I using CCS5.2 to develop OMAPL138, I have a problem:
When I compile a project using Debug it can work very well. But when I compile it using Release it can not work.
why?
Can you reduce the optimization level and try to run the project . the release mode code makes certain assumptions while optimizing the code . If these assumptions are not correct may lead to incorrect results. Can you describe a little what the code is trying to do?
Rahul
