SHA2MD5 clock stuck in TRANSITION state after mounting SMC(TF) driver on JB
Hi All,
I'm faced that SHA2MD5 clock  stuck in TRANSITION state after mounting SMC(TF) driver on JB(base code is 4AJ.2.2) & Customer board.
And it is normal if this mount is not executed forcely.
I don't have experience wrt the security(SMC) part.
Please check attched file below(i.e. kernel.log).
7484.stuck_SHA2MD5_clock.log
  <6>[04-03 17:56:48.078] SMC PA: INFO 00000004 00:00:29.861 P-0001 T-0009 System --------- File system mounted successfully in partition 1
After executing above code, I found the clue that suddenly SHA2MD5 clock is stucked in TRANSITION state continuously until entering Sleep state.
So bottom current is high 25mA more at sleep state.
Blaze with 4AJ2.2 is normal, but Customer board with 4AJ2.2 has this issue.
Have you ever experience on this issue ?
Could you please give me advice on this ?
Thank you & Merry X-MAS in advance...
