AIF example code not running as desired
I have a C6488x EVM board and trying to run the example AIF code in both loopback(within one core) & non loopback across 2 dsp's. I see that always the TX task runs where as the Rx task do not run at all. Can you pls help me out in debugging this.
Tejas
    Your description is too short to understand what you are doing. so you got right data for internal loopback but failed on DSP to DSP communication. Is that correct? I don't know what version(who is the maker)  of EVM you are using, but you may need to check breakout card setup if you have right timer0 output for Phy and Rad timer sync.
    I don't understand what TX task and RX task means. is that your application task run on TI BIOS?
    Albert
