVP5158 probe : START *** TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e TI DVR : TVP5158 device address : 0x58, 0x59, 0x5a, 0x5b Device found : I2C (0xXX): 0x08 = 0x51 I2C (0xXX): 0x09 = 0x58 Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2) *******************instId: 3 deviname: /dev/i2c-3 device opened success I2C (0x58): Read ERROR !!! (reg[0x08], count = 2) *******************instId: 3 deviname: /dev/i2c-3 device opened success I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2) *******************instId: 3 deviname: /dev/i2c-3 device opened success I2C (0x5c): 0x08 = 0x02 I2C (0x5c): 0x09 = 0x80 *******************instId: 3 deviname: /dev/i2c-3 device opened success I2C (0x5e): Read ERROR !!! (reg[0x08], count = 2) *******************instId: 3 deviname: /dev/i2c-3 device opened success I2C (0x59): Read ERROR !!! (reg[0x08], count = 2) *******************instId: 3 deviname: /dev/i2c-3 device opened success I2C (0x5b): Read ERROR !!! (reg[0x08], count = 2) *** TVP5158 probe : END *** /opt/dvr_rdk/ti814x root@dm814x:/opt/dvr_rdk/ti814x# ./loroot@dm814x:/opt/dvr_rdk/ti814x# ./load.sh Attached to slave procId 2. Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2. Started slave procId 2. After Ipc_loadcallback status [0x00000000] [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 240000000 [m3vpss ] notify_attach rtnVal 0 [m3vpss ] initProxyServer rtnVal 0 [m3vpss ] [m3vpss ] *** UTILS: CPU KHz = 480000 Khz *** [m3vpss ] [m3vpss ] 54: SYSTEM : System Common Init in progress !!! [m3vpss ] 54: SYSTEM: IPC init in progress !!! [m3vpss ] 54: SYSTEM: Attaching to [HOST] ... [m3vpss ] 1053: SYSTEM: Attaching to [HOST] ... [m3vpss ] 1055: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3vpss ] 1055: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x097d2000] Attached to slave procId 1. Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1. Started slave procId 1. After Ipc_loadcallback status [0x00000000] [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 240000000 [m3vpss ] 2055: SYSTEM: Attaching to [DSP] ... [m3video] [m3video] *** UTILS: CPU KHz = 480000 Khz *** [m3video] [m3video] 1328: SYSTEM : System Common Init in progress !!! [m3video] 1328: SYSTEM: IPC init in progress !!! [m3video] 1328: SYSTEM: Attaching to [HOST] ... [m3video] 2328: SYSTEM: Attaching to [HOST] ... [m3video] 2330: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3video] 2330: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x00000000] Attached to slave procId 0. Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0. Started slave procId 0. After Ipc_loadcallback status [0x00000000] [c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 750000000 [m3video] 3330: SYSTEM: Attaching to [DSP] ... [m3vpss ] 3055: SYSTEM: Attaching to [DSP] ... [c6xdsp ] [c6xdsp ] *** UTILS: CPU KHz = 750000 Khz *** [c6xdsp ] [c6xdsp ] 1: SYSTEM : System Common Init in progress !!! [c6xdsp ] 1: SYSTEM: IPC init in progress !!! [c6xdsp ] 1: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1000: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1003: SYSTEM: Attaching to [HOST] .DMA: Module install successful, device major num = 251 .. SUCCESS !!! DRV: Module install successful [c6xdsp ] 1003DRV: Module built on Dec 14 2012 18:36:33 : SYSTEM: Attaching to [VIDEO-M3] ... After Ipc_startcallback status [0x00000000] [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [m3vpss ] 4055: SYSTEM: Attaching to [DSP] ... [m3video] 4330: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2002: SYSTEM: Attaching to [VIDEO-M3] ... [m3vpss ] 5055: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2848: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3video] 5330: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2848: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 5330: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3video] 5330: SYSTEM: Attaching to [VPSS-M3] ... [m3vpss ] 6055: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 3847: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 6330: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 4574: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 7055: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 4574: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 7056: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3vpss ] 7056: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 7330: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 5573: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 8056: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 8055: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 8056: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 8056: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3vpss ] 8056: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 8056: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ... [m3vpss ] 8057: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ... [m3vpss ] 8058: SYSTEM: Notify register to [HOST] line 0, event 15 ... [m3vpss ] 8059: SYSTEM: Notify register to [DSP] line 0, event 15 ... [m3vpss ] 8059: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... [m3vpss ] 8059: SYSTEM: IPC init DONE !!! [m3vpss ] 8067: MEM: Shared Region 2: Base = 0xb3800000, Length = 0x0b800000 (184 MB) [m3vpss ] 8067: MEM: Shared Region 1: Base = 0x88000000, Length = 0x05400000 (84 MB) [m3vpss ] 8069: SYSTEM : System Common Init Done !!! [m3vpss ] 8069: SYSTEM : System VPSS Init in progress !!! [m3vpss ] === I2C0/2 Clk is active === [m3vpss ] 8088: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ... [m3vpss ] 8088: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ... [m3vpss ] 8088: SYSTEM: ListElem Shared Addr = 0xbf08b680 [m3vpss ] 8090: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ... [m3vpss ] 8091: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ... [m3vpss ] 8091: SYSTEM: ListElem Shared Addr = 0xbf08eb80 [m3vpss ] 8103: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ... [m3vpss ] 8103: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ... [m3vpss ] 8103: SYSTEM: ListElem Shared Addr = 0xbf092080 [m3vpss ] 8106: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ... [m3vpss ] 8106: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ... [m3vpss ] 8106: SYSTEM: ListElem Shared Addr = 0xbf0b1a80 [m3vpss ] 8109: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ... [m3vpss ] 8109: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ... [m3vpss ] 8109: SYSTEM: ListElem Shared Addr = 0xbf0d1480 [m3vpss ] 8111: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37 [m3vpss ] 8111: SYSTEM : FVID2 Init in progress !!! [m3vpss ] 8175: SYSTEM : FVID2 Init in progress DONE !!! [m3vpss ] 8175: SYSTEM : Device Init in progress !!! [m3vpss ] initPrms.isI2cInitReq = 0 [m3vpss ] initPrms.isI2cInitReq = 0 [m3vpss ] 8266: SYSTEM : Device Init in progress DONE !!! [m3vpss ] 8405: SYSTEM : System VPSS Init Done !!! [m3vpss ] 8405: UTILS: DMA: HWI Create for INT63 !!! [m3vpss ] 8405: SYSTEM : Initializing Links !!! [m3vpss ] 8405: SYSTEM : FREE SPACE : System Heap = 189312 B, Mbx = 10240 msgs) [m3vpss ] 8405: SYSTEM : FREE SPACE : SR0 Heap = 8189824 B (7 MB) [m3vpss ] 8406: SYSTEM : FREE SPACE : Frame Buffer = 188627840 B (179 MB) [m3vpss ] 8406: SYSTEM : FREE SPACE : Bitstream Buffer = 88080256 B (83 MB) [m3vpss ] 8406: SYSTEM : FREE SPACE : Tiler 8-bit = 38797312 B (37 MB) - TILER ON [m3vpss ] 8406: SYSTEM : FREE SPACE : Tiler 16-bit = 18874368 B (18 MB) - TILER ON [m3vpss ] Received character 's' [m3vpss ] 8495: SYSTEM : Initializing Links ... DONE !!! [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [m3vpss ] 8495: SYSTEM : Set Static L3 pressure for HDVPSS as High [c6xdsp ] 6573: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 9056: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [c6xdsp ] 6574: SYSTEM: Creating MsgQ [DSP_MSGQ] ... [m3video] 9056: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ... [c6xdsp ] 6574: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ... [m3video] 9057: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ... [c6xdsp ] 6574: SYSTEM: Notify register to [HOST] line 0, event 15 ... [m3video] 9058: SYSTEM: Notify register to [HOST] line 0, event 15 ... [c6xdsp ] 6574: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... [m3video] 9058: SYSTEM: Notify register to [DSP] line 0, event 15 ... [c6xdsp ] 6574: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... [m3video] 9059: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... [c6xdsp ] 6574: SYSTEM: IPC init DONE !!! [m3video] 9059: SYSTEM: IPC init DONE !!! [c6xdsp ] 6577: MEM: Shared Region 2: Base = 0xb3800000, Length = 0x0b800000 (184 MB) [c6xdsp ] 6577: MEM: Shared Region 1: Base = 0x88000000, Length = 0x05400000 (84 MB) [m3video] 9067: MEM: Shared Region 2: Base = 0xb3800000, Length = 0x0b800000 (184 MB) [c6xdsp ] 6577: SYSTEM : System Common Init Done !!! [m3video] 9067: MEM: Shared Region 1: Base = 0x88000000, Length = 0x05400000 (84 MB) [c6xdsp ] 6576: SYSTEM : System DSP Init in progress !!! [c6xdsp ] 6577: SYSTEM : RpeServer_init() done... Ret Val 0!!! [c6xdsp ] 6581: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ... [c6xdsp ] 6581: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ... [c6xdsp ] 6581: SYSTEM: ListElem Shared Addr = 0xbf0f0e80 [c6xdsp ] 6582: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ... [c6xdsp ] 6582: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ... [c6xdsp ] 6582: SYSTEM: ListElem Shared Addr = 0xbf110880 [c6xdsp ] 6583: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ... [c6xdsp ] 6583: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ... [c6xdsp ] 6583: SYSTEM: ListElem Shared Addr = 0xbf130280 [c6xdsp ] 6584: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ... [m3video] 9069: SYSTEM : System Common Init Done !!! [c6xdsp ] 6584: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ... [c6xdsp ] 6584: SYSTEM: ListElem Shared Addr = 0xbf14fc80 [c6xdsp ] 6585: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ... [m3video] 9070: SYSTEM : System Video Init in progress !!! [c6xdsp ] 6585: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ... [c6xdsp ] 6585: SYSTEM: ListElem Shared Addr = 0xbf16d780 [c6xdsp ] !!WARNING.Resource already registered:2 [c6xdsp ] 6585: SYSTEM : Initializing Links !!! [m3video] 9070: SYSTEM : System Video Init Done !!! [c6xdsp ] 6586: SYSTEM : FREE SPACE : System Heap = 6270752 B, Mbx = 10240 msgs) [m3video] 9070: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ... [m3video] 9070: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ... [m3video] 9071: SYSTEM: ListElem Shared Addr = 0xbf18b280 [m3video] 9073: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ... [m3video] 9073: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ... [m3video] 9073: SYSTEM: ListElem Shared Addr = 0xbf18e780 [m3video] 9079: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ... [m3video] 9079: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ... [m3video] 9080: SYSTEM: ListElem Shared Addr = 0xbf191c80 [c6xdsp ] 6597: SYSTEM : Initializing Links ... DONE !!! [m3video] 9082: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ... [m3video] 9082: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ... [c6xdsp ] 6597: SYSTEM : System DSP Init Done !!! [m3video] 9082: SYSTEM: ListElem Shared Addr = 0xbf1b1680 [m3video] 9085: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ... [m3video] 9085: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ... [m3video] 9085: SYSTEM: ListElem Shared Addr = 0xbf1d1080 [m3video] 9097: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ... [m3video] 9097: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ... [m3video] 9097: SYSTEM: ListElem Shared Addr = 0xbf1f0a80 [m3video] 9100: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ... [m3video] 9100: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ... [m3video] 9100: SYSTEM: ListElem Shared Addr = 0xbf20e580 [m3video] 9102: HDVICP: Doing PRCM for IVAHD[0] ... [m3video] 9102: HDVICP: PRCM for IVAHD[0] ... DONE. [m3video] 9102: SYSTEM : Initializing Links !!! [m3video] Received character 's' [m3video] 9103: SYSTEM : FREE SPACE : System Heap = 6280328 B, Mbx = 10240 msgs) [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [c6xdsp ] Received character 's' /opt/dvr_rdk/ti814x [m3video] 9103: SYSTEM : FREE SPACE : SR0 Heap = 6899072 B (6 MB) [module] vpss probe done. [m3video] 9103: SYSTEM : FREE SPACE : Frame Buffer = 188627840 B (179 MB) [m3video] 9103: SYSTEM : FREE SPACE : Bitstream Buffer = 88080256 B (83 MB) [m3video] 9103: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... [m3video] 9104: SYSTEM : FREE SPACE : Tiler 8-bit = 38797312 B (37 MB) - TILER ON [m3video] 9105: SYSTEM : FREE SPACE : Tiler 16-bit = 18874368 B (18 MB) - TIL[module] ti81xxfb probe done. ER ON [m3video] 9128: SYSTEM : Initializing Links ... DONE !!! HDMI W1 rev 4.0 HDMI CEC Spec version 1.2 [module] ti81xx_hdmi probe done. ## Interface is 1 [0:DVI, 1:HDMI] ORG 0x46c00524: 0 NEW 0x46c00524: 2 root@dm814x:/opt/dvr_rdk/ti814x# ./biroot@dm814x:/opt/dvr_rdk/ti814x# ./bin/dvroot@dm814x:/opt/dvr_rdk/ti814x# ./bin/dvr_rdk_demo_liroot@dm814x:/opt/dvr_rdk/ti814x# ./bin/dvr_rdk_demo_link_api.out 0: SYSTEM: System Common Init in progress !!! 0: SYSTEM: IPC init in progress !!! 9: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... 11: SYSTEM: Creating MsgQ [HOST_MSGQ] ... 12: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ... 13: SYSTEM: Opening MsgQ [DSP_MSGQ] ... 13: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ... 14: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... 15: SYSTEM: Notify register to [DSP] line 0, event 15 ... 15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... 15: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... 16: SYSTEM: IPC init DONE !!! 17: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ... 18: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ... 20: SYSTEM: ListElem Shared Addr = 0x405ed080 20: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ... 22: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ... 23: SYSTEM: ListElem Shared Addr = 0x4060ab80 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ... 26: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ... 28: SYSTEM: ListElem Shared Addr = 0x40628680 28: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ... 30: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ... 31: SYSTEM: ListElem Shared Addr = 0x40648080 32: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ... 34: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ... 35: SYSTEM: ListElem Shared Addr = 0x40667a80 54: SYSTEM: System Common Init Done !!! ============ Chain Select ============ Current System Settings, NSF Mode : SNF + TNF 1: Multi CH Capture + NSF + DEI + Display (16CH 4x TVP5158, NTSC, YUV422I ) 2: Multi CH Src + Enc + Dec + Snk (VideoM3 chain) (VideoM3 local loopBack) 3: Multi CH Cap + NF + Enc + Dec + SW (DEI/H,SC5) + Disp (16CH Cap+Enc+Dec+Disp, Interlace Enc/Dec) 4: Multi CH Cap + NF + DEI/H + Enc + Dec + SW (SC5) + Disp (16CH Cap+Enc+Dec+Disp, Progressive Enc/Dec) s: System Settings x: Exit Enter Choice: 2 3290: CHAINS : CPU Revision [ES2.1] !!! 3290: CHAINS : Detected [UNKNOWN] Board !!! 3290: CHAINS : Base Board Revision [REV A] !!! [host] CHAINS:Enable file write :(y -- yes/n -- no):n [host] CHAINS_IPCBITS:Chains_ipcBitsSendFxn:Entered... [host] CHAINS_IPCBITS:Chains_ipcBitsRecvFxn:Entered...waiting************************************ [m3vpss ] 20712: NULL_SRC: Create in progress !!! [m3vpss ] 20718: NULL_SRC: Create Done !!! [host] CHAINS_IPCBITS:Chains_ipcBitsSendFxn:INFO: periodic print.. [m3video] 20720: IPC_IN_M3 : Create in progress !!! [m3vpss ] 20719: IPC_OUT_M3 : Create in progress !!! [m3video] 20721: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ... [m3vpss ] 20720: IPC_OUT_M3 : Create Done !!! [m3video] 20721: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ... [m3video] 20724: IPC_IN_M3 : Create Done !!! [m3video] 20724: ENCODE: Create in progress ... !!! [m3video] 20831: ENCODE: Creating CH0 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:13808 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20835: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20839: ENCODE: Creating CH2 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [host] IpcBitsInLink_tskMain:Entered [host] 4858: IPC_BITS_IN : Create in progress !!! [host] 4858: IPC_BITS_IN : ListMPOpen start !!! [host] 4859: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ... 4860: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ... [host] 4861: IPC_BITS_IN : ListMPOpen done !!! [host] 4864: IPC_BITS_IN : System_linkGetInfo done !!! [host] 4864: IPC_BITS_IN : Create Done !!! [host] 4864: IPC_BITS_OUT : Create in progress !!! ###Bit buff of size from the SR # 1 : 39813120 [host] IPC_BITSOUT:BitBuffer Alloc.PoolID:0,Size:0x25F8000 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4206f080 To Phy:0x892fc080 [host] 4865: IPC_BITS_OUT : Create Done !!! [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20842: ENCODE: Creating CH3 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20845: ENCODE: Creating CH4 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... 4904:!!!SLAVE CORE [VIDEO-M3] DOWN!!! SystemLink_copySlaveCoreExceptionContext:146 mmap of [0xbf8c0000:36864] mmap virt addresss:0x4005a000 munmap of [0x4005a000:36864] SystemLink_copySlaveCoreExceptionContext:153 [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3vpss ] 20931:WARN [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3vpss ] 20931:TILER AllocFailed:CntMode:1,Width=896,Height=336 [m3video] 20849: ENCODE: Creating CH5 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20852: ENCODE: Creating CH6 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20855: ENCODE: Creating CH7 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20859: ENCODE: Creating CH8 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20862: ENCODE: Creating CH9 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20865: ENCODE: Creating CH10 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20869: ENCODE: Creating CH11 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20872: ENCODE: Creating CH12 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20875: ENCODE: Creating CH13 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20879: ENCODE: Creating CH14 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20882: ENCODE: Creating CH15 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:45056 [m3video] 20885: ENCODE: All CH Create ... DONE !!! [m3video] ENCLINK:HEAPID:0 USED:192528 [m3video] ENCLINK:HEAPID:2 USED:19906560 [m3video] ENCLINK:HEAPID:3 USED:720896 [m3video] 20886: ENCODE: Create ... DONE !!! [m3video] 20887: IPC_BITS_OUT : Create in progress !!! [m3video] 20889: IPC_BITS_OUT : Create Done !!! [m3video] 20897: IPC_BITS_IN : Create in progress !!! [m3video] 20897: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ... [m3video] 20897: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ... [m3video] 20898: SYSTEM: Opening MsgQ [HOST_MSGQ] ... [m3video] 20901: IPC_BITS_IN : Create Done !!! [m3video] 20902: DECODE: Create in progress ... !!! [m3video] DECLINK_H264:HEAPID:0 USED:2368 [m3video] DECLINK_H264:HEAPID:3 USED:4501504 [m3video] 20932: SYSTEM : FREE SPACE : System Heap = 6083984 B, Mbx = 10239 msgs) [m3video] 20932: SYSTEM : FREE SPACE : SR0 Heap = 4450048 B (4 MB) [m3video] 20932: SYSTEM : FREE SPACE : Frame Buffer = 182887040 B (174 MB) [m3video] 20932: SYSTEM : FREE SPACE : Bitstream Buffer = 28360576 B (27 MB) [m3video] 20933: SYSTEM : FREE SPACE : Tiler 8-bit = 18272256 B (17 MB) - TILER ON [m3video] 20933: SYSTEM : FREE SPACE : Tiler 16-bit = 8025600 B (7 MB) - TILER ON [m3video] 20934: Assertion @ Line: 168 in utils/src/utils_tiler.c: (UInt32)(pFrame->addr[0][1]) != SYSTEM_TILER_INVALID_ADDR : failed !!! root@dm814x:/opt/dvr_rdk/ti814x#
I have observed that it fails to create decoder link.i.e "System_linkCreate(decId, &decPrm, sizeof(decPrm)); "
I have verified decoder parameters but didn't find any mistake.
Can anyone help me to run this demo ?
Thanks in advance,
Shabbir Limdiwala
