Other Parts Discussed in Thread: TCA6424, PMP, TMP102, TWL6040
team,
Flashed an SD card twice with this: http://opbuwiki.dal.design.ti.com/index.php/Omap5_uevm_engineering_releases#Engineering_release_7. try redownloading the FS.
I get stuck at boot up always:
U-Boot SPL 2012.10-rc3-00009-g3748fea (Oct 12 2012 - 11:38:51)
OMAP5432 ES1.0
die_id1: 1545d18
Hack! Disabling faulty EMIF1
lisa_map_2: 0x80600200
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2012.10-rc3-00009-g3748fea (Oct 12 2012 - 11:38:51)
CPU : OMAP5432 ES1.0
Board: OMAP5430 EVM
I2C: ready
DRAM: 1008 MiB
relocation Offset is: 3e105000
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
timed out in wait_for_bb: I2C_STAT=1410
reading boot.scr
** Unable to read "boot.scr" from mmc 0:1 **
reading uImage
3646120 bytes read
Booting from mmc0 ...
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-3.4.13vs-02043-g6738901
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3646056 Bytes = 3.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.4.13vs-02043-g6738901 (vstehle@vincent-panda) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Fri Oct 12 11:53:08 CEST 2012
[ 0.000000] CPU: ARMv7 Processor [410fc0f0] revision 0 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: OMAP5430 evm board
[ 0.000000] cma: CMA: reserved 8 MiB at 98800000
[ 0.000000] cma: CMA: reserved 112 MiB at 99000000
[ 0.000000] cma: CMA: reserved 64 MiB at ab000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] omap_5430evm_map_io
[ 0.000000] omap54xx_init_early
[ 0.000000] omap2_set_globals_tap
[ 0.000000] OMAP5432 ES1.0
[ 0.000000] FIXME: omap5 opp layer init
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c102d000 s11008 r8192 d13568 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 255520
[ 0.000000] Kernel command line: console=ttyO2,115200n8 vram=16M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 758MB 248MB = 1006MB total
[ 0.000000] Memory: 823940k/823940k available, 208252k reserved, 253952K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc06c0000 (6880 kB)
[ 0.000000] .init : 0xc06c0000 - 0xc071eb00 ( 379 kB)
[ 0.000000] .data : 0xc0720000 - 0xc07a9e60 ( 552 kB)
[ 0.000000] .bss : 0xc07a9e84 - 0xc084495c ( 619 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:562
[ 0.000000] omap_sr_disable: omap_sr struct for sr_wakeup not found
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000091] Calibrating delay loop... 1590.23 BogoMIPS (lpj=6213632)
[ 0.070373] pid_max: default: 32768 minimum: 301
[ 0.070709] Mount-cache hash table entries: 512
[ 0.071594] CPU: Testing write buffer coherency: ok
[ 0.071624] ftrace: allocating 20223 entries in 60 pages
[ 0.107788] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.108245] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.108306] Setting up static identity map for 0x804fbbd0 - 0x804fbc28
[ 0.108306] omap_sar_ram_init
[ 0.108581] generating sar_ram layout...
[ 0.108795] sar ram layout created
[ 0.108978] Failed to get l3_init_clkdm
[ 0.186950] CPU1: Booted secondary processor
[ 0.256744] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.256774] CPU1: Unknown IPI message 0x1
[ 0.256805] Brought up 2 CPUs
[ 0.256835] SMP: Total of 2 processors activated (3188.82 BogoMIPS).
[ 0.257446] devtmpfs: initialized
[ 0.263366] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.263397] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.263427] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.263458] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.263488] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.263519] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.263549] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.263580] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.266387] omap_hwmod: aess: _wait_target_disable failed
[ 0.266418] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.266448] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.266479] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.269256] omap_hwmod: dsp: Hack! NOT disabling clock.
[ 0.269256] omap_hwmod: dsp: _wait_target_ready error: -16
[ 0.269256] omap_hwmod: dsp: Hack! NOT disabling clkdm.
[ 0.269287] omap_hwmod: dsp: cannot be enabled (3)
[ 0.284759] omap_hwmod: dss_dsi1_b: softreset failed (waited 10000 usec)
[ 0.300201] omap_hwmod: dss_rfbi: softreset failed (waited 10000 usec)
[ 0.304077] omap_hwmod: ipu: Hack! NOT disabling clock.
[ 0.304077] omap_hwmod: ipu: _wait_target_ready error: -16
[ 0.304077] omap_hwmod: ipu: Hack! NOT disabling clkdm.
[ 0.304107] omap_hwmod: ipu: cannot be enabled (3)
[ 0.307006] omap_hwmod: mcpdm: Hack! NOT disabling clock.
[ 0.307037] omap_hwmod: mcpdm: _wait_target_ready error: -16
[ 0.307037] omap_hwmod: mcpdm: Hack! NOT disabling clkdm.
[ 0.307037] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.309967] omap_hwmod: sl2if: Hack! NOT disabling clock.
[ 0.309997] omap_hwmod: sl2if: _wait_target_ready error: -16
[ 0.309997] omap_hwmod: sl2if: Hack! NOT disabling clkdm.
[ 0.310028] omap_hwmod: sl2if: cannot be enabled (3)
[ 0.312469] dummy:
[ 0.317840] NET: Registered protocol family 16
[ 0.328582] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.332305] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.332397] OMAP GPIO hardware version 0.1
[ 0.332672] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.333007] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.333343] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.333709] gpiochip_add: registered GPIOs 128 to 159 on device: gpio
[ 0.334075] gpiochip_add: registered GPIOs 160 to 191 on device: gpio
[ 0.334411] gpiochip_add: registered GPIOs 192 to 223 on device: gpio
[ 0.334777] gpiochip_add: registered GPIOs 224 to 255 on device: gpio
[ 0.336395] omap_mux_init: Add partition: #1: core, flags: 4
[ 0.337432] omap_mux_init: Add partition: #2: wkup, flags: 4
[ 0.337524] Starting 5430 sEVM setup
[ 0.541961] Failed to get HDMI HPD EN GPIO
[ 0.543823] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.543823] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.546997] Could not look up iss hwmod
[ 0.551513] OMAP DMA hardware revision 0.0
[ 0.552246] emif emif.1: Device configured with addr = f0e00000 and IRQ142
[ 0.552429] emif emif.2: Device configured with addr = f1000000 and IRQ143
[ 0.573608] bio: create slab <bio-0> at 0
[ 0.576263] SCSI subsystem initialized
[ 0.577087] usbcore: registered new interface driver usbfs
[ 0.577392] usbcore: registered new interface driver hub
[ 0.577606] usbcore: registered new device driver usb
[ 0.578857] i2c-gpio i2c-gpio: using pins 195 (SDA) and 194 (SCL)
[ 0.579162] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 400 kHz
[ 0.602935] SMPS12: 600 <--> 1310 mV at 1150 mV normal standby
[ 0.603942] SMPS45: 600 <--> 1310 mV at 1150 mV normal standby
[ 0.604766] SMPS6: 1200 mV normal standby
[ 0.605590] SMPS7: 1800 mV normal standby
[ 0.606597] SMPS8: 600 <--> 1310 mV at 1150 mV normal standby
[ 0.607788] SMPS9: 2100 mV normal standby
[ 0.608459] SMPS10: 5000 mV normal standby
[ 0.609130] LDO1: 2800 mV normal standby
[ 0.610137] LDO2: 2900 mV normal standby
[ 0.610809] LDO3: 3000 mV normal standby
[ 0.611480] LDO4: 2200 mV normal standby
[ 0.612152] LDO5: 1800 mV normal standby
[ 0.612792] LDO6: 1500 mV normal standby
[ 0.613555] LDO7: 1500 mV normal standby
[ 0.614257] LDO8: 1500 mV normal standby
[ 0.615081] LDO9: 1800 <--> 3000 mV at 2450 mV normal standby
[ 0.615966] LDOLN: 1800 mV normal standby
[ 0.616973] LDOUSB: 3250 mV normal standby
[ 0.618682] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 400 kHz
[ 0.619537] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 400 kHz
[ 0.619842] omap_i2c omap_i2c.4: bus 4 rev2.4.0 at 400 kHz
[ 0.620300] omap_i2c omap_i2c.5: bus 5 rev2.4.0 at 400 kHz
[ 0.622039] gpiochip_add: registered GPIOs 256 to 279 on device: tca6424
[ 0.622283] Linux media interface: v0.10
[ 0.623260] omap-iommu omap-iommu.0: dsp registered
[ 0.623321] omap-iommu omap-iommu.1: ipu registered
[ 0.623626] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.625000] Switching to clocksource 32k_counter
[ 0.631744] Clockevents: could not switch to one-shot mode:
[ 0.631744] Clockevents: could not switch to one-shot mode: dummy_timer is not functional.
[ 0.631774] Could not switch to high resolution mode on CPU 1
[ 0.631774] dummy_timer is not functional.
[ 0.631805] Could not switch to high resolution mode on CPU 0
[ 0.661407] NET: Registered protocol family 2
[ 0.661621] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.662109] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.664550] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 0.665893] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.665924] TCP: reno registered
[ 0.665924] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.665954] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.666198] NET: Registered protocol family 1
[ 0.666473] RPC: Registered named UNIX socket transport module.
[ 0.666503] RPC: Registered udp transport module.
[ 0.666503] RPC: Registered tcp transport module.
[ 0.666503] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.666595] usbhs_omap usbhs_omap: ehci_logic_fck failed:-2
[ 0.668395] Registering 23 OPPs
[ 0.795806] ------------[ cut here ]------------
[ 0.795837] WARNING: at arch/arm/mach-omap2/opp.c:93 omap_init_opp_table+0x110/0x208()
[ 0.795867] omap_init_opp_table: No clock by name fdif_fck found
[ 0.795867] Modules linked in:
[ 0.795898] Backtrace:
[ 0.795928] [<c0013094>] (dump_backtrace+0x0/0x118) from [<c04f35c4>] (dump_stack+0x20/0x24)
[ 0.795928] r6:c062cd90 r5:0000005d r4:ef043f18 r3:c076f3cc
[ 0.795959] [<c04f35a4>] (dump_stack+0x0/0x24) from [<c0041360>] (warn_slowpath_common+0x5c/0x74)
[ 0.795989] [<c0041304>] (warn_slowpath_common+0x0/0x74) from [<c0041434>] (warn_slowpath_fmt+0x40/0x48)
[ 0.796020] r8:0000009c r7:00000017 r6:ef1b8200 r5:00000011 r4:c06fc9f4
[ 0.796051] r3:00000009
[ 0.796051] [<c00413f4>] (warn_slowpath_fmt+0x0/0x48) from [<c06cdd38>] (omap_init_opp_table+0x110/0x208)
[ 0.796081] r3:c04fe37b r2:c062ce31
[ 0.796112] [<c06cdc28>] (omap_init_opp_table+0x0/0x208) from [<c06cdfe4>] (omap5_opp_init+0x38/0xc8)
[ 0.796112] r7:c07a9ec0 r6:00000000 r5:c06cdfac r4:00000006
[ 0.796142] [<c06cdfac>] (omap5_opp_init+0x0/0xc8) from [<c00087a4>] (do_one_initcall+0xa0/0x170)
[ 0.796173] r5:c06cdfac r4:00000006
[ 0.796203] [<c0008704>] (do_one_initcall+0x0/0x170) from [<c06c097c>] (kernel_init+0x100/0x1c0)
[ 0.796203] r9:c071aa5c r8:0000009c r7:c07a9ec0 r6:c06f35b4 r5:c06f35d4
[ 0.796234] r4:00000006
[ 0.796264] [<c06c087c>] (kernel_init+0x0/0x1c0) from [<c00452d8>] (do_exit+0x0/0x7b4)
[ 0.796295] ---[ end trace 0082d2be168e2855 ]---
[ 0.796295] ------------[ cut here ]------------
[ 0.796325] WARNING: at arch/arm/mach-omap2/opp.c:93 omap_init_opp_table+0x110/0x208()
[ 0.796325] omap_init_opp_table: No clock by name fdif_fck found
[ 0.796356] Modules linked in:
[ 0.796356] Backtrace:
[ 0.796386] [<c0013094>] (dump_backtrace+0x0/0x118) from [<c04f35c4>] (dump_stack+0x20/0x24)
[ 0.796386] r6:c062cd90 r5:0000005d r4:ef043f18 r3:c076f3cc
[ 0.796417] [<c04f35a4>] (dump_stack+0x0/0x24) from [<c0041360>] (warn_slowpath_common+0x5c/0x74)
[ 0.796447] [<c0041304>] (warn_slowpath_common+0x0/0x74) from [<c0041434>] (warn_slowpath_fmt+0x40/0x48)
[ 0.796478] r8:0000009c r7:00000017 r6:ef1b8200 r5:00000012 r4:c06fca0c
[ 0.796478] r3:00000009
[ 0.796508] [<c00413f4>] (warn_slowpath_fmt+0x0/0x48) from [<c06cdd38>] (omap_init_opp_table+0x110/0x208)
[ 0.796539] r3:c04fe37b r2:c062ce31
[ 0.796569] [<c06cdc28>] (omap_init_opp_table+0x0/0x208) from [<c06cdfe4>] (omap5_opp_init+0x38/0xc8)
[ 0.796569] r7:c07a9ec0 r6:00000000 r5:c06cdfac r4:00000006
[ 0.796600] [<c06cdfac>] (omap5_opp_init+0x0/0xc8) from [<c00087a4>] (do_one_initcall+0xa0/0x170)
[ 0.796630] r5:c06cdfac r4:00000006
[ 0.796630] [<c0008704>] (do_one_initcall+0x0/0x170) from [<c06c097c>] (kernel_init+0x100/0x1c0)
[ 0.796661] r9:c071aa5c r8:0000009c r7:c07a9ec0 r6:c06f35b4 r5:c06f35d4
[ 0.796691] r4:00000006
[ 0.796691] [<c06c087c>] (kernel_init+0x0/0x1c0) from [<c00452d8>] (do_exit+0x0/0x7b4)
[ 0.796722] ---[ end trace 0082d2be168e2856 ]---
[ 0.796722] omap_init_opp_table: no hwmod or odev for hsi, [19] cannot add OPPs.
[ 0.796752] ------------[ cut here ]------------
[ 0.796752] WARNING: at arch/arm/mach-omap2/opp.c:93 omap_init_opp_table+0x110/0x208()
[ 0.796783] omap_init_opp_table: No clock by name hsi_fck found
[ 0.796783] Modules linked in:
[ 0.796813] Backtrace:
[ 0.796813] [<c0013094>] (dump_backtrace+0x0/0x118) from [<c04f35c4>] (dump_stack+0x20/0x24)
[ 0.796844] r6:c062cd90 r5:0000005d r4:ef043f18 r3:c076f3cc
[ 0.796875] [<c04f35a4>] (dump_stack+0x0/0x24) from [<c0041360>] (warn_slowpath_common+0x5c/0x74)
[ 0.796905] [<c0041304>] (warn_slowpath_common+0x0/0x74) from [<c0041434>] (warn_slowpath_fmt+0x40/0x48)
[ 0.796905] r8:0000009c r7:00000017 r6:ef1b8200 r5:00000014 r4:c06fca3c
[ 0.796936] r3:00000009
[ 0.796966] [<c00413f4>] (warn_slowpath_fmt+0x0/0x48) from [<c06cdd38>] (omap_init_opp_table+0x110/0x208)
[ 0.796966] r3:c04fe37b r2:c062ce31
[ 0.796997] [<c06cdc28>] (omap_init_opp_table+0x0/0x208) from [<c06cdfe4>] (omap5_opp_init+0x38/0xc8)
[ 0.796997] r7:c07a9ec0 r6:00000000 r5:c06cdfac r4:00000006
[ 0.797027] [<c06cdfac>] (omap5_opp_init+0x0/0xc8) from [<c00087a4>] (do_one_initcall+0xa0/0x170)
[ 0.797058] r5:c06cdfac r4:00000006
[ 0.797088] [<c0008704>] (do_one_initcall+0x0/0x170) from [<c06c097c>] (kernel_init+0x100/0x1c0)
[ 0.797088] r9:c071aa5c r8:0000009c r7:c07a9ec0 r6:c06f35b4 r5:c06f35d4
[ 0.797119] r4:00000006
[ 0.797149] [<c06c087c>] (kernel_init+0x0/0x1c0) from [<c00452d8>] (do_exit+0x0/0x7b4)
[ 0.797149] ---[ end trace 0082d2be168e2857 ]---
[ 0.797180] Did not LOW OPP to CORE domain - this is expected on 5432 device
[ 0.798065] omap-rproc.1: alias fck already exists
[ 0.801727] highmem bounce pool size: 64 pages
[ 0.811920] VFS: Disk quotas dquot_6.5.2
[ 0.812255] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.815643] NFS: Registering the id_resolver key type
[ 0.816345] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.816375] msgmni has been set to 1481
[ 0.817474] io scheduler noop registered
[ 0.817474] io scheduler deadline registered
[ 0.817749] io scheduler cfq registered (default)
[ 0.818389] OMAP DSS rev 6.0
[ 0.845062] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.846710] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 2.296844] console [ttyO2] enabled
[ 2.300903] omap_uart.4: ttyO4 at MMIO 0x48066000 (irq = 137) is a OMAP UART4
[ 2.309112] [drm] Initialized drm 1.1.0 20060810
[ 2.323852] brd: module loaded
[ 2.332275] loop: module loaded
[ 2.336883] 1-004b supply vio not found, using dummy regulator
[ 2.343109] 1-004b supply v2v1 not found, using dummy regulator
[ 2.355224] PALMAS 32kHz enable
[ 2.360473] ahci ahci: forcing PORTS_IMPL to 0x1
[ 2.365386] ahci ahci: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 2.373535] ahci ahci: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
[ 2.383026] scsi0 : ahci_platform
[ 2.386993] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 86
[ 2.395812] usbcore: registered new interface driver asix
[ 2.402008] usbcore: registered new interface driver cdc_ether
[ 2.408355] usbcore: registered new interface driver smsc95xx
[ 2.414581] usbcore: registered new interface driver net1080
[ 2.420684] usbcore: registered new interface driver cdc_subset
[ 2.427124] usbcore: registered new interface driver zaurus
[ 2.433197] usbcore: registered new interface driver cdc_ncm
[ 2.439178] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.446258] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 2.452239] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 2.460479] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 2.475494] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 2.481628] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.488769] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.496398] usb usb1: Product: OMAP-EHCI Host Controller
[ 2.501983] usb usb1: Manufacturer: Linux 3.4.13vs-02043-g6738901 ehci_hcd
[ 2.509216] usb usb1: SerialNumber: ehci-omap.0
[ 2.514709] hub 1-0:1.0: USB hub found
[ 2.518646] hub 1-0:1.0: 3 ports detected
[ 2.554046] Initializing USB Mass Storage driver...
[ 2.559356] usbcore: registered new interface driver usb-storage
[ 2.565704] USB Mass Storage support registered.
[ 2.571136] input: omap4-keypad as /devices/platform/omap4-keypad/input/input0
[ 2.580474] mpu6050 2-0068: mpu6050_i2c_read failed (Reset, -121)
[ 2.588073] mpu6050 2-0068: mpu6050_i2c_write failed (Reset, -121)
[ 2.595703] mpu6050 2-0068: mpu6050_i2c_read failed (Reset, -121)
[ 2.602172] mpu6050 2-0068: Reset failed
[ 2.607391] mpu6050 2-0068: mpu6050_i2c_write failed (Init fsr, -121)
[ 2.615295] mpu6050 2-0068: mpu6050_i2c_write failed (Init hpf, -121)
[ 2.623199] mpu6050 2-0068: mpu6050_i2c_write failed (Init thr, -121)
[ 2.631134] mpu6050 2-0068: mpu6050_i2c_write failed (Init dur, -121)
[ 2.639038] mpu6050 2-0068: mpu6050_i2c_write failed (Accel SP-reset, -121)
[ 2.647521] mpu6050 2-0068: mpu6050_i2c_read failed (Accel STBY, -121)
[ 2.655487] mpu6050 2-0068: mpu6050_i2c_write failed (Accel STBY, -121)
[ 2.662841] input: mpu6050-accelerometer as /devices/virtual/input/input1
[ 2.671386] mpu6050 2-0068: mpu6050_i2c_write failed (Enable Intr, -121)
[ 2.679595] mpu6050 2-0068: mpu6050_i2c_read failed (Clear Isr, -121)
[ 2.687500] mpu6050 2-0068: mpu6050_i2c_read failed (Accel STBY, -121)
[ 2.695495] mpu6050 2-0068: mpu6050_i2c_write failed (Accel STBY, -121)
[ 2.704772] input: palmas_pwron as /devices/platform/omap_i2c.1/i2c-1/1-0048/palmas_pwron.5/input/input2
[ 2.715362] i2c /dev entries driver
[ 2.721618] tmp102 4-0048: error reading config register
[ 2.727233] tmp102: probe of 4-0048 failed with error -121
[ 2.727264] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.739227] omap_hsmmc.1 supply vmmc not found, using dummy regulator
[ 2.746093] omap_hsmmc.1 supply vmmc_aux not found, using dummy regulator
[ 2.754516] omap_hsmmc omap_hsmmc.1: could not set regulator OCR (-22)
[ 2.754669] omap_hsmmc.0 supply vmmc not found, using dummy regulator
[ 2.860107] omap_hsmmc.2 supply vmmc not found, using dummy regulator
[ 2.867004] omap_hsmmc.2 supply vmmc_aux not found, using dummy regulator
[ 2.879791] usbcore: registered new interface driver usbhid
[ 2.885650] usbhid: USB HID core driver
[ 2.889739] RMH: STM: 956: stm_arm_init
[ 2.893768] RMH: STM device init
[ 2.897186] RMH: STM: 808: stm_device_setup
[ 2.901611] RMH: STM: 815: stm_probe: base_addr=0x5415a000 regs=0xf0076000
[ 2.908874] RMH: STM: 823: stm_device_setup: probing device
[ 2.914764] RMH: STM: 826: DEVTYPE = 0x0
[ 2.918884] RMH: STM: 836: PID=0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0
[ 2.925048] RMH: STM: 843: CID=0x0 0x0 0x0 0x0
[ 2.929901] RMH: STM device init'd
[ 2.933502] mmc0: new high speed DDR MMC card at address 0001
[ 2.933502] stm_fw: vendor driver stm_arm registered
[ 2.945404] mmcblk0: mmc0:0001 SEM08G 7.39 GiB
[ 2.947235] omap-dmic omap-dmic: invalid dma memory resource
[ 2.948364] omap_pcm_dummy() init
[ 2.948944] OMAP4/5 SoC init
[ 2.948944] omap_pcm_dummy() init
[ 2.948944] omap_mcpdm_dummy() init
[ 2.969909] mmcblk0boot0: mmc0:0001 SEM08G partition 1 2.00 MiB
[ 2.976348] mmcblk0boot1: mmc0:0001 SEM08G partition 2 2.00 MiB
[ 2.988647] Alternate GPT is invalid, using primary GPT.
[ 2.994323] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[ 3.004180] mmcblk0boot1: unknown partition table
[ 3.010559] mmcblk0boot0: unknown partition table
[ 3.015991] omap_hsmmc omap_hsmmc.2: could not set regulator OCR (-22)
[ 3.092864] twl6040 1-004b: timeout waiting for READYINT
[ 3.098449] twl6040 1-004b: automatic power-down failed
[ 3.104156] twl6040-codec twl6040-codec: asoc: failed to probe CODEC twl6040-codec: -110
[ 3.112762] asoc: failed to instantiate card OMAP5EVM: -110
[ 3.118804] omap-abe-twl6040 omap-abe-twl6040: snd_soc_register_card() failed: -110
[ 3.126892] omap-abe-twl6040: probe of omap-abe-twl6040 failed with error -110
[ 3.135589] asoc: omap-hdmi-hifi <-> omap-hdmi-audio-dai mapping ok
[ 3.144134] oprofile: using timer interrupt.
[ 3.148925] TCP: cubic registered
[ 3.153289] NET: Registered protocol family 10
[ 3.158691] IPv6 over IPv4 tunneling driver
[ 3.163940] NET: Registered protocol family 17
[ 3.168640] NET: Registered protocol family 15
[ 3.173675] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 3.181793] ThumbEE CPU extension supported.
[ 3.186309] Registering SWP/SWPB emulation handler
[ 3.191467] mux: Failed to setup hwmod io irq -22
[ 3.200805] Power Management for TI OMAP4XX/OMAP5XXX devices.
[ 3.206939] omap_sr_disable: omap_sr struct for sr_wakeup not found
[ 3.213531] save_l2x0_context: failed
[ 3.217498] sr_init: No PMIC hook to init smartreflex
[ 3.222839] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 3.231201] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 3.239562] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[ 3.248046] SmartReflex class 1.5 driver: initialized (86400000ms)
[ 3.256958] clock: disabling unused clocks to save power
[ 3.266540] registered taskstats version 1
[ 3.271209] LDOUSB: incomplete constraints, leaving on
[ 3.276947] LDOLN: incomplete constraints, leaving on
[ 3.283508] LDO6: incomplete constraints, leaving on
[ 3.289031] LDO5: incomplete constraints, leaving on
[ 3.294860] LDO3: incomplete constraints, leaving on
[ 3.300415] SMPS10: incomplete constraints, leaving on
[ 3.306121] SMPS8: incomplete constraints, leaving on
[ 3.311767] SMPS7: incomplete constraints, leaving on
[ 3.317382] SMPS6: incomplete constraints, leaving on
[ 3.322998] SMPS45: incomplete constraints, leaving on
[ 3.328735] SMPS12: incomplete constraints, leaving on
[ 3.334533] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 3.342712] dmm dmm: initialized all PAT entries
[ 3.352172] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 3.359161] [drm] No driver support for vblank timestamp query.
[ 3.365661] omap5evm_panel_enable_hdmi
[ 3.371337] Enter hdmi_core_init
[ 3.375030] Enable video_path
[ 4.194244] Failed to set PHY power mode to 0
[ 4.204833] omap5evm_panel_disable_hdmi
[ 4.210052] [drm] Enabling DMM ywrap scrolling
[ 4.222564] omap5evm_panel_enable_hdmi
[ 4.233306] Failed to set PHY power mode to 1
[ 4.237304] Enter hdmi_core_init
[ 4.237304] Enable video_path
[ 4.244262] Console: switching to colour frame buffer device 128x48
[ 4.272064] fb0: omapdrm frame buffer device
[ 4.276580] drm: registered panic notifier
[ 4.280914] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 4.287384] ALSA device list:
[ 4.290527] #0: OMAPHDMI
[ 4.327087] List of all partitions:
[ 4.330780] b300 7757824 mmcblk0 driver: mmcblk
[ 4.336395] b301 256 mmcblk0p1 f9f21f00-a8d4-5f0e-9746-594869aec34e
[ 4.344116] b302 256 mmcblk0p2 f9f21f01-a8d4-5f0e-9746-594869aec34e
[ 4.351989] b303 128 mmcblk0p3 f9f21f02-a8d4-5f0e-9746-594869aec34e
[ 4.359893] b304 16384 mmcblk0p4 f9f21f03-a8d4-5f0e-9746-594869aec34e
[ 4.367767] b305 16 mmcblk0p5 f9f21f04-a8d4-5f0e-9746-594869aec34e
[ 4.375671] b306 8192 mmcblk0p6 f9f21f05-a8d4-5f0e-9746-594869aec34e
[ 4.383544] b307 8192 mmcblk0p7 f9f21f06-a8d4-5f0e-9746-594869aec34e
[ 4.391479] b308 524288 mmcblk0p8 f9f21f07-a8d4-5f0e-9746-594869aec34e
[ 4.399383] b309 262144 mmcblk0p9 f9f21f08-a8d4-5f0e-9746-594869aec34e
[ 4.407257] b30a 6937456 mmcblk0p10 f9f21f09-a8d4-5f0e-9746-594869aec34e
[ 4.415252] b320 2048 mmcblk0boot1 (driver?)
[ 4.421081] b310 2048 mmcblk0boot0 (driver?)
[ 4.426666] No filesystem could mount root, tried: ext3
[ 4.431610] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[ 4.441162] CPU1: stopping
[ 4.444000] Backtrace:
[ 4.444213] [<c0013094>] (dump_backtrace+0x0/0x118) from [<c04f35c4>] (dump_stack+0x20/0x24)
[ 4.444213] r6:c0742b00 r5:00000001 r4:ef09ff58 r3:c076f3cc
[ 4.459869] [<c04f35a4>] (dump_stack+0x0/0x24) from [<c0014aac>] (handle_IPI+0x10c/0x1e4)
[ 4.470001] [<c00149a0>] (handle_IPI+0x0/0x1e4) from [<c0008688>] (gic_handle_irq+0x60/0x68)
[ 4.478851] r7:ef09fea4 r6:c0742b00 r5:ef09fe70 r4:fa212000
[ 4.483276] [<c0008628>] (gic_handle_irq+0x0/0x68) from [<c000e680>] (__irq_svc+0x40/0x70)
[ 4.483276] Exception stack(0xef09fe70 to 0xef09feb8)
[ 4.498779] fe60: 00000001 c07bc0c0 00000000 00000001
[ 4.507354] fe80: ef09e000 00000082 c0742b00 ef09ff58 c07a9f88 410fc0f0 00000000 ef09fefc
[ 4.515960] fea0: ef09ff00 ef09feb8 c0048760 c00480e0 20000113 ffffffff
[ 4.522338] r6:ffffffff r5:20000113 r4:c00480e0 r3:c0048760
[ 4.522338] [<c0048080>] (__do_softirq+0x0/0x274) from [<c0048760>] (irq_exit+0x58/0xb0)
[ 4.522338] [<c0048708>] (irq_exit+0x0/0xb0) from [<c0014a70>] (handle_IPI+0xd0/0x1e4)
[ 4.522338] r4:00000000 r3:00000001
[ 4.522338] [<c00149a0>] (handle_IPI+0x0/0x1e4) from [<c0008688>] (gic_handle_irq+0x60/0x68)
[ 4.522338] r7:ef09ff8c r6:c0742b00 r5:ef09ff58 r4:fa212000
[ 4.564239] [<c0008628>] (gic_handle_irq+0x0/0x68) from [<c000e680>] (__irq_svc+0x40/0x70)
[ 4.572906] Exception stack(0xef09ff58 to 0xef09ffa0)
[ 4.578216] ff40: c1035b28 00000000
[ 4.584838] ff60: 00000000 c07aa7b4 ef09e000 c0742adc c0501408 c07472a0 c07a9f88 410fc0f0
[ 4.595367] ff80: 00000000 ef09ffac ef09ff8c ef09ffa0 c00268d4 c000fe04 60000013 ffffffff
[ 4.600463] r6:ffffffff r5:60000013 r4:c000fe04 r3:c00268d4
[ 4.600463] [<c000fdd0>] (default_idle+0x0/0x3c) from [<c00101f0>] (cpu_idle+0xbc/0x114)
[ 4.600463] [<c0010134>] (cpu_idle+0x0/0x114) from [<c04f0304>] (secondary_start_kernel+0x12c/0x150)
[ 4.600463] r8:8000406a r7:c07aa1c4 r6:c07aa1b0 r5:00000001 r4:00000001
[ 4.634857] r3:00000000
[ 4.637634] [<c04f01d8>] (secondary_start_kernel+0x0/0x150) from [<804efc54>] (0x804efc54)
[ 4.637634] r6:10c0387d r5:00000015 r4:af08c06a r3:c04efc3c
[ 4.652252] panic occurred, switching back to text console
