AM335x android ubifs mouts error
Hi, I feel puzzled about mouting ubifs on nandflash. It suddently came up lots of "UBI error: ubi_io_write: error -5 while writing 512 bytes to PEB 3336:0, written 0 bytes".
The messages is posted in the text . please give me response as quickly as possiable . Appreciating your attention.
U-Boot SPL 2011.09-00000-g518a597 (Apr 11 2012 - 16:55:25)
Texas Instruments Revision detection unimplemented
Could not probe the EEPROM; something fundamentally wrong on the I2C bus.
read_eeprom() failure
U-Boot 2011.09 (Dec 18 2012 - 21:44:40)
I2C:   ready
DRAM:  256 MiB
WARNING: Caches not enabled
NAND:  HW ECC Hamming Code selected
1024 MiB
MMC:   OMAP SD/MMC: 0
Net:   cpsw
Hit any key to stop autoboot:  0
Booting from nand ...
HW ECC BCH8 Selected
NAND read: device 0 offset 0x280000, size 0x500000
 5242880 bytes read: OK
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-3.2.0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3634544 Bytes = 3.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Linux version 3.2.0 (root@ubuntu) (gcc version 4.4.3 (GCC) ) #13 Tue Dec 18 19:49:28 PST 2012
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: am335xevm
[    0.000000] Truncating RAM at 80000000-bfffffff to -af7fffff (vmalloc region overlap).
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES1.0 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 193040
[    0.000000] Kernel command line: console=ttyO0,115200n8 noinitrd ip=off mem=1024M rootwait=1 rw ubi.mtd=7,2048 rootfstype=ubifs root=ubi0:rootfs init=/init
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 760MB = 760MB total
[    0.000000] Memory: 762852k/762852k available, 15388k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc067f000   (6620 kB)
[    0.000000]       .init : 0xc067f000 - 0xc06bb000   ( 240 kB)
[    0.000000]       .data : 0xc06bc000 - 0xc0714b60   ( 355 kB)
[    0.000000]        .bss : 0xc0714b84 - 0xc08459c8   (1220 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[    0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[    0.000000] Console: colour dummy device 80x30
[    0.000183] Calibrating delay loop... 498.89 BogoMIPS (lpj=2494464)
[    0.118591] pid_max: default: 32768 minimum: 301
[    0.118774] Security Framework initialized
[    0.118865] Mount-cache hash table entries: 512
[    0.119323] CPU: Testing write buffer coherency: ok
[    0.140716] omap_hwmod: gfx: failed to hardreset
[    0.157501] omap_hwmod: pruss: failed to hardreset
[    0.158630] print_constraints: dummy:
[    0.158905] NET: Registered protocol family 16
[    0.160339] OMAP GPIO hardware version 0.1
[    0.161743] omap_mux_init: Add partition: #1: core, flags: 0
[    0.164062]  da8xx_lcdc.0: alias fck already exists
[    0.164306]  omap_hsmmc.0: alias fck already exists
[    0.164428] TSC connected to beta GP EVM
[    0.164794]  omap_i2c.1: alias fck already exists
[    0.165435]  omap2_mcspi.1: alias fck already exists
[    0.165618]  omap2_mcspi.2: alias fck already exists
[    0.165832]  edma.0: alias fck already exists
[    0.165863]  edma.0: alias fck already exists
[    0.178710] bio: create slab <bio-0> at 0
[    0.180053] SCSI subsystem initialized
[    0.181182] usbcore: registered new interface driver usbfs
[    0.181335] usbcore: registered new interface driver hub
[    0.181518] usbcore: registered new device driver usb
[    0.181701] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.181884] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.182495] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.184020] tps65910 1-002d: JTAGREVNUM 0x0
[    0.186340] print_constraints: VRTC:
[    0.187774] print_constraints: VIO: at 1800 mV
[    0.190124] print_constraints: VDD1: 600 <--> 1500 mV at 1100 mV normal
[    0.192443] print_constraints: VDD2: 600 <--> 1500 mV at 1100 mV normal
[    0.193450] print_constraints: VDD3: 5000 mV
[    0.194854] print_constraints: VDIG1: at 1800 mV
[    0.196258] print_constraints: VDIG2: at 1800 mV
[    0.197662] print_constraints: VPLL: at 1800 mV
[    0.199096] print_constraints: VDAC: at 1800 mV
[    0.200500] print_constraints: VAUX1: at 1800 mV
[    0.201934] print_constraints: VAUX2: at 3300 mV
[    0.203338] print_constraints: VAUX33: at 3300 mV
[    0.204742] print_constraints: VMMC: at 3300 mV
[    0.205139] tps65910 1-002d: No interrupt support, no core IRQ
[    0.205627] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.206420] Bluetooth: Core ver 2.16
[    0.206512] NET: Registered protocol family 31
[    0.206542] Bluetooth: HCI device and connection manager initialized
[    0.206542] Bluetooth: HCI socket layer initialized
[    0.206573] Bluetooth: L2CAP socket layer initialized
[    0.206604] Bluetooth: SCO socket layer initialized
[    0.206909] Switching to clocksource gp timer
[    0.217742] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.217956] musb-hdrc musb-hdrc.0: dma type: pio
[    0.218780] musb-hdrc musb-hdrc.0: USB OTG mode controller at f001c000 using PIO, IRQ 18
[    0.219055] musb-hdrc musb-hdrc.1: dma type: pio
[    0.219390] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.219482] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.219665] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.219665] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.219696] usb usb1: Product: MUSB HDRC host driver
[    0.219696] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.219726] usb usb1: SerialNumber: musb-hdrc.1
[    0.220397] hub 1-0:1.0: USB hub found
[    0.220428] hub 1-0:1.0: 1 port detected
[    0.221008] musb-hdrc musb-hdrc.1: USB Host mode controller at f001e800 using PIO, IRQ 19
[    0.221435] NET: Registered protocol family 2
[    0.221710] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.222351] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.225555] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
[    0.226501] TCP: Hash tables configured (established 131072 bind 65536)
[    0.226501] TCP reno registered
[    0.226531] UDP hash table entries: 512 (order: 1, 8192 bytes)
[    0.226562] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[    0.226867] NET: Registered protocol family 1
[    0.227355] RPC: Registered named UNIX socket transport module.
[    0.227386] RPC: Registered udp transport module.
[    0.227386] RPC: Registered tcp transport module.
[    0.227386] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.227722] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.227966] omap-gpmc omap-gpmc: GPMC revision 6.0
[    0.227996] Registering NAND on CS0
[    0.425384] ashmem: initialized
[    0.425720] VFS: Disk quotas dquot_6.5.2
[    0.425811] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.427001] msgmni has been set to 1489
[    0.428405] io scheduler noop registered
[    0.428405] io scheduler deadline registered
[    0.428527] io scheduler cfq registered (default)
[    0.429290] Could not set LED4 to fully on
[    0.430297] da8xx_lcdc da8xx_lcdc.0: GLCD: Found QY_LCD panel
[    0.441772] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    1.130065] console [ttyO0] enabled
[    1.134277] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    1.142150] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    1.149963] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    1.157836] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    1.165618] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    1.181823] brd: module loaded
[    1.189331] loop: module loaded
[    1.192840] i2c-core: driver [tsl2550] using legacy suspend method
[    1.199401] i2c-core: driver [tsl2550] using legacy resume method
[    1.205871] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    1.267486] No daughter card found on AM335x EVM
[    1.272399] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    1.337493] AM335X: EVM Config read fail: -110
[    1.343444] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.350585] omap2-nand driver initializing
[    1.355010] pdata->ecc_opt is 4
[    1.358734] NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
[    1.368225] Creating 8 MTD partitions on "omap2-nand.0":
[    1.373809] 0x000000000000-0x000000020000 : "SPL"
[    1.380157] 0x000000020000-0x000000040000 : "SPL.backup1"
[    1.387054] 0x000000040000-0x000000060000 : "SPL.backup2"
[    1.394012] 0x000000060000-0x000000080000 : "SPL.backup3"
[    1.400787] 0x000000080000-0x000000260000 : "U-Boot"
[    1.407867] 0x000000260000-0x000000280000 : "U-Boot Env"
[    1.414520] 0x000000280000-0x000000780000 : "Kernel"
[    1.423004] 0x000000780000-0x000040000000 : "File System"
[    1.860992] OneNAND driver initializing
[    1.865539] UBI: attaching mtd7 to ubi0
[    1.869598] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    1.876190] UBI: logical eraseblock size:    126976 bytes
[    1.881866] UBI: smallest flash I/O unit:    2048
[    1.886810] UBI: sub-page size:              512
[    1.891693] UBI: VID header offset:          2048 (aligned 2048)
[    1.898010] UBI: data offset:                4096
[    8.000427] UBI: max. sequence number:       478
[    8.026794] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 46, need 80
[    8.042633] UBI: attached mtd7 to ubi0
[    8.046600] UBI: MTD device name:            "File System"
[    8.052459] UBI: MTD device size:            1016 MiB
[    8.057769] UBI: number of good PEBs:        8035
[    8.062713] UBI: number of bad PEBs:         97
[    8.067474] UBI: number of corrupted PEBs:   0
[    8.072174] UBI: max. allowed volumes:       128
[    8.077026] UBI: wear-leveling threshold:    4096
[    8.081970] UBI: number of internal volumes: 1
[    8.086639] UBI: number of user volumes:     1
[    8.091339] UBI: available PEBs:             0
[    8.095977] UBI: total number of reserved PEBs: 8035
[    8.101226] UBI: number of PEBs reserved for bad PEB handling: 46
[    8.107635] UBI: max/mean erase counter: 2/0
[    8.112121] UBI: image sequence number:  1080923749
[    8.117614] CAN device driver interface
[    8.121673] CAN bus driver for Bosch D_CAN controller 1.0
[    8.127777] PPP generic driver version 2.4.2
[    8.132507] PPP BSD Compression module registered
[    8.137451] PPP Deflate Compression module registered
[    8.142944] usbcore: registered new interface driver cdc_ether
[    8.149169] usbcore: registered new interface driver cdc_eem
[    8.155181] usbcore: registered new interface driver dm9601
[    8.161163] usbcore: registered new interface driver cdc_subset
[    8.167419] cdc_ncm: 04-Aug-2011
[    8.170928] usbcore: registered new interface driver cdc_ncm
[    8.177001] usbcore: registered new interface driver cdc_acm
[    8.182952] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    8.191406] Initializing USB Mass Storage driver...
[    8.196685] usbcore: registered new interface driver usb-storage
[    8.203002] USB Mass Storage support registered.
[    8.208099] usbcore: registered new interface driver usbserial
[    8.214294] USB Serial support registered for generic
[    8.219726] usbcore: registered new interface driver usbserial_generic
[    8.226593] usbserial: USB Serial Driver core
[    8.231262] USB Serial support registered for GSM modem (1-port)
[    8.237792] usbcore: registered new interface driver option
[    8.243652] option: v0.7.2:USB Driver for GSM modems
[    8.250823] UBI: background thread "ubi_bgt0d" started, PID 49
[    8.258453]  gadget: Mass Storage Function, version: 2009/09/11
[    8.264678]  gadget: Number of LUNs=1
[    8.268585]  lun0: LUN: removable file: (no medium)
[    8.274017]  gadget: android_usb ready
[    8.278045] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    8.283691] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[    8.291625] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    8.298797] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.306365] usb usb2: Product: MUSB HDRC host driver
[    8.311614] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[    8.317199] usb usb2: SerialNumber: musb-hdrc.0
[    8.322601] hub 2-0:1.0: USB hub found
[    8.326599] hub 2-0:1.0: 1 port detected
[    8.331573] mousedev: PS/2 mouse device common for all mice
[    8.408477] input: ti-tsc-adcc as /devices/platform/omap/tsc/input/input0
[    8.417327] using rtc device, omap_rtc, for alarms
[    8.422302] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
[    8.429290] i2c /dev entries driver
[    8.433197] Linux video capture interface: v2.00
[    8.438262] usbcore: registered new interface driver uvcvideo
[    8.444305] USB Video Class driver (1.1.1)
[    8.448822] UBI error: ubi_io_write: error -5 while writing 512 bytes to PEB 3070:0, written 0 bytes
[    8.458496] UBI error: erase_worker: failed to erase PEB 3070, error -5
[    8.465454] UBI: mark PEB 3070 as bad
[    8.469848] UBI: 45 PEBs left in the reserve
[    8.508941] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    8.515563] device-mapper: uevent: version 1.0.3
[    8.520721] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    8.529602] Bluetooth: HCI UART driver ver 2.2
[    8.534301] Bluetooth: HCI H4 protocol initialized
[    8.539337] Bluetooth: HCILL protocol initialized
[    8.544281] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[    8.599029] cpuidle: using governor ladder
[    8.603546] cpuidle: using governor menu
[    8.619110] usbcore: registered new interface driver usbhid
[    8.624969] usbhid: USB HID core driver
[    8.638122] logger: created 256K log 'log_main'
[    8.643035] logger: created 256K log 'log_events'
[    8.648162] logger: created 256K log 'log_radio'
[    8.653167] logger: created 256K log 'log_system'
[    8.658752] usbcore: registered new interface driver snd-usb-audio
[    8.666259] ALSA device list:
[    8.669433]   No soundcards found.
[    8.673004] oprofile: hardware counters not available
[    8.678344] oprofile: using timer interrupt.
[    8.683013] nf_conntrack version 0.5.0 (11919 buckets, 47676 max)
[    8.690185] ip_tables: (C) 2000-2006 Netfilter Core Team
[    8.695983] TCP cubic registered
[    8.699615] NET: Registered protocol family 10
[    8.705200] IPv6 over IPv4 tunneling driver
[    8.710510] NET: Registered protocol family 17
[    8.715209] can: controller area network core (rev 20090105 abi 8)
[    8.721893] NET: Registered protocol family 29
[    8.726562] can: raw protocol (rev 20090105)
[    8.731079] can: broadcast manager protocol (rev 20090105 t)
[    8.737365] UBI error: ubi_io_write: error -5 while writing 512 bytes to PEB 3121:0, written 0 bytes
[    8.747009] UBI error: erase_worker: failed to erase PEB 3121, error -5
[    8.753997] UBI: mark PEB 3121 as bad
[    8.758392] UBI: 44 PEBs left in the reserve
[    8.827636] Bluetooth: RFCOMM TTY layer initialized
[    8.832824] Bluetooth: RFCOMM socket layer initialized
[    8.838226] Bluetooth: RFCOMM ver 1.11
[    8.842193] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    8.847778] Bluetooth: BNEP filters: protocol multicast
[    8.853271] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    8.859680] Registering the dns_resolver key type
[    8.864654] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    8.872711] ThumbEE CPU extension supported.
[    8.877227] mux: Failed to setup hwmod io irq -22
[    8.883026] Power Management for AM33XX family
[    8.887969] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[    8.894683] Copied the M3 firmware to UMEM
[    8.899017] omap_hwmod: wkup_m3: wkup_m3: hwmod data error: OMAP4 does not support st_shift
[    8.912811] clock: disabling unused clocks to save power
[    8.920166] omapfb omapfb: no displays
[    8.924102] omapfb omapfb: failed to setup omapfb
[    8.929138] omapfb: probe of omapfb failed with error -22
[    8.935241] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[    9.098175] UBIFS: recovery needed
[    9.324890] UBIFS: recovery completed
[    9.328826] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[    9.335144] UBIFS: file system size:   199225344 bytes (194556 KiB, 189 MiB, 1569 LEBs)
[    9.343566] UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[    9.351287] UBIFS: media format:       w4/r0 (latest is w4/r0)
[    9.357421] UBIFS: default compressor: lzo
[    9.361724] UBIFS: reserved for root:  0 bytes (0 KiB)
[    9.368927] VFS: Mounted root (ubifs filesystem) on device 0:13.
[    9.375854] Freeing init memory: 240K
[    9.544403] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[    9.638153] UBI error: ubi_io_write: error -5 while writing 512 bytes to PEB 3336:0, written 0 bytes
[    9.647796] UBI error: erase_worker: failed to erase PEB 3336, error -5
[    9.654785] UBI: mark PEB 3336 as bad
[    9.678100] UBI error: ubi_io_mark_bad: cannot mark PEB 3336 bad, error -5
[    9.685363] UBI warning: ubi_ro_mode: switch to read-only mode
[    9.691528] UBI error: do_work: work failed with error code -5
[    9.697662] UBI error: ubi_thread: ubi_bgt0d: work failed with error code -5
[    9.770812] init: cannot open '/initlogo.rle'
[    9.826904] Disabling lock debugging due to kernel taint
[    9.833374] Compat-wireless backport release: compat-wireless-2011-12-05-1-g84dbe2c
[    9.841461] Backport based on wl12xx.git v2.6.39-1328-g0890f48
[    9.913665] cfg80211: Calling CRDA to update world regulatory domain
[   10.344909] cfg80211: World regulatory domain updated:
[   10.350402] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   10.359191] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   10.367523] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   10.375885] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   10.384216] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   10.392547] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   10.439727] UBIFS error (pid 70): ubifs_leb_write: writing 2048 bytes to LEB 918:36864 failed, error -30
[   10.449768] UBIFS warning (pid 70): ubifs_ro_mode: switched to read-only mode, error -30
[   10.458282] Backtrace:
[   10.460906] [<c001803c>] (dump_backtrace+0x0/0x10c) from [<c04ed65c>] (dump_stack+0x18/0x1c)
[   10.469818]  r7:00009000 r6:00000396 r5:ffffffe2 r4:00000004
[   10.475799] [<c04ed644>] (dump_stack+0x0/0x1c) from [<c01c2c40>] (ubifs_ro_mode+0x6c/0x78)
[   10.484527] [<c01c2bd4>] (ubifs_ro_mode+0x0/0x78) from [<c01c3114>] (ubifs_leb_write+0x8c/0x98)
[   10.493682]  r5:ffffffe2 r4:eeb00000
[   10.497467] [<c01c3088>] (ubifs_leb_write+0x0/0x98) from [<c01c33ac>] (ubifs_wbuf_write_nolock+0x21c/0x348)
[   10.507720]  r8:000000d8 r7:0000049f r6:eeb00000 r5:000000d8 r4:ef39ae98
[   10.514831] [<c01c3190>] (ubifs_wbuf_write_nolock+0x0/0x348) from [<c01b854c>] (write_head.clone.0+0x44/0x64)
[   10.525299] [<c01b8508>] (write_head.clone.0+0x0/0x64) from [<c01b9620>] (ubifs_jnl_truncate+0x1d8/0x564)
[   10.535369]  r5:00000000 r4:ee45c0a0
[   10.539154] [<c01b9448>] (ubifs_jnl_truncate+0x0/0x564) from [<c01bb87c>] (ubifs_setattr+0x3ac/0x3f0)
[   10.548889] [<c01bb4d0>] (ubifs_setattr+0x0/0x3f0) from [<c00c39b4>] (notify_change+0x19c/0x29c)
[   10.558135] [<c00c3818>] (notify_change+0x0/0x29c) from [<c00ab564>] (do_truncate+0x78/0x94)
[   10.567047] [<c00ab4ec>] (do_truncate+0x0/0x94) from [<c00b9f9c>] (do_last+0x4bc/0x94c)
[   10.575469]  r5:eed1a8cc r4:ee4f7ed0
[   10.579254] [<c00b9ae0>] (do_last+0x0/0x94c) from [<c00ba4f0>] (path_openat+0xc4/0x3c8)
[   10.587677] [<c00ba42c>] (path_openat+0x0/0x3c8) from [<c00ba8ec>] (do_filp_open+0x38/0x8c)
[   10.596496] [<c00ba8b4>] (do_filp_open+0x0/0x8c) from [<c00aa600>] (do_sys_open+0xe4/0x1b8)
[   10.605285]  r8:00000001 r7:ffffff9c r6:00000009 r5:00020242 r4:ef180000
[   10.612396] [<c00aa51c>] (do_sys_open+0x0/0x1b8) from [<c00aa70c>] (sys_open+0x24/0x28)
[   10.620849] [<c00aa6e8>] (sys_open+0x0/0x28) from [<c00142c0>] (ret_fast_syscall+0x0/0x30)
[   10.629547] UBIFS error (pid 70): ubifs_wbuf_write_nolock: cannot write 216 bytes to LEB 918:36864, error -30
[   10.772399] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[   10.872924] android_usb: already disabled
[   10.877532] adb_bind_config
/system/bin/sh: No controlling tty (open /dev/tty: No such device or address)
/system/bin/sh: warning: won't have full job control
root@android:/ # [   11.378936] adb_open
[   14.585937] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   14.595550] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1142, error -30
[   14.659393] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   14.668945] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1143, error -30
[   14.760040] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   14.769592] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1144, error -30
[   14.903228] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   14.912841] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1181, error -30
[   14.946411] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   14.956024] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1149, error -30
[   14.989929] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   14.999481] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1150, error -30
[   15.028686] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.038208] UBIFS error (pid 123): ubifs_write_inode: can't write inode 75, error -30
[   15.058807] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.068359] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1140, error -30
[   15.092895] request_suspend_state: wakeup (3->0) at 15084369668 (2000-01-01 00:00:06.646707781 UTC)
[   15.108062] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.117706] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1151, error -30
[   15.128753] init: untracked pid 67 exited
[   15.169006] init: untracked pid 73 exited
[   15.177307] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.186920] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1152, error -30
[   15.258697] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.268249] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1153, error -30
[   15.333496] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.343109] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1154, error -30
[   15.384155] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.393798] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1155, error -30
[   15.448760] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.458282] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1156, error -30
[   15.498626] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.508148] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1157, error -30
[   15.558624] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.568176] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1158, error -30
[   15.608581] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.618103] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1159, error -30
[   15.658630] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.668182] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1160, error -30
[   15.718688] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.728240] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1161, error -30
[   15.778686] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.788208] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1162, error -30
[   15.818695] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.828247] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1163, error -30
[   15.878723] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.888244] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1164, error -30
[   15.918701] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.928222] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1165, error -30
[   15.958679] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.968231] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1166, error -30
[   15.988739] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   15.998260] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1167, error -30
[   16.028686] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.038208] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1168, error -30
[   16.068634] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.078155] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1169, error -30
[   16.098602] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.108123] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1170, error -30
[   16.139373] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.148956] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1171, error -30
[   16.168609] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.178161] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1172, error -30
[   16.199127] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.208679] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1173, error -30
[   16.231933] request_suspend_state: wakeup (0->0) at 16223407582 (2000-01-01 00:00:07.785745695 UTC)
[   16.241699] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.251251] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1174, error -30
[   16.262207] init: untracked pid 127 exited
[   16.289031] init: untracked pid 126 exited
[   16.293548] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.303100] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1175, error -30
[   16.343475] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.353088] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1176, error -30
[   16.398620] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.408172] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1177, error -30
[   16.448333] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.457946] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1178, error -30
[   16.498779] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.508331] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1179, error -30
[   16.538604] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.548126] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1183, error -30
[   16.578613] UBIFS error (pid 123): make_reservation: cannot reserve 160 bytes in jhead 1, error -30
[   16.588134] UBIFS error (pid 123): ubifs_write_inode: can't write inode 1185, error -30
[   19.978790] PVR_K: User requested SGX debug info
[   19.983703] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@789263)
[   19.992156] PVR_K: Flip Command Complete Data 0 for display device 1:
[   19.998962] PVR_K:   SRC 0: (Not in use)
[   20.002990] PVR_K: Flip Command Complete Data 1 for display device 1:
[   20.009796] PVR_K:   SRC 0: ROC DevVAddr:0xD800034 ROP:0x1 ROC:0x0, WOC DevVAddr:0xD800024 WOP:0x1 WOC:0x1
[   20.019866] PVR_K:   SRC 1: ROC DevVAddr:0xD800054 ROP:0x2 ROC:0x1, WOC DevVAddr:0xD800044 WOP:0x2 WOC:0x1
[   20.029968] PVR_K: SGX Host control:
[   20.033721] PVR_K:   (HC-0) 0x00000001 0x0000000C 0x00000000 0x00000001
[   20.040618] PVR_K:   (HC-10) 0x00000000 0x00000000 0x0000000A 0x00030D40
[   20.047576] PVR_K:   (HC-20) 0x00000065 0x00000004 0x00000000 0x00000000
[   20.054565] PVR_K:   (HC-30) 0x00000004 0x00000225 0xEF352430 0x00000000
[   20.061553] PVR_K:   (HC-40) 0x00000000 0x00000000 0xE6FF7DBC 0xBE7FEAFF
[   20.068511] PVR_K: SGX TA/3D control:
[   20.072387] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   20.079345] PVR_K:   (T3C-10) 0x0F0C01C0 0x00000001 0x00000002 0x00000001
[   20.086425] PVR_K:   (T3C-20) 0x0F0AD4E0 0x00000000 0x00000000 0x00000000
[   20.093475] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   20.100555] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   20.107604] PVR_K:   (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[   20.114654] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x00000000 0x0F00AE80
[   20.121734] PVR_K:   (T3C-70) 0x00000000 0x00000000 0x0F00AE80 0x00000000
[   20.128814] PVR_K:   (T3C-80) 0x00000000 0x00000000 0x00000000 0x0F000000
[   20.135864] PVR_K:   (T3C-90) 0xAE59A000 0x0F0AFC00 0x00000000 0x0F08BB40
[   20.142913] PVR_K:   (T3C-A0) 0x0F0AD4E0 0x00000000 0x0F08BB40 0x00000000
[   20.149993] PVR_K:   (T3C-B0) 0x00000000 0x00000000 0x00000000 0x00000000
[   20.157043] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000001
[   20.164123] PVR_K:   (T3C-D0) 0x00000001 0x0F000000 0x8000B000 0x8004B000
[   20.171203] PVR_K:   (T3C-E0) 0x0F004000 0x0F00A420 0x0F00A740 0x00000000
[   20.178253] PVR_K:   (T3C-F0) 0x00000000 0x00000000 0x00000077 0x00000077
[   20.185302] PVR_K:   (T3C-100) 0x00000000 0x00000003 0x00000000 0x00000000
[   20.192474] PVR_K:   (T3C-110) 0x00000000 0x00000000 0xEBFAFBEA 0xEFFFBBFF
[   20.199615] PVR_K: SGX Kernel CCB WO:0x12 RO:0x12
