Hi.
i'm migrate DVRRDK_03.00.00.xx to DVRRDK_03.50.00.05 .
our dvr application is work well (live display and capture) in the usecase of VSYS_USECASE_MULTICHN_PROGRESSIVE_VCAP_VDIS_VENC_VDEC.
but i can't playback encoded data with below message.
i didn't change our dvr application code .
what should i do to play video data ?(i'm using tied with VGA and HDMI0 display. and not use HDMI1)
i attached remote debug log
############### message ###############################
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000026],CHNUM[0]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000026],CHNUM[1]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000026],CHNUM[2]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000026],CHNUM[3]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000026],CHNUM[4]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000026],CHNUM[5]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000026],CHNUM[6]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000026],CHNUM[7]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000028],CHNUM[0]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000028],CHNUM[1]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000028],CHNUM[2]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000028],CHNUM[3]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000028],CHNUM[4]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000028],CHNUM[5]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000028],CHNUM[6]
MULTICH_PROGRESSIVE_DVR:DEI Preview Output disable invisible channel.DEI_LINKID[0x20000028],CHNUM[7]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[0]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[1]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[2]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[3]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[4]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[5]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[6]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[7]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[8]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[9]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[10]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[11]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[12]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[13]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[14]
MULTICH_PROGRESSIVE_DVR:Decode enable visible channel.DEC_LINKID[0x10000022],CHNUM[15]
