Hi experts,
Is there any verified USB wireless LAN chipset compatible with DM8168?
Would you please give your suggestions?
Thanks in advance.
Jed ZHU
Hi experts,
Thanks in advance.
Jed ZHU
Hi Jed,
I made a search, but I found info only for old Davinci devices:
http://processors.wiki.ti.com/index.php/Wireless_USB_Network
You can still try if this will work for DM8168 device.
Pavel
Thank you Pavel.
We tried use EdiMAX 7711 (with RT3070 chipset which from Ralink Tech Inc.) which can be used with DM6446 but it doesn't work properly with DM8168.
Jed ZHU
Hi Jed,
I asked our USB experts, whether we have any verified USB wireless LAN chipset compatible with DM8168. I will let you know when/if I have something more on this issue.
Pavel
Pavel
I have tested with DWA-125 Wireless 150 USB Adapter on DM8168.
Ravi B
Thank you Pavel and Ravi.
I will test DWA-125 wireless USB adapter.
Jed
Hi, can any of you share the driver you used for the DWA-125 adapter ?
I have had some trouble compiling the "2011_0719_RT3070_RT3370_RT5370_RT5372_Linux_STA_V2.5.0.3_DPO" version.
A modified makefile and the os/linux/config.mk as an example, would also be very helpful.
Thanks !
