Hello all :
There is maybe some problem on decoding Streaming H.264 video media content from on-board Ethernet port of DM8148 EVM . The details of the problem are the followings. Now,I doubt may be h264parse and omx_h264dec will have some problem, Is there anyone can tell me what could be the cause of the problem and how to fix them?Thanks so much!
Platform: Spectrum DM8148 EVM reversion: G
EZSDK version:5_05_01_04_dm814x
Gstreamer revision: the latest (1041)from https://gstreamer.ti.com/svn/gstreamer_ti/trunk/gstreamer_ti_dm81xx
Streaming program : Windows version VLC(Use VLC to sent Ts video)
Streaming Protocol: RTP
media:TS Stream(Video:H264,25fps or 30fps ,progressive or interlaced ,test result all is same)
Gsteamer pipeline:
gst-launch-0.10 udpsrc multicast-iface=eth0 multicast-group=230.0.0.1 port=5004 caps="application/x-rtp,clock-rate=(int)90000,payload=(int)33, \
encoding-name=(string)MP2T-ES" \
! .recv_rtp_sink_0 gstrtpbin ! queue ! rtpmp2tdepay \
! mpegtsdemux \
! 'video/x-h264' ! h264parse access-unit=true ! omx_h264dec ! omx_mdeiscaler name=d d.src_00 \
! 'video/x-raw-yuv,width=800,height=480' ! omx_ctrl display-mode=OMX_DC_MODE_1080P_60 display-device=LCD ! \
gstperf ! omx_videosink top=50 left=50 display-mode=OMX_DC_MODE_1080P_60 display-device=LCD sync=false d.src_01 ! fakesink silent=true -v
Case 1:
If DM8148 gstreamer pipeline start before VLC streaming out, the result of playing is the video picture is fluent.(OK)
the message on console is :
Setting pipeline to PAUSED ...
IPTV:udpsrc revmodel is 0
IPTV:revmodel is 0,use udp sockded
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstRtpBin:rtpbin0/GstRtpSession:rtpsession0.GstPad:recv_r
tp_sink: caps = application/x-rtp, clock-rate=(int)90000, payload=(int)33, encod
/GstPipeline:pipeline0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_sink_0: caps = app
lication/x-rtp, clock-rate=(int)90000, payload=(int)33, encoding-name=(string)MP
2T-ES
/GstPipeline:pipeline0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_sink_0.GstProxyPad
:proxypad0: caps = application/x-rtp, clock-rate=(int)90000, payload=(int)33, en
tp_src: caps = application/x-rtp, clock-rate=(int)90000, payload=(int)33, encodi
/GstPipeline:pipeline0/GstRtpBin:rtpbin0/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:si
nk: caps = application/x-rtp, clock-rate=(int)90000, payload=(int)33, encoding-n
ame=(string)MP2T-ES
/GstPipeline:pipeline0/GstRtpBin:rtpbin0/GstRtpJitterBuffer:rtpjitterbuffer0.Gst
Pad:src: caps = application/x-rtp, clock-rate=(int)90000, payload=(int)33, encod
Pad:sink: caps = application/x-rtp, clock-rate=(int)90000, payload=(int)33, enco
/GstPipeline:pipeline0/GstRtpBin:rtpbin0/GstRtpPtDemux:rtpptdemux0.GstPad:sink:
caps = application/x-rtp, clock-rate=(int)90000, payload=(int)33, encoding-name=
(string)MP2T-ES
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = application/x-rtp, cl
ock-rate=(int)90000, payload=(int)33, encoding-name=(string)MP2T-ES
/GstPipeline:pipeline0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_src_0_2764225876_3
3.GstProxyPad:proxypad1: caps = application/x-rtp, clock-rate=(int)90000, payloa
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = application/x-rtp, clo
/GstPipeline:pipeline0/GstRtpMP2TDepay:rtpmp2tdepay0.GstPad:src: caps = video/mp
egts, packetsize=(int)188, systemstream=(boolean)true
/GstPipeline:pipeline0/GstRtpMP2TDepay:rtpmp2tdepay0.GstPad:sink: caps = applica
tion/x-rtp, clock-rate=(int)90000, payload=(int)33, encoding-name=(string)MP2T-E
S
/GstPipeline:pipeline0/GstMpegTSDemux:mpegtsdemux0.GstPad:sink: caps = video/mpe
/GstPipeline:pipeline0/GstMpegTSDemux:mpegtsdemux0: pat-info = ((GValueArray*) 0
x1d5c00)
/GstPipeline:pipeline0/GstMpegTSDemux:mpegtsdemux0: pmt-info = ((MpegTsPmtInfo*)
0x1d6da0)
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2: caps = video/x-h264
/GstPipeline:pipeline0/GstCapsFilter:capsfilter3: caps = video/x-h264
/GstPipeline:pipeline0/GstCapsFilter:capsfilter3.GstPad:src: caps = video/x-h264
, stream-format=(string)byte-stream, alignment=(string)nal
/GstPipeline:pipeline0/GstCapsFilter:capsfilter3.GstPad:sink: caps = video/x-h26
4, stream-format=(string)byte-stream, alignment=(string)nal
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264,
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264,
stream-format=(string)byte-stream, alignment=(string)au, width=(int)720, height=
(int)576
/GstPipeline:pipeline0/GstOmxH264Dec:omxh264dec0.GstPad:sink: caps = video/x-h26
4, stream-format=(string)byte-stream, alignment=(string)au, width=(int)720, heig
ht=(int)576
ht=(int)576
/GstPipeline:pipeline0/GstOmxH264Dec:omxh264dec0.GstPad:src: caps = video/x-raw-
yuv-strided, width=(int)720, height=(int)576, format=(fourcc)NV12, rowstride=(in
t)896, interlaced=(boolean)false, framerate=(fraction)0/1
t)896, interlaced=(boolean)true, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstOmxMDeiScaler:d.GstPad:sink: caps = video/x-raw-yuv-st
rided, width=(int)720, height=(int)576, format=(fourcc)NV12, rowstride=(int)896,
/GstPipeline:pipeline0/GstOmxMDeiScaler:d.GstPad:src_00: caps = video/x-raw-yuv,
width=(int)800, height=(int)480, format=(fourcc)YUY2, framerate=(fraction)0/1,
/GstPipeline:pipeline0/GstOmxMDeiScaler:d.GstPad:src_01: caps = video/x-raw-yuv,
width=(int)720, height=(int)576, format=(fourcc)NV12, framerate=(fraction)0/1,
this input params: 720x288,896 774144 1
incoming buffer: nFilledLen: 881632, nOffset: 21536 nFlags: 50000
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw-
yuv, width=(int)800, height=(int)480, format=(fourcc)YUY2, framerate=(fraction)0
/1, interlaced=(boolean)false
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw
-yuv, width=(int)800, height=(int)480, format=(fourcc)YUY2, framerate=(fraction)
0/1, interlaced=(boolean)false
/GstPipeline:pipeline0/GstOmxBaseCtrl:omxbasectrl0.GstPad:src: caps = video/x-ra
w-yuv, width=(int)800, height=(int)480, format=(fourcc)YUY2, framerate=(fraction
)0/1, interlaced=(boolean)false
/GstPipeline:pipeline0/GstOmxBaseCtrl:omxbasectrl0.GstPad:sink: caps = video/x-r
aw-yuv, width=(int)800, height=(int)480, format=(fourcc)YUY2, framerate=(fractio
n)0/1, interlaced=(boolean)false
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw-yuv
, width=(int)720, height=(int)576, format=(fourcc)NV12, framerate=(fraction)0/1,
/GstPipeline:pipeline0/Gstperf:perf0.GstPad:src: caps = video/x-raw-yuv, width=(
int)800, height=(int)480, format=(fourcc)YUY2, framerate=(fraction)0/1, interlac
ed=(boolean)false
/GstPipeline:pipeline0/Gstperf:perf0.GstPad:sink: caps = video/x-raw-yuv, width=
(int)800, height=(int)480, format=(fourcc)YUY2, framerate=(fraction)0/1, interla
ced=(boolean)false
IPTV:left:50 top:50 width:800 high:480
/GstPipeline:pipeline0/GstOmxVideoSink:omxvideosink0.GstPad:sink: caps = video/x
-raw-yuv, width=(int)800, height=(int)480, format=(fourcc)YUY2, framerate=(fract
ion)0/1, interlaced=(boolean)false
perf0: frames: 43 current: 41.75 average: 41.75 arm-load: 9
Case 2:
If VLC streaming out first then DM8148 gstreamer pipeline start, the streaming video playback will always have wrong decoded frame order problems.and the result of playing is the video picture is dithering.(Bad)
2T-ES
ame=(string)MP2T-ES
(string)MP2T-ES
/GstPipeline:pipeline0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_src_0_3210768595_3
S
x20a4d0)
0x20b5a0)
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-h264
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-h26
(int)576
ht=(int)576
ht=(int)576
Stream is corrupt error, ignorable ...
incoming buffer: nFilledLen: 881632, nOffset: 21536 nFlags: 50200
ed=(boolean)false
ced=(boolean)false
perf0: frames: 12 current: 11.27 average: 11.27 arm-load: 8
perf0: frames: 46 current: 33.12 average: 21.99 arm-load: 24
summarize :
Just as the above ,the only different infor betwwen the first case and the second was :
1、The first difference
The first case :(play fluently and good)
and the second case (play dithering and bad )
2、Second difference
The first case :
and the second case:
3. the third difference
the second case always turn out:
And:
When I use the same gstreamer cmd (only decoder is different) to test on PC platform,all is OK,the result of playing is the video was played very well and fluent.
On PC ,the cmd is :
! mpegtsdemux \
! 'video/x-h264' ! ffdec_h264 ! ffmpegcolorspace ! videoscale ! queue ! xvimagesink
So,comparing to on DM814x,the difference is :
'video/x-h264' ! ffdec_h264 ! ffmpegcolorspace ! videoscale ! queue ! xvimagesink-------------------PC
and
h264parse access-unit=true ! omx_h264dec ! omx_mdeiscaler ! 'video/x-raw-yuv,width=800,height=480' ! omx_ctrl ! omx_videosink---------On Dm814x
SO,Wheather the h264parse or omx_h264dec or omx_mdeiscaler may be have some problem.
Thanks very much .
zhichao.
