DM365 "out of memory" errors and the demos fail. Please help!
Other Parts Discussed in Thread: TVP7002, THS7353
I have a TMX320DM365 and I'm receiving some errors upon initial boot. As a result of the errors, the demo programs do not work. I have not made any changes to the system. It's dated as February 29th, 2012 on the box, revision H. The boot output is below. You can see I'm getting these "out of memory" errors, and at the end both demos fail. Any input would be greatly appreciated; thanks!
Loading from NAND 1GiB 3,3V 8-bit, offset 0x400000
   Image Name: Linux-2.6.18_pro500-davinci_evm-
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2026248 Bytes =  1.9 MB
   Load Address: 80008000
   Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.............................................................
Linux version 2.6.18_pro500-davinci_evm-arm_v5t_le (a0850430@gtlnxlsf02.gt.desi9
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: DaVinci DM365 EVM
Memory policy: ECC disabled, Data cache writeback
DaVinci DM0365 variant 0x8
PLL0: fixedrate: 24000000, commonrate: 121500000, vpssrate: 243000000
PLL0: vencrate: 27000000, ddrrate: 243000000, mmcsdrate: 121500000
PLL1: armrate: 297000000, voicerate: 99000000, vencrate: 74250000
MUX: initialized SPI0_SCLK
MUX: initialized SPI0_SDO)
MUX: initialized SPI0_SDI
MUX: initialized SPI0_SDENA0
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
Built 1 zonelists.  Total pages: 29696
Kernel command line: mem=116M console=ttyS0,115200n8 root=/dev/mtdblock3 rw roo0
PID hash table entries: 512 (order: 9, 2048 bytes)
Clock event device timer0_0 configured with caps set: 03
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 116MB = 116MB total
Memory: 113152KB available (3497K code, 712K data, 168K init)
Security Framework v1.0.0 initialized
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
DaVinci: 104 gpio irqs
DM365 IPIPE initialized in Continuous mode
Generic PHY: Registered new driver
ch0 default output "COMPOSITE", mode "NTSC"
VPBE Encoder Initialized
LogicPD encoder initialized
Avnetlcd encoder initialized
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 4096 bind 2048)
TCP reno registered
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 3.1 (2006/08/19) Phillip Lougher
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
yaffs Mar  2 2009 12:21:46 Installing.
SGI XFS with no debug enabled
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
davincifb davincifb.0: check_fb_var: calling convert_fb_var_to_osd, var->bits_p6
davincifb davincifb.0: convert_fb_var_to_osd: bits per pixel: 16
davincifb davincifb.0: davincifb_set_par: calling convert_fb_info_to_osd bpp: 16
davincifb davincifb.0: convert_fb_info_to_osd: var->bits_per_pixel: 16
davincifb davincifb.0: dm_osd0_fb: 720x480x16@0,0 with framebuffer size 675KB
davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 1020KB
davincifb davincifb.0: check_fb_var: calling convert_fb_var_to_osd, var->bits_p4
davincifb davincifb.0: convert_fb_var_to_osd: bits per pixel: 4
davincifb davincifb.0: davincifb_set_par: calling convert_fb_info_to_osd bpp: 4
davincifb davincifb.0: convert_fb_info_to_osd: var->bits_per_pixel: 4
davincifb davincifb.0: dm_osd1_fb: 720x480x4@0,0 with framebuffer size 675KB
davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 1020KB
DAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 60 sec
davinci_ldc initialized
imp serializer initialized
davinci_previewer initialized
davinci_resizer initialized
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfac20000 (irq = 40) is a 16550A
serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfad06000 (irq = 41) is a 16550A
RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
netconsole: not configured, aborting
Davinci EMAC MII Bus: probed
MAC address is 00:0e:99:03:51:b5
TI DaVinci EMAC Linux version updated 4.0
Linux video capture interface: v2.00
starting ccdc_reset...<7>
End of ccdc_reset...<5>vpfe ccdc capture vpfe ccdc capture.1: vpif_register_dec1
vpfe ccdc capture vpfe ccdc capture.1: vpif_register_decoder: decoder = MT9P031
TVP514X : nummber of channels = 1
vpfe ccdc capture vpfe ccdc capture.1: vpif_register_decoder: decoder = TVP514X
Trying to register davinci display video device.
layer=c72e9400,layer->video_dev=c72e9560
layer=c72e9200,layer->video_dev=c72e9360
davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
vpfe ccdc capture vpfe ccdc capture.1: vpif_register_decoder: decoder = TVP7002
i2c /dev entries driver
nand_davinci nand_davinci.0: Using 4-bit hardware ECC
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xd3 (Micron NAND 1GiB 3,3V 8-bit)
Creating 5 MTD partitions on "nand_davinci.0":
0x00000000-0x00360000 : "bootloader"
0x00360000-0x003a0000 : "params"
0x003a0000-0x007a0000 : "kernel"
0x007a0000-0x207a0000 : "filesystem1"
0x207a0000-0x307a0000 : "filesystem2"
nand_davinci nand_davinci.0: hardware revision: 2.3
dm_spi.0: davinci SPI Controller driver at 0xc7866000 (irq = 42) use_dma=0
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
musb_hdrc: version 6.0, cppi-dma, host, debug=0
MUX: initialized GPIO33
musb_hdrc musb_hdrc: No DMA interrupt line
musb_hdrc: USB Host mode controller at c7868000 using DMA, IRQ 12
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
davinci-mmc davinci-mmc.0: Supporting 4-bit mode
davinci-mmc davinci-mmc.0: Using DMA mode
davinci-mmc davinci-mmc.1: Supporting 4-bit mode
davinci-mmc davinci-mmc.1: Using DMA mode
Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50.
ASoC version 0.13.1
AIC3X Audio Codec 0.1
asoc: aic3x <-> davinci-i2s mapping ok
ALSA device list:
  #0: DaVinci DM365 EVM (aic3x)
IPv4 over IPv4 tunneling driver
TCP bic registered
NET: Registered protocol family 17
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Time: timer0_1 clocksource has been installed.
Clock event device timer0_0 configured with caps set: 08
Switched to high resolution mode on CPU 0
yaffs: dev is 32505859 name is "mtdblock3"
yaffs: Attempting MTD mount on 31.3, "mtdblock3"
nand_update_bbt: Out of memory
**>> Block 1422 retired
**>> Block 1419 retired
**>> Block 1389 retired
**>> Block 1357 retired
**>> Block 1345 retired
**>> Block 1318 retired
**>> Block 1303 retired
**>> Block 1288 retired
**>> Block 1284 retired
**>> Block 1273 retired
**>> Block 1226 retired
**>> Block 1214 retired
**>> Block 1148 retired
**>> Block 1137 retired
**>> Block 1073 retired
**>> Block 1013 retired
**>> Block 1005 retired
**>> Block 994 retired
**>> Block 990 retired
**>> Block 985 retired
**>> Block 939 retired
**>> Block 928 retired
**>> Block 874 retired
**>> Block 863 retired
**>> Block 854 retired
**>> Block 821 retired
**>> Block 810 retired
**>> Block 801 retired
**>> Block 800 retired
**>> Block 798 retired
**>> Block 745 retired
**>> Block 731 retired
**>> Block 719 retired
**>> Block 655 retired
**>> Block 642 retired
**>> Block 570 retired
**>> Block 558 retired
**>> Block 470 retired
**>> Block 393 retired
**>> Block 372 retired
**>> Block 354 retired
**>> Block 309 retired
**>> Block 281 retired
**>> Block 265 retired
**>> Block 219 retired
**>> Block 199 retired
**>> Block 180 retired
**>> Block 135 retired
**>> Block 107 retired
**>> Block 15 retired
**>> Block 1949 retired
**>> Block 1857 retired
**>> Block 1477 retired
**>> Block 1429 retired
**>> Block 1406 retired
**>> Block 1328 retired
**>> Block 1326 retired
**>> Block 1309 retired
**>> Block 1282 retired
**>> Block 1265 retired
**>> Block 1264 retired
**>> Block 1259 retired
**>> Block 1237 retired
**>> Block 1236 retired
**>> Block 1234 retired
**>> Block 1217 retired
**>> Block 1201 retired
**>> Block 1200 retired
**>> Block 1197 retired
**>> Block 1169 retired
**>> Block 797 retired
**>> Block 796 retired
**>> Block 795 retired
**>> Block 794 retired
**>> Block 793 retired
**>> Block 791 retired
**>> Block 790 retired
**>> Block 789 retired
**>> Block 788 retired
**>> Block 787 retired
**>> Block 784 retired
**>> Block 783 retired
**>> Block 777 retired
**>> Block 776 retired
**>> Block 773 retired
**>> Block 772 retired
**>> Block 771 retired
**>> Block 770 retired
**>> Block 769 retired
**>> Block 766 retired
**>> Block 763 retired
**>> Block 762 retired
**>> Block 761 retired
**>> Block 760 retired
**>> Block 759 retired
**>> Block 758 retired
**>> Block 734 retired
**>> Block 730 retired
**>> Block 718 retired
**>> Block 716 retired
**>> Block 711 retired
**>> Block 704 retired
**>> Block 696 retired
**>> Block 684 retired
**>> Block 676 retired
**>> Block 656 retired
**>> Block 648 retired
**>> Block 644 retired
**>> Block 636 retired
**>> Block 624 retired
**>> Block 622 retired
**>> Block 619 retired
**>> Block 611 retired
**>> Block 603 retired
**>> Block 592 retired
**>> Block 581 retired
**>> Block 573 retired
**>> Block 541 retired
**>> Block 533 retired
**>> Block 525 retired
**>> Block 505 retired
**>> Block 501 retired
**>> Block 499 retired
**>> Block 492 retired
**>> Block 468 retired
**>> Block 464 retired
**>> Block 454 retired
**>> Block 437 retired
**>> Block 430 retired
VFS: Mounted root (yaffs2 filesystem).
Freeing init memory: 168K
**>> Block 1418 retired
**>> Block 1435 retired
**>> Block 1437 retired
**>> Block 1439 retired
**>> Block 1441 retired
**>> Block 1443 retired
**>> Block 1445 retired
**>> Block 1475 retired
**>> Block 1478 retired
**>> Block 1479 retired
**>> Block 1480 retired
**>> Block 1486 retired
**>> Block 1487 retired
**>> Block 1488 retired
**>> Block 1489 retired
**>> Block 1490 retired
**>> Block 1491 retired
**>> Block 1498 retired
**>> Block 1499 retired
**>> Block 1500 retired
**>> Block 1510 retired
**>> Block 1513 retired
**>> Block 1525 retired
**>> Block 1526 retired
INIT: Entering runlevel: 3
Starting internet superserver: inetd.
Starting audio loopback demo
Starting video loopback demo
audio_loopback: underrun occurred
ths7353_setvalue -start
main : Enter
vpbe_UE_1 : Enter
initializing capture device
ths7353_setvalue -end
setting data format
Detecting if driver supports COMPONENT
input.name = RAW
input.name = RAW-1
input.name = COMPOSITE
input.name = SVIDEO
input.name = COMPONENT
querystd, erorxxx, val = 1, val1 = 1
error: InitDevice:ioctl:VIDIOC_G_INPUT
Error in setting capture format
Failed to intialize capture
main : Leave
