Dear All!
I have a trouble that when I change resolution of video frames, the declink may crack(sometimes, not always).Can anyone help me?Below is the message printed on the console.
[m3vpss ] ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 16 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 0, 0 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 1 | 17 | 0, 0 | 1280 x 720 | 16384 / 32768 | TILED | 480, 0 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 2 | 18 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 960, 0 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 3 | 19 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 1440, 0 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 4 | 20 | 0, 0 | 352 x 288 | 16384 / 32768 | TILED | 0, 270 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 5 | 21 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 480, 270 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 6 | 22 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 960, 270 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 7 | 23 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 1440, 270 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 8 | 24 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 0, 540 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 9 | 25 | 0, 0 | 352 x 288 | 16384 / 32768 | TILED | 480, 540 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 10 | 26 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 960, 540 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 11 | 27 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 1440, 540 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
=== set play stream to 320 * 192 ===//I print this when I change video stream
[m3vpss ] 12 | 28 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 0, 810 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 13 | 29 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 480, 810 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 14 | 30 | 0, 0 | 352 x 288 | 16384 / 32768 | TILED | 960, 810 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 15 | 31 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 1440, 810 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ]
[m3video] 244508:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] ALGPROCESS FAILED:STATUS
[m3video] outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x82001a80
[m3video] Sequence called number 5627
[m3video] 244520:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x80001a90
[m3video] Sequence called number 5628
[m3video] 244541:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] Sequence called number 5629
[m3video] 244553:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] Sequence called number 5630
[m3video] 244575:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] Sequence called number 5631
[m3video] 244586:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] Sequence called number 5632
[m3video] 244605:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] Sequence called number 5633
[m3video] 244617:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] Sequence called number 5634
[m3video] 244638:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] Sequence called number 5635
[m3video] 244649:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] Sequence called number 5636
[m3video] 244661:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] Sequence called number 5637
[m3video] DEC_LINK: CH1 decoder changing resolution
[m3video] 244662: DECODE: CH1: Decoder flush needed (1048833)!!!
[m3video] 244662: DECODE: CH1: Decoder Flushing !!!
[m3vpss ] SWMS: *** UPDATING RT Params ***
[m3vpss ] 244695: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 244695: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 244695: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 244696: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 30
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame |
[m3vpss ] 1 | 17 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 480, 0 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ]
[m3vpss ] 247320: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 247320: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 247320: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 247325: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 0 | 0, 0 | 704 x 480 | 1408 / 1408 | NON-TILED | 0, 0 | 1920 x 1080 | 3840 / 0 | NON-TILED | OFF | 0 | 422I | OFF |
[m3vpss ]
[m3vpss ] 247331: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 247331: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 247331: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 247332: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 21 | 0, 0 | 320 x 192 | 16384 / 32768 | TILED | 0, 0 | 1920 x 1080 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ]
=== set play stream to 1280 * 720 ===
[m3video] DEC_LINK: CH5 decoder changing resolution
[m3video] 247781: DECODE: CH5: Decoder flush needed (3178753)!!!
[m3video] 247781: DECODE: CH5: Decoder Flushing !!!
[m3video] 247783:DECLINK::links_m3video/iva_dec/decLink_h264.c:[488]::INTERNAL ERROR:-1
[m3video] outArgs->viddec3OutArgs.extendedError for channel 5 with Resolution chnage Error: 0x208001
235937:!!!SLAVE CORE [VIDEO-M3] DOWN!!!
SystemLink_copySlaveCoreExceptionContext:120
mmap of [0xbe9c0000:36864]
mmap virt addresss:0x2ab14000
munmap of [0x2ab14000:36864]
SystemLink_copySlaveCoreExceptionContext:127
[m3video] 247813:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1
[m3video] outArgs->viddec3OutArgs.extendedError for channel 5 Error: 0x4000
[m3video] Sequence called number 4567
[m3video] 247814: Assertion @ Line: 885 in links_m3video/iva_dec/decLink_common.c: (freeFrameInfo->pVdecOrgFrame == NULL) && (freeFrameInfo->vdecRefCount > 0) : failed !!!
